Novice » Operacijski sistemi » Windows 10 z reklamami tudi v Raziskovalcu
AndrejO ::
Jaz sem tisti tretji tabor, ki enakopravno in brez diskriminacije pljuva po vseh pojavnih oblikah dreka.
- spremenil: AndrejO ()
AndrejO ::
krneki0001 je izjavil:
Ne, ti si samo še en, ki pljuva.
Seveda je moj tabor podmnožica množice vseh, ki pljuvamo (vključno s teboj). Hkrati sta preseka mojega tabora s tistima, ki si ju predhodno navedel, prazni množici.
krneki0001 ::
########## # Tweaked Win10 Initial Setup Script # Primary Author: Disassembler <disassembler@dasm.cz> # Original Version: 1.4, 2016-01-16 # Tweaked based on personal preferences for @alirobe 2016-03-23 - v1.4.1 # NOTE: MAKE SURE YOU READ THIS SCRIPT CAREFULLY BEFORE RUNNING IT + ADJUST COMMENTING AS APPROPRIATE # This script will reboot your machine when completed. ########## # Ask for elevated permissions if required If (!([Security.Principal.WindowsPrincipal][Security.Principal.WindowsIdentity]::GetCurrent()).IsInRole([Security.Principal.WindowsBuiltInRole]"Administrator")) { Start-Process powershell.exe "-NoProfile -ExecutionPolicy Bypass -File `"$PSCommandPath`"" -Verb RunAs Exit } ########## # Privacy Settings ########## # Disable Telemetry Write-Host "Disabling Telemetry..." Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry" -Type DWord -Value 0 # Enable Telemetry # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry" # Disable Wi-Fi Sense Write-Host "Disabling Wi-Fi Sense..." If (!(Test-Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting")) { New-Item -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Force | Out-Null } Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 0 Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 0 # Enable Wi-Fi Sense # Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 1 # Disable SmartScreen Filter # Write-Host "Disabling SmartScreen Filter..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "Off" # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation" -Type DWord -Value 0 # Enable SmartScreen Filter # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "RequireAdmin" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation" # Disable Bing Search in Start Menu Write-Host "Disabling Bing Search in Start Menu..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled" -Type DWord -Value 0 # Enable Bing Search in Start Menu # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled" # Disable Location Tracking Write-Host "Disabling Location Tracking..." Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 0 Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 0 # Enable Location Tracking # Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 1 # Disable Feedback Write-Host "Disabling Feedback..." If (!(Test-Path "HKCU:\Software\Microsoft\Siuf\Rules")) { New-Item -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod" -Type DWord -Value 0 # Enable Feedback # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod" # Disable Advertising ID Write-Host "Disabling Advertising ID..." If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo")) { New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled" -Type DWord -Value 0 # Enable Advertising ID # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled" # Disable Cortana Write-Host "Disabling Cortana..." If (!(Test-Path "HKCU:\Software\Microsoft\Personalization\Settings")) { New-Item -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy" -Type DWord -Value 0 If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization")) { New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 1 Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 1 If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore")) { New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts" -Type DWord -Value 0 # Enable Cortana # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy" # Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 0 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 0 # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts" # Restrict Windows Update P2P only to local network Write-Host "Restricting Windows Update P2P only to local network..." Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode" -Type DWord -Value 1 If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization")) { New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode" -Type DWord -Value 3 # Unrestrict Windows Update P2P # Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode" # Remove AutoLogger file and restrict directory Write-Host "Removing AutoLogger file and restricting directory..." $autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger" If (Test-Path "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl") { Remove-Item "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl" } icacls $autoLoggerDir /deny SYSTEM:`(OI`)`(CI`)F | Out-Null # Unrestrict AutoLogger directory # $autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger" # icacls $autoLoggerDir /grant:r SYSTEM:`(OI`)`(CI`)F | Out-Null # Stop and disable Diagnostics Tracking Service Write-Host "Stopping and disabling Diagnostics Tracking Service..." Stop-Service "DiagTrack" Set-Service "DiagTrack" -StartupType Disabled # Enable and start Diagnostics Tracking Service # Set-Service "DiagTrack" -StartupType Automatic # Start-Service "DiagTrack" # Stop and disable WAP Push Service Write-Host "Stopping and disabling WAP Push Service..." Stop-Service "dmwappushservice" Set-Service "dmwappushservice" -StartupType Disabled # Enable and start WAP Push Service # Set-Service "dmwappushservice" -StartupType Automatic # Start-Service "dmwappushservice" # Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\dmwappushservice" -Name "DelayedAutoStart" -Type DWord -Value 1 ########## # Service Tweaks ########## # Lower UAC level # Write-Host "Lowering UAC level..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 0 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 0 # Raise UAC level # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 5 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 1 # Enable sharing mapped drives between users # Write-Host "Enabling sharing mapped drives between users..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections" -Type DWord -Value 1 # Disable sharing mapped drives between users # Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections" # Disable Firewall # Write-Host "Disabling Firewall..." # Set-NetFirewallProfile -Profile * -Enabled False # Enable Firewall # Set-NetFirewallProfile -Profile * -Enabled True # Disable Windows Defender # Write-Host "Disabling Windows Defender..." # Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" -Type DWord -Value 1 # Enable Windows Defender # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" # Disable Windows Update automatic restart Write-Host "Disabling Windows Update automatic restart..." Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 1 # Enable Windows Update automatic restart # Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 0 # Stop and disable Home Groups services Write-Host "Stopping and disabling Home Groups services..." Stop-Service "HomeGroupListener" Set-Service "HomeGroupListener" -StartupType Disabled Stop-Service "HomeGroupProvider" Set-Service "HomeGroupProvider" -StartupType Disabled # Enable and start Home Groups services # Set-Service "HomeGroupListener" -StartupType Manual # Set-Service "HomeGroupProvider" -StartupType Manual # Start-Service "HomeGroupProvider" # Disable Remote Assistance # Write-Host "Disabling Remote Assistance..." # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 0 # Enable Remote Assistance # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 1 # Enable Remote Desktop w/o Network Level Authentication # Write-Host "Enabling Remote Desktop w/o Network Level Authentication..." # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 0 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 0 # Disable Remote Desktop # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 1 ########## # UI Tweaks ########## # Disable Action Center # Write-Host "Disabling Action Center..." # If (!(Test-Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer")) { # New-Item -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" | Out-Null # } # Set-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter" -Type DWord -Value 1 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled" -Type DWord -Value 0 # Enable Action Center # Remove-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled" # Disable Lock screen Write-Host "Disabling Lock screen..." If (!(Test-Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization")) { New-Item -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" | Out-Null } Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen" -Type DWord -Value 1 # Enable Lock screen # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen" # Disable Autoplay # Write-Host "Disabling Autoplay..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 1 # Enable Autoplay # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 0 # Disable Autorun for all drives # Write-Host "Disabling Autorun for all drives..." # If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer")) { # New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" | Out-Null #} # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun" -Type DWord -Value 255 # Enable Autorun # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun" #Disable Sticky keys prompt Write-Host "Disabling Sticky keys prompt..." Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "506" # Enable Sticky keys prompt # Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "510" # Hide Search button / box Write-Host "Hiding Search Box / Button..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode" -Type DWord -Value 0 # Show Search button / box # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode" # Hide Task View button # Write-Host "Hiding Task View button..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton" -Type DWord -Value 0 # Show Task View button # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton" # Show small icons in taskbar # Write-Host "Showing small icons in taskbar..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons" -Type DWord -Value 1 # Show large icons in taskbar # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons" # Show titles in taskbar # Write-Host "Showing titles in taskbar..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel" -Type DWord -Value 1 # Hide titles in taskbar # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel" # Show all tray icons # Write-Host "Showing all tray icons..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray" -Type DWord -Value 0 # Hide tray icons as needed # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray" # Show known file extensions Write-Host "Showing known file extensions..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 0 # Hide known file extensions # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 1 # Show hidden files Write-Host "Showing hidden files..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 1 # Hide hidden files # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 2 # Change default Explorer view to "Computer" Write-Host "Changing default Explorer view to `"Computer`"..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo" -Type DWord -Value 1 # Change default Explorer view to "Quick Access" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo" # Show Computer shortcut on desktop # Write-Host "Showing Computer shortcut on desktop..." # If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu")) { # New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" | Out-Null # } # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0 # Hide Computer shortcut from desktop # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" # Remove Desktop icon from computer namespace # Write-Host "Removing Desktop icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" -Recurse -ErrorAction SilentlyContinue # Add Desktop icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" # Remove Documents icon from computer namespace # Write-Host "Removing Documents icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" -Recurse -ErrorAction SilentlyContinue # Add Documents icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" # Remove Downloads icon from computer namespace # Write-Host "Removing Downloads icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" -Recurse -ErrorAction SilentlyContinue # Add Downloads icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" # Remove Music icon from computer namespace # Write-Host "Removing Music icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" -Recurse -ErrorAction SilentlyContinue # Add Music icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" # Remove Pictures icon from computer namespace Write-Host "Removing Pictures icon from computer namespace..." Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" -Recurse -ErrorAction SilentlyContinue Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" -Recurse -ErrorAction SilentlyContinue # Add Pictures icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" # Remove Videos icon from computer namespace Write-Host "Removing Videos icon from computer namespace..." Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" -Recurse -ErrorAction SilentlyContinue Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" -Recurse -ErrorAction SilentlyContinue # Add Videos icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" ## Add secondary en-US keyboard #Write-Host "Adding secondary en-US keyboard..." #$langs = Get-WinUserLanguageList #$langs.Add("en-US") #Set-WinUserLanguageList $langs -Force # Remove secondary en-US keyboard # $langs = Get-WinUserLanguageList # Set-WinUserLanguageList ($langs | ? {$_.LanguageTag -ne "en-US"}) -Force ########## # Remove unwanted applications ########## # Disable OneDrive # Write-Host "Disabling OneDrive..." # If (!(Test-Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive")) { # New-Item -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" | Out-Null # } # Set-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC" -Type DWord -Value 1 # Enable OneDrive # Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC" # Uninstall OneDrive # Write-Host "Uninstalling OneDrive..." # Stop-Process -Name OneDrive -ErrorAction SilentlyContinue # Start-Sleep -s 3 # $onedrive = "$env:SYSTEMROOT\SysWOW64\OneDriveSetup.exe" # If (!(Test-Path $onedrive)) { # $onedrive = "$env:SYSTEMROOT\System32\OneDriveSetup.exe" # } # Start-Process $onedrive "/uninstall" -NoNewWindow -Wait # Start-Sleep -s 3 # Stop-Process -Name explorer -ErrorAction SilentlyContinue # Start-Sleep -s 3 # Remove-Item "$env:USERPROFILE\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # Remove-Item "$env:LOCALAPPDATA\Microsoft\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # Remove-Item "$env:PROGRAMDATA\Microsoft OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # If (Test-Path "$env:SYSTEMDRIVE\OneDriveTemp") { # Remove-Item "$env:SYSTEMDRIVE\OneDriveTemp" -Force -Recurse -ErrorAction SilentlyContinue # } # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKCR:\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue # Install OneDrive # $onedrive = "$env:SYSTEMROOT\SysWOW64\OneDriveSetup.exe" # If (!(Test-Path $onedrive)) { # $onedrive = "$env:SYSTEMROOT\System32\OneDriveSetup.exe" # } # Start-Process $onedrive -NoNewWindow # Uninstall default Microsoft applications Write-Host "Uninstalling default Microsoft applications..." Get-AppxPackage "Microsoft.3DBuilder" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingFinance" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingNews" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingSports" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingWeather" | Remove-AppxPackage Get-AppxPackage "Microsoft.Getstarted" | Remove-AppxPackage Get-AppxPackage "Microsoft.MicrosoftOfficeHub" | Remove-AppxPackage # Get-AppxPackage "Microsoft.MicrosoftSolitaireCollection" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Office.OneNote" | Remove-AppxPackage # Get-AppxPackage "Microsoft.People" | Remove-AppxPackage # Get-AppxPackage "Microsoft.SkypeApp" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Windows.Photos" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsAlarms" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsCamera" | Remove-AppxPackage # Get-AppxPackage "microsoft.windowscommunicationsapps" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsMaps" | Remove-AppxPackage Get-AppxPackage "Microsoft.WindowsPhone" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsSoundRecorder" | Remove-AppxPackage # Get-AppxPackage "Microsoft.XboxApp" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ZuneMusic" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ZuneVideo" | Remove-AppxPackage # Get-AppxPackage "Microsoft.AppConnector" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ConnectivityStore" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Office.Sway" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Messaging" | Remove-AppxPackage # Get-AppxPackage "Microsoft.CommsPhone" | Remove-AppxPackage Get-AppxPackage "9E2F88E3.Twitter" | Remove-AppxPackage Get-AppxPackage "king.com.CandyCrushSodaSaga" | Remove-AppxPackage # Install default Microsoft applications # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.3DBuilder").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingFinance").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingNews").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingSports").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingWeather").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Getstarted").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftOfficeHub").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftSolitaireCollection").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.OneNote").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.People").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.SkypeApp").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Windows.Photos").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsAlarms").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsCamera").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.windowscommunicationsapps").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsMaps").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsPhone").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsSoundRecorder").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.XboxApp").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneMusic").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneVideo").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.AppConnector").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ConnectivityStore").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.Sway").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Messaging").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.CommsPhone").InstallLocation)\AppXManifest.xml" # In case you have removed them for good, you can try to restore the files using installation medium as follows # New-Item C:\Mnt -Type Directory | Out-Null # dism /Mount-Image /ImageFile:D:\sources\install.wim /index:1 /ReadOnly /MountDir:C:\Mnt # robocopy /S /SEC /R:0 "C:\Mnt\Program Files\WindowsApps" "C:\Program Files\WindowsApps" # dism /Unmount-Image /Discard /MountDir:C:\Mnt # Remove-Item -Path C:\Mnt -Recurse # Uninstall Windows Media Player # Write-Host "Uninstalling Windows Media Player..." # dism /online /Disable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart # Install Windows Media Player # dism /online /Enable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart # Uninstall Work Folders Client # Write-Host "Uninstalling Work Folders Client..." # dism /online /Disable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart # Install Work Folders Client # dism /online /Enable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart # Set Photo Viewer as default for bmp, gif, jpg and png Write-Host "Setting Photo Viewer as default for bmp, gif, jpg, png and tif..." If (!(Test-Path "HKCR:")) { New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null } ForEach ($type in @("Paint.Picture", "giffile", "jpegfile", "pngfile")) { New-Item -Path $("HKCR:\$type\shell\open") -Force | Out-Null New-Item -Path $("HKCR:\$type\shell\open\command") | Out-Null Set-ItemProperty -Path $("HKCR:\$type\shell\open") -Name "MuiVerb" -Type ExpandString -Value "@%ProgramFiles%\Windows Photo Viewer\photoviewer.dll,-3043" Set-ItemProperty -Path $("HKCR:\$type\shell\open\command") -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1" } # Remove or reset default open action for bmp, gif, jpg and png # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\Paint.Picture\shell\open" -Recurse # Remove-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "MuiVerb" # Set-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "CommandId" -Type String -Value "IE.File" # Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "(Default)" -Type String -Value "`"$env:SystemDrive\Program Files\Internet Explorer\iexplore.exe`" %1" # Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "DelegateExecute" -Type String -Value "{17FE9752-0B5A-4665-84CD-569794602F5C}" # Remove-Item -Path "HKCR:\jpegfile\shell\open" -Recurse # Remove-Item -Path "HKCR:\pngfile\shell\open" -Recurse # Show Photo Viewer in "Open with..." Write-Host "Showing Photo Viewer in `"Open with...`"" If (!(Test-Path "HKCR:")) { New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null } New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Force | Out-Null New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Force | Out-Null Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Name "MuiVerb" -Type String -Value "@photoviewer.dll,-3043" Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1" Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Name "Clsid" -Type String -Value "{FFE2A43C-56B9-4bf5-9A79-CC6D4285608A}" # Remove Photo Viewer from "Open with..." # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Recurse ########## # Restart ########## Write-Host Write-Host "Press any key to restart your system..." -ForegroundColor Black -BackgroundColor White $key = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown") Write-Host "Restarting..." Restart-Computer 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 ########## # Tweaked Win10 Initial Setup Script # Primary Author: Disassembler <disassembler@dasm.cz> # Original Version: 1.4, 2016-01-16 # Tweaked based on personal preferences for @alirobe 2016-03-23 - v1.4.1 # NOTE: MAKE SURE YOU READ THIS SCRIPT CAREFULLY BEFORE RUNNING IT + ADJUST COMMENTING AS APPROPRIATE # This script will reboot your machine when completed. ########## # Ask for elevated permissions if required If (!([Security.Principal.WindowsPrincipal][Security.Principal.WindowsIdentity]::GetCurrent()).IsInRole([Security.Principal.WindowsBuiltInRole]"Administrator")) { Start-Process powershell.exe "-NoProfile -ExecutionPolicy Bypass -File `"$PSCommandPath`"" -Verb RunAs Exit } ########## # Privacy Settings ########## # Disable Telemetry Write-Host "Disabling Telemetry..." Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry" -Type DWord -Value 0 # Enable Telemetry # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry" # Disable Wi-Fi Sense Write-Host "Disabling Wi-Fi Sense..." If (!(Test-Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting")) { New-Item -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Force | Out-Null } Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 0 Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 0 # Enable Wi-Fi Sense # Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 1 # Disable SmartScreen Filter # Write-Host "Disabling SmartScreen Filter..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "Off" # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation" -Type DWord -Value 0 # Enable SmartScreen Filter # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "RequireAdmin" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation" # Disable Bing Search in Start Menu Write-Host "Disabling Bing Search in Start Menu..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled" -Type DWord -Value 0 # Enable Bing Search in Start Menu # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled" # Disable Location Tracking Write-Host "Disabling Location Tracking..." Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 0 Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 0 # Enable Location Tracking # Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 1 # Disable Feedback Write-Host "Disabling Feedback..." If (!(Test-Path "HKCU:\Software\Microsoft\Siuf\Rules")) { New-Item -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod" -Type DWord -Value 0 # Enable Feedback # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod" # Disable Advertising ID Write-Host "Disabling Advertising ID..." If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo")) { New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled" -Type DWord -Value 0 # Enable Advertising ID # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled" # Disable Cortana Write-Host "Disabling Cortana..." If (!(Test-Path "HKCU:\Software\Microsoft\Personalization\Settings")) { New-Item -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy" -Type DWord -Value 0 If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization")) { New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 1 Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 1 If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore")) { New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Force | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts" -Type DWord -Value 0 # Enable Cortana # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy" # Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 0 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 0 # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts" # Restrict Windows Update P2P only to local network Write-Host "Restricting Windows Update P2P only to local network..." Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode" -Type DWord -Value 1 If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization")) { New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" | Out-Null } Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode" -Type DWord -Value 3 # Unrestrict Windows Update P2P # Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode" # Remove AutoLogger file and restrict directory Write-Host "Removing AutoLogger file and restricting directory..." $autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger" If (Test-Path "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl") { Remove-Item "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl" } icacls $autoLoggerDir /deny SYSTEM:`(OI`)`(CI`)F | Out-Null # Unrestrict AutoLogger directory # $autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger" # icacls $autoLoggerDir /grant:r SYSTEM:`(OI`)`(CI`)F | Out-Null # Stop and disable Diagnostics Tracking Service Write-Host "Stopping and disabling Diagnostics Tracking Service..." Stop-Service "DiagTrack" Set-Service "DiagTrack" -StartupType Disabled # Enable and start Diagnostics Tracking Service # Set-Service "DiagTrack" -StartupType Automatic # Start-Service "DiagTrack" # Stop and disable WAP Push Service Write-Host "Stopping and disabling WAP Push Service..." Stop-Service "dmwappushservice" Set-Service "dmwappushservice" -StartupType Disabled # Enable and start WAP Push Service # Set-Service "dmwappushservice" -StartupType Automatic # Start-Service "dmwappushservice" # Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\dmwappushservice" -Name "DelayedAutoStart" -Type DWord -Value 1 ########## # Service Tweaks ########## # Lower UAC level # Write-Host "Lowering UAC level..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 0 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 0 # Raise UAC level # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 5 # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 1 # Enable sharing mapped drives between users # Write-Host "Enabling sharing mapped drives between users..." # Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections" -Type DWord -Value 1 # Disable sharing mapped drives between users # Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections" # Disable Firewall # Write-Host "Disabling Firewall..." # Set-NetFirewallProfile -Profile * -Enabled False # Enable Firewall # Set-NetFirewallProfile -Profile * -Enabled True # Disable Windows Defender # Write-Host "Disabling Windows Defender..." # Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" -Type DWord -Value 1 # Enable Windows Defender # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" # Disable Windows Update automatic restart Write-Host "Disabling Windows Update automatic restart..." Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 1 # Enable Windows Update automatic restart # Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 0 # Stop and disable Home Groups services Write-Host "Stopping and disabling Home Groups services..." Stop-Service "HomeGroupListener" Set-Service "HomeGroupListener" -StartupType Disabled Stop-Service "HomeGroupProvider" Set-Service "HomeGroupProvider" -StartupType Disabled # Enable and start Home Groups services # Set-Service "HomeGroupListener" -StartupType Manual # Set-Service "HomeGroupProvider" -StartupType Manual # Start-Service "HomeGroupProvider" # Disable Remote Assistance # Write-Host "Disabling Remote Assistance..." # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 0 # Enable Remote Assistance # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 1 # Enable Remote Desktop w/o Network Level Authentication # Write-Host "Enabling Remote Desktop w/o Network Level Authentication..." # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 0 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 0 # Disable Remote Desktop # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 1 # Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 1 ########## # UI Tweaks ########## # Disable Action Center # Write-Host "Disabling Action Center..." # If (!(Test-Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer")) { # New-Item -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" | Out-Null # } # Set-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter" -Type DWord -Value 1 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled" -Type DWord -Value 0 # Enable Action Center # Remove-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled" # Disable Lock screen Write-Host "Disabling Lock screen..." If (!(Test-Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization")) { New-Item -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" | Out-Null } Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen" -Type DWord -Value 1 # Enable Lock screen # Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen" # Disable Autoplay # Write-Host "Disabling Autoplay..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 1 # Enable Autoplay # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 0 # Disable Autorun for all drives # Write-Host "Disabling Autorun for all drives..." # If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer")) { # New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" | Out-Null #} # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun" -Type DWord -Value 255 # Enable Autorun # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun" #Disable Sticky keys prompt Write-Host "Disabling Sticky keys prompt..." Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "506" # Enable Sticky keys prompt # Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "510" # Hide Search button / box Write-Host "Hiding Search Box / Button..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode" -Type DWord -Value 0 # Show Search button / box # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode" # Hide Task View button # Write-Host "Hiding Task View button..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton" -Type DWord -Value 0 # Show Task View button # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton" # Show small icons in taskbar # Write-Host "Showing small icons in taskbar..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons" -Type DWord -Value 1 # Show large icons in taskbar # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons" # Show titles in taskbar # Write-Host "Showing titles in taskbar..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel" -Type DWord -Value 1 # Hide titles in taskbar # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel" # Show all tray icons # Write-Host "Showing all tray icons..." # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray" -Type DWord -Value 0 # Hide tray icons as needed # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray" # Show known file extensions Write-Host "Showing known file extensions..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 0 # Hide known file extensions # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 1 # Show hidden files Write-Host "Showing hidden files..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 1 # Hide hidden files # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 2 # Change default Explorer view to "Computer" Write-Host "Changing default Explorer view to `"Computer`"..." Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo" -Type DWord -Value 1 # Change default Explorer view to "Quick Access" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo" # Show Computer shortcut on desktop # Write-Host "Showing Computer shortcut on desktop..." # If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu")) { # New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" | Out-Null # } # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0 # Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0 # Hide Computer shortcut from desktop # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" # Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" # Remove Desktop icon from computer namespace # Write-Host "Removing Desktop icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" -Recurse -ErrorAction SilentlyContinue # Add Desktop icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" # Remove Documents icon from computer namespace # Write-Host "Removing Documents icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" -Recurse -ErrorAction SilentlyContinue # Add Documents icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" # Remove Downloads icon from computer namespace # Write-Host "Removing Downloads icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" -Recurse -ErrorAction SilentlyContinue # Add Downloads icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" # Remove Music icon from computer namespace # Write-Host "Removing Music icon from computer namespace..." # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" -Recurse -ErrorAction SilentlyContinue # Add Music icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" # Remove Pictures icon from computer namespace Write-Host "Removing Pictures icon from computer namespace..." Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" -Recurse -ErrorAction SilentlyContinue Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" -Recurse -ErrorAction SilentlyContinue # Add Pictures icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" # Remove Videos icon from computer namespace Write-Host "Removing Videos icon from computer namespace..." Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" -Recurse -ErrorAction SilentlyContinue Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" -Recurse -ErrorAction SilentlyContinue # Add Videos icon to computer namespace # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" # New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" ## Add secondary en-US keyboard #Write-Host "Adding secondary en-US keyboard..." #$langs = Get-WinUserLanguageList #$langs.Add("en-US") #Set-WinUserLanguageList $langs -Force # Remove secondary en-US keyboard # $langs = Get-WinUserLanguageList # Set-WinUserLanguageList ($langs | ? {$_.LanguageTag -ne "en-US"}) -Force ########## # Remove unwanted applications ########## # Disable OneDrive # Write-Host "Disabling OneDrive..." # If (!(Test-Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive")) { # New-Item -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" | Out-Null # } # Set-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC" -Type DWord -Value 1 # Enable OneDrive # Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC" # Uninstall OneDrive # Write-Host "Uninstalling OneDrive..." # Stop-Process -Name OneDrive -ErrorAction SilentlyContinue # Start-Sleep -s 3 # $onedrive = "$env:SYSTEMROOT\SysWOW64\OneDriveSetup.exe" # If (!(Test-Path $onedrive)) { # $onedrive = "$env:SYSTEMROOT\System32\OneDriveSetup.exe" # } # Start-Process $onedrive "/uninstall" -NoNewWindow -Wait # Start-Sleep -s 3 # Stop-Process -Name explorer -ErrorAction SilentlyContinue # Start-Sleep -s 3 # Remove-Item "$env:USERPROFILE\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # Remove-Item "$env:LOCALAPPDATA\Microsoft\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # Remove-Item "$env:PROGRAMDATA\Microsoft OneDrive" -Force -Recurse -ErrorAction SilentlyContinue # If (Test-Path "$env:SYSTEMDRIVE\OneDriveTemp") { # Remove-Item "$env:SYSTEMDRIVE\OneDriveTemp" -Force -Recurse -ErrorAction SilentlyContinue # } # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue # Remove-Item -Path "HKCR:\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue # Install OneDrive # $onedrive = "$env:SYSTEMROOT\SysWOW64\OneDriveSetup.exe" # If (!(Test-Path $onedrive)) { # $onedrive = "$env:SYSTEMROOT\System32\OneDriveSetup.exe" # } # Start-Process $onedrive -NoNewWindow # Uninstall default Microsoft applications Write-Host "Uninstalling default Microsoft applications..." Get-AppxPackage "Microsoft.3DBuilder" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingFinance" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingNews" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingSports" | Remove-AppxPackage Get-AppxPackage "Microsoft.BingWeather" | Remove-AppxPackage Get-AppxPackage "Microsoft.Getstarted" | Remove-AppxPackage Get-AppxPackage "Microsoft.MicrosoftOfficeHub" | Remove-AppxPackage # Get-AppxPackage "Microsoft.MicrosoftSolitaireCollection" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Office.OneNote" | Remove-AppxPackage # Get-AppxPackage "Microsoft.People" | Remove-AppxPackage # Get-AppxPackage "Microsoft.SkypeApp" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Windows.Photos" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsAlarms" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsCamera" | Remove-AppxPackage # Get-AppxPackage "microsoft.windowscommunicationsapps" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsMaps" | Remove-AppxPackage Get-AppxPackage "Microsoft.WindowsPhone" | Remove-AppxPackage # Get-AppxPackage "Microsoft.WindowsSoundRecorder" | Remove-AppxPackage # Get-AppxPackage "Microsoft.XboxApp" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ZuneMusic" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ZuneVideo" | Remove-AppxPackage # Get-AppxPackage "Microsoft.AppConnector" | Remove-AppxPackage # Get-AppxPackage "Microsoft.ConnectivityStore" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Office.Sway" | Remove-AppxPackage # Get-AppxPackage "Microsoft.Messaging" | Remove-AppxPackage # Get-AppxPackage "Microsoft.CommsPhone" | Remove-AppxPackage Get-AppxPackage "9E2F88E3.Twitter" | Remove-AppxPackage Get-AppxPackage "king.com.CandyCrushSodaSaga" | Remove-AppxPackage # Install default Microsoft applications # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.3DBuilder").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingFinance").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingNews").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingSports").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingWeather").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Getstarted").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftOfficeHub").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftSolitaireCollection").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.OneNote").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.People").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.SkypeApp").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Windows.Photos").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsAlarms").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsCamera").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.windowscommunicationsapps").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsMaps").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsPhone").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsSoundRecorder").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.XboxApp").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneMusic").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneVideo").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.AppConnector").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ConnectivityStore").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.Sway").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Messaging").InstallLocation)\AppXManifest.xml" # Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.CommsPhone").InstallLocation)\AppXManifest.xml" # In case you have removed them for good, you can try to restore the files using installation medium as follows # New-Item C:\Mnt -Type Directory | Out-Null # dism /Mount-Image /ImageFile:D:\sources\install.wim /index:1 /ReadOnly /MountDir:C:\Mnt # robocopy /S /SEC /R:0 "C:\Mnt\Program Files\WindowsApps" "C:\Program Files\WindowsApps" # dism /Unmount-Image /Discard /MountDir:C:\Mnt # Remove-Item -Path C:\Mnt -Recurse # Uninstall Windows Media Player # Write-Host "Uninstalling Windows Media Player..." # dism /online /Disable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart # Install Windows Media Player # dism /online /Enable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart # Uninstall Work Folders Client # Write-Host "Uninstalling Work Folders Client..." # dism /online /Disable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart # Install Work Folders Client # dism /online /Enable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart # Set Photo Viewer as default for bmp, gif, jpg and png Write-Host "Setting Photo Viewer as default for bmp, gif, jpg, png and tif..." If (!(Test-Path "HKCR:")) { New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null } ForEach ($type in @("Paint.Picture", "giffile", "jpegfile", "pngfile")) { New-Item -Path $("HKCR:\$type\shell\open") -Force | Out-Null New-Item -Path $("HKCR:\$type\shell\open\command") | Out-Null Set-ItemProperty -Path $("HKCR:\$type\shell\open") -Name "MuiVerb" -Type ExpandString -Value "@%ProgramFiles%\Windows Photo Viewer\photoviewer.dll,-3043" Set-ItemProperty -Path $("HKCR:\$type\shell\open\command") -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1" } # Remove or reset default open action for bmp, gif, jpg and png # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\Paint.Picture\shell\open" -Recurse # Remove-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "MuiVerb" # Set-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "CommandId" -Type String -Value "IE.File" # Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "(Default)" -Type String -Value "`"$env:SystemDrive\Program Files\Internet Explorer\iexplore.exe`" %1" # Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "DelegateExecute" -Type String -Value "{17FE9752-0B5A-4665-84CD-569794602F5C}" # Remove-Item -Path "HKCR:\jpegfile\shell\open" -Recurse # Remove-Item -Path "HKCR:\pngfile\shell\open" -Recurse # Show Photo Viewer in "Open with..." Write-Host "Showing Photo Viewer in `"Open with...`"" If (!(Test-Path "HKCR:")) { New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null } New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Force | Out-Null New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Force | Out-Null Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Name "MuiVerb" -Type String -Value "@photoviewer.dll,-3043" Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1" Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Name "Clsid" -Type String -Value "{FFE2A43C-56B9-4bf5-9A79-CC6D4285608A}" # Remove Photo Viewer from "Open with..." # If (!(Test-Path "HKCR:")) { # New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null # } # Remove-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Recurse ########## # Restart ########## Write-Host Write-Host "Press any key to restart your system..." -ForegroundColor Black -BackgroundColor White $key = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown") Write-Host "Restarting..." Restart-Computer
Copy-Paste ga je malo zj***l .
AndrejO ::
krneki0001 je izjavil:
Ne, 2 skripti sta v enem zapisu. Nisem ju ločil. Ena je original in ena tweakana.
Komu so pa ta magična zaklinjanja sploh namenjena?
krneki0001 ::
Vsakomur, kdor hoče kaj izklopit ali vklopit v windows 10.
Sej so povsod komentarji, kaj dela vsak ukaz posebaj.
AndrejO ::
OK, bom testiral na svoji mami, ce bo razumela, kaj ji zelis povedati.
Ja, ja ... vem. Tukaj smo menda samo znalci. Ampak Windows 10 naj bi bil OS za mase, ne pa zgolj za znalce, mar ne?
krneki0001 ::
Tisto kar navaden človek dela v OS-u za mase, lahko vse naklika preko GUI-ja.
Tukaj, na tehnološkem forumu, pa človek predvideva, da so tudi taki, ki bi radi kaj več znali. In višje gor je bilo vprašanje, kako kaj preko powershella rešiš, pa je bil to tudi en izmed odgovorov, kako.
AndrejO ::
Ah, OK. Se mi je zdelo, da ni bilo namenjeno meni, ceprav je sledilo mojem komentarju o pljuvanju.
BTW, mojh problemov z Win10 ta skripta ne resuje ... Se bo moral kar MS se malo potruditi oz. se je ze uspel potruditi. Pa ne zato, ker bi "jaz" pljuval, ampak zato, ker se zdalec nisem edini s to ali ono tezavo/kritiko/pljuvanjem.
AndrejO ::
#1 Nekonsistenten UI (očitno še vedno v fazi "migracije" tudi še po nekaj letih).
#2 Nezmožnost nadzora nad posodobitvami za spodobno ceno (Enterprise Edition? Ja pa valjda si bom to kupoval za svoje postranske projekte, mar ne?)
#3 Občasna ponastavitev vsega že enkrat odstranjenega dreka, ko se MS-ju to sprdne.
"Creators Update" naj bi vsaj delno uredil #2, čeprav se bojim, kaj mi bo spet crknilo, kot mi je za nekaj časa crknil webcam pri eni izmed teh "juhuhu" vsiljenih novih verzij.
#1 ... kaj pa vem. Morda počakam še 5 let, pa se bom bodisi navadil ali pa bodo končno uspeli vsaj eno stvar dokončati, ne pa da se obnašajo, kot moj trenuten delodajalec.
#3 ... se bojim, da bo to šlo samo še navzdol.
krneki0001 ::
1.) nekonsistenten UI imata recimo android in ubuntu, ki sta resnična polizdelka. Win 10 so kr dost konsistentni.
2.) Tista skripta, ki sem jo višje gor objavil, deluje tudi na pro verziji in je namenjena ravno temu, da lahko updejte poštimaš kakor ti paše.
3.) ne vem kakšne občasne ponastavitve imaš ti? Česa?
AndrejO ::
V primerjavi z Win7 je Win10 nekako tako konsistenten kot Pahor pred volitvami. Vse kar vem je to, da ne vem kaj me bo pričakalo pri naslednjem kliku. Nekako tako, kot ne vem, če bo Pahor jutri kidal gnoj ali pa vozil viličarja.
Žal ni delovalo. Nocoj sem prišel do VM-ja in, glej ga zlomka, nekje vmes se je resetiral, da je namestil KB4013429.
Ampak nič ne de. MS je mene in meni podobne vsaj v tej točki po nekaj letih le uslišal in "ugotovil", da mora napako odpraviti. Creators Update je za vogalom.
Bom počakal na Creators Update in bom podal povzetek, če se bo znova kaj podrekalo. Pri Anniversary Update se je MS odločil, da bi resnično raje videl, da slike in filme gledam z nekimi njihovimi jajci in ne z meni priljubljenima XnViewMP in VLC. Pa še nekaj Windows Store aplikacij mi je nametal na tisti drek od "Start" menuja, ki to ni.
- spremenil: AndrejO ()
AndrejO ::
No, pa imam še ta odgovor. Creators Update mi je popacal naslednje:
- V taskbar mi je pripel MS-jev Mail.
- Ponovno mi je namestil "Get Office". BTW, toliko je zabit, da ni "opazil", da imam Office 2016 že nameščen.
- Ponovno mi je namestil tudi sledeča že enkrat izbrisana jajca: Alarms & Clock, Calculator, Camera, Feedback Hub, Get Help, Mail, Maps, Microsoft Solitaire Collection, OneDrive, One Note (podrekana Windows Store verzija, seveda in to navkljub temu, da že imam One Note 2016), Paid WiFi & Cellular (karkoli že je to), Paint 3D, People, Photos, Sticky Notes, Store (duh!), Tips, View 3D Preview, Weather, Windows 10 Upgrade Assistant (but, why!), Wireless Display Media Viewer (s pokvarjeno ikono - bel kvadrat namesto česarkoli že) in Xbox. Skupaj torej 22 aplikacij za katere nisem prosil ali pa sem jih že dvakrat odstranil.
- V Action Center mi je dodal že dvakrat prej odstranjen "Tablet mode", ker očitno zelo potrebujem ta "Tablet mode" na računalniku, ki nima ne baterije, ne zaslona na dotik.
- V Action Center mi je ponovno dodal že dvakrat prej odstranjeno povezavo do "VPN".
- Ponovno mi je omogočil prikazovanje sporočil (notifications) na zaklenjenem računalniku (lock screen). Idioti!
- Ponovno mi je vključil prikazovanje opomnikov in VoIP klicev na zaklenjenem računalniku. Idioti drugič!
- Ponovno mi je izključil skrivanje opomnikov, kadar imam kloniran zaslon. OK, ni pomembno na namiznem računalniku, ampak od kje tem opicam ideja, da mi lahko spremenijo to nastavitev?
- Gonilniki za HP OfficeJet so mi crknili. Bom popravil jutri. Zaenkrat bom to štel v slabo MS-ju, ki se je že enkrat izkazal z Logitech spletno kamero in drekanjem API-jev pod havbo.
- Ponovno mi je ponastavil svoj drek od Photos namesto XnViewMP (slike) in VLC (video).
- Ponovno je dovolil dostop do kamere za "apps" (torej drek iz Windows Store), med drugimtudi za (ponovno in brez vprašanja nameščene) Feedback Hub, Maps, in Store aplikacije. Same takšne aplikacije, ki resnično potrebujejo dostop do kamere.
- Enako kot za kamero, tudi za mikrofon, sliko, kontakte, opomnike, ... Praktično vse razen (začuda!) lokacije.
Kot bonus se je Creators Update pritoževal zaradi Microsoft Security Essentials in vključil Windows Defender, ker MSE ni kompatibilen z novo verzijo. Yay! Posodobitev za MSE tudi še ni na voljo. Yay še drugič! Uf ... kaj je že to? Aja, to je nekaj, kar je bilo odstranjeno že takrat, ko sem naredil nadgradnjo iz Win7 na Win10. Thanks Obama za lažen alarm.
Kaj se je spremenilo na boljše?
V Pro lahko ponovno izključim nadležen auto-reboot. It only took two years!
ThinkTech ::
Me kar glava boli ob misli, da bom moral spet 6x vse na novo nastavljat. Upam, da je treba za posodobitev sprejet kakšne licenčne pogoje, ker jih ne bom.
Te Windowsi in njih updati res zvenijo kot pekel, kjer moraš celo večnost spreminjati nastavitve, ki se potem resetirajo. Kako lahko Microsoft imenuje to Proffesional?
Meni ni spremenil nobene nastavitve. Vse je ostalo tako kot mora biti.
Se pravi je popravek čisto nedeterminističen, enemu spremeni vse, drugemu nič? Mogoče ima kak random notri.
krneki0001 ::
Jaz imam vse nastavitve v cloudu in ko se naloži nova verzija potegne vse nastavitve nazaj.
Jaz imam vse nastavitve v cloudu in ko se naloži nova verzija potegne vse nastavitve nazaj.lahko link, ker nisem vedo. bi rad preveril kak imam nastavljeno.
AndrejO ::
To morda pojasni razliko. Jaz nimam ničesar v oblaku in sem se kar potrudil, da sem se izognil kakršnikoli on-line registraciji za katerokoli izmed MS-jevih storitev.
(razen aktivacije same)
krneki0001 ::
Ni linka. Sam ti vse shrani in sinhronizira (sync), samo v nastavitvah si nastavi da ti vse zadeve sinhronizira.
Zadeva je zelo uporabna, ker dost menjam računalnike in samo sistem naložim, potem pa se prijavim s svojim accountom in mi sam sinhronizira vse (nastavitve, teme, ozadja, maile, koledarje, gesla za sistem, gesla za brskalnike, aplikacije (ki so v domeni MS-a in tiste v metroju).
Seveda. Če imaš samo lokalni račun, ti vse povozi in moraš vse spet nastavljat. Če imaš MS account ti sinhronizira vse nastavitve in vse nazaj postavi.
- spremenilo: krneki0001 ()
Se pravi update zna brati obstoječe nastavitve iz oblaka, ne zna pa jih prebrati iz diska. Hm, zanimivo.
Spajky ::
...Te Windowsi in njih updati res zvenijo kot pekel, kjer moraš celo večnost spreminjati nastavitve, ki se potem resetirajo. Kako lahko Microsoft imenuje to Proffesional?Tako : To je verzija MS Win10 Professional Confusion. Cilj, da se s svojim OS post-upgrade čimveč ukvarjate in manj resno delate ter stojite v vrsti za novi upgrade v tresočem pričakovanju. Life is a thrill ...
meni dela vse ok.
nevone ::
Software je ponavadi toliko konfuzen, kolikor je konfuzen uporabnik.
o+ nevone
krneki0001 ::
Zelo verjetno jih zna, vendar mu moraš to nekako razložiti da naj jih uporabi.
ender ::
Meni je kot ponavadi pozabil Alt+Tab nastavitve (ne maram modernega, je preveč nepregleden) in debelino okvirjev oken, samo imam za to že od prej pripravljeno .reg datoteko, ki te nastavitve povrne.
Alexius Heristalski ::
Te velike nadgradnje so in-place upgrade, normalno, da bo popravil register in nazaj naložil aplikacije iz Storea, to je itak point in-place upgradea. Je nerodno, če imaš nadpovprečno število prilagoditev.
AndrejO ::
Zakaj normalno? Ali obstaja kakršnakoli tehnična omejitev, da se mora stvari ponastaviti? Če vprašaš mene, je to samo še en gnoj od strategije, ki na plačljivem OS-u zapravlja čas z iskanjem načinov kako pospeševati prodajo preko svojega klona App Store, nima pa časa poskrbeti za stvari, ki bi izboljšale uporabnost samega sistema.
Pa še dve čudoviti malenkosti. Včeraj sem dobil to novo opozorilo, da bi se okna zaradi posodobitve želela ponovno zagnati. Pridno sem kliknil, da ne, ker tega nisem želel.
Danes zjutraj sedem pred računalnik in glej ga zlomka. Nekje vmes so se okna vseeno odločila, da se bodo ponovno zagnala. Toliko glede "popravka" na to temo. Sumim, da bodo okna odlagala ponovno zagon samo, če bo nekdo vztrajno klikal na okence, sicer pa se bodo delala francoza.
Druga neumnost pa me še vedno moti. Njega dni (beri: Win7) se je pred vsako posodobitvijo naredil system restore point. Jako prikladna stvar, če pomislim, da so posodobitve znale kakšno stvar tudi pokvariti. No, Win10 tega več nima. Posodobitve pa še vedno znajo kakšno stvar pokvariti in, če jo dovolj pokvarijo, rešitve več ni. System restore, ki je delal v varnem načinu, pa več ne rešuje te težave, ker ga posodobitve več ne uporabljajo.
Hvala, lolekom.
Skratka ... Win10 še naprej ostaja školjka za zagon igric. Za resno delo do nadaljnega ostane Win7.
Hvala, lolekom.
Hvala, lolekom.
Najbolj je pa to, ko berem forume, da jim npr. update pokvari nekaj z driverji in podobno. Potem pa uporabniki krivijo proizvajalca hardwera, da ni dosti hitro spisal nove driverje za trenutni update lol. Smisel neke platforme kot je bila npr Windows 7 je, da proizvajalci pričakujejo da bodo gonilniki delovali skozi celotno dobo platforme, razen v preteklosti SP-ji so lahko zagodli vsake nekaj let. Zdaj pa naj bi proizvajalec kar naenkrat vsak mesec ali dva izdajal in prilagajal driverje ker Microsoft pokvari API ali kaj drugega.
- spremenil: LeQuack ()
xmetallic ::
- spremenilo: xmetallic ()
Nikonja ::
Fak ali ste nesposobni ali imate neki drek od računalnikov, ker jaz dobesedno enega edinega problema nisem imel od prvega dneva vporabe win 10. Vse dela kot urca, dobesedno 0 problemov (vsaj ne zaradi windowsov). Sej ste imeli cel kup dreka od dodatnih aplikacij tudi v 7ki ampak tamo vas to ni motilo. Kupite si Mac-a ali instalirajte Linux in nehajte nekontrolirano nakladat kaj vam ni všeč, najbolj tragično je da ste enako srali o win 7 ko ste leteli iz win xp.
Fak ali ste nesposobni ali imate neki drek od računalnikov, ker jaz dobesedno enega edinega problema nisem imel od prvega dneva vporabe win 10. Vse dela kot urca, dobesedno 0 problemov (vsaj ne zaradi windowsov). Sej ste imeli cel kup dreka od dodatnih aplikacij tudi v 7ki ampak tamo vas to ni motilo. Kupite si Mac-a ali instalirajte Linux in nehajte nekontrolirano nakladat kaj vam ni všeč, najbolj tragično je da ste enako srali o win 7 ko ste leteli iz win xp.jaz se strinjam. tud sam mam win10 in mi vse dela. sem pa par krat dobil blue screen, a to je bilo vse.
Malajlo ::
Pa še res ... 95 je bil zakon, ko je 98 prišla. XP so bili jajca napram 98 SE. Itak pa isto kot 2000. Ker 2000 je pa bil sistem, to pa. Vista ... (tri leta sem jo uporabljal bp) Potem pa sedmica, ki marsikaterega xp sp3 ni zamenjala (ker z sp3 so pa končno poštimal ves drek). In here we go again ...
Desetko uporabljam že od štarta, še po telefonih jo imam, pa bogami je to najbolj zanesljiv sistem iz Redmonda. Ok, takoj za XP sp3, itak.
Za vas ki imate gor samo tiste 3 igre in browser je itak vseeno a ni?jaz mam gor tudi stuff kot wireshark, fiddler, tunnelbear... pa še kaj bi se našlo.
Top kek of the day.
|HP EliteBook|R5 6650U|
jest10 ::
» | Microsoft OneDriveOddelek: Operacijski sistemi | 2448 (641) | gwtlwesncw |
» | Windows 10 z reklamami tudi v Raziskovalcu (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 36899 (30463) | D3m |
» | Microsoft ne bo več ponujal neomejenega oblačnega prostora naročnikom na Office 365 (strani: 1 2 )Oddelek: Novice / Windows Mobile | 27042 (21511) | Lonsarg |
» | Izšel Office 2016 (strani: 1 2 )Oddelek: Novice / Pisarniški paketi | 28294 (24447) | s1m0n |
» | Windows 10 je tu! (strani: 1 2 3 4 5 6 )Oddelek: Novice / Operacijski sistemi | 102668 (81451) | MrStein |
