ATi Catalyst 3,8 in pregrevanje
Rage3D - Pojavila so se poročanja o tem, da naj bi ATIjevi video gonilniki povzročali pregrevanje grafičnih kartic in celo pripeljali do uničenja monitorja. Monitor se je skuril sicer le enemu od uporabnikov, pa še ta je bil beta tester, tako da glede tega verjetno ni skrbi. Zanimivo pa je dejstvo, da se grafične kartice segrejejo za 10°C bolj kot z drugimi gonilniki. Atijevci seveda pravijo, da to segrevanje še zdaleč ni blizu kritične temperature oziroma temperature za katero jamčijo delovanje grafične kartice, a hkrati zadevo še vedno raziskujejo. Rage3D
37 komentarjev
speed machine ::
Zakaj se mi zdi, da hoce Nvidia spet spravit vodo na svoj mlin?8-)
zakaj vedno usi obtozujejo nvidio?
_Mortal_ ::
Kr itaq nvidia wedno neki muti...
Is reading in the bathroom considered as multi-tasking?
MrX ::
mislš rečt nlamia :D
modicr ::
Tony Smith from 'The Register' comes up with this conclusion:
So is there a problem at all?
ATI doesn't think so. "We do not currently believe these stories are valid," it says.
Such is the level of willy-waving among some of the more infantile graphics card fanboys, we wouldn't be at all surprised if followers of a rival company had posted the claims in order to damage ATI. Nothing new there - in the past, ATI buffs have tried to suggest major problems with Nvidia cards. It's all part of the bizarre war these idiots believe they're fighting on behalf of their favoured firms.
While such claims may send a frisson of schadenfreude up the spines of competitors, we'd like to believe none of them countenance this sort of thing. As we witnessed with this year's Nvidia 3Dmark03 story, none of them are above trying to tacitly put the boot in to rivals when they can, but posting claims that drivers damage hardware? We don't think so. But past spats between the companies themselves, typified by the issuing of tit-for-tat press releases, hasn't exactly set down an example of adult competitive behaviour.
ja nvidia je podkupila ati-jeve programerje da mal zjebejo driverje ane.
MrX: a si lohk se mal bolj patitecen??
pingo76 ::
Kot reden gost www.rage3d.com foruma sem opazil da je dosti radeoniziraih ljudi to opazilo. Sam ne morem kaj dosti dodati na to temo ker imam na svojemu radeonu P4 stock cooler, in na otip je vedno hladno :D . Vsekakor pa se ne čudim ako je res kajti tako debilne buge kot jih z vsako verzijo kantalystov "integrirajo" je možno vse. Glede skurjenih monitorjev pa je verjetno crknil kak 14" ki je "pomotoma" zašel na 1024x768@100 in katodna cev je veselo skakala po sobi...
mocno dvomim da majo testerji take monitorje.prej ksn hud 20"+...
undefined ::
Kakšna bedarija. Monitor crkne zarad navitja kartice? Ja, seveda. Men je pa printer crknu zarad navitja procesorja. To še smešno ni več, ampak glupost do amena. |O
Drugače pa, kaj ima nVidia tu zraven, da jo eni zraven mešate? Pejte domače naloge delat. :)
ripmork ::
tut jaz ne razumem kje je tu monitor vpleten zraven......
sicer pa mam jst catalyst3.8 že kakšen teden in sem zadovoljen z njimi
(nobenih problemov-tut s pregrevanjem ne,imam pa Sapphireovega radeona 9500PRO)
....tko da so to po moje samo govorice...
C_maniak ::
hm, sam men s ezdi, pa da so res bl vroči rami... :|
Brane2 ::
Bedarije. Monitor NE SME crknit zaradi nepravilnih frekvenc, ki mu jih pošilja kartica (če mu jih pošilja). Enostavno ne sme.
Če mu kaj v poslani sliki ni všeč, se mora pač interno odklopit in napisat kaj v stilu "No signal.", "Bad syncs" itd.
Monitor, ki zaradi tega crkne, je delo idiotov...
undefined ::
Točno tako. Drugače pa, kar se tiče pregrevanja same kartice, lahko v Catalystih 3.8 _izključiš_ to funkcijo, pa bo vse po starem. Joj kolk je folk še laičen. Pa kot vem, to sploh po defaultu _ni_ vključeno, tko da ne vem, kaj eni klobasajo. :\
flipflop ::
To se tudi jst sprašujem.:\
krho ::
Brane2 imas prav ampak meni je pred casom ATIjeva graficna kartica skurila novo 17", na 15" LCD ju pa sploh ni hotela delovati v graficnem nacinu.
Potem pa sem nanjo prikljucil enega izmed prvih 14" noname monitorjev pa mi je vse skupaj delovalo.
NO Comment on that.
Tarzan ::
Krho, potem nam lahko iz prve roke poveš, kako je uničila tvojo 17 inčno makino. Jaz namreč v ta vudu ne verjamem ravno :\ .
krho ::
Po pravici tudi jaz ne. Tako, da sem samo povedal kaj se mi je zgodilo.
Ko je prisel v Winse so releji "ponoreli", zato sem ugasnil monitor. Ker mi stvar ni bila jasna sem ga pac prizgal nazaj in je naredilo samo se BUM. Aja pa kartica ni bila Radeon ampak je bil rage 3D s 4MB. Ze jaz sem se takrat spraseval kako je to mogoce. Po pravilih bi se moral monitor izklopiti tako kot se je ponavadi.
(V bistvu to ni skurila moja masina, ampak masina, ki sem jo imel na popravilu.)
swar ::
Verjetno je krho svojo 17" priklopil vga konektor na 220v ter strom na radeona :D
LCD je pa zihr kak beta izdelek made in taiwan za 60k >:D
krho ::
swar pa misli da sem jest se fejst zelen.:D
nicjasno ::
si pomislu na to, da je bil monitor defekten in okvara ni imela veze z graficno kartico?
krho ::
V bistvu sem. Samo tudi 15" LCD ni delal. Samo je blo bl zanimivo da je delal gor en prastar 14" CRT. Tako, da tud frekvenca osvezevanja ni mogla bit previsoka.
MKrmec ::
No ker ste vsi tako pametni vam moram povedat da je to res ampak kartice bo skurl samo tistim k nimajo aktivnga hlajenja (Sapphire Radeon 9000 pa ne pro) kot jest!!
Npr.:
Odkar sem namestil 3.8 sem opazil razliko ker se v igricah pojavljajo horizontalne črne črte ta problem naj bi bil povezan z RAM-om grafične (Pregrevanje)!!!
Romčy ::
dajte mi povedat kakšno normalno temperaturo imajo (default) rami na Radeonih 9800 pro 256mb. Sam imam vodno hlajenje na čipu, tako da ni ventilatorja na kartici ,na ramih pa so original hladilna rebra in imam temperaturo ramov 80 stopinj. Zanima me kako je drugot, čeprav vem da jih ni dosti.:\
jlpktnst ::
Hm, zakaj naj bi se pregrevalo? Overclock funkcija vendar dela le v XT verzijah (ki imajo termalno diodo vgrajeno, mimogrede). Tist glede monitorja je pa seveda popolnoma noro. Nekdo je imel pač tolk slab monitor da mu ga je skurl zarad napačne frekvence osv. (še moj 8 let stari 15' je sam reku out of synch ko sem ga dal na 85@1280...).
Pa če se že pregreva bi to lahk bil le boljši izkoristek hardvera (se motim?).
Zheegec ::
Mogoče pa driverji povečajo napetost RAMov, GPUja ter izhodov.
Čisto mogoče, kajne?
Janez Janša, 29.04.2014
undefined ::
Ravno toliko mogoče, kot da ti "novi" bencin pospeši avto na 300 kmph, kjer se ubiješ. ;)
Zanimivo bi bilo vedeti, pri katerih proizvajalcih grafične se skurijo monitorji.
Drugo pa je napetost na izhodu analognega izhoda lahko le tolikšna kolikšna je digitalna informacija , ki je bila uporabljena za DA pretvorbo. In kolikor sem se jaz ukvarjal zdi DA pretvorbo je tu na samem nivoju hardwera omejeno koliko sme biti MAX izhodna napetost, tako da prevelika napetost nima veze.
Kar pa je zanimivo je pa to da so crknjeni monitorji povezani s predhodnim šejkanjem relejev. To pa je lahko povezano z marsičem kar je povezano z izhodi grafike, kot je recimo signal z vertikalno sinhronizacijo in podobno. Načeloma pa napetost nebi smela preseči max vrednostih, lahko se samo deformira v tej smeri da se zgubi sinhronizacija z monitorjem, njegova elektronika pa izklopi rele...
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Šimpanz ::
Ljudje kar neki tvezjo. To je glik tho kot če bi meni disk crknil jaz bi pa krivil matično ploščo ker sem jo pred kratkim zamenju al pa če bi mi crknu avto jaz bi pa slabe ceste krivil. Monitor je crknil zato ker vsake toliko kakšen monitor mora crkniti.
Pa še neki na celem širnem svetu se pokvari en monitor in panika je takoj tu. Malo več objektivnosti prosim.
necromncr ::
Da skomentiram pokvarjanje monitorja ob graficnih: DA, je mozno. AMPAK samo na starejsih analog-only monitorjih, ki se niso imel logike ala: Freq. out of range. Je mozno, ker sam hardwer zaoscilira na frekvenci, ki je vecji od predvidene.
Drugace pa, RadeOn 9700 caka na skuritev in vrnitev v servis, menite da bodo driverji pomagal? :P
AtaStrumf ::
Jaz sem imel tele 3.8 (Omega) točno en teden in sem jih včeraj vseeno zamenjal za 3.7, ker sem opazil črte v grafiki, kot da bi bila grafika preveč navita, čeprav sploh ni navita. Ne skrbi me toliko za monitor, ker to je ZELO (2 do sedaj od najmanj 200 prebranih postov na to temo) redko da vidim, da kdo iz prve ali druge roke reče da je crknil monitor, (večino samo nekaj nabijajo, da so slišali, prebrali, ...) tole pregrevanje je pa kar pogosta pripomba. Razen teh par črt nisem opazil NIČ drugega, ampak saj veste: better safe than sorry.
Jeebs ::
Men se tud zdi tale s crkovanjem monitorja prehuda. Sam imam še zmeri v redni uporabi Packard Bell SME 1412 (če se ne motim), torej skor 10 let stara 14 inčna jajca, k sm jih priklapljal že na vse mogoče računalnike, pa še ni nič crknilo. Razen enkrat še na stari 486, ampak od takrat dela brez problema, pa je mašina dost časa prižgana.8-O
Press any key to continue... RESET. Didn't you say ANY key?!?!?!
undefined ::
In zakaj nisi poskusil raje 3.8 original? :\
ripmork ::
jaz sem si dal dol 3.8 catalyst direktno iz ATI-jeve strani.....in sploh nimam problemov.
tut s pregrevanjem ne......kolk vas pa sploh ma te gonilnike?
Romčy ::
AtaStrumf točno to se meni dogaja na Radeonu 9800 pro 256mb in z 3.8 driverji (original) Včasih ko prižgem se kar čez cel ekran pokažejo kvadratki točno tako kot če je navito, ampak imam na default. Na ramih imam diodo in se mi segrevajo od 70- 75 stopinj, na čipu pa vodni blok. Kakšno kartico imaš ti, ker me zanima ali se še komu to dogaja.8-O
jest10 ::
Jaz na radeonu 9000pro ne opazim onbene razlike.
Mogoče zato ker imam voznike za win98.
V glavnem nobenih problemou ni
jlpktnst ::
če se res tk segreva (marija!) pa kr hitr atiju poslat report:)
AtaStrumf ::
Jaz mam Hercules 9700 nePro. Omega sem pa dal gor ker imajo par dodatnih možnosti. To izjavo, ki je danes (četrtek) prišla kot novica so ATi podali že včeraj in sem jo vedel preden sem zamenjal gonilnike nazaj na 3.7, samo kot sem rekel: boljš počakat mal kot pa da se ti kaj skuri. Vem, da sem nekaj čudnega videl v sliki, tako da bom kar lepo počakal, da se tole do konca razplete. Nimam pa nobenega načina da merim temperaturo kot samo z prstom, to je pa itak brezveze. Pa itak imam en vent. v stranici (poleg treh od spredaj), ki lepo piha nad grafiko, pa še rebra mam že original na RAM-ih, tako da je pokvarjena slika, lahko tudi kaj drugega kot pregrevanje, ki bi mu morala biti moja grafika nadpovprečno kos. Vprašanje je samo če dovolj :\?
Računalnik zmrzuje pri obremenitvah
152034 (1808) solatko
temperatura grafične kartice
113583 (2552) DeeCoy
ATI Grafične kartice (strani: 1 2 3 415 16 17 18 )
87559348 (23586) Galaxy
Problem z graficno - kocke - je pokvarjena?
Oddelek: Zvok in slika
131552 (1188) Azrael
Club 3D 7600 GS AGP
301650 (977) hokuto
