Forum » Igre » Steam - Nakup iger
Steam - Nakup iger
Valve's Steam Machine Gets Delayed Due To Memory Shortage
The company is blaming the ongoing memory shortage for forcing it to revisit both the shipping schedule and pricing for the Steam Machine and Steam Frame.
https://www.pcmag.com/news/uh-oh-valves...
Gabe Newell "stepped back" from making games at Valve after Portal 2 because everyone kept agreeing with him when he wanted "to be part of the team and come up with ideas"
He didn't want Valve to be all 'yes' people
https://www.gamesradar.com/games/gabe-n...
Valve Uploads Steam Controller Unboxing Video, Launch Imminent
https://www.techpowerup.com/348382/valv...
rkobarov ::
in kaj je "finta" v tem kontrolerju?
Ryzen 7800x3D AIO280 16gb 30cl600 3080ti FE B650 EAGLE Samsung 970 1Tb M27q
globoko grlo ::
Kaj je zdej? Steam controler al game controler?
PARTyZAN ::
Kaj pa je nejasnega? Zgoraj je fotografija kontrolerja, internet je pa že poln reviewov.
https://store.steampowered.com/sale/ste...
V dobre pol ure je bil controller razprodan v ameriki, pri nas (EU) je bil po dveh urah out of stock.
rdecaluc ::
Rezervacije ki gredo po številki, samo 1 kontroler na račun, samo računi ki imajo "good standing" in pa samo računi ki so kupili nekaj pred 27. aprilom 2026 ga lahko kupijo.
Kr vredu boj proti "scalperjem", ker se preprodajajo po 300€.
Est modus in rebus. ,typos
yayo ::
Ravno zdaj sem pogledal ebay. Ne samo to, da se preprodaja za 300, je tam cel kup optimistov, ki ponujajo "prednaročilo" za dvesto. Kar jaz razumem kot, da so rezervirali na Steamu za sto pa ponujajo naprej za dvesto, ko bodo dobili.Seveda denar hočejo vnaprej. Ne moreš verjeti.
globoko grlo ::
A to se za mario in podobne spile uporablja?
globoko grlo je izjavil:
The Steam Controller is designed to work with all Steam games—even those without native controller support—by utilizing Steam Input to emulate mouse and keyboard commands. It acts as a universal input device, allowing you to play your entire Steam library, including strategy games, on your TV or desktop.
Kontroler kot kontroler. Ima ustrezne digitalne in analogne vhodne vzvode (D-pad, gobice...).
Težava je bolj v tem, če ga emulator itd. ustrezno prepozna. Potem lahko igraš Maria ipd. podobno, kot z x-box kontrolerjem.
XInput Emulation: Steam enables the controller to act as a standard XInput device, making it compatible with most modern PC games.
Without Steam: If Steam is not running, the controller often defaults to acting as a basic mouse and keyboard rather than an XInput gamepad.
Torej, po navedbah je zadeva bolj uporabna, če v ozadju deluje Steam (app). Potem je to v rangu x-box kontrolerja.
Key Details on Steam Controller Compatibility:
Steam Input Emulation: Steam hooks traditional input APIs (XInput, DirectInput) and injects emulated Xbox controller input, making games recognize it as an Xbox controller.
Limitations: Because it acts as a hybrid device, it may not work natively with non-Steam games or apps unless they are added to Steam.
XInput Limits: When using more than four Steam Controllers, you may need to configure additional controllers as keyboard/mouse, as Windows restricts XInput to four devices.
Game Specifics: While most games recognize the emulation, some, particularly older or specific developer titles (e.g., certain Koei Tecmo games), may require customized, keyboard-based configurations.
- spremenil: Jarno ()
Steam Machine Price Might Have Leaked - And It's Over $1,000
https://www.vice.com/en/article/steam-m...
PARTyZAN ::
Špekulacija. Komentar nekoga, ki tesno spremlja dogajanje:
https://x.com/SadlyItsBradley/status/20...
That modification was done in a file for the new Steam Community Market Beta, not the store
Has no exact bearing on anything being priced directly on the Steam Store. Including Hardware
(Not saying that a piece of hardware couldn't cost 1,000+, just that this isn't the proof)
Netrunner ::
Čas bo pokazal ali je vreden svoje cene ali ne. Mogoče si bom naročil enega čez kako leto ali dve, ko bodo zaloge normalne.
IvoJan ::
Pravijo, da je dober samo drag je.
drag? dualsense edge je 200, microsoft elite tudi.
Valve razkril cene za Steam machine
Steam Machine 512 GB
US$1,049 (CA$1,509 / EU€1,039 / UKGBP879 / AU$1,609)
Steam Machine 512 GB with Steam Controller
US$1,128 (CA$1,628 / EU€1,108 / UKGBP938 / AU$1,728)
Steam Machine 2 TB
US$1,349 (CA$1,919 / EU€1,359 / UKGBP1,149 / AU$2,109)
Steam Machine 2 TB with Steam Controller
US$1,428 (CA$2,038 / EU€1,428 / UKGBP1,208 / AU$2,228)
Steam Machine 2 TB
PARTyZAN ::
Pričakovano. Trg je trenutno v zelo slabem stanju, če si povprečen potrošnik. Valve si z odprto platformo pač ne more privoščit, da bi prodajal pod ceno.
mahone ::
Da placas toliko za hardware, ki ga scat pelje 6 let star pc z 5600/6700xt.
- spremenil: mahone ()
Seljak ::
Zanimivo, da se gredo politiko služenja na HWju. Vrednost tega sistema je cirka po trenutnih cenah 800€. Verjetno so omejeni s količinami in so namerno dvignili ceno.
Samo so razmere res slabe. Lani sem dal 1400€ za sistem, ki je svetlobna leta pred tem. 9070, 32GB rama, 2TB SSD, 850W, boljša plata.
PARTyZAN ::
Več kot pol leta stare cene so irelevantne. RAM in flash storage je šel od takrat v stratosfero. Pa ignoriraš tudi dejstvo da je gabecube manjši od najmanjšega SFF builda, tišji, porabi mnogo manj elektrike in ima delujoč HDMI CEC.
Mislim, da se valve ne gre "politike služenja na HWju" ampak se gre politiko "nočemo delat izgub s prodajo HWja". Sony, MS in Nintendo si lahko privoščijo prodajat pod ceno, ker je HW locked down in ga preprosto ne moreš uporabljat v druge namene. Valveov HW je odprt.
S tem se ne strinjam. Po današnjih cenah je SM vredna cirka 800€ (prej manj na količino). Torej imajo 25% marže. Kot sem rekel, so se verjetno tako zavestno odločili, ker imajo omejeno dobavo materiala/proizvodnje. Z nižjo ceno bi tudi reskirali problem skalperjev. Je trenutno pač zelo usrana situacija za cel gaming sektor.
Žalostno je to da se ne dela normalnih dobrih iger za mobitele. Kje so kakšne single player igre s zgodbo, kvalitetne strategije (ne klinčev tower defence 1000x).
Izi ::
Predrago!!! Steam Mašina bi morala konkurirati konzolam, ampak s to ceno je še vedno bolj pametno kupiti konzolo, čeprav si bolj omejen z igrami in so igre precej dražje.
PS5 Pro je trenutno okoli 900 € in ima 2TB prostora in kontroler, Steam Mašina z 2TB in kontrolerjem pa je kar 1428 €. To je vsaj 400 € predrago.
Ryzen 5 7500, 32 Gb DDR5 rama, 1 Tb SSD, in GeForce 5060 Ti z 8 Gb Vrama, asus budget plata te pride pri nas okoli 1400EUR z ohišjem, napajalnikom in ventilatoji. Je pa res da sta tukaj zraven 2 kontrolerja.
Lahko bi se malo bolj potrudili, glede na to da imajo sigurno na hardware popust pri večjih količinah.
- spremenil: Zmajc ()
Kateri CPU ima ta steam machine?
Semi-custom zen4 6c/12t @30W. So prava zen4 jedra, ne tista "učinkovita".
Verjetno okoli tretjino počasnejša zadeva od 7600/58003D. Načeloma ok, samo ne za kakšne hudo visoke fpsje. 175W komplet porabe je pomoje še največja cokla, ki bremza celo mašino. Procesor 50% manj porabi od primerljivega 7400F, grafična tretjino od RX7600 in to se pozna na rezultatih.
Novi časi in inflacija, zabavna elektronika bo po novem jurja.
Jaz tudi mislim, da nima smisla kaj takega kupit. Pač vzameš en rabljen PS5 350EUR in imaš podobno zadevo. Ali sestaviš svoj komp, ki je boljši za podoben denar.
7600 130EUR, MB 120EUR, 9600xt/5060ti 320EUR, 2*16gb ram 350EUR (cene 1x16gb so absurdne pri 250EUR), SSD 1TB 140EUR, cooler+nap+ohišje 120EUR. 100EUR več za dosti boljšo kišto.
- spremenil: Magic1 ()
TucoX ::
Čez dva dni (torej 25.6.2026), se začenja poletna razprodaja iger na Steamu.
Jaz imam kar nekaj zadev wishlistanih in čakam ugodne cene (Colony ship, Gothic remake, Tainted grail, Pragmata, Dying light the beast, Outer worlds 2)
Eto, nabavil Cyberpunk osnovno igro za 17.99€ (-70%). Nekje je potrebno potestirat FSR 4.1.
Pa še Borderlands: The Pre-Sequel za 3.99€ (-90%). Tista zastonjska z Epic stora ima težave z 64-bitnimi Windowsi.
To mi nič kaj dosti ne pove. Če je drastično slabše, je pač slabo, če pa je marginalno slabše pa glih nima veze. Kaj ti pomaga boljši dlss, če pa moraš detaile znižat pri rtx 5070 zaradi pomanjkanja rama. Trenutno stane 5060Ti 16gb skoraj toliko kot 9070. Ni glih primerjave, dlss gor ali dol.
Napiši kako dela Cybepunk s FSR 4.1.
Testirano na RX 7700XT. Po nekaj zafrkancije sem v igri dobil opcijo za FSR 4. Sicer sem omejil FPS na 90, da mi v vročini ventilatorji ne delajo preveč hrupa.
Kvaliteta slike je na mestu, v smislu nastavi FSR in igraj.
XBOX could eventually stop releasing games on Steam
https://nichegamer.com/xbox-could-event...
Pod novim Xbox vodstvom se govori nič uradnega, da bi lahko Xbox spet zapustil Steam.
Microsoft je v preteklosti že poskusil z zaprtimi sistemi (kot sta bila zloglasni Games for Windows Live ali začetno zaklepanje iger izključno na Microsoft Store). Vsi ti poskusi so propadli, zato se je Microsoft leta 2019 ponižno vrnil na Steam, saj so ugotovili, da brez Valveove platforme na PC-ju ne morejo preživeti.
Steam ima več kot 130 milijonov aktivnih uporabnikov mesečno. Umik s te platforme bi pomenil drastičen padec prodaje novih Xbox iger.
Jaz imam od 2007.
Seljak ::
Tudi jaz imam na tem profilu 16 let. Ampak sem že prej imel en profil, ki pa sem ga napravil mislim da 2003/04. Ampak takrat še ni bil mišljen kot takšen, ki ga poznamo sedaj. Na njem so se posodabljale njihove igre...
