Forum » Kaj kupiti » Kupujem računalnik okoli 150 000 SIT
M.B. ::
Odločil sem se, da kupim računalnik. Imam Monitor, miško, tipkovnico, Pekač. Računalnik, bi uporabljal večinoma za bolj nezahtevna opravila in igre ki tečejo že na starem.
Sedaj imam:
Processor
Model : AMD Duron(tm) Processor
Speed : 997MHz
Model Number : 997 (estimated)
Performance Rating : PR1446 (estimated)
Type : Standard
L2 On-board Cache : 64kB ECC Synchronous Write-Back (16-way, 64 byte line size)
Mainboard
Bus(es) : ISA AGP PCI USB i2c/SMBus
MP Support : No
MP APIC : No
System BIOS : American Megatrends Inc. 062710
Mainboard : Matsonic MS8308E
Total Memory : 367MB SDRAM
Chipset 1
Model : Silicon Integrated Systems (SiS) SiS730 CPU to PCI Bridge
Front Side Bus Speed : 2x 100MHz (200MHz data rate)
Total Memory : 384MB SDRAM
Shared Memory : 16MB
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : FUJITSU MPD3064AT
Hard Disk : Maxtor 6Y080L0
CD-ROM/DVD : _NEC DVD_RW ND-2500A
Logical Storage Devices
1.44MB 3.5" (A:) : N/A
Moj disk (C:) : 76.3GB (3.2GB, 4% Free) (NTFS)
Glasba (D:) : 6.0GB (1.3GB, 21% Free) (FAT32)
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : SiS 7001 PCI to USB Open Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Genius PS/2 Scroll Mouse
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 1)
Na mimovrste sem si ogledal te stvari:
CPU AMD Sempron 2800+ BOX 25.758 SIT
Matična plošča Abit NF7 16.999 SIT
Trdi disk WD 160 GB IDE 7200rpm 8MB cache 21.165 SIT
Grafična kartica Sapphire Radeon 9600 PRO 128MB DVI TV 25.800 SIT
Geil DDR LONG DIMM 512 MB 400 MHz 19.436 SIT
Mogoče Ohišje Midi tower MR05W 350w plexi 12.052 SIT
Vse skupaj je 121.210 SIT
Zanima, me, če gre tole skupaj(Mislim, da procesor ne. Katerega?) in eno zahtevo imam, vse mora podpirati Linux, vem, da večina stvari linux podpira, vem, da ne podpira SATA diskov, pa me zanima, če je še kaj takega.
Zanima me še Kaj pomeni pri imenu procesorja(CPU AMD Sempron 2800+ BOX) 2800+ in BOX.
Procesor bi imel 2 GHZ ali več.
Se že vnaprej zahvaljujem za vse.
Sedaj imam:
Processor
Speed : 997MHz
Type : Standard
Mainboard
MP Support : No
MP APIC : No
Chipset 1
Peripherals
Operating System(s)
- spremenil: M.B. ()
jest10 ::
2800+ naj bi bila primerjava zmoglivosti procesorja proti novemu celeronu. Drugače ta proc teče na 2GHz. BOX pa pomeni proc + ventilator v kompletu.
Za linux bi bilo bolje imeti kako drugo grafično-ati ima švoh gonilnike
zee ::
Gonilniki od ATIja za Linux sicer niso ne vem kaj, vendar delajo brezhibno.
SATA diski so v Linuxu podprti. Je pa potrebno malo čaranja, da jih usposobiš. Odvisno sicer od distribucije, ki si jo boš namontiral.
zee
M.B. ::
Torej Ati kartice imajo male slabše gonilnike. Katere imajo boljše? Namestil bi si Pingo(Fedora Core 3), Mandrake, Suse. Nekaj od teh.
Hvala zaenkrat za vse.
| » | Komp za zajebancijeOddelek: Kaj kupiti | 2849 (2346) | M-XXXX |
| » | Je dober nakup WD 160 GB IDE?Oddelek: Kaj kupiti | 1870 (1682) | msms |
| » | Nakup Novega Compa Po KomponentahOddelek: Kaj kupiti | 4666 (4020) | cassiel |
| » | Glasbene komponenteOddelek: Kaj kupiti | 1903 (1794) | Nephthys |
| » | Nakup TV tunerjaOddelek: Strojna oprema | 2409 (2235) | Šimpanz |
