Forum » Loža » Delo vlade - PV Janez Janša
Levica ::
Bravo Tanja. Tanja že skoraj 1 mesec nazaj napovedala kaj bo... sedaj je eskaliralo.
Fejk. Daj link.
https://twitter.com/tfajon/status/14507...
.@FedericaMog
in a video msg: “We, the @TheProgressives
, have a big responsibility when it comes to #migration. We also have to tell our people in #Europe that migration can be managed. We’re a party of ‘Yes, we care’, but also ‘Yes, we can’.” #EuropeTogether
https://twitter.com/tfajon/status/98447...
We can’t afford to fail. Listening to @YlvaJohansson
on new proposal on #EU migration and asylum policy. It’s extremely difficult, we all know. But without an agreement the countries of first entry will suffer most. It’s not fair. Can we find mandatory mechanism? @TheProgressives
https://twitter.com/tfajon/status/12729...
Migration is historic, is global question. For centuries & always a positive experience for countries of final destination @SJLambrinidis
https://twitter.com/tfajon/status/81078...
.@FedericaMog
Only we can say it loud & proudly 'We welcome ppl knocking on #Europe's door!' @TheProgressives
#EUmigration #EuropeTogether
https://mobile.twitter.com/tfajon/statu...
Tanja Fajon je borka zato jo podpiram.
- spremenilo: Levica ()
kotanyi ::
@Levica: Sej vse lepo pa prav, troll being fun and all, ampak daj vseeno en malček več efforta v tole. Al pa pejt na kak siol boomerje strašit.
- spremenilo: kotanyi ()
Levica ::
Matr, če fajonka razmišlja vsaj 10 procentno tako, kot tukajšnji trol, se je treba tudi nje izogniti kot hudič križa.
Ni se tako simpl čelavega znebiti. Alternative preprosto ni.
OK, vse je boljše, ampak še vedno preveč slabo.
LightBit ::
widj3098dj32 je izjavil:
Fejk. Daj link.
HAHAHAH OMG
Tip je šel dejansko ponaredit.
Kako janšistično. Bravo LightBit za razkritje.
Oboje je isti drek, nafukala bo pa navadna raja, ne te svinje iz Bruslja.
Morda.
Še vedno je dezinformacija, ki jih kar mrgoli.
ADIJOOO1 ::
Tanja Fajon je iz stranke vrgla Emil Rojca, ker se je zavzemal za zaščiteno mejo in tam ni pustil migrantskega centra.
Ampak ja Emil Rojc nima pojma kaj so migracije Tanja Fajon ve kako je živeti ob meji saj je večino časa v Bruslju.
kotanyi ::
Ne, naš trol hoče pokazat kako VernikiČelavegaTM razmišljajo da Fajonova razmišlja.
Tudi to je nekaj kar bi si SDSovci blazno želeli da bi ovce verjele.
Ampak treba se je predvsem vprašat kaj sledi če se čelavega ne znebimo? Še 4 leta sedanjega nesposobnega naegotripanega pofla? Ne ga no srat.
Voss ::
TheBlueOne je izjavil:
Dobro so zavedli pokvarjenca Vizjaka. Je mislil, da obstaja samo prvi posnetek. Najprej zlepljenka, pa smetarski lobij, potem je delal v dobro države, kako se bo zdaj vlekel ven, ko je v javnost prišel uro dolg pogovor o glupih davkih?
https://www.24ur.com/novice/slovenija/v...
Kje je Tonin? Počivalšek? Podpirata sebi enake.
Kako se bo zvlekel ven? Rekel bo, da folk ne razume pogovorov na tem nivoju, da ne bo odstopil in da je njegova vest čista… 20% volivcev bo zadovoljnih in se bo spraševalo, kak to nekaterim ni dost, ostali pa bomo še naprej apatično čakali, da dobimo volilni listek v roke
Niti tega ne bo. Za SDS vernike bo vec kot dovolj kaj v stilu "Kaj se ne bi raje pogovarjali o tem zakaj ravno sedaj?" ali pa "Kaj se ne bi raje pogovarjali o tem zakaj ni takoj bil podan celoten video?". Se je tezko pametno lagati, ce mediji ne povedo vsega kar imajo na zalogi. Potem je treba lazi prilagajati, kar pa je v pravni drzavi za SDSovce v primeru, ki je proti SDS bolj nesprejemljivo, kot ce njihovi kradejo. Verjetno, ker slednje ze dolgo vedo ampak "Kaj ne bi raje o tem kaj pocne Zoki?". Ceprav Zoki ni sef vlade je treba najprej obdelati njega, potem Kucana, potem vse kar je levega v tujini. Potem pa morda lahko recemo kaksno o SDSu, ce do takrat ne bo imel pod sabo medijev in policije. Potem bo to pac ilegalno in vse kar delal SDS legalno. Bo povedala Nova24, da bi bilo boljse govoriti o....
Si kar zadel:
"Namen objavljanja "lepljenk" po segmentih je, da se zgodba ohranja pri življenju in se diskreditira ministra," je zapisal. Trdi, da mu ni mogoče očitati nobene nezakonitosti."
solatko ::
feryz - Slabše od Jajota ne more bit, v prvi vladi je naredil za 24miljard€ minusa, pri debelih kravah, dve vladi sta spravljali bilanco v okvir, tretja je imela lagodno vladanje, zdar pa spet 3 vlade fajn garanja in stiskanja, da bo spet red.
Delo krepa človeka
kotanyi ::
24? Minus je že bil, tudi majhen ne, ampak pretiravat vseeno ni treba. Ocene bančne luknje so bile okoli 5 miljard, če čez palec prištejemo še par drugih propadlih projektov pa dodamo še priložnostne proračunske kraje, še vedno ne pridemo niti blizu tvoji cifri. Obenem imata tudi LDS in SD svoj (še zdaleč ne majhen) delež krivde za takratno stanje.
Če Jajotovi lažejo, ni treba da si tudi ti isti.
solatko ::
kotanyi - Možakar je v štirih letih, za toliko dvignil zadolženost države, z izgovorom, da se v času deblih krav, splača zadolževati, ne govorim o bančni luknji. Šlo je baje za doseganje pogojev ob uvedbi €, kdo bi vedu, morda je celo res.
Ta denar je verjetno romal v davčne oaze, kjer je po milih ocenah okoli 50+miljard našega denarja. Seveda se transferjev na NBS po navodilih ECB-ja ne sme preverjat. Preiskovalna komisija je imela kar nekaj težav, ko je od NBS zahtevala podatke in jih seveda ni dobila.
Delo krepa človeka
spegli - Bi bilo bolje, če bi šli vsi skupaj igrat golf.
Tvoj Jankovič je za obvezno cepljenje, je blo zaj na RTV .
Vlada je prepovedala slavja, veselje in ples. Ni hec, resno:
https://www.rtvslo.si/gospodarstvo/zajc...
Hej, kaj ni to ravno premiza filma Footloose (iz leta 1984!!) , ki govori o mestu, kjer je pesem in tesno druženje PREPOVEDANO.
- spremenil: Miki N ()
GregiB ::
Torej? Kaj bomo rekli?
If you think there's a solution, you're part of the problem! - George Carlin
LightBit ::
"Tisti, ki je brez greha, naj prvi vrže kamen"
Kaj težiš saj se je spovedal, bog mu je že vse odpustil.
SDS pa v anketah lepo pada, počasi in sigurno. Tole z Vizjakom je treba vsake tolk pogrevat, pa bo.
Ja lah da mu bog odpusto, to res ni problem, ........................
......................sam volilci mu ne bojo.
Gremo stavit, da razumejo kaj on flanca na tko visokem nivoju...
- spremenilo: Telbanc ()
Unilseptij ::
Še vedno je tudi vprašanje, kje je žakelj denarja, ki ga je nekdo nekje prejel... saj ne verjamete, da so se pogovarjali samo zaradi dobrobiti države, hehe.
Unilseptij je izjavil:
Morda bo Nasledni posnetek to razkril. Menda ne mislite, da je sam en posnetek?
spegli ::
Kje so časi ko si zarad sendviča odstopil ? Barabe. Tožilstvo pa kwa dela od doma ?
- spremenilo: spegli ()
A ni en odstpu, k je bleknu, da se penziči nimajo kej bat, razen Matilde.....
cvalsr ::
Pravkar videl v odmevih:
Neka 'živina' z ministrstva (za izobraževanje ?) je razlagal Staričevi Tanji, da vlada ni naredila prav nič za boljše prezračevanje v šolah zato, ker je naravno zračenje še vedno najboljše. (Moja pripomba - zlasti pozimi; otroci se bodo prehladili ter ostali doma in evo - problem rešen.) Sicer pa so nekatere šole dobile
"ONO, KAKO SE REČE, ZA INFRARDEČE PREZRAČEVANJE"
Bebec je najbrž mislil naprave za razkuževanje z ultravijolično svetlobo?
In taka nesposobna govna redimo na visokih položajih na ministrstvih ...
solatko ::
Telbanc - Ni moj in ne sledim slepo ljudem, ki jim dam priznanje za to, kar v svojem mandatu naredijo. Če bi dokazali vsaj eno od afer in ga zaprli, bi mu vsake toliko poslal kakšno škatlo cigaret, nebi pa šel na Dob stat, kot so to počeli za največjega slovenskega kriminalca nove dobe. V A posrednik sedi, pri nas pa hrvati držijo jajota za jajca, ker imajo podatke o švercu in prodaji orožja in morda še kaj pa ga vseeno podpira kar precej svečk. No manj, ker mu je najzvestejše odnesel covid. Nekaj jih bo omagalo zaradi Vizjaka, ki ravno tako veliko ve o njegovih rabotah, tako, da upam, da na volitvah pade nekam tjs, kjer jesedaj NSi, sploh, če se vrne Luda Mila, namesto mlečnezobca.
GregiB - Čakajo, da najprej ata Smrk pove svoje, ampak se ne upa, stara bataba partijska preveč ve o njem pa še precej pametnejši je od njega. Tako, da za enkrat status quo.
LightBit - Odpustila mu je cerkev, z bogom se bo moral še zment, če bo sploh prišel po njega, si gledal film DUH.
Unilseptij - V davčnih odazah, tam, kjer je ves mafiski denar. Zato pa fuckoff wax.
spegli - Držijo razdaljo 1,5m.
Delo krepa človeka
spegli ::
To državo je treba ukinit. Nima smisla. Prključmo se najhujšim napadalcem. Banda.
Pošljite vse 4 pilatuse in une tanke ko je nabavil tonin naenkrat nekam.
solatko ::
spegli - Tej greznici le redki rečemo država, to je peskovnik v obliki kure, v katerem se s kanglicami in lopatkami igrajo naši izbranci, ob tem pa delajo nepopravljivo škodo. Mandarič je pri Olimpiji vsaj svoj denar zapravljal, te cigani pa našega.
Delo krepa človeka
Renima_Bar ::
Ja, dokaj žalostno.
Ob vsem tem 10-dnevnem ognjemetu in stalnem rezgetanju o novih "pravicah in svoboššinah" smo prišli na to, da boti v tej in podobnih temah prožijo "debate" in lovijo obiskovalce, da se postavijo na eno ali drugo "stran".
Živela "demokracija".
V bistvu bi mroali spremenit zakon o zastavi.
Kdor na državni praznik izobesi manj kot 5 zastav, je izdajalec.
Ali kaj v tem stilu.
Ko smo že pri tem, mogoče bi bil čas za glasovanje o novi zastavi ?
- spremenilo: Renima_Bar ()
GregiB ::
Se samo meni zdi, ali smo potem, ko se je NSi na nekaterih medijih že povolilno odpisovali v zadnjih 2 mesecih priča kar opazni migraciji SDSovcev k Toninčkovim?
no comment ::
Nov način kako kako kanalizirat davkoplačevalski denar k prijateljčkom.
Prijateljček toži državo, država se ne sodišču ne brani, prijateljček dobi denar. Simpl ko... gulyás!
Država se ne more braniti na sodišču. Ker nima gobca za gobezdanje in rok za pisanje.
Torej je treba najti odgovorno osebo in jo iztožiti za ukradeni denar.
Prej začnemo, prej bo mir. Prej je, seveda, nikoli.
Hypathia ::
Skela bo odletela, ker je pozivala na množične proteste na vrhuncu epidemije. https://siol.net/novice/slovenija/strok...
Začuda je to za naše "neodvisne" novinarje na poptv in rtv, ne-novica.
6bt9hmDwY ::
Siol ima neke zyebane komentarje, vsi (tudi replike) so oddani isto minuto kot post, čeprav zagotovo niso mogli biti napisani isto minuto glede na zaporedje bockanj. Who cares...
Kaj pa je s tabo!?
Protest je osnovna človekova pravica.
Zaprita jo v zapor, ti in tvoja plešasta opica. Tako se dela v demokraciji.
Epidemije nimamo, btw. Že dolgo ne. Ampak to je že preveč za vaš nivo pismenosti.
Da se je sedaj tudi Petan spomnil pogovora in se obrnil proti Vizjaku.
Petan: "Posnetek je avtentičen in sam po sebi dovolj zgovoren."
Koruptivnež Vizjak še kar ne vidi razloga za odstop, vladne stranke imajo državljane še naprej za navadne bedake. Nekje bo počilo.
ripmork ::
Šokantno, pa tak nedolžno izgleda ...
/s
In other news, Tonin je končno dobil dovoljenje iz višje inštance, da spregovori in se odreče podpori Vizjaku.
#AvtentičnaZlepljenka
/s
Po mojem Vizo še ne ve, da bo žrtveno prase. Roštilj se že pripravlja a ta še sprašuje "o za koga?".
Sure
https://www.gov.si/novice/z-danasnjim-d...
Kayzon ::
"Zaračunavanje dodatnih stroškov ob hitrem testiranju je nezakonito
Z ministrstva za zdravje sporočajo, da je zaračunavanje kakršnih koli dodatnih stroškov ob opravljanju hitrega testa nezakonito. Med njimi naštevajo zaračunavanje administrativnih stroškov, stroškov izdajanja QR-kode ali izpisa potrdila."
Torej kaj je zdej,dva meseca smo pa morali placati hitre teste komu na cast? Za nekaj kar smo kupili s davkoplacevalskim denarjem. Banana slovenija od drzave,sramota res.
Trupl0 ::
ko berem tole se mi zdi, da bi ti moral še enkrat ali dvakrat prebrat napisano...
dodatni stroški....ne strošek testiranja...
Torej ti plačaš test se testiraš oni te pa upalijo še izdaja testa, tisk enostransko, poraba kartuše črna XY1213 ter malica.
If you are going through Hell, keep going !
Kayzon ::
PCT testi so sedaj zastonj,danes sem se testiral ,vendar bi morali biti zastonj od samega zacetka. Isto dokler ne zacnejo testirati cepljenih,PCT nima nobenega smisla. Ta vlada in stroka je res idiotska.
Voss ::
/s
Ni pa povedal, kako bo NSi glasoval na interpelaciji. Ker v veliki verjetnosti, Vizjak sam od sebe pač ne bo odstopil, Janša pa tudi dvomim, da ga bo razrešil.
Tam se bo NSi zadržal, ne pa tudi dal glasove ZA razrešitev Vizjaka.
Trupl0 ::
še enkrat preberi kaj si napisal...
V akciji je spet Snežić, stari Jajov cimer iz zapora
https://www.rtvslo.si/slovenija/drustvo...
Primer še enega, ki drugim očita, kar sam dela?
Da je policija ena izmed največjih skorumpiranih greznic pri nas, očitno samo še novinarji ne vejo.
Ali pa se zgolj delamo norca sami iz sebe.
Za FURS-ove spiske nedotakljivih pa tudi mora vedeti vsak.
- spremenil: feryz ()
VaeVictis ::
Mogoče pa točno ve, kaj delajo, ker jim je on ali kak njegov kolega pomagal to izvajati?
Nič čudnega ne bi bilo, da bi novinarski aktivisti proti utaji davkov na necenzurirano.si, sami utajevali davke!
DNS je pa v posmeh svojemu imenu in se običajno oglašajo samo, ko je kak levaški novinar "napaden".
Let's Go Brandon!
Slo-tech.com je postal greznica in izguba časa!
Adijo!
Adijo!
