Slo-techova ikona nevarna?
frke ::
Vedno, ko obiščem stran www.slo-tech.com, mi "Proventia Desktop" izpiše HIGH RISK opozorilo:
[Unauthorized Access Attempt] This signature detects when you visit a Web site that provides a "favorites icon" that has a suspicious format. This includes an icon that contains a large number of images or an icon with one or more overlapping images. These icons can overflow a buffer in some older browsers allowing the server to take control of the client.
Poleg tega pa tudi:
[Suspicious Activity] This signature parses Windows Icon image files and triggers when any field deviates from specification.
Pri skoraj nobenih drugih straneh tega nisem opazil.
Kaj se dogaja pri vas?
  • spremenil: frke ()
Avby ::
A sploh ima slo-tech favicon? Sam menim da ne?
Edit: V FF jo vidim v IE pa ne tak oda načeloma jo ima... težava pa je pomojena tvoji strani.
  • spremenil: Avby ()
t3hn0 ::
v ie ne prikaze ker nima definiranga favicona v headu...drugace pa opera in ff sta "pametna" in pogledata ce datoteka obstaja in jo avtomaticno prikaze. ne vidim pa razloga zakaj bi bila nevarna ikona^^
BigWhale ::
Ja, virusi se vam bojo namnozil v biose in pol bojo instaliral linukse!
McMallar ::
Zakaj pa bi se virusi 2x inštailrali? >:D
Because OCT31 = DEC25
V-i-p ::
Težka bo... če so virusi, so sigurno toliko pametni, da ne bodo šli inštalirat linukse :D
StratOS ::
Favicon
Zgleda, da je problem v tipu (type) ali pa nepravilen MIME identifier od serverja:
Primer
<link rel="shortcut icon" href="http://example.com/favicon.ico" type="image/vnd.microsoft.icon">
<link rel="icon" href="http://example.com/favicon.ico" type="image/vnd.microsoft.icon">
GET /favicon.ico HTTP/1.1
Accept: */*
Accept-Language: sl
UA-CPU: x86
Accept-Encoding: gzip, deflate
If-Modified-Since: Fri, 30 May 2003 15:42:24 GMT
If-None-Match: [DELETED]
User-Agent: [DELETED]
Host: slo-tech.com
Connection: Keep-Alive
Cookie: [DELETED]
Ker gre za ico :
ICO files image/vnd.microsoft.icon (Alternatively, image/x-icon can be used instead, for compatibility reasons. However, it is preferable to use the IANA-registered MIME type, as most major browsers now support it.)
Torej ker gre za image/x-icon (vsaj tako IE prepozna ta tip, čeprav ni določena iz server strani) ne vem v čem bi bil problem, sama *.ico datoteka pa tudi upam brez "čudne kode".
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187286 (7145) ManDriver
"ikona" na brskalniku, levo od naslova.
Oddelek: Izdelava spletišč
51384 (1297) jinzo
Slikca pred naslovom spletne strani
191842 (1566) Tody
Favorite icon
131535 (1386) darh
Kaj pomeni favicon.ico ?
61900 (1767) pivmik
