Adobe Acrobat/Reader =< 9 zirou dej
denial ::
Heap sprayable memory corruption. KLIK
If you use Adobe Acrobat:
Edit | Preferences | JavaScript | Uncheck the 'Enable Acrobat JavaScript' option.
SELECT finger FROM hand WHERE id=3;
  • spremenil: denial ()
tsh2 ::
ja sem opazil da ob obisku določenih redkih strani se zažene acrord32.exe in potem gre poraba njegovega spomina v neskončnost.
Pyr0Beast ::
Že tako je plugin neroden za uporabo ...
denial ::
jan01 ::
boogie_xlr ::
na oni strani avast javi virus in prekine povezavo -> firefox crashne
denial ::
From the web:
Immunity released working JBIG/PDF exploit w/o JavaScript
Days until Adobe will patch the hole: 7
Ironija?
