Novice » Znanost in tehnologija » Boeing 737 Max 9 lahko spet leti, krivec za incident proizvajalec
DamijanD ::
Je pa želja (šefe Emiratov), da bo novi CEO Boeinga moral imet tehnično podlago:
Sir Tim Clark also said he backed efforts by the US group's largest labour union to win a seat on the board. "To fix Boeing's issues the company needs a strong engineering lead as its head coupled to a governance model which prioritises safety and quality," Clark told the Financial Times on Tuesday.
You can speak up, but prepare for suicide.
Ja, redno se zgodi, ravno včeraj na Brniku in 3x na Dunaju.
https://avherald.com/h?article=517b5c24... ... to je bilo že v nedeljo. Nič posebnega, se zgodi tu in tam, nima veze s proizvajalcem letala.
- spremenil: c3p0 ()
McAjvar ::
Ker "se zgodi tu in tam" definitivno pomeni "redno se zgodi"... [vstavi /facepalm gif]
"[...] the advance of civilization is nothing
but an exercise in the limiting of privacy."
- Isaac Asimov
- Isaac Asimov
kamiKaZaA ::
Tokrat Boeing 767.
Letalo družbe Delta, ki je iz New Yorka vzletelo v smeri Los Angelesa, se je moralo namreč takoj vrniti na letališče JFK. Odpadla je loputa za tobogan za evakuacijo pri enem izmed zasilnih izhodov. Incident za potnike na boeingu 767 sicer ni imel varnostnih posledic, so se pa pošteno prestrašili, ko je v zraku začelo tresti in ropotati.
Emergency Exit Slide Detaches As Delta Flight Takes Off, Forces Return to New York JFK
https://twitter.com/BoardingArea/status...
kamiKaZaA ::
Tokrat Boeing 767. Odpadla vrata? Ne. Odpadel pokrov motorja? Ne. Odpadlo kolo? Ne. Kaj se je tokrat torej zgodilo? Malo je z nosom podrajsal po pisti pri pristanku.
FedEx 767-300SF has landed with its nosegear up at Istanbul Airport, Turkey. The flight from Paris-CDG reported problems to ATC in extending the nosegear and did a low-pass for an inspection. No injuries reported.
https://twitter.com/aviationbrk/status/...
Maxlos ::
Evo,
krivi so delavci, sedaj morajo najti še nezadovolnega delovca ki je pospravil oba...
Boeing says workers skipped required tests on 787 but recorded work as completed
Boeing exec confirms skipped tests
Boeing VP Scott Stocker, who leads the 787 Dreamliner program, described "misconduct" in an April 29 email to employees in South Carolina. Boeing provided a copy of the email to Ars.
Barking up the wrong tree
Sej tako je marisikje danes. Imaš ljudi v firmi, ki skrbi za papirologijo in skladnost s zahtevami raznih standardov. Samo problem je ko tak človek danes dostikrat ne vidi nikoli proizvodnje ali razvoja. In potem imaš delavce, inženirje, ki jih zasujejo s izpolnjevanjem formularjev pri vsakem koraku, hkrati pa vodstvo pričakuje, da se vedno več stvari naredi. Potem nekdo opozori, da ni časa za vse po protokolu delat in sledit časovnim rokom, vendar se to gladko presliši. Oziroma vodsvo še tiho podpira, da se ne sledi vsem protokolom, ker deadline je bolj pomemben od varnosti. Pač grejo na večji rizik. Samo dlje kot se to počne, bolj se dviguje verjetnost težav.
- spremenil: Magic1 ()
Boeing je znal delati kvalitetna letala, kamor je spadala tudi "birokratska" papirologija.
Tako da ne more biti sedaj to izgovor!
Seveda dokler imajo inženirji kakšno besedo. Načeloma tudi inženir pripravlja papriologijo. Vendar inženirjev ni dovolj in potem se x kader napifla standarde in piše vso potrebno papriologijo. Vodstvu tudi ne pride bližje inženir in oni terajo svoje poslovne fore. Boeing je šel navzdol od združenja s Douglasom, ko so menegerji popolnoma izrinili vse inženirje iz vodilnih funkcij.
Douglas je imel drugacno filozofijo, financniki so imalu glavno besedo in tega so se navzeli v zdruzeni firmi, delnicarji so radi videli dividende in to zato podprli novo finančno strujo.
Najboljša letala potniška se delajo v evropi. Prevelike dividende, zgleda niso v redu. Če zasleduješ le dobiček, zna biti kaj hudo narobe.
https://twitter.com/Megatron_ron/status...
- spremenilo: Telbanc ()
brbr21 ::
https://aviation-safety.net/database/ye...
Precej creepy na tem seznamu letošnjih incidentov bogato vodi Boeing z 19 primeri proti trem Airbusa. So vsi incidenti, neglede na to kaj je vzrok in je res, da je v zraku cca 25% več Boeingov ter so nekaj starejši, pa vseeno 19:3. Hm...
Here we go again.. se zgodi:
Engine Engulfs in Flames on Boeing Plane With 468 Aboard
https://uk.news.yahoo.com/engine-engulf...
Da, se zgodi. Odpovedi motorjev so dnevni pojav po celem svetu. Če pa hočeš bit selektiven pri konzumiranju novic, pač bodi. Tvoj lajf ...
Boeing je trenutno na tapeti.
Je pa res,da ima zadnjih 10 let cel kup zajebov tako v letalski kot vesoljski tehniki.
Staliner še vedno ni poletel s šloveško posadko, svaka čast tistemu, ki ima dovolj jajc, da bo vzletel s tistim sranjem.
