Forum » Omrežja in internet » Ganymede 822+
Ganymede 822+
Klenobo ::
Imam problem z hitrostjo na ADSLu. Prej ko sem imel stari dobri calisto modem je delovalo vse kot je moralo.
Ko sem zamenjal ISPja in vzel paket z ADSL, IP Phone in IPTV sem dobil tudi drugi modem in tudi s tem težave.
Vzel sem paket 2048/386, pa mi ta deluje z 1Mb aali pa še majn. Težava se mi že vleče skoraj 2 tedna, pa pravijo
na TK, da je vse vredu. HItrost je ista če sem priključen direktno na modem ali pa preko router-ja. Zdaj ne vem ali
je modem fuč ali pa kaj na centrali, ker so me pomoje prestavili na drugi port.
Spodaj prilagam statistiko modema. Kaj mislite, na kateri strani se pojavljajo napake?
DSL Port: Status
Operational mode G.Dmt.BisPlus
State Showtime
Trained transmit bit rate 448 kbps
Trained receive bit rate 2272 kbps
Upstream power 12.9 dB
Local Fast channel FEC error count 0
Local Interleaved channel FEC error count 0
Local Fast channel CRC 0
Local Interleaved CRC 0
Local line attenuation 43.0 dB
Local signal-to-noise margin 18.5 dB
Local LOS 0
Local SEF 0
Remote Fast channel FEC error count 0
Remote Interleaved channel FEC error count 0
Remote Fast channel CRC 0
Remote Interleaved CRC 0
Remote line attenuation 27.0 dB
Remote signal-to-noise margin 21.5 dB
Remote LOS 0
Remote SEF 0
Local FEC error count 275
Local CRC 6
Local FEC errored seconds 0
Local errored seconds 0
Local severly errored seconds 0
Local LOS errored seconds 0
Local HEC 9
Remote FEC error count 587202560
Remote CRC 0
Remote FEC errored seconds 0
Remote errored seconds 0
Remote severly errored seconds 0
Remote LOS errored seconds 0
Remote HEC 0
DSL Port: Status
State Showtime
Local LOS 0
Local SEF 0
Remote LOS 0
Remote SEF 0
Local CRC 6
Local HEC 9
Remote CRC 0
Remote HEC 0
Pajek.Net, (http://www.pajek.net)
Brezplačna MojaPosta.Com (http://www.MojaPosta.Com)
amigo_no1 ::
Glede na info iz modema&routerja piše da se poveže z 2272 kbps (2 mb) kar je v redu.
S koliko vleče od http://file.siol.net/ ?
Klenobo ::
Mene bolj motijo spodnje napake v statistike. Tudi mislim, da je zato počasno vse, ker moram večkrat iste paketke pošiljati, dokler nepridejo pravilni na cilj in potem vse to zabaše.
| » | 4Mb + tel + tv po kabluOddelek: Omrežja in internet | 1786 (1686) | borut_p |
| » | Problem s hitrostjo povezave - AMISOddelek: Omrežja in internet | 1388 (1321) | zelodko |
| » | PPPoE vprašanje - storitve in motnje na linijiOddelek: Omrežja in internet | 2513 (2192) | Ovchka |
| » | Sinhronizacija modemaOddelek: Omrežja in internet | 2176 (2133) | Tilen |
| » | Pomoc glede ADSL in telefonski kabel dolzinaOddelek: Omrežja in internet | 2636 (2374) | Cinderela |
