Nakup namiznega PC-ja
GenZNPC ::
@goldhorn
za cirka 5€ več dobiš 2x4gb CL9 rama če se ne motim. Malo prebrskaj rame. Glede diska, če bo samo za shranjevanje je vseeno. Samo glej da ma 64mb cache in 2 ali več let garancije.
skibidi
Texslo ::
Hayabusa ::
Z87 mobo in ne "k" cpu.
Rami cl11 -> vzemi cl9 1600 mhz 1.5V.
Če si izbral i7 za igre:
https://slo-tech.com/forum/t200222/p433...
  • spremenilo: Hayabusa ()
Texslo ::
i7 ni za igre, ampak za programe ... ker nisem edini uporabnik tudi ne vem kakšne. :) Kakšna je razlika med cl11 in cl9? Kaj so pri matični plošči te oznake mi lahko prosim daš nadomestilo tej?
goldhorn ::
GenZNPC je izjavil:
@goldhorn
Kaj pa pomenijo ti CL pri RAMu? Ali ni bolje, da imaš 1x8gb kot pa 2x4gb?
Disk ne bo le za shranjevanje. Je kakšen, ki bi bolj izstopal po kvaliteti? Tudi če je dražji.
goldhorn ::
Sem našel info glede CL:
To know the difference, you have to know what CL means. The CAS latency is the time between accessing memory and being able to read the memory from the output, so 8 is faster than 9 is faster than 10. BUT and this is a huge BUT. Notice the all caps. Sometimes a higher CAS is faster because the memory operates at different speeds. For instance a DDR3 1333 module runs at 666mhz and ha a cycle time of 1.5ns. With a CL of 6 that means it takes 9ns for the memory to be available on the output. However a DDR3 1600 module runs at 800 and has a cycle time 1.25ns. With a CL of 7 it takes 8.75ns. As you can see, even though the CL is higher, it is still faster because the mhz jump increases the cycle time enough to give it a little boost. Going further, DDR3 2000 is just as fast at CL9 as the 1333 is at CL6.
1333vs1600:
You're not going to notice anything different. the only time you would notice, is if you are running one of AMD's new APU processors. It was shown that faster memory did speed up the gaming experience for the integrated GPU.
Better to go for 1600mhz cl9.
GenZNPC ::
Če je med 1600 CL11 in 1600 CL9 le 5EUR razlike (2 bureka) vzameš valda CL9. Pa če za isto ceno lahko dobiš dualchannel kit vzem to. Nevem zakaj nebi.
- Aja vidim da ima matična samo 2 reži za rame. Ja potem pa vzemi tako, ki ima 4 (če te je stra da ti nebo dovolj rama nekoč)
Za 2EUR več H87M Pro4. Sicer bi ti kaka B85 tudi bila ok (bussines modeli)
Nekaj časa je bil objavljen članek o zanesljivosti diskov različnih proizvajalcev na ST, poišči. Ti pa povem, da sem dal skozi vse te proizvajalce pa mi še noben ni crknil razen hitachija, ki pa potem ko sem ga dobil iz garancije že 5 let dela in dela.
Tako da glede zanesljivosti so vsi isti (moje mnenje), razlike ustvari po mojem server segment (kjer je 100% obremenjenost 24/7, toplota itd.) in prenosniki, kjer folk udarja meče pa ne neve da ima v kompu stvar, ki se vrti 120obratov/s
skibidi
  • spremenil: GenZNPC ()
matic492 ::
Ste opazli nekaj novega na sestavi.si? :D
Zdaj majo ceno v BTC napisano zraven.
Anway, iščem novo ohišje, zdajšnje je premalo, rabim plac za 2 H55 zdaj in kasneje upgrade verejtno na en H55 in en H100 (torej 2x120mm in kasneje 1x120mm + 1x240mm HLADILNIK) pa da nebo zmanjkal placa, gledal sem pa tole:
http://www.computeruniverse.net/en/prod...
Se da tole hitro dobit kje v sloveniji, tukaj piše 3-21 dni:
Hladilnik najverjetnej še en H55 iz nemčije, najceneje pride tako.
goldhorn ::
Še eno vprašanje okrog napajalnika. Kar sem na forumu zasledil, se nekako za igričarski računalnik priporoča za zadostno napajanje 550W (npr. XFX Core Edition PRO 550W). Pri izbiranju grafike pa sem za Gigabyte Radeon R9 270X OC BF4 Edition zasledil tale podatek:
Priporočljivo napajanje----izhod: min. 700 Watt
GIGABYTE grafična kartica R9 270 OC ---- ZAHTEVE NAPAJANJA: 500W min.
Kaj sedaj????
klkkkkkkkkkk ::
Če imaš XFX 550W je vse vredu .. tudi G 360W ti bo poganjal ali XFX 450W ...
GA-990XA-UD3, FX 6300 4.6GHz, R9 270X, 8Gb Ram, 1TB, G-550W, Win7
goldhorn je izjavil:
Kaj sedaj????
te priporočila so mišljena za napajalnike tipa inter-tech/lcpower, ki majo napihnjene moči...
FlyingBee ::
r9 270x bo peak imela 175W tako da ostalo ti mora do xfx 550W porabi še razliko do približno 520W kot ima ta napajalnik
Hayabusa ::
bansi ::
Živjo!
Imam eno kišto, kjer je par stvari crknilo, pa me zanima, če bi na sedanjo konfiguracijo lahko obesil dobro grafično? Grafična je itak crknila, kupil bi nekaj boljšega, da bi še coin minanje malo sprobal :) Matična plošča je gigabyte ga-945gm-s2, grafično sem pa gledal v rangu 250-350EUR, kar bi pač dobil, glede na to, da je povpraševanje kar hudo. Recimo ta: http://www.mlacom.si/sapphire-vapor-x-r... ali pa radeon hd7950 boost. Bi to laufalo ali je treba matično zamenjat? Druge komponente, razen napajalnika, niti niso važne, kolikor sem zasledil. Kakšen bi pa moral biti napajalnik, da bi to poganjal?
  • spremenilo: bansi ()
Hayabusa ::
http://www.guru3d.com/articles_pages/am...
241W poraba grafične, dodaj še ostalo za worst case, čeprav pri gpu miniranju cpu bolj kot ne idla.
Xfx 550 in imaš mir za v bodoče.
bansi ::
Hvala za hiter odgovor! Razmišljam, da bi vzel kar 750W, če bi kasneje dodal še eno grafično.
Kar pa se tiče kompatibilnosti matične in grafične, bi pa zadeva morala laufati, ne? Predvsem izkoristek me zanima, ker z matičnimi ploščami nisem preveč seznanjen.
matic492 ::
matic492 je izjavil:
BUMP.
Tale nzxt G10 me res zanima, nima nobne izkušenj z naročanjem tega?
Remie7 ::
zdravo,zanimam se za nakup novega gaming pc-ja (z monitorjem-25inčni,zvočniki,tipkovnico in miško vred), me pa zanima kaj se da dobit za največ 1500€ (mogoče kaki evro odstopanja). lp
Hayabusa ::
Samo za te 4 postavke lahko nabiješ ceno na 1500.
Bodi bolj konkreten.
GenZNPC ::
Ja pa moram poročat o Dark Rock 3 in Thermalright macho PCGH. Glede nato da ima DR3 PWM ventilator, hladi na max rpm enako kot macho z nizkimi (testiral v istem ohišju na istem procesorju). Predvidevam, da je vzrok polovico manjša razdalja med alu ploščami in heatpipei in se počasneje ohlaja zadeva, ker ni dost airflowa v coolerju. Tak da sem kr poslal nazaj in menjam za machoja pcgh.
skibidi
Remie7 ::
Hayabusa je izjavil:
Monitor:LED LCD 24" Samsung S24C300B
Zvočniki:Komplet zvočnikov 2.1 Logitech Z523
Tipkovnica:Trust eLight LED Illuminated
Miška:Razer Abyssus
torej vse te podstavke skupaj stanejo 277,39€, potem ostane še 1222,61€ za pc.
m@nt@ ::
Zdravo,
Odločam se za nakup novega delovnega PCja, ker je trenutni v poslednjih izdihljajih. Tukaj ste sami stučkoti pa vas prosim za nasvet glede komponent :)
Računalnik se bo uporabljal za Java in C programiranje ter poganjanje virtualk.
Potrebe po grafični moči ni.
Na sistemu bo laufal Linux (Xubuntu).
Predvsem me zanima katero matično ploščo in procesor naj izberem, da bo sistem deloval stabilno. Procesor naj bi bil iz nabora Intel i7 (ne Extreme).
Prosim za predloge :)
Hayabusa ::
Remie7
non OC sestava
http://www.mlacom.si/konfigurator?mycon...
oc
#1
#2
m@nt@
non OC sestava
+ 8 Gb rama (ne znam 2x dodati v mlacom sestavo)
http://www.mlacom.si/crucial-bx-8gb-2x4...
za oc glej Remie7 konfig zgoraj in odstrani grafično, dodaj ssd 250 gb in 16 gb rama.
sandi4444 ::
Po dolgem premisleku sem si skonfiguriral rač na platformi i5 4670
http://www.funtech.si/si/konfigurator/
A je tale matična plošča vredu glede na to da ne bom navijal računala? Bi morala biti z78?
Ima kdo oz. pozna kdo, kako cenejšo opcijo za nakup komponent?
GenZNPC ::
Zakaj mu silite 4670K, če zato dobi E3-1230v3 206 EUR?
Tukaj klikni na sliko: https://slo-tech.com/forum/t588643/p432...
+ Poštnina 11€
skibidi
Hayabusa ::
sandi4444 je izjavil:
Ta konfigurator prikaže sestavo samo na tvojem pcju, kjer je funtech cookie.
Mi ostali vidimo prazen konfig.
sandi4444 ::
Gigabyte G1.Sniper B5, Intel B85 Mainboard - S1150
Procesor Intel Core i5 4670 BOX , Haswell
SAPPHIRE RADEON R9 280X OC Vapor-X, 3072 MB DDR5, DP, HDMI, DVI 11221-02-40G
Pomnilnik Kingston HyperX Genesis 8GB 1600MHz DDR3 KHX16C9/8
kasneje še pa boljši napajalnik in SSD disk, sedaj imam 550W saj to bi moralo zadostvovat?
klkkkkkkkkkk ::
Kater 550W?
sandi4444 ::
me neki lc power
klkkkkkkkkkk ::
Menjaj za XFX 550W
Ajnstajn` ::
Končno sem po dolgem času na vrsto prišel tudi jaz :), na nov komp čakam že 3 mesece in mislim da je zadnji čas. odkar sem gledal tale komp decembra, so cene rahlo padle (ne toliko, kot sem jaz želel :P)
http://prntscr.com/2w6t7n
kakšen dodaten nasvet dobrodošel, sicer pa bi bil hvaležen, če mi kod poda primerne rame za to konfiguracijo.
kdorkoli ?
Ajnstajn` ::
Zanima me tudi, koliko vloge spila 30EUR drazji al slabsi ram ? ce recimo vzamem nekaj za 140 EUR al 170 EUR ?
govorim o 16GB (2x8GB)
klkkkkkkkkkk ::
Odvisno zakaj rabiš
gaming?
Obdelavo slike, itd.?
http://www.hardwareversand.de/1600+Low+...
http://www.hardwareversand.de/1866+Low+...
Važno je da vzameš CL9 pa 1600mhz+ in pri intelovih paziš na na V = max 1.5V
Tvoj konfig je vredu samo je vredno dodajat CF notri?
GenZNPC ::
Se strinjam z flyingbeejem, rajši bi vzel GTX 780Ti OC za 600EUR, kot dve za 290x za 810EUR oz. če že tak drag komp mora met CUDO pa physix :D . Posledično je lahko slabši napajalnik.
Sicer pa v 2kEUR bi jaz spravil not GTX 780Ti OC, 16GB rama, 4930K (na P9 X79 gre na 4,3ghz brez problema) machota BW. Ostalo pa bi prilagodil.
Pa še ena osebna: ohišje za 70-80EUR bo enako dobro kot ohišje za 200EUR :D pri gamingu :D
skibidi
klkkkkkkkkkk ::
Ma ne, GTX 780 Ti se pa res nesplača.
1x R9 290 naj prišpara denar 400EUR za naslednjo generacijo recimo maxwell na 20nm :)
Če hočeš fiziko vzameš GTX 780 ... dodatnih 150-200EUR ni vredno za GTX 780 TI
Drgač pa tale
http://www.hardwareversand.de/articlede...
Kar je nad R9 290 mečeš denar skozi oken.
Navij tole R9 290 na 1150-1200 core clock pa je to to
Razen, če boš igral na 4K?
klkkkkkkkkkk ::
Eto še en test za R9 290
http://www.guru3d.com/articles_pages/po...
top hladilnik
GenZNPC ::
Ja v bistvu ja. V celem konfigu lahko ene 500-600€ prišparaš pa boš mel enako igralno izkušnjo recimo. Pa si čez 1,5 - 2 leti kupiš drugo grafo za 500€ ki bo top.
- Posledično boš imel čet leto pa pol boljši performance, kot z dvema 290X v CF.
skibidi
Ciklamen ::
Upsala, nisem videl da se je že zadeva posodobila v tem času :D
- End of the Post ->
  • spremenil: Ciklamen ()
SuperVeloce ::
GenZNPC je izjavil:
Sicer nisem pristaš CF in te zadeve tudi sam odsvetujem če se da, vendar se motiš. Pred letom in pol si dobil 2x 7950, ki je hitrejša od 290x. 2x 7970 je hitrejša od Titana Ti.
GenZNPC ::
Ja ampak, zdaj vemo da pride maxwell in volta. Tk da lahko predvidevamo večji skok kot takrat.
skibidi
GenZNPC ::
Predlog pa prideš z 350EUR manj skozi in nebo ti žal, ne zdaj in ne v prihodnosti.
 1641 Eur
1641 Eur
Popravek: daj not 250GB SSD :D
skibidi
klkkkkkkkkkk ::
m0ln4r tale GTX 7880 se nesplača naj vzame cenejšo ... glede nato, da je počasnejša od R9 290, ki pa je cenejša
GenZNPC ::
Glede GTX 780, res nevem katera je best buy, ker sem kr tak dal not eno iz lista.
Za 400EUR jaz pričakujem, da ma zadeva fiziko, cudo(pa tudi če ne rabim), geforce experience +še kaj :D nebi glih "mercedesa z 15" gumami in radkapami :D"
skibidi
klkkkkkkkkkk ::
GenZNPC je izjavil:
kaj ti bo fizika? še malo pa nebo več noenega špila z fiziko, če nebodo pustili AMD-ju
"Nvidia samo svinja z fiziko", na konzolah bodo pustili tu pa ne...
Aliaga ::
Pozdravljeni,
pa sm našla temo :)
Prosim za pomoč ljudi ki se na to spozanjo, ker js pojma nimam :)
Gre se za nakup novega računalnika, ki bi bil zmožen brezhibno poganjati 3d programe kot so: ZBrush, Maya, 3DS MAX, Mudbox, ter standard adobe programe (Photoshop, Indesign, AfterEfects, Illustrator,...). Ker se seveda ne spoznam na računalnike, bi prosila za vašo pomoč. Rada bi tudi odigrala igrco WatchDogs od Ubisofta. Vem, da so računalniki iz trgovine predragi za to kar ponujajo, zato upam da s tem, da bi dala sestaviti nov računalnik (dinokomp?) ta denar mogoče vložila v boljše komponente. Moj budget je okoli 1200€.
Hvala za vašo pomoč,
Aliaga
GenZNPC ::
i7 4770 tray + macho pcgh (po želji) + 16GB dualchannel CL8 ram + gtx 770 + 250gb ssd + SSHD 1TB + xfx 550w + matična + ohišje po želji + card reader slučajno, dvd pekač?
ali ceneje:
Xeon 1230v3 + macho pcgh (po želji) + 16GB dualchannel CL10 ram + gtx 760 + 250 ssd + navaden 1tb + xfx 550w + matična + ohišje po želji + card reader slučajno, dvd pekač?
skibidi
Aliaga ::
Hvala za hiter odgovor :)
kok približno pa je cena teh konfiguracij? Dvd pekač sicer ne uporabljam ampak mislim da niso dragi 30€?
Aliaga ::
p.s: + matična + ohišje po želji pojma nimam katera matična in ohišje gre tle zrovn
GenZNPC ::
Nekaj takega:
Oz. 1024€ z (1230v3 + gtx760) ali 1045€ z (1240v3 + gtx 760) ali 996€ (z 1230v + gtx 760 + 1TB sshd)
skibidi
Ajnstajn` ::
okej, fantje, tule se jaz malo oproščam, ker sem anredil napako...
ne mislim imeti 2 grafični ampak samo eno.
316 / 1176
