Steam - Nakup iger
Steam - Nakup iger
208 / 246
BorutK-73 ::
L1nK je izjavil:
eden naj humble bundlov v zgodovini, 18:
https://www.humblebundle.com/humble-ind...
Ne vem kaj je tako "naj" v tem bundlu.
L1nK ::
potem pa svetujem, da se izobraziš in boš vedel
https://www.facebook.com/link.zhizhekian
L1nK je izjavil:
In kako se za takšno oceno 'izobraziš'? 8-)
Ena od teh "tahudih" iger je ziher Goat Simulator :))
Za ostale pa nevem.
Jerry000 ::
Meeeeh :)
L1nK ::
šit v kako obscenih časih živimo, da je 'ne vem' postal argument. model še dodatno sprašuje, kje naj se izobrazi o kakovosti specifičnih iger. bravo
  • spremenil: L1nK ()
Kakšne argumente, razen nabijanja in pametovanja pa si ti podal?
dr.Akula ::
Starpoint Gemini 2 zastonj na voljo za 2 dni. Kliknite download in se vam doda v vaš library.
ni podatka
ales85 ::
Hvala za info, kar tako naprej :)
BorutK-73 ::
dr.Akula je izjavil:
pa še dlc je zraven free:
http://store.steampowered.com/app/37106...
Jerry000 ::
Imam problem z steamom. Po dooolgem casu imam zeljo prodat karte, nalozim si app, karte dodam v prodajo, tam se v appu confirmam, nastavim authenticator nakar vidim da imam stvari na holdu...in steam hoce da cakam 15 dni da bojo itemi sli naprej v prodajo...pa kaj so fukjeni? Autentikator/steam guard sem nastavil, zakaj moram zdaj 15 dni cakat da mi boge karte.da na market? Kako se resim tega?
VelkBla ::
Jerry000 je izjavil:
Ce prav zastopim, si si sele prvic nalozil steam authenticator?
https://support.steampowered.com/kb_art... ; Why are my items on hold?
Any trades or Market listings created before a Mobile Authenticator is added, or during the first 7 days after it is added, will be held for 15 days. Trades or Market listings created more than 7 days after a Mobile Authenticator is added will not be held by Steam. Adding a Mobile Authenticator will not reduce the length of existing item holds.
In potem se nadaljuje v: How does it work?
If you haven't had your account protected by a Mobile Authenticator for at least the last 7 days, items leaving your account will be held by Steam for up to 15 days.
Moral bos pocakati 15 dni, po 15 dnevih pa ne bos imel vec te omejitve.
  • spremenilo: VelkBla ()
Jerry000 ::
Sej to...dear god zakaj to steam dela. Tok varuje da ze skoduje. Jaz hocem zdaj prodat karte, autentikator imam ker spet tezijo, a potem moram se.cakat 15 (!!!!) dni...nazadnje mi bodo se sporocili da rabim kri device in zrtvovat ovco da bom lahko boge karte prodal
Alamar ::
Tu si naredil napako, ker si dodal karte v prodajo preden si imel sedem dni nameščen authenticator. Sedaj moraš čakati 15 dni, da bo prodaja odobrena. Tako, da če hočeš tole skrajšati na sedem dni, zbriši karte iz prodaje in počakaj sedem dni. Po tem obdobju, gredo karte lahko instantno v prodajo.
OK.d ::
Ali mogoče kdo ve ali obstaja Forza Horizon 3 za PC na cd-ju?
LPOK.d
Seljak ::
Kolikor vem ne.
Tezaab ::
Stellaris je na voljo za 12$ ob narocnini na mesecni humblebundle (pise, da ponudba velja do 2.6.), dobis Steam key.
Na Steamu je spil (zaenkrat) 39,99€.
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
kitl76 ::
Zakaj so igre na steam-u skoraj 100% dražje kot drugje?
Verjetno ker je steam, main platforma. Kupiš drugje in aktiviraš na Steamu. Problem rešen.
sentiš ::
Sej na pirate bayu so igrice zastonj.
Jah če si dijak/študent, potem res, sam ne vse. Če pa hočeš dat kaj za avtorje pa pač poiščeš najnižjo ceno.
Truga ::
kitl76 je izjavil:
Ce primerjas igro ki je znizana z redno ceno na steamu je 100% drazje ja.
Pol je pa steam sale, pa je 80% znizan, in kupis takrat. Na steamu se ne kupuje po rednih cenah.
Seljak ::
sentiš je izjavil:
Morda res, ampak se bova od 100 iger lahko igrala online samo z dvema naslovoma ;) Če želiš zares izkoristiti igro in igrati online (kar je večini prioriteta) potem boš moral kupiti original. Potem pa je tukaj še posodabljanje iger, tehnična pomoč,.... pa konec koncev z piratom tvegaš tudi okuženost in ker se otepaš originalov je pričakovati,da imaš morda nameščen tudi piratski AV ali pa ga sploh nimaš. Potem pa tukaj jokate kako imate 100 problemov.
Jerry000 ::
Poleg tega pa steam sale ima smesne cene da se se piratizirat ne splaca. Jaz ze kakih 4 let nisem nobene igre piratiziral ravno zaradi steama in raznih bundlov. Res pa je da jih vec kupim kot preigram :)
Trenutno je Witcher 3 močno znižan.
sentiš ::
Če je igra na GOGu in je single player jo osebno vedno raje piratiziram in sprobam, ker se prevečkrat zgodi, da odigram pol ure ali urco in nikoli več ne dokončam. Če mi je igra všeč ali če je early access in bi rada pomagala razvijalcem igre, potem gledam, da jo kupim.
Mogoče je res hinavsko, da ravno DRM-free igre piratiziram, ker so tako lahko za naštimat, samo download&play. Če so igre pod neko zaščito in loginom ali always-online, ki zakomplicirajo zadeve, pa ponavadi se raje ne ukvarjam z njimi.
ales85 ::
@sentiš saj veš, da lahko pri večini online distributerjev igro preizkušaš 2 uri in nato zahtevaš vračilo kupnine?
sentiš ::
Meni je kolega rekel, da če pri Steamu to narediš, da ti potem nekaj zaklenijo račun ali kako...
Mislim, da je tema namenjena Steamu ter ugodnostim na temu in ne debati ali je boljši Steam ali kaj drugega.
Tako Steam kot PirateBay imata vsak svoje prednosti in pomanjkljivosti. Vsak od nas se sam odloča kdaj bo posegel po eni ali drugi rešitvi.
matic492 ::
sentiš je izjavil:
Meni so zatežili, ko sem kupil na predlanskem summer salu ene 10 iger, pa potem za 3 zahteval refund.
So mi napisali nekaj v tem smislu da to ni za testiranje iger, da naj prej pogledam kaj kupujem in da mi ne bojo več refundali če bom spet to delal.
EDIT: evo našel mail:
You've requested a bunch of refunds recently. If you're unsure about a product, make sure to check out the customer reviews before purchasing.
Okej, zgleda sem imel v spominu malo hžujše kot so zares napisali :D
  • spremenilo: matic492 ()
Seljak ::
ales85 je izjavil:
Res je in sploh ni več izgovorov, da bi moral piratizirati! Če se skupina ljudi trudi in ustvari nek izdelek, ki je všečen po tem je tudi prav, da se jih nagradi z plačilom.
sentiš ::
zakaj ne delajo več demotov?
next3steps ::
Zato, ker bi si morda premislil, ko bi zagnal demo.
BorutK-73 ::
Nisi edini.:P
dottor ::
BorutK-73 je izjavil:
Nisi edini.:P
Same here.
Xeon X5650@3.8GHz |Asus P6T|
2x4GB+4x2GB|ASUS R9 280X@1100MHz|
WD Green 240GB SSD + 4x1TB Hitachi
Jerry000 ::
sentiš je izjavil:
To jaz ze skos pravim...pogresam cajte demotov kjer si igro sprobal al pa nazigal demo ce ti je blo veselje :). Pa casi ko so bli dodatki res dodatki
Seljak ::
dottor je izjavil:
Nisi edini.:P
Same here.
Enako :D
branc ::
Seljak je izjavil:
dottor je izjavil:
Nisi edini.:P
Same here.
Enako :D
+1 :)
ales85 ::
branc je izjavil:
Seljak je izjavil:
dottor je izjavil:
Nisi edini.:P
Same here.
Enako :D
+1 :)
Če se že gremo tole igro... Bundle stars je prekletstvo :)
grašek ::
Kaj mislite kupiti na Summer sale?
Jas trenutno gledam Fallout 4, GTA 5 in Cities Skylines. Mogoče še Euro Truck Simulator 2.
Nisem pa ziher, če bom imel čas za igre.
Sssaga ::
Sam bi takoj podpisal za demo različice. Sem namreč na ADSL liniji.
Seljak ::
Slaba linija je lahko zares moteč faktor, sploh dan danes, ko so igre zares velike, ampak vedi, da so tudi demoti dosti večji kot pa včasih ;) Te pa razumem, ker sem tudi sam imel včasih preklemano slab internet.
dottor ::
grašek je izjavil:
Nič kot vsako leto. Mi to uspe? Ne. :))
Jerry000 ::
Jaz bom karte prodal in nabavil kaj z tem denarjem :)
BorutK-73 ::
ales85 je izjavil:
In Humble Bundle. Od 300+ iger na steamu sem jih kupil prav na steamu mogoče 10%.
Tezaab ::
grašek je izjavil:
Ciljam na dodatke za Stellaris. Karkoli mi bo pac uspelo dobiti od tega.
treker ::
No, jaz teh težav nimam, ker Steam-a ne uporabljam. :D
Sem si pa zdaj v poletni razprodaji privoščil nekaj iger na GOG.
Jerry000 ::
opeter je izjavil:
Ne uporabljaš steama? Kakšen gamer pa si :o (Malizia reklama nostalgija)?
Kako to da se ne uporabljaš Steama?
111111111111 ::
Patis?
208 / 246
