Novice » Operacijski sistemi » Aktivacija Windows 7 že razbita
FitnessBoy ::
Loooooka> Tiste cracke iskat downloadat pa gor dajat...ko se ti mogoce mudi nekam vn...zna bit nadlezno.
Nadležno je, da moraš isto reč početi celo če imaš licenco!
Meni se plačilo licence za toliko vloženega znanja in truda ne zdi veliko! Aktivacija pa vzame cele 3 klike - joj je težko!
- spremenil: FitnessBoy ()
zee ::
Meni pa ja, kajti za ta denar bi pricakoval, da mi M$ ne tezil z raznoraznimi aktivacijami in podobnim sranjem.
Samo to.
Samo to.
zee
darkolord ::
Windows 7 OEM Product Key Leak
Yesterday we were alerted to reports of a leak of a special product key issued to an OEM partner of ours. The key is for use with Windows 7 Ultimate RTM product that is meant to be pre-installed by the OEM on new PCs to be shipped later this year. As such, the use of this key requires having a PC from the manufacturer it was issued to. We've worked with that manufacturer so that customers who purchase genuine copies of Windows 7 from this manufacturer will experience no issues validating their copy of Windows 7. At the same time we will seek to alert customers who are using the leaked key that they are running a non-genuine copy of Windows. It's important to note that no PCs will be sold that will use this key.
Windows 7 already includesan improved ability to detect hacks, also known as activation exploits, and alert customers who are using a pirated copy. There is a hack that is said to enable, when paired with the leaked key, a system to install and use a copy of Windows 7 Ultimate. Both the hack and the key are indications that a copy of Windows may not be genuine. The Windows Activation Technologies included in Windows 7 are designed to handle situations such as this one, and customers using these tools and methods should expect Windows to detect them.
Our primary goal is to protect users from becoming unknowing victims, because customers who use pirated software are at greater risk of being exposed to malware as well as identity theft. Someone asked me recently - and I think it's worth noting here -- whether we treat all exploits equally in responding to new ones we see. Our objective isn't to stop every "mad scientist" that's out there from dabbling; our aim is to protect our customers from commercialized counterfeit software that impacts our customers' confidence in knowing they got what they paid for. That will continue to be our focus as we continue to evolve our anti-piracy platforms, and respond to new threats that we see emerge in the future.
Samo to.
vprasaj pirate. saj je to zaradi njih.
c00L3r ::
Če imaš licenčne windowse vneseš ključ, daš activate in to je to. Zadeva deluje v 99% primerih. Če gre kaj narobe pa pokličeš MS. Če je slučajno praznik ali vikend tudi ni problem, saj lahko uporabljaš 30 dni brez aktivacije.
M-XXXX ::
Soo naive
Spc ::
Je pa ni.
Kaj pa tisti uporabniki, ki kupijo windowse in jih hočejo inštalirat na 5 domačih računalnikov ?
Je pa ni.
jaz mam 2 pcja in 2 licence. ena Oem druga retail. vecina katero jaz poznam ima pirat windowse. in se jim ob svakem bootu izpise da so zrtve ponarejanja softwarea.
ene to ne moti. pa tudi verjetno sploh ne vedo kaj pomeni :D
- spremenil: mtosev ()
c00L3r ::
Soo naive
Zelo konstruktiven odgovor si podal. Težave z izražanjem?
Jaz sem aktiviral enih 50 XP licenc in sem do zdaj vedno vse rešil. Če ni šlo skozi sem poklical na MS. Zato pa imajo support.
techfreak :) ::
Jaz dejansko ne razumem, zakaj moram ključ vpisati. Ga je tako težko na DVD nekam zapisati in si potem inštaller sam prebere?
tudi kljuc rabis v avto vtaknit in ga obrnit.
Čestitam za zelo neumno primerjavo.
Problem pa je, ker bi blo težko napisat na vsak cd drug ključ. Morda pa kdaj bo.
techfreak :) ::
RFID?
Mene samo moti, da moram vpisati ključ, če kupim originalno verzijo.
Zanimivo, da Applov Mac OS X nima nobene aktivacije, čeprav ga marsikdo nelegalno poganja na svojem sestavljenem PC-ju.
c00L3r ::
Zelo dobra ideja. Torej bi naj bil vsak inštalacijski DVD unikaten? Če se ti medij poškoduje, pa lahko čakaš 2 do 3 tedne da ti pošljejo novega in dodatno zaračunajo? Sicer pa je to stalna praksa pri programski opremi od praktično vseh proizvajalcev, da je potrebo vpisat ključ ob namestitvi.
techfreak :) ::
Ne, ključ je lahko napisan tudi na škatli, če bi slučajno zgubil DVD. Enako tudi za vse programe, ne samo za OS.
wooted ::
da se Microsoft posveča zaščiti uporabnikov pred ponarejeno in nelegalno programsko opremo.
aha, se pravi da nas folk po ulici obmetava z cdji od winsew, oni mi pa varnostnike prskrbijo :D
Bistri007 ::
Počakati bo treba na to, da OEM začnejo dejansko prodajati računalnike z Windows 7. Potem MSFT ne bo mogel kar tako prepovedati ključa na že prodanih računalnikih.
Največja napaka desetletja je bila narejena 4. novembra 2008
Oni so goljufali in Alah je goljufal, Alah je najboljši prevarant. (Koran 3:54)
Citiraj svetega očeta Benedikta XVI. in postani "persona rudis"...
BigWhale ::
Meni je aktivacija vzela tri dni. Ponedeljek je bil praznik.
PS: Pri visti.
- spremenil: BigWhale ()
bluefish ::
Jah, BigWhale ima kronične težave z MS produkti, kar je jasno dal vedeti že nekajkrat, tudi na svojem blogu.
BigWhale ::
Avtomatski odzivnik je meni povedal, da naj poklicem v delovnem casu, med osmo in cetrto vsak delavnik. A zdaj je ze sposoben urediti aktivacijo, ce ti ne deluje preko interneta? Zanimivo. Kako mu pa poves serijsko stevilko? Jo crkujes?
techfreak :) ::
Nabavi si internet. Ali pa preprosto nehaj uporabljati OS-a, ki ga še aktivirati ne moreš.
Ziga Dolhar ::
Ne poves serijske, ampak vtipkas eno drugo cifre-only stevilko, ki jo zgenerira Windows.
(Apparently, you didn't even get that far :))
https://dolhar.si/
BigWhale ::
Ziga, saj pravim, da to telefonskega odzivnika sploh prisel nisem, oziroma mi je rekel naj poklicem v delovnem casu. :)
Dejan, ne trollaj. Kot sem ze povedal, aktivacija pri na novo kupljeni visti ni delovala, ne prvic ne vsakic naslednjic, ko sem instaliral.
Ziga Dolhar ::
No, jaz sem imel "težave" z aktivacijo Win2k8. Key sem dobil na Dreamsparku, vendar je bila tam za download na voljo le x86 verzija.
Namestil sem x64, aktiviral brez problema. Po enem tednu sem ponovno inštaliral (prvič sem inštaliral "testno", da sem si pogledal in se poigral, drugič pa pač finalno in produkcijsko), vendar mi ni želel več aktivirat. Tudi prek avtomatskea telefonskega odzivnika in uporabe ukazne vrstice ni šlo, tako da sem pol počakal na "človeškega" sogovornika. Takrat je pa šlo :).
https://dolhar.si/
techfreak :) ::
Kaj pa kupuješ rabljen OEM OS ...
Kolikokrat si jo pa ponovno inštaliral? To vsak dan delaš?
Jaz sem že nekajkrat ponovno namestil Windows Visto in mi je vedno uspelo preko interneta registrirati. Enako za Windows 2003 iz DreamSpark-a.
Če večkrat namestiš, se lahko zgodi da boš moral poklicati.
BigWhale ::
Ja, vprasaj v Big Bangu kaj so delal.
Hm, to sem naredil trikrat. Vsakic potem, ko se je Vista tako sesula, da se ni hotla vec zbootat. Visto sem imel izkljucno za igranje iger.
Mavrik ::
In glede na pogovor, za namensko unicevanje in pizdenje po tem ;)
haha mater ste eni nesposoni :D jaz mam vista install date 22/12/2007 in se ni crashala da se ne bi naslednjic pobrala. ocitno imajo eni kronicne tezave in to tocno tisti kateri uporabljajo linuxe. zanimivo
Kolega še slišal ni za Linux. Začeli fajli izginjat na laptopu. Reinstaliral Visto. Aktivacija preko telefona (avtomatski, naj se cvre v peklu tisti, ki je tak dolg niz številk izmislil).
Aja, ni delala mrežna (ni driverja). Čist užitek. Rulz.
» | Izteka se možnost brezplačne nadgradnje na Windows 10 (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 24393 (17589) | orreel |
» | Nakup windows 7 (strani: 1 2 )Oddelek: Operacijski sistemi | 16136 (7577) | gslo |
» | Licenčni windowsiOddelek: Operacijski sistemi | 3338 (2830) | feryz |
» | windows 8 (nakup) (strani: 1 2 3 4 5 6 )Oddelek: Operacijski sistemi | 54872 (36613) | mtosev |
» | Aktivacija Windows 7 že razbita (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 22931 (11460) | MrStein |
