Forum » Loža » Torx
Torx
Loki ::
ok, kaj je torx vrsta vijaka vemo, samo kaj je pa blind torx?
I left my wallet in El Segundo
|Luka| ::
Tole je google izpljunil:
Anyway, a Blind Torx is a star like pattern type of head but with a post in the middle of the hole to prevent the average user from unscrewing it. Blind Torx drives are not something you just pick up at your local hardware store, so do yourself a favor and purchase one online at any industrial tool outlet like JC Whitney or McMaster Car – do a Google on Blind Torx driver and you’ll surely find a set of drivers that you can purchase for under $15 dollars.
Loki ::
uh, to sem jaz prebral na ravno tem blogu, mene pa bi zanimala predvsem oblika vijaka, ki mi je ni ratalo dobiti (niti na tisti jc whitney strani)
|Luka| ::
Sicer se mu ne reče Blind Torx, ampak Button Torx (predvidevam, da zaradi glave - ima pa v sredini pin...)
HudsonFasteners
W1: linkifisation
HudsonFasteners
W1: linkifisation
- spremenilo: WarpedGone ()
| » | Kje kupiti nadomestne šravfkeOddelek: Strojna oprema | 3115 (164) | Malajlo |
| » | Osnovno orodje (izvijači)Oddelek: Kaj kupiti | 7835 (5906) | noraguta |
| » | Odpiranje Xbox 360 Kontrolerja brez Torx-aOddelek: Konzole | 1361 (1278) | nomad_soul |
| » | Kaj je to zaen vijakOddelek: Loža | 1543 (1273) | levaky |
| » | nastavkiOddelek: Loža | 1838 (1633) | Vikking |
