Janac ::
nevem jugozahod verjetno
Lion29 ::
keteces...
mora biti
<th>one</th> in ne </th>one</th>
Rias Gremory ::
@janac
povej koordinate
Janac ::
navem
Rias Gremory ::
potem dvomim da igraš
Mentalist ::
Lev. hvala.
Lool.
na netu sn našo nVidia ION barebore 330 dual core nettop za 130E, če koga zanima.
Rias Gremory ::
@ketečeš
saj ti je lev pomagal. :)
Mentalist ::
Moja napaka.
Lool.
Bananovec ::
Grem probam naredit en HIIT trening.
Regards, Apple
Rias Gremory ::
@ketečeš
ni kej
@bananovec
navijamo
Janac ::
js mam enak ime kot tukej no
MB -8C
Mentalist ::
Gremo navijat za njega in zraven procesor ali grafično.
Lool.
Mentalist ::
Lool.
Janac ::
Mentalist ::
Zajebavam se no.
Lool.
gremo navijati za JANŠOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
__Devil__ ::
http://www.partis.si/torrent/podrobno/2...
a je boljše, če naložim tale modificiran windows: Windows 7 xDark™ Deluxe v4.6 x64
ali bi vi raje priporočali standardno verzijo kot je v originalu (ultimate) ?
privlači me stuff kot je:
Services:
? Disabled:
* Windows BackUp
* Parental ControlS
* Remote Registry
* Hibernation
* Disk Defragmenter
* Offline Files
* Windows Error Reporting Service
* Program Compatibility Assistant Service
* Windows Media Player Network Sharing Service
* Security Center
* Windows Search
(to enable a services type services.msc in the start menu search box and enable it from the services manager or run the xDark? Services Manager)
# Integrated Tweaks:
* Disable CEIP (Customer Experience Improvement Program):
The Windows Customer Experience Improvement Program in Windows 7 is a completely voluntary program designed to help Microsoft improve its operating systems over time. This program collects information about computer hardware and how people use Windows 7.
* Speed up Windows Thumb Time-Delay:
Windows 7 has provided a cool feature with ability to preview taskbar thumbnails whenever the mouse is hovered on the program icon. However, you may notice that it does have some latency to display the preview after mouse over the icon, Thumb Time-Delay has been improved to avoid this problem.
* NTFS; Disable 8.3 Names and Last Access:
NTFS Files systems create file names in 8.3 format. Disabling this option reduces the overhead during the creation of new files or directories.
* Improve DNS Caching:
By default Windows also caches erroneous data and this can take space of valid cache items and thus slow down your Internet access. This will tell windows not to cache erroneous DNS data at all.
* SpeedUp Access to AVI Files:
Speeds up the access of AVI folders as well as makes the renaming and deletion of AVIs easier.
* Enable Boot Optimization:
The Boot Optimization function will automatically defragment boot files and rearrange them so that all boot files are in close proximity to one another.
* Allocate more Critical Threads to Increase Performance:
This Option lets Windows create more critical threads for when your system load is high in order to improve your systems performance.
* Unload DLLS from Memory after Use:
Remove DLLs from memory after use to free up more resources.
* Disable Network Redirector File Caching for Workstation Service:
On network computers, when data is written to a file, it is written to the cache and not immediately flushed to the redirector.
* Improve Core System Performance:
This option lets drivers and system code move to disk whenever required as sometimes more physical RAM is requiered to run an application
kaj bi ti nareo? :o
pomoje bom kar naložil tega, v kolikor nebo dal noben dobrega razloga, ki me bo odvrnil od instalacije =P
Janac ::
pirat
Mentalist ::
Devil, org gor pa basta. ::DD
Lool.
__Devil__ ::
če ma tak lepe nastavitve Windows 7 xDark™ Deluxe v4.6 x64 ^^
Rias Gremory ::
@devil
jaz sem že od nekdaj skeptičen glede teh "hitrih" verzij, zmeraj sem si dol potegnil "originalne" oz. nespremenjene verzije.
pa še ne veš kdo je delal te pohitritve. raje si sam naštelaj kar rabiš je moje mnenje.
edit: pa še vidim da ima nekaj aplikacij že zapakiranih v sami inštalaciji kar meni ni všeč ker si dam raje sam gor kar rabim. ampak to sem samo jaz. :)
__Devil__ ::
ja moja mama jih verjetno ni
Rias Gremory ::
tudi jaz mislim tako
__Devil__ ::
zelo pametno misliš :))
Bananovec ::
Nasnameš gor Retail verzijo in si sam po potrebi zmodificiraš. Rezultat je isti.
Regards, Apple
Mentalist ::
Lenuh sem.
Lool.
stop piracy now
Bananovec ::
Regards, Apple
Rias Gremory ::
to si dejansko naredil bananovec :O
@ketečeš
zakaj
__Devil__ ::
sem se odločo za modificirano verzijo pika
Janac ::
jst bom tutt to instaleru
Rias Gremory ::
@devil
veliko sreče
__Devil__ ::
hvala hvala :'D
iNooby ::
Haters gonna hate...
Janac ::
Deluja seveda brezhibno.
Bananovec ::
Rias Gremory je izjavil:
@ketečeš
zakaj
Da. V bistvu sem čakal, da temperature čimbolj padejo, pa me je že skoraj tema dohitela. Se pa ta hlad sploh ne čuti, ko se malo segreješ.
Regards, Apple
__Devil__ ::
aleluja :))
edit dva: zaj se grem sankat
Rias Gremory ::
še minuto in pol :O
__Devil__ ::
en dva tri mogo bi odnest smeti pa se ne mudi ragadi ragado
Rias Gremory ::
galu ::
Kak sem bil enkrat zasvojen s tem travianom...:))
Tako to gre.
Bananovec ::
Vsi smo bili :D
Moj naj dogodek iz traviana (3x speed)
Registriram se pol dneva po začetku,
račune razmnožim,
na serverju sem pol 20 (od 20 000),
čez 5 dni sem benan.
Pol skočim v jok
in
se
nikoli
več
ne
zmenim
za
TRAVIAN.
4Chanerji, a ste obiskali kdaj svoje prednike?
Regards, Apple
Rias Gremory ::
nope, itak pa 4chan (zaenkrat) obiskujem samo za /b/ če mi je dolgčas (čeprav po kakšni minuti zaprem /b/..) pa za /h/ 8-)
btw kaj naredite ko mate preveč stvari naenkrat za naredit? ;(
Bananovec ::
Jih ne naredim.
Če si len, moraš biti len do skrajnosti.
Za Hentai in drugo zlato Japonske si nasnami
Perfect Dark.
Regards, Apple
Rias Gremory ::
saj sem za moje pojme preveč len ;(
bom pogledal
Mentalist ::
Končal fiziko in slovenščino. Feel like a boss.
Lool.
Bananovec ::
Piši: Perfect Dark p2p, če ne boš dobil ven neki špil.
Za vozlišča vpiši v Gugl: PD nodes, Perfect Dark nodes, Perfect Dark Node list
Programčič podoben emuli, vendar usmerjen v japonski trg.
Regards, Apple
Rias Gremory ::
@ketečeš
zavidam ti :P
@banana
je tudi ang jezik?
901 / 1180
