Steam - Nakup iger
Steam - Nakup iger
47 / 247
BALAST ::
Scammer, ki je na koncu priznal, da so ljudje tako neumni da mu nasedejo. :O
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
Če pri COD MW3 nekoga prijaviš,da heka ali grdo govori kako to steam ukrepa?Se pravi mu zablokira,on line igranje ali cel račun?
Bor H ::
Online igranje, VAC ban dobi. Kar se pol če se ne motim vidi tudi v njegovem profilu.
Se pravi prepoved za to igro.
Hvala za odgovor,
kmetek ::
  • spremenil: kmetek ()
PARTyZAN ::
Sem nabavil Darkspore. Upam, da ga bom imel čas igrat :D
kmetek ::
pa gre potem na steam ali je origin? :D
ahac ::
Če je Origin, je Origin...
PNG ::
Ni nujno. Vsaj za 5 iger vem, da en key kupiš in jih je moč registrirati pri obeh.
ahac ::
Katerih 5? 8-O
  • spremenil: ahac ()
def0r ::
oo7 je izjavil:
Nikamor ne mores prijavit VAC ban ce bo, bo avtomatsko :)
PNG ::
ahac je izjavil:
Katerih 5? 8-O
Battlefield 2 collection
- Battlefield Bad Company 2
- Burnout Paradise
- Command & Conquer 4
- Command & Conquer: Red Alert 3
- Crysis 2 (view cdkey in registry)
- Dead Space (view cdkey in registry or Hidden)
- Dead Space 2
- Dragon Age Ultimate Edition
- Gatling Gears (It give the US version in any case.)
- Mass Effect 2
- Medal of Honor (2010)
- NFS Undercover (view cdkey in registry)
- NFS Hot Pursuit
- NFS Shift (view cdkey in registry)
- Shank (REGION RESTRICTED)
- The Sims 3
- The Sims 3 World Adventures
- The Sims 3 Ambitions
- The Sims 3 Late Night
- The Sims 3 High-End Loft Stuff
- The Sims 3 Fast Lane Stuff
- The Sims 3 Outdoor Living Stuff
- The Sims 3 Generations
- Crysis (ask EA support for activating)
- Crysis Warhead (activate from here: https://activate.ea.com/gameactivation....
- Command & Conquer 3 Kane's Wrath (ask EA support for activating)
- Command & Conquer 3 Tiberium Wars (ask EA support for activating)
Drugače ni tako težko tega zgooglati. Cca ~ 10 sekund dela porabiš pa ne rabiš dezinformacij širiti.
Crysis 2 ne dela. Mam key in sem ga hotel registrirat na steamu,pa ne dela.
Bor H ::
Ampak to je kontra, EA špili grejo iz Steama na Origin. Trenutno pa se na Originu (kot vem) ne prodaja nič kar bi se registriralo na Steamu.
ahac ::
Dr_M je izjavil:
Seveda ne dela. i100k100 širi dezinformacije. ;)
Origin sprejme cdkeye določenih EAjevih iger, ki so bile kupljene na Steamu ali drugje.
Obratno pa ne gre, kar pomeni, da ne moreš kupit igre na Originu in je aktivirat na Steamu.
Tuki je en seznam, kaj Steam sprejme.
https://support.steampowered.com/kb_art...
PNG ::
ahac je izjavil:
Dr_M je izjavil:
Preberi si moj post, prosim, hvala.
  • spremenil: PNG ()
ahac ::
Ti tudi preberi svoj post in še kakšnega pred njim. Vse se namreč nanaša na vprašanje, če je možno igre kupljene na Originu aktivirat na Steamu.
ahac ::
Btw, tole mislm, da še ni bilo postano: http://ww1.cheapshark.com/
Pesimist ::
Prvo kot prvo kdaj bo steam summer sell?
  • spremenilo: Pesimist ()
pijavka ::
TechBeats ::
ahac je izjavil:
Oz Retail igre ki so novejše od 2008?..
Jaz sem hotel aktivrat MassEffect1 , NFS Carbon in še ene par malo starejših na Origin in ne gre, potem sem pa videl ta beden limit z letnico izdaje.
In meni isto ne zazna Crysis2 na steam, imam pa retail "lite" verzijo.. Sicer nisem probal na Orgin, in tudi nimam potrebe, Orgin je itak en fail. >:D
AciD TriP
Bor H ::
Normalno da Steam ne bo zaznal Crysis 2, sej je bil prej link dan...
Steam seal se pa začne baje zadnji četrtek v juniju. Torej okvirno čez kak teden do dva. Dva načina kako lahko zvemo predčasno za termin: če bo kak indie razvijalec se zagovoril in objavil "naš špil -50% od 30.6 do 10.7" (se redno dogaja), lahko pa spremljaš http://marlamin.com/cdr/view.php?type=s... sigurno bo pred začetkom razprodaje kup novih packov se pojavu ;)
Jakob_X ::
Commandos 3 so zastonj zacasno na greenmangaming.com.
Trupl0 ::
hvala za tole dec :)
If you are going through Hell, keep going !
RejZoR ::
Vidim, da ni še nihče omenil, ALL DEUS EX GAMES -75%:
http://store.steampowered.com/sub/15147/
Slabih 14 EUR za 3 fenomenalne špile!
Bor H ::
Kar je celih 91 centov prihranka v primerjavi z nakupom vsakega špila posebej!
def0r ::
RejZoR je izjavil:
2 fenomenalna spila :) Deus Ex 2 je obupen da ne more biti bolj :p
kmetek ::
Bor H je izjavil:
pol kavice!
RejZoR ::
Tud Deus Ex 2 ni tko zanič. Je sicer slabši ampak ima svoje momente
kmetek ::
deus 1+2 kupljen s svetlobno hitrostjo.
Ce kdo rabi kodo za 4% za g2play.net, naj mi pise na ZS.
Vem, da ni veliko, ampak nekaj pa je. :) Dobil za RD, ampak nevem za kaj pa ponucal, se mi pa skoda zdi, da bi slo v nic.
Kupon oddan :)
  • spremenil: Dr_M ()
mr1two ::
Evo kupil DX:missing link. Za 2.5eur, pismo, itak da kupim :D
RejZoR ::
Jezst sem ga za več pa mi ni žal.
Bor H ::
a sm ful cheap če mam občutek da bo med poletnimi razprodajami še cenej?
Jakob_X ::
Si ja :). Je ze zdej 75%. Ne bo nic manj.
Pesimist ::
mnja mene tudi mika da bi armo 2 za 25€ vzel, samo imam obcutek da bo med summer sellom za 15€. Zaj pa nevem ce mi je 10€ vredno da dobim cca 10 dni prej. Sploh pa nevem ali bom zraven zivce zgublal ko bom DayZ spilal ko me bo en fstrelo pri punem packu. Ze zdaj pri fifi 12 ko me AI premaga ragam pune, da sem ze en kontroler zlamo. lolz.
btw. Max Payne 3 prodajajo po 20$ v Cdkey shopih.
Bor H ::
Arma 2 je že bila (Combined Operations) na 12.5€, samo Arma 2 pa tudi ceneje. Pomoje počakej.
20$ je verjetno RU key ki ne gre na Steam?
Pesimist ::
Ne niso steam keyi. Oz zaj sem celo najso po 12€. To so cisto elgitni shopi ce kopujem vse moje keye tu. Pa nic ne psie da je ruski. http://www.gamekeyfinder.de/games/Max_P...
Arma 2 combinet operationr ravno rabim ja. Sranje bo potem ko nebo na steam sellu pa bom zastojn cako hahaha.
Pesimist ::
Pa ko je ta steam sell. Kaj moram cakati na tocno tisti dan ko majo armo znizano ali je znizano ze od zacetka prodaje?
Jakob_X ::
Cakas da je daily deal. Od zacetka je vse znizano ampak ko je daily deal je se bolj znizano. Ce se slucajno ne pojavi daily deal pa pac zadnji dan kupis.
Pesimist ::
mah sem kr zaj kupo se mi neda cakat. Boli me k pa se fifa me je spet razpizdla tak da...
kmetek ::
ti tale gamekeyfinder so zanesljivi?
lopov ::
Nabavil sem DX:HR + oba DLC.
Igro mam naloženo pa nikjer ne najdem nič o DLC; kako preverim, da sta nameščena?
Odigral sem kakšnih 10 minut, tko da sem res še zelo na začetku :)
Ah ... Sem že "našel" ;((
  • spremenil: lopov ()
kmetek ::
tam pri igri v steamu desni klik.
RejZoR ::
Če kdo ni opazil, pod Midweek Madness imajo LA Noire za -75%, danes pa je AvP z -80% popustom. Ceneje od tega ne bo, tko da kdor rabi naj navali.
PNG ::
ahac je izjavil:
Imaš prav, se opravičujem, sem prav obratno prebral. Oprosti za na pol žaljive post, sem jaz bedak :)
Bor H ::
Mogoče bodo vsaj na $=€ padl...zdj je oboje v eurih tudi numerično več, kaj šele po vrednosti.
bajsibajsi ::
Bor H je izjavil:
Saj je tema na Steam forumu o tem; dolga preko 1000 odgovorov. OP teme pa benan.
Bor H ::
Na Steam forumih radi banajo folk, zakaj mislš da ne sodelujem več ;)
47 / 247
