Instalacija Pro/Engineerja WF3
arra ::
Zdravo;
Z neta sem potegnil Pro/Engineerja, ker se ga želim naučiti, vendar se mi je zataknilo pri licenci. Poizkusil sem skoraj da že vse vendarne na najdem rešitve za licenco. Če kdo ve kaj je potrebno storiti ga prosim za info.
Hvala že v naprej in LP.
šernk ::
natančen postopek inštalacije, lahko je kaj spremenjeno v tvoji verziji. je pa res da pred kakega pol leta mi je sesulo licenco od takrat pa nisem probal več, tako da morda je treba nov keygen. delaj pa točno po navodilih, ko narediš 1 stvar po svoje lahko greš kar znova. to je za moje CDje navodila, tako da je lahko pri tebi kaj spremenjeno
English
1. Mount DISK1 and DISK2 in Daemon Tools
or load them into your CD Drive, whichever you prefer.
2. Go into the Crack folder in DISK1 and copy the file
"keygen.exe" to your desktop. (You will get an error
when you open the keygen.exe in the Crack folder
if you try to generate a license.dat file). SO COPY TO DESKTOP!
3. Open keygen.exe that you copied to your desktop
and type in your PTC HostID, including the dashes.
The PTC HostID is on the bottom when you first
start setup (the "Select your country") screen.
Once you type in your HostID, click "Generate"
in keygen.exe. Also, remember your Hostname.
4. It will say license file generated successful
and a "license.dat" file will appear on your desktop.
5. Back to the Setup screen, select your country and click Next
6. Accept the license aggreement.
7. Click on "PTC License Server"
8. Click the little folder icon and locate the "license.dat"
generated by the keygen on your desktop. (change to DAT Files) for file type.
9. Click Install. Half way through, it will ask for the second CD.
Once complete, you have successfully installed the license file
required to install Pro/Engineer.
10. Click next and it will bring you back to the original screen.
11. This time, click "Pro/Engineer"
12. Ater selecting what you want to install, click next
13. Remeber when I said take note of your Hostname?
Under "FLEXnet License Servers", if you don't see 7788@(Hostname),
select it and click Edit.
14. Type in your hostname, leave the default 7788 for Port.
15. Click next and select your optins. Click Next, then Install.
16. Go to the crack folder (the one with the bin/cue files, not on the CD1)
and finish installation
Crucial bx100 počasen boot time (strani: 1 2 )
5811031 (9645) ajfon
Šifrirana mapa
Oddelek: Operacijski sistemi
92829 (2300) amigo_no1
Unencrypt...
71633 (1526) solatko
Ne predvaja novega audio CD
52604 (2560) Tea Time
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52688 (2644) riba43
