X-Bit Labs - Pri X-bit labs so pred dvema dnevoma pod prste vzeli kar pet Samsungovih najnovejših SyncMaster ( 172X, 173VT, 510MP, 710MP in 173MP) zaslonov, ki so se ali šele prikazali na policah ali pa so jih šele predstavili, jih preizkusili in spisali dvanajst stranski članek. Verjetno največje presenečenje je model 172X, saj se ponaša z odzivnim časom komaj 12ms.
Skrajni čas, da posodobim moje računalniško namizje in postavim nanj dva nova srebrna lepotca...
Novice » Zasloni / projektorji / ... » Pregled in ocenitev petih Samsungovih LCD monitorjev
ragnarock ::
hmmm...
173VT se mi zdi boljša naložba
Quite contrary to the manufacturer’s claims at the company website, this monitor is unsuitable for dynamic computer games as it uses a PVA matrix. If you are into 3D shooters such as Counter Strike or Unreal Tournament, you will hardly like this monitor: the image will become blurred at sudden movements, and if the action goes on indoors, with low contrast, the blur will become simply unacceptable. Keeping this in mind I can conclude that SyncMaster 172X with its PVA matrix becomes a perfect choice for working with text, images, drawings, especially now that 17” LCD monitors on MVA and IPS matrixes have nearly left the market. Excellent viewing angles and contrast ratio, good color reproduction and response time on “black-to-white” transitions are the key advantages of the PVA matrix over TN+Film matrixes in the above-enumerated tasks. And those features are packed into the beautiful case of SyncMaster 172X here.
» | Prvi USB monitor - Samsung 940UXOddelek: Novice / Grafične kartice | 4342 (3085) | Bass0 |
» | scanerjiOddelek: Kaj kupiti | 1715 (1603) | AtaStrumf |
» | Samsung SyncMaster LCD 214T 21"Oddelek: Kaj kupiti | 2003 (1560) | raceboy |
» | X-bit labs popeljal na test 4 najnovejše procesorske hladilnike!Oddelek: Novice / Procesorji | 2673 (2196) | damjanster |
» | 17" LCD monitorji pod drobnogledomOddelek: Novice / Zasloni / projektorji / ... | 3719 (3719) | antonija |
