[Dump kode] COM 1 in PIC programator ne gresta skupaj!?
Azrael ::
Zaradi preglednosti teme COM 1 in PIC programator ne gresta skupaj!?, prestavljam v novo temo post, ki ga je spisal uporabnik |Luka| dne 03.02.2006 ob 11:16:47
Tole mi vrže ven serial port monitor:
0,IRP_MJ_CREATE,DOWN,TRUE,0x0,4D 00 69 00 63 00 72 00 6F 00 50 00 72 00 6F 00 2E 00 65 00 78 00 65 00 00 00 ,M.i.c.r.o.P.r.o...e.x.e...,
1,IRP_MJ_CREATE,UP,FALSE,0x0,,,
2,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size),DOWN,TRUE,0x0,00 04 00 00 00 04 00 00 ,........,
3,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size),UP,FALSE,0x0,,,
4,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),DOWN,FALSE,0x0,,,
5,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate),UP,TRUE,0x0,00 4B 00 00 ,.K..,
6,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),DOWN,FALSE,0x0,,,
7,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control),UP,TRUE,0x0,00 00 08 ,...,
8,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),DOWN,FALSE,0x0,,,
9,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_CHARS: Retrieve special characters),UP,TRUE,0x0,00 3F 3F 00 11 13 ,.??...,
10,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),DOWN,FALSE,0x0,,,
11,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 08 00 00 00 02 00 00 ,................,
12,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate),DOWN,TRUE,0x0,00 4B 00 00 ,.K..,
13,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate),UP,FALSE,0x0,,,
14,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),DOWN,FALSE,0x0,,,
15,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),UP,FALSE,0x0,,,
16,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
17,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
18,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL: Set line control),DOWN,TRUE,0x0,00 00 08 ,...,
19,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_LINE_CONTROL: Set line control),UP,FALSE,0x0,,,
20,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS: Set special characters),DOWN,TRUE,0x0,00 3F 3F 00 11 13 ,.??...,
21,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_CHARS: Set special characters),UP,FALSE,0x0,,,
22,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW: Set handshake information),DOWN,TRUE,0x0,00 00 00 00 00 00 00 00 55 01 00 00 55 01 00 00 ,........U...U...,
23,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_HANDFLOW: Set handshake information),UP,FALSE,0x0,,,
24,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts),DOWN,TRUE,0x0,FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,yyyy................,
25,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts),UP,FALSE,0x0,,,
26,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),DOWN,FALSE,0x0,,,
27,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),UP,FALSE,0x0,,,
28,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS: Set RTS),DOWN,FALSE,0x0,,,
29,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_RTS: Set RTS),UP,FALSE,0x0,,,
30,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),DOWN,TRUE,0x0,7D 01 00 00 ,}...,
31,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),UP,FALSE,0x0,,,
32,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
33,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
34,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
35,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,41 00 00 00 ,A...,
36,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
37,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
38,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),DOWN,FALSE,0x0,,,
39,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),UP,FALSE,0x0,,,
40,IRP_MJ_READ,DOWN,FALSE,0x0,,,
41,IRP_MJ_READ,UP,TRUE,0x0,00 ,.,
42,IRP_MJ_READ,DOWN,FALSE,0x0,,,
43,IRP_MJ_READ,UP,TRUE,0x0,00 ,.,
44,IRP_MJ_READ,DOWN,FALSE,0x0,,,
45,IRP_MJ_READ,UP,FALSE,0x0,,,
46,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
47,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
48,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
49,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,61 00 00 00 ,a...,
50,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),DOWN,FALSE,0x0,,,
51,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),UP,TRUE,0x0,80 00 00 00 ,?...,
52,IRP_MJ_READ,DOWN,FALSE,0x0,,,
53,IRP_MJ_READ,UP,FALSE,0x0,,,
54,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
55, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
56, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
57, IRP_MJ_WRITE,DOWN,TRUE,0x0,50 03 ,P.,
58, IRP_MJ_WRITE,UP,TRUE,0x0,50 03 ,P.,
59,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,04 00 00 00 ,....,
60,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
61,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
62,IRP_MJ_WRITE,DOWN,TRUE,0x0,04 00 ,..,
63,IRP_MJ_WRITE,UP,TRUE,0x0,04 00 ,..,
64,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
65,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
66,IRP_MJ_WRITE,DOWN,TRUE,0x0,00 80 ,.?,
67,IRP_MJ_WRITE,UP,TRUE,0x0,00 80 ,.?,
68,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
69,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
70,IRP_MJ_WRITE,DOWN,TRUE,0x0,08 ,.,
71,IRP_MJ_WRITE,UP,TRUE,0x0,08 ,.,
72,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
73,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
74,IRP_MJ_WRITE,DOWN,TRUE,0x0,03 ,.,
75,IRP_MJ_WRITE,UP,TRUE,0x0,03 ,.,
76,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
77,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
78,IRP_MJ_WRITE,DOWN,TRUE,0x0,50 ,P,
79,IRP_MJ_WRITE,UP,TRUE,0x0,50 ,P,
80,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
81,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
82,IRP_MJ_WRITE,DOWN,TRUE,0x0,04 ,.,
83,IRP_MJ_WRITE,UP,TRUE,0x0,04 ,.,
84,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
85,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
86,IRP_MJ_WRITE,DOWN,TRUE,0x0,02 ,.,
87,IRP_MJ_WRITE,UP,TRUE,0x0,02 ,.,
88,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
89,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
90,IRP_MJ_WRITE,DOWN,TRUE,0x0,01 ,.,
91,IRP_MJ_WRITE,UP,TRUE,0x0,01 ,.,
92,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
93,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
94,IRP_MJ_WRITE,DOWN,TRUE,0x0,01 ,.,
95,IRP_MJ_WRITE,UP,TRUE,0x0,01 ,.,
96,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
97,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,04 00 00 00 ,....,
98,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
99, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
100, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
101, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),DOWN,FALSE,0x0,,,
102, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status),UP,TRUE,0x0,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 7F ,..................y,
103, IRP_MJ_WRITE,DOWN,TRUE,0x0,3F ,?,
104, IRP_MJ_WRITE,UP,TRUE,0x0,3F ,?,
105,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,04 00 00 00 ,....,
106,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
107, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
108, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
109, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
110, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
111, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
112, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,20 00 00 00 , ...,
113, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),DOWN,FALSE,0x0,,,
114, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),UP,TRUE,0x0,00 00 00 00 ,....,
115,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
116,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),DOWN,FALSE,0x0,,,
117,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_DTR: Set DTR),UP,FALSE,0x0,,,
118,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
119,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,20 00 00 00 , ...,
120,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),DOWN,FALSE,0x0,,,
121,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),UP,TRUE,0x0,80 00 00 00 ,?...,
122,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
123,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,40 00 00 00 ,@...,
124,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
125,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,01 00 00 00 ,....,
126,IRP_MJ_READ,DOWN,FALSE,0x0,,,
127,IRP_MJ_READ,UP,TRUE,0x0,00 ,.,
128,IRP_MJ_READ,DOWN,FALSE,0x0,,,
129,IRP_MJ_READ,UP,FALSE,0x0,,,
130,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),DOWN,FALSE,0x0,,,
131, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,02 00 00 00 ,....,
132, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
133, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),DOWN,TRUE,0x0,03 00 00 00 ,....,
134, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_PURGE: Purge requests),UP,FALSE,0x0,,,
135, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),DOWN,FALSE,0x0,,,
136, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_WAIT_ON_MASK: Wait for event),UP,TRUE,0x0,20 00 00 00 , ...,
137, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),DOWN,FALSE,0x0,,,
138, IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status),UP,TRUE,0x0,00 00 00 00 ,....,
139,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_DTR: Clear DTR),UP,FALSE,0x0,,,
140,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),DOWN,FALSE,0x0,,,
141,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_CLR_RTS: Clear RTS),UP,FALSE,0x0,,,
142,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),DOWN,TRUE,0x0,00 00 00 00 ,....,
143,IRP_MJ_DEVICE_CONTROL (IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask),UP,FALSE,0x0,,,
144,IRP_MJ_CLOSE,DOWN,FALSE,0x0,,,
145,IRP_MJ_CLOSE,UP,FALSE,0x0,,,
Nekoč je bil Slo-tech.
  • zaklenil: Azrael ()
Problem z ramom ali diskom? Prosim za nasvet.
111579 (1481) Duhec
WiFi Woes ... 2 x Linux : Belkin + LinkSys
Oddelek: Omrežja in internet
302014 (1499) Icematxyz
Ubuntu vprašanja
Oddelek: Operacijski sistemi
483375 (2124) roksson
750 Gb Samsung crknil - kako do podatkov?
142076 (1856) lopov
Zmrzal linux-a
61721 (1565) T(he) Boss
