Forum » Kaj kupiti » SSD za sistemski disk
Anney ::
Še tole me zanima razlika med:
Samsung 256 GB PM871 SSD in Samsung 850 EVO, hojnikb?
The VNAND TLC flash memory used in the PM871 is related to but not the same as the flash memory used in the Samsung 850 EVO. The sequential write performance has been slowed down compared to the 850 EVO.
Hitrost me ne zanima toliko, kot stabilnost.
- spremenilo: Anney ()
mailer ::
Saj vidiš po podatkih, da je razlika v hitrosti zapisovanja podatkov.
O stabilnosti je težko kej rečt, ker je to še vedno relativno frišno. Ni pa nekih problemov, vsaj kar se tiče 850EVO.
Backup itk morš vedno met.
Anney ::
Kako pa je s kontrolerji, PM871 ima čisto drugega in naj bi bil boljši kot EVO? Ni pa nekih podatkov o njem, tako kot o EVO. Torej po tvoje je 850EVO boljša izbira? Ali čisto kaj drugega?
Če te skrbi zanesljivost, vzameš 2 in daš v raid0.
Sicer pa tale PM serija deluje kot OEM varjanta 850evota z drugim firmwareom
- spremenil: iloveboobz ()
ST-777 ::
iloveboobz je izjavil:
Ni pa nekih problemov, vsaj kar se tiče 850EVO.Z nekaterimi ploščami ima Samsung 850 EVO težave, vendar je problem rešljiv:
"I just purchased the Samsung 850 EVO SSD. Like many people on this forum, I'm connecting it with a USB 3.0 to 2.5" SATA SSD cable as instructed by the manufacturer. Installed the software as instructed but neither the software, nor windows explorer detects the drive. I've tested the unit on another windows 7 machine (this one is W10)."
"Two of my new Samsung 850 EVO SSDs had similar issues on my Z77 desktop. And like you I thought that the drives were DOA. Then I connected them (one at a time) to another desktop and I was able to see them and format them. After formatting, I moved one Samsung SSD to the Z77 computer and everything was fine."
http://www.tomsguide.com/answers/id-278...
D3m0r4l1z3d ::
850 evo je sigurno p/p zdaj najboljši v DE ali leclerc v slo, drugače bx100 na mimovrste za 85 eur, če govorimo o 250gb
bosmla ::
mastazeko ::
Pozdravljeni, imam 6 let star laptop Toshiba, ki ima sicer samo SATA2. Bi delal Samsung 850 notri? AHCI podpora v bios-u je.
Morda kakšen drug predlog? SSD bo v roku pol leta romal v desktop ko bo kakšen € več v roki.
Hvala in lp
Hvala in lp
Ti pa imaš kampanjo proti Kingstonu. Koliko je pa failure rate, da si tako alergičen?
bait and switch.
ti kr podpiraj firme, ki ti prodajajo inferiorne produkte napram reviewom
SuperVeloce ::
jap. Za razliko od Samsunga, kjer se je naredilo tako štalo in sedaj ljudje odsvetujejo TLC (failure rate ni bil višji ali izgube podatkov ni bilo), čeprav je sedaj popolnoma drug flash na 850evo (+ na precej večji litografiji)...
Kar je najhuje, je to, da marsikatera review stran je za to vedla, pa so namenoma prikrili, ker oni Kingstonu "zaupajo". Whatever.
- spremenil: SuperVeloce ()
Modri dirkač ::
Glede na to kakšno štalo dela kingston tudi drugje (ram fiasko ipd.), od njih ne kupim niti šraufa več.
Everybody lies!
jero_no1 ::
Kaj je pa s tem SSDjem? Samsung 650
Al bi bil Intenso vseeno boljši nakup? Hvala za odgovor.
SuperVeloce ::
Nek skonto enterprise ssd. Verjetno je flash podoben tistim v 850evo, ampak IOPS so smešno nizki (verjetno dodatno omejeni, da si ne skačejo v zelje). Jaz bi raje Intenso
zee ::
Hvala in lp
Starsem sem v pet let star racunalnik namontiral omenjenega Evota in se danes mislijo, da imajo nov racunalnik, ker vse dela tako hitro in odzivno. Verjetno je temu tako tudi zaradi Windows 10.
zee
D3m0r4l1z3d ::
a Samsung sploh še misli na sata3 kaj ustvarit, 250gb 850 EVO je v DE že na 76 EUR padel, kaj dosti hitrejši ne more niti več biti, verjetno se jim splača saat3 zdaj v cheap pogone do 500 gb spravit, višje pa samo še pcie
D3m0r4l1z3d ::
aha, potem kot Plextor in Crucial, samo še v budget z novostmi, ki niso niti novosti :-)
ST-777 ::
D3m0r4l1z3d je izjavil:
a Samsung sploh še misli na sata3 kaj ustvarit, 250gb 850 EVO je v DE že na 76 EUR padel, kaj dosti hitrejši ne more niti več biti ...Samsung 950 Pro je sicer M.2, ima dobre ocene uporabnikov, vendar je drag.
"I loaded a 10 GB dummy file on a ram disk and measured how long it took to copy and paste to the 950 Pro, and my old 850 Evo for comparison. At 44 seconds the 850 Evo was quick, but the 950 Pro was in another league. It took just 7 seconds." http://www.newegg.com/Product/Product.a...
Še nekaj o cenah: "Since Computex, we've talked about the road to the bottom and how SSD prices have and will continue to plummet. We already see 256 GB-class drives selling for $60" http://www.tomshardware.com/news/samsun...
PrimozR ::
Zakaj bi na SATA3 imeli samo pogone do 500 GB, če je pa zaenkrat na M.2 fizičen limit ~500 GB na račun fizičnega prostora, ki ga format omogoča? SATA3 z 2,5" pogoni enostavno omogoča 2 in celo več TB. Pa pri trenutnih cenah vedno vzamem SATA3 namesto M.2, žal. Morda je M.2 hiter, a že SATA3 SSD je v ključnih elementih dovolj hiter. Itak imaš potem hitro težave s kopiranjem podatkov z mreže oz. z drugih trdih diskov, kjer si omejen, sploh če imaš samo 500 GB SSD (ali celo manj).
Tezaab ::
Baje naj bi bil pri vecanju kapacitete M.2 pogonov glavni problem hlajenje, ne fizicni prostor na 22x60/80/110mm kartici. Samsung naj bi izdal (ne vem a je ze ali se bo, se nisem poglabljal) 960GB M.2 SSD, model PM953 (pravijo, da naj bi bila to zamenjava za SM951).
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
D3m0r4l1z3d ::
Ja, PIPI je zadel bistvo, ssd-je na sata3 čim večje, ker so že poceni, pcie pa kot nov sata3 ssd, ko je hddje izrinil, sicer pa lahko kot grafične kartice začnejo delat na pcb, lahko tudi z ventom, vendar problem je, da ne visok bandwidth kot tudi ne nvme spet ne doprineseta RL pohitritve, v sintetiki pa blestijo
PrimozR ::
Si znam predstavljati, da je tudi to težava, a še nekaj časa nazaj vem da je bila težava, da čipi (in posledično tudi pakiranja) enostavno niso bili dovolj veliki, da bi na ta dolgo M.2 palčko lahko spravil 1 TB flasha. Pač glede na javno objavljene podatke, kako velika jedra so na voljo. Die stacking je pa relativno omejen ja, ker boš hitro pregrel nekatera izmed njih, hlajenje teh jeder je pa tudi bolj tako-tako.
Kar se tiče hitrosti, delni konkurent v poznanem pakiranju je lahko tudi SATA Express.
Anymal PCIe SSD-ji so v veliki večini v M.2 paketu, kjer se podatki lahko prenašajo ali prek SATA ali pa prek PCIe standarda. Za splošno rabo PCIe pogonov za v režo pomojem ne bo, bo vse na M.2.
Sicer bi pa z veseljem prebral kaj več glede teh toplotnih težav, če obstaja kak prispevek.
- spremenil: PrimozR ()
dans se da diestackat do 16 dieov, tko da na m.2 bi lahko brez težav spravl 1TB+....
Samsung ima take package že od nekdaj
http://www.anandtech.com/show/8979/sams...
PrimozR ::
A, problem je na kontrolerju... Še eno področje v stilu grafičnih kartic izpred 15+ let, ko se je začelo nanje lepiti hladilna rebra? :D
hehe, z razlogom še vedno ni novga pcie sandforce controlerja
m.2 ssdje jebe tut mal to, da nimajo nobenga ohišja, medtem ko sata majo vsaj nek case, ki rahlo pomaga.
Kaj pa tocno pomaga plasticno ohisje?
Ampak vecina je plasticnih. Kaj tocno to pomaga?
Kovinska so bila ze dolgo nazaj.
SuperVeloce ::
Kako dolgo nazaj? Vsi, katere imam, so pleh. crucial mx100, intenso, samsung..
SuperVeloce je izjavil:
Samsungi imajo res alu ohisje, ampak nobenih padingov na kontrolerju (840evo in 850evo). Se vedno nic ne pomaga.
Tezaab ::
Po moje bi s hlajenjem delno resil zadevo, ce bi dal na M.2 disk neko tako ohisje, kot ga imajo moduli RAM (da je vsaj nek heat spreader, ce ne ze hladilnik), ali pa kar s hladilnikom, kot je na cipih na maticni plosci. Bi pa lahko s tem zaprl katere izmed ostalih rez za kartice, odvisno od postavitve M.2 slota.
Pozabi, ni prostora. Ene plate imajo tako malo prostora, da mora bit spodnja stran prazna.
Nekatere desktop plate imajo slot pod graficno, kjer spet ni prostora.
D3m0r4l1z3d ::
zakaj ne pcie kartice kot je Intelov 750
ST-777 ::
zakaj ne pcie kartice kot je Intelov 750Intel Solid-State Drive 750 PCI-Express 3.0 je sicer zelo hiter: "I used the Crystal Disk Mark tool to compare this drive to three SATA HDs and one SATA SSD installed in this same PC, and this thing is between 10 to 831 times faster than my slowest HD (depending on the test), and between 1.4 to 14 times faster than my Intel 535-series SSD." http://www.amazon.com/Intel-Solid-State...
Ker pa ima Intel 750 PCI-Express ceno le nekoliko nižjo, kot je 1$/1GB (velja za model 400GB), se bo večina raje odločila za SSD 2.5 SATA III, ki ima precej nižjo ceno.
GA_PI ::
Pozdravljeni, zanima me kateri je trenutno P/P model SSd-ja na mSATA vodilu? Tujina ni ovira.
Uporabljal se bo izključno za obdelovanje in shranjevanje projektov (hitrost ni prioriteta, bolj kapaciteta na €). Gledam velikosti 128 in 256GB.
Hvala in LP
Hvala in LP
D3m0r4l1z3d ::
enostavno na idealo msata SSD-je adš v iskalno polje in ti izpiše veliko le-teh, nato razporediš po Grundpreis torej po EUR/Gb
http://www.idealo.de/preisvergleich/Pro...
bo pa vsaj 12 eur še poštnine (priporočam Computer universe trgovino ali mind factory, ki ima malo boljše cene, vendar 8 EUR dražjo poštnino), tako da moraš podoben manever tudi v Slo. trgovinah narediti in potem vidiš ali se sploh splača v tujini samo eno komponento naročevat
- spremenilo: D3m0r4l1z3d ()
Koliko časa bo še treba trobit za geizhals.eu?
D3m0r4l1z3d ::
kaj je narobe z idealom?
To je že za stick post na začetku in koncu vsake teme o nakupih...
Bolj za auto-reply vsakemu vprašanju o ceni ...
