Forum » Operacijski sistemi » Ubuntu vprašanja
Ubuntu vprašanja
Zvezdica27 ::
lp,
jaz bi poizkusil s smxi skripto, ki potem namesti najboljše gonilnike. Mislim, da smxi obvlada tudi Nvidio - in hkrati posodobi kernel (recimo na liquorix).
Meni je dosedaj vedno delalo, dokler ne gre za debian stable. Ker je ubuntu na debian sid, mislim da ne bo problema.
b
b
---> It (smxi) does not support Ubuntu based distros because there are too many differences between Debian and Ubuntu.
Da ne bo presenečenj.
Za sgfxi (simple graphics installer) sicer piše, da podpira Ubuntu, tako da...
A ni imel Ubuntu včasih "meta" package, ki je naložil nvidiin gonilnik?
- spremenil: MrStein ()
Še vedno je: nvidia-current
Vprašanje, pa kako bo deloval z novimi karticami, ker ne sledi redno novim verzijam.
Tu imajo novejše verzije: https://launchpad.net/~xorg-edgers/+arc...
Navodila za namestitev: http://www.binarytides.com/install-nvid...
Kiborg ::
Ko preverim če gonilniki delujejo je zadnja stvar Capabilities: (access denied)
Kernel driver in use vrstice sploh ni.
napiši -A 20 namesto -A 12 na koncu
napiši samo lspci -vnn in prilepi sem izpis.
Kiborg ::
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v3 Processor DRAM Controller [8086:0c08] (rev 06) Subsystem: ASRock Incorporation Device [1849:0c08] Flags: bus master, fast devsel, latency 0 Capabilities: <access denied> 00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller [8086:0c01] (rev 06) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 0000e000-0000efff Memory behind bridge: ee000000-ef0fffff Prefetchable memory behind bridge: 00000000d0000000-00000000e1ffffff Capabilities: <access denied> Kernel driver in use: pcieport 00:14.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB xHCI Controller [8086:8cb1] (prog-if 30 [XHCI]) Subsystem: ASRock Incorporation Device [1849:8cb1] Flags: bus master, medium devsel, latency 0, IRQ 30 Memory at ef520000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: xhci_hcd 00:16.0 Communication controller [0780]: Intel Corporation 9 Series Chipset Family ME Interface #1 [8086:8cba] Subsystem: ASRock Incorporation Device [1849:8cba] Flags: bus master, fast devsel, latency 0, IRQ 44 Memory at ef53a000 (64-bit, non-prefetchable) [size=16] Capabilities: <access denied> Kernel driver in use: mei_me 00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I218-V [8086:15a1] Subsystem: ASRock Incorporation Device [1849:15a1] Flags: bus master, fast devsel, latency 0, IRQ 41 Memory at ef500000 (32-bit, non-prefetchable) [size=128K] Memory at ef538000 (32-bit, non-prefetchable) [size=4K] I/O ports at f040 [size=32] Capabilities: <access denied> Kernel driver in use: e1000e 00:1a.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2 [8086:8cad] (prog-if 20 [EHCI]) Subsystem: ASRock Incorporation Device [1849:8cad] Flags: bus master, medium devsel, latency 0, IRQ 16 Memory at ef537000 (32-bit, non-prefetchable) [size=1K] Capabilities: <access denied> Kernel driver in use: ehci-pci 00:1b.0 Audio device [0403]: Intel Corporation 9 Series Chipset Family HD Audio Controller [8086:8ca0] Subsystem: ASRock Incorporation Device [1849:1151] Flags: bus master, fast devsel, latency 0, IRQ 45 Memory at ef530000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel 00:1c.0 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 [8086:8c90] (rev d0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=02, subordinate=02, sec-latency=0 Capabilities: <access denied> Kernel driver in use: pcieport 00:1c.2 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 3 [8086:8c94] (rev d0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=03, subordinate=03, sec-latency=0 I/O behind bridge: 0000d000-0000dfff Memory behind bridge: ef400000-ef4fffff Prefetchable memory behind bridge: 00000000e2100000-00000000e21fffff Capabilities: <access denied> Kernel driver in use: pcieport 00:1c.3 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 4 [8086:8c96] (rev d0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=04, subordinate=09, sec-latency=0 I/O behind bridge: 0000b000-0000cfff Memory behind bridge: ef100000-ef2fffff Capabilities: <access denied> Kernel driver in use: pcieport 00:1c.6 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 7 [8086:8c9c] (rev d0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0 Memory behind bridge: ef300000-ef3fffff Capabilities: <access denied> Kernel driver in use: pcieport 00:1d.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1 [8086:8ca6] (prog-if 20 [EHCI]) Subsystem: ASRock Incorporation Device [1849:8ca6] Flags: bus master, medium devsel, latency 0, IRQ 23 Memory at ef536000 (32-bit, non-prefetchable) [size=1K] Capabilities: <access denied> Kernel driver in use: ehci-pci 00:1f.0 ISA bridge [0601]: Intel Corporation 9 Series Chipset Family Z97 LPC Controller [8086:8cc4] Subsystem: ASRock Incorporation Device [1849:8cc4] Flags: bus master, medium devsel, latency 0 Capabilities: <access denied> Kernel driver in use: lpc_ich 00:1f.2 SATA controller [0106]: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode] [8086:8c82] (prog-if 01 [AHCI 1.0]) Subsystem: ASRock Incorporation Device [1849:8c82] Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 39 I/O ports at f090 [size=8] I/O ports at f080 [size=4] I/O ports at f070 [size=8] I/O ports at f060 [size=4] I/O ports at f020 [size=32] Memory at ef535000 (32-bit, non-prefetchable) [size=2K] Capabilities: <access denied> Kernel driver in use: ahci 00:1f.3 SMBus [0c05]: Intel Corporation 9 Series Chipset Family SMBus Controller [8086:8ca2] Subsystem: ASRock Incorporation Device [1849:8ca2] Flags: medium devsel, IRQ 10 Memory at ef534000 (64-bit, non-prefetchable) [size=256] I/O ports at f000 [size=32] 01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev a1) (prog-if 00 [VGA controller]) Subsystem: Gigabyte Technology Co., Ltd Device [1458:366a] Flags: fast devsel, IRQ 16 Memory at ee000000 (32-bit, non-prefetchable) [size=16M] Memory at d0000000 (64-bit, prefetchable) [size=256M] Memory at e0000000 (64-bit, prefetchable) [size=32M] I/O ports at e000 [size=128] Expansion ROM at ef000000 [disabled] [size=512K] Capabilities: <access denied> 01:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1) Subsystem: Gigabyte Technology Co., Ltd Device [1458:366a] Flags: bus master, fast devsel, latency 0, IRQ 17 Memory at ef080000 (32-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel 03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 11) Subsystem: ASRock Incorporation Motherboard (one of many) [1849:8168] Flags: bus master, fast devsel, latency 0, IRQ 40 I/O ports at d000 [size=256] Memory at ef400000 (64-bit, non-prefetchable) [size=4K] Memory at e2100000 (64-bit, prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: r8169 04:00.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184] (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=04, secondary=05, subordinate=09, sec-latency=0 I/O behind bridge: 0000b000-0000cfff Memory behind bridge: ef100000-ef2fffff Capabilities: <access denied> Kernel driver in use: pcieport 05:01.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184] (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=05, secondary=06, subordinate=06, sec-latency=0 Capabilities: <access denied> Kernel driver in use: pcieport 05:03.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184] (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=05, secondary=07, subordinate=07, sec-latency=0 I/O behind bridge: 0000c000-0000cfff Memory behind bridge: ef200000-ef2fffff Capabilities: <access denied> Kernel driver in use: pcieport 05:05.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184] (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=05, secondary=08, subordinate=08, sec-latency=0 Capabilities: <access denied> Kernel driver in use: pcieport 05:07.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184] (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0 Bus: primary=05, secondary=09, subordinate=09, sec-latency=0 I/O behind bridge: 0000b000-0000bfff Memory behind bridge: ef100000-ef1fffff Capabilities: <access denied> Kernel driver in use: pcieport 07:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02) (prog-if 01 [AHCI 1.0]) Subsystem: ASRock Incorporation Motherboard [1849:0612] Flags: bus master, fast devsel, latency 0, IRQ 42 I/O ports at c050 [size=8] I/O ports at c040 [size=4] I/O ports at c030 [size=8] I/O ports at c020 [size=4] I/O ports at c000 [size=32] Memory at ef200000 (32-bit, non-prefetchable) [size=512] Capabilities: <access denied> Kernel driver in use: ahci 09:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02) (prog-if 01 [AHCI 1.0]) Subsystem: ASRock Incorporation Motherboard [1849:0612] Flags: bus master, fast devsel, latency 0, IRQ 43 I/O ports at b050 [size=8] I/O ports at b040 [size=4] I/O ports at b030 [size=8] I/O ports at b020 [size=4] I/O ports at b000 [size=32] Memory at ef100000 (32-bit, non-prefetchable) [size=512] Capabilities: <access denied> Kernel driver in use: ahci 0a:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller [1b21:1142] (prog-if 30 [XHCI]) Subsystem: ASRock Incorporation Device [1849:1142] Flags: bus master, fast devsel, latency 0, IRQ 18 Memory at ef300000 (64-bit, non-prefetchable) [size=32K] Capabilities: <access denied> Kernel driver in use: xhci_hcd
dottor ::
Danes sem zamenjal grafično (HD5750 vn in X1650 not), da sem lahko vtaknu TV kartico v kišto (Gigabyte GT-P6000) in sedaj za pridet v Ubuntu imam črn ekran. Preko LIVE DVD sem zbrisal xorg.conf kot sem zasledil na forumih ampak zadeva še vedno ne pride do slike. Kartico sem menjal zato, ker rabim eno single slot da lahko vstavim še tv kartico not.
Xeon X5650@3.8GHz |Asus P6T|
2x4GB+4x2GB|ASUS R9 280X@1100MHz|
WD Green 240GB SSD + 4x1TB Hitachi
Zvezdica27 ::
hmm... ni pa unclaimed... pa driverja ne napiše---
daj še
lshw -C video
če se tam kaj pametnega napiše, pa prilepi tu pa še povej ker kernel maš trenutno (uname -a), jaz mam na 14.10 lubuntu 3.16.0
Kar bi jaz naredil je
1 update in dist-upgrade
2) potem reboot in proprietary drivers (če potegne)
če ne potegne še:
3) na http://kernel.ubuntu.com/~kernel-ppa/ma... potegnil dol 3.19 kernel in ga namestil
4) še enkrat poizkusil z driverji z Nvidia strani.
MIslm, če pa kaj na ubuntu dela, pa namestitev grafike res ni problem (proti recimo vanilla debian, kjer moraš malo vedeti za kaj se gre)-
daj še
lshw -C video
če ne potegne še:
Kiborg ::
Krnel imam 3.16.0-31-generic.
Lshow -C video da:
*-display UNCLAIMED
description: VGA compatible controller
product: GM204 [GeForce GTX 970]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version:a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:ee000000-eeffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:e000(size=128) memory:ef000000-ef07ffff
Lshow -C video da:
*-display UNCLAIMED
physical id: 0
version:a1
width: 64 bits
clock: 33MHz
dottor ::
Kako nastavim skupno rabo na ubuntuju. Mapo sem dodal v Souporaba krajevnega omrežja, ko pa grem na Možnosti osebne souporabe datotek mi pod Souporaba datotek preko omrežja izpiše:
Te možnosti ni mogoče omogočiti, ker na vašem sistemu niso nameščeni vsi potrebni programski paketi.
Ni včasih pod obvestilom bil gumb "Namesti potrebne pakete.." ?
b3D_950 ::
Mislm, da moraš naredit še ponoven reboot/logout, da te doda pod novo skupino sambashare.
dottor ::
Sicer gre za Lubuntu ampak bom tu pisal saj je tema bla kar aktivna. V društvu smo dobili en star Athlon XP 1500+, dodal sem še 1GB rama (1,5GB zdej) in gor dal Lubuntu (ker nimamo Windows licenc je blo treba dat linux gor). Sedaj imam težavo, da mi firefox kreša na random, na jutubu pa ne začne predvajat ampak je črna slika... Chrome ne dela ker je prestar hardware, Midori tudi kreša na veliko. Kakršna koli pomoč pride prav. Hvala.
echoman ::
Lahko poskusiš še s kakšno drugo različico Lubuntuja - če imaš sedaj 15.04, potem preizkusi še 14.10 in 14.04 (LTS). Preden nameščaš preizkusi kako se zadeve odrežejo v Live seji in se potem na podlagi tega odločiš. Poleg Lubuntuja lahko sprobaš še Xubuntu ali pa kater drug lightweight distro. Nekaj bo zagotovo delovalo, saj je tudi meni na starem Celeronu s 512 MB RAMa zadeva delovala solidno - celo 360p posnetke sem lahko gledal na YouTube, 480p so bili že bolj v korakih.
- spremenil: echoman ()
dottor ::
Hvala bom probal 14.10 in 04, čene pa še Xubuntu.
lmorgh ::
pozdravljeni
imam laptop s ssd in hdd diskom. je kak catch, na katerega moram biti pozoren, ko inštaliram Ubuntu (inštaliral bom seveda na ssd, hdd bo le za podatke)?
b3D_950 ::
Da trim enableš med bootanjem (po defaultu je preko crontaba, ampak ne vem kdaj se izvaja - baje boljš da izklopiš: sudo mv -v /etc/cron.weekly/fstrim /fstrim) in zmanjšaš swappiness...
Bolj detaljno:
https://sites.google.com/site/easylinux...
in dodaš fstrim /
Bolj detaljno:
sudo nano /etc/rc.local
in dodaš fstrim /
#!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. fstrim / exit 0
N4m31355 ::
Dann!
Imam SSD crucial bx100 in lubuntu 15.4 ko se loginam je vse vredu, po screen lock-u, pa vse zmrzne.. kaksna ideja?
pravtako htop pokaze da je zasedeno 4.4GB/12GB rama, medtem ko je rumen graf bolj pri 11GB? Swap je izklopljen.
Zvezdica27 ::
lp,
hja, pogosto openbox pri takih hecih zaserje. Recimo screene (eksterni monitor ponovno nastaviti itd.). To se doaja, kjer Openbox ni edini DE oz. bolje WM.
Ena od rešitev, če si upaš tvegati, je da odtraniš druge DE, tprej kaj maš, xfce zraven?
Na debian openbox only teh hecev ni.
Jaz nimam časa to raziskovati, a zdi se mi, da xfce procesi pod površjem nadzoruje precej zadev, vključno s screenlockom. čaki da probam zdajle pri sebi ,sem na lubuntu 14.
Torej rešitev: debian vanilla ali net install + openbox. Ali pa ubuntu server + nabiltat na openbox.
čaki sam mal
zz
torej ja, meni na screen locku ko je monitor2 edini, vklopi tudi monitor 1 za sam login, pol ga pa disabla. Torej ne zmrzne, sumim da xfce ne ve točno kaj dela openbox in pol ko se zbudi spet arandr prevzame.
Zmrzne pa ne.
Torej:
-zamenjat screenlocker
-update dist-upgrade
-reinstall
-najnovejši kernel (ali smxi, liquorix...)
-najnovejši lubuntu ali pa ena starejša verzija
Ni druge, žal, ali pa distro, ki je openbox only (sam jebi ga, ker na ubuntu vsi driverji tako lepo delajo...). Mene ne moti.
zz
čaki sam mal
zz
Zmrzne pa ne.
Torej:
-reinstall
zz
- spremenil: Zvezdica27 ()
N4m31355 ::
zadeva se je z updejti popravila. tezava, ki pa ostaja, pa je reserved ram. tega je hitro cez 6GB... in ko se zapolni useh 12GB v sistemu, se reserved ne zmanjsa, pac pa cel sistem zasteka in se ustavi.
čuhalev ::
Kako priklopiti particijo, ki je znotraj particije.
Torej imam /dev/md-3 (block special file fe,3), ki vsebuje mbr. Če bi bila to datoteka, jo je mogoče priklopiti z loop in offset, kar pa tu ne deluje.
Ideje ... razen tega, da z dd naredim datoteko.
kpartx saved the day ... vendar ali gre še kako drugače?
- spremenil: čuhalev ()
Kaj točno bi rad?
Imel posamezno particijo kot ločen file? Ali dev node?
Mountal jo?
Imel sem podoben problem: mountati particijo iz image fajla.
Če je to to, reci, pa poiščem skripto (ena vrstica v bistvu) ki to naredi. Če me kdo ne prehiti, seveda...
Mountal jo?
čuhalev ::
Želel sem dostopati do particije, ki je znotraj particije. Torej kot ,,dev node."
Torej jaz imam /dev/sda, ki je fizičen disk. Znotraj tega diska imam prvo particijo /dev/sda1, znotraj te particije imam pa še particije. Kar sem želel, bi izgledalo kot
/dev/sda11, /dev/sda12 ...
Sem se spomnil na ... Yo dawg I heard you like partitions, so I put a partitions inside partition. :P
lmorgh ::
Kateri so najboljši driverji in nastavitve za AMD radeon r7 m265 grafično na laptopu? Se mi zdi da ni najbolj tekoče...
Zvezdica27 ::
sistem?
Če ubuntu - iamjo svoje v svojih kernelih, daj gor najnovejši kernel. VSe ostalo, še posebno debian - uporabi smxi skripto (pazi, backup obvezen!).
zz
zz
lmorgh ::
še eno vprašanje...
Laufam 15.10 Kubuntu in bi si rad nastavil eduroam...ko z neta poberem .sh skripto in jo hočem zalaufat, dobim tale error... kaj moram narediti?
~/Downloads$ sh eduroam-linux-UoT-University_of_Trieste_eduroam_profile.sh
eduroam-linux-UoT-University_of_Trieste_eduroam_profile.sh: 7: eduroam-linux-UoT-University_of_Trieste_eduroam_profile.sh: function: not found
eduroam-linux-UoT-University_of_Trieste_eduroam_profile.sh: 32: eduroam-linux-UoT-University_of_Trieste_eduroam_profile.sh: Syntax error: "}" unexpected
isti error je če zalaufam sh od UniLJ
N4m31355 ::
še eno vprašanje...
katero skripto?
do 1 meseca nazaj sem lahko bil povezan z clean installom.. brez skript, brez certifikata
Res pa je da sedaj iz meni neznanega razloga to ni vec mogoce.
poweroff ::
Tole sicer nima veze s tvojim primerom, ampak bo vseeno morda koristno za koga...
Že kakšno leto im Ubuntu spremembo v kernelu, ki ne dovoli povezovanja na WPA strežnike, ki uporabljajo prekratke DH ključe. Ključi morajo biti vsaj 2048-bitni. In zadeve mora porihtati tvoja organizacija, nima veze s teboj.
Kar je lahko včasih problem, namreč treba je restartati cel Eduroam znotraj organizacije.
sudo poweroff
Ojoj, korporacija vsiljuje standarde uporabnikom...
N4m31355 ::
samo resetirati? torej ce "se sistem slucajno resetira sam od sebe) bi to moralo delovati?
je kaksen bypass tega?
Hexx ::
Ima kdo izkušnje z Quadro 1000m grafično?
Kako nastavim driverje da dela dual screen?
So sam problemi z Optimusom
Zvezdica27 ::
optimus - kao bumblebee dobr dela... ne bi vedu, ne kupuješ HW, ki je sporen za linux ;)
zz
zz
Zvezdica27 ::
helou... sicer to nima veze z ubuntu, a za službo si moram naročiti PC, kišto, gor bo linux, najbrž lubuntu.
Kje se sestavlja računala, katera firma?
zz
zz
N4m31355 ::
mindfactory ma prolly najceneje, sestavis sam/kolega/slotech
- spremenilo: N4m31355 ()
lmorgh ::
DuleKrtola ::
Sledeče mi gre že en cajt na jetra in se vleče že iz xubuntu 14.04 do 15.10. Karkoli odprem iz terminala z '&' opcijo, mi še vedno printa v terminal. Npr.
gedit readme.txt & nautilus . & ...A se to tudi na Unityju dogaja, ali je samo neka Gtkjeva glupost? Se da to disableat?
- spremenil: DuleKrtola ()
DuleKrtola ::
evo, super rešitev za tearing, če uporabljate xubuntu
http://duncanlock.net/blog/2013/06/07/h...
Probal in odstranil, ker mi kar neke okvirje okoli menujev riše. Verjetno pokvarjene sence.
DuleKrtola je izjavil:
Sledeče mi gre že en cajt na jetra in se vleče že iz xubuntu 14.04 do 15.10. Karkoli odprem iz terminala z '&' opcijo, mi še vedno printa v terminal. Npr.gedit readme.txt &A se to tudi na Unityju dogaja, ali je samo neka Gtkjeva glupost? Se da to disableat?
nautilus . &
To je vedno tako delalo.
WizmoTo ::
Če te motijo izpisi, jih lahko kam preusmeriš, recimo v /dev/null:
gedit readme.txt > /dev/null 2>&1 &
! | [(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Operacijski sistemi | 318191 (1570) | polozweii |
» | [UBUNTU SERVER 10.04] Grub se ne postaviOddelek: Operacijski sistemi | 8901 (8113) | Icematxyz |
» | Ubuntu 10.10 - 10 Out Of 10 (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Operacijski sistemi | 160348 (117941) | Icematxyz |
» | [UBUNTU 10.04] GRUB se ne postaviOddelek: Operacijski sistemi | 5367 (5151) | matijaz74 |
» | Ubuntu 10.04 LTS - Change is coming (strani: 1 2 3 4 … 17 18 19 20 )Oddelek: Operacijski sistemi | 134812 (97698) | Icematxyz |
