Forum » Kaj kupiti » Pomnilnik za DFI in AMD
Suli ::
Mene pa zanima kateri pomnilnik od spodaj naštetih je najbolj primeren za:
<b>DFI LANPARTY UT nF4 Ultra-D</b>
in
AMD Athlon 64
3000+ 0.09µ podnožje-939 z ventilatorjem, 1.80GHz, 512kB predpomnilnika (ADA3000BIBOX):
<b>Platinum Series</b>
- OCZ EL DDR PC-3200 Platinum
- OCZ EL DDR PC-3200 Platinum Revision 2
- OCZ EL DDR PC-3700 Platinum
- OCZ EL DDR PC-4200 Platinum
- OCZ EL DDR PC-3200 Dual Channel Platinum
- OCZ EL DDR PC-3200 Dual Channel Platinum Rev 2
- OCZ EL DDR PC-3700 Dual Channel Platinum
- OCZ EL DDR PC-4200 Dual Channel Platinum
<b>Gold Series</b>
- OCZ EL DDR PC-3200 Gold VX
- OCZ EL DDR PC-3200 Dual Channel Gold VX
- OCZ EL DDR PC-3700 Gold Revision 3
- OCZ EL DDR PC-4000 Gold
- OCZ EL DDR PC-4000 Gold Revision 2
- OCZ EL DDR PC-3700 Dual Channel Gold Rev 3
- OCZ EL DDR PC-4000 Dual Channel Gold
- OCZ EL DDR PC-4000 Dual Channel Gold Rev 2
- OCZ EL DDR PC-4400 Dual Channel Gold
<b>Performance Series</b>
- OCZ DDR PC-2700 Rev 3.2
- OCZ DDR PC-3200 Rev 3
- OCZ DDR PC-3200 1GB Module
- OCZ DDR PC-3500
- OCZ DDR PC-4200
- OCZ DDR PC-3200 Rev 3 Dual Channel
- OCZ DDR PC-3200 2GB Dual Channel
- OCZ DDR PC-3500 Dual Channel
- OCZ DDR PC-4200 Dual Channel
- OCZ DDR PC-4400 Dual Channel
- OCZ EL DDR PC-3200 ECC Registered
- OCZ EL DDR PC-3500
- OCZ EL DDR PC-2700 Dual Channel
- OCZ PC-3200 ECC Registered Dual Channel DDR
- OCZ EL DDR PC-3500 Dual Channel
Hvala
in
AMD Athlon 64
<b>Gold Series</b>
- OCZ DDR PC-3500
- OCZ DDR PC-4200
Hvala
timj010 ::
Yup OCZ EL Platinium rev.2, se jih še naročo grejo komot do ddr500 pa z malo truda tudi do ddr600
AMD 3500+; OCZ platinium rev. 2;
OCZ powerstream 520w; DFI lanparty sli-d;
6600GT
6600GT
Suli ::
offtopic:
MEDENA oprosti, ker se pred nakupom pozanimam, kaj je najbolše za matično ploščo. Nekateri pač nimamo namena plačevati poštnino iz Nemčije za vsak kos opreme posebej.
| » | OCZ rami s BH-5 čipiOddelek: Kaj kupiti | 2094 (1519) | Primoz78 |
| » | OCZ 2x512MB PC-4200 DDR 533 EL PlatinumOddelek: Kaj kupiti | 1316 (1193) | Good Guy |
| » | Najboljsi RAM (strani: 1 2 )Oddelek: Navijanje | 5100 (4305) | MEDENA |
| » | nForce3 Ultra s939 + RAM??!Oddelek: Kaj kupiti | 1490 (1386) | kewo |
| » | Koliko je vredno Abit NF7-s, Barton 2500+,....Oddelek: Strojna oprema | 1367 (1152) | LittleDevil |
