Forum » Navijanje » Slo-Tech Team: GPUPI 1B&32B
fr4nc ::
Pa da vidimo...
Download link: klik
Nastavitve:
Select digits of pi to be calculated: 1B HWBOT both ali 32B HWBOT both
Obkljukate: OpenCL GPU devices
Batch Size: 20M
Reduction Size: 64
Primer:
NUJNO: "Formula"
vzdevek | grafična (frekvenca jedra/frekvenca spomina/hlajenje/driver) | procesor (frekvenca/hlajenje) | količina_rama@frekvenca, latenca | rezultat
rezultat je potrebno objaviti v sekundah, z decimalnim delom. Torej če recimo dobite rezultat 12m 4s 234ms, ga pretvorite v sekunde, da dobi obliko 724.234
Za potrditev še seveda screenshot zaslona z CPU-Z (CPU, Mainboard, Memory) in GPU-Z.
Lestvica
1B HWBOT both:
1. nvlf4sh | 2x Titan X 12GB(stock/355.98) | INTEL i7 4790K (4.7GHz/NZXT Kraken X41) | 8GB@2666MHz, 11-13-13-35 | 11.132 | link
2. Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 26.502 | link
3. dj_uro | gtx 970 G1 gaming (stock/stock/stock/355.98) | I7 4790K (4.00GHz/Noctua NH-D14) | 16GB@1600MHz, 10-10-10-27 | 40.742 | link
4. Fr4nc | AMD HD 7950 (1320/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 42.606 | link
5. MacGyver141 | NVIDIA GTX 650 Ti BOSST (1097.4/1502/stock/355.98) | INTEL i5 6600K (4.2GHz/Scythe Ninja 4) | 16GB@2133MHz, 15-15-15-36 | 195.263 | link
32B HWBOT both:
1. Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 1682.53 | link
2. Fr4nc | AMD HD 7950 (1200/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 2764.62 | link
Download link: klik
Nastavitve:
Batch Size: 20M
Reduction Size: 64
Primer:
NUJNO: "Formula"
Lestvica
1B HWBOT both:
32B HWBOT both:
- spremenil: galu ()
Jst ::
Doesn't work on my laptop. High Precision Event Timer Not Found. Ker mi vse lepo dela, in je to prenosnik, na kateremu služim kruh, se ne mislim zafrkavati s tem.
Drugače pa tale Iris Pro sploh ni švoh.
fr4nc ::
1B HWBOT both
Fr4nc | AMD HD 7950 (1320/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 42s 606ms
32B HWBOT both
Fr4nc | AMD HD 7950 (1200/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 46m 04s 616ms
32B HWBOT both
MacGyver141 ::
fr4nc ::
MacGyver141 je izjavil:
Sej CPU-Z zgleda narobe kaže. AIDA64 napiše 1.284V.
Verjetno bo potreben update s strani CPU-Z...
Drugače pa a res nima noben vsaj 5min časa za 1B HWBOT both test?
MacGyver141 ::
Tole treba naredit, pa dela.
Pol pa, ko nehate uporabljati tale benchmark pa raje napište nazaj v cmd: bcdedit /set useplatformclock no
Men se je čudno obnašal vse skupaj, ko sem imel ta platforem clock vključen.
Error: High Precision Event Timer for time measurement not found!
GPUPI needs a timer with a very high resolution to ensure that the time measurement for a benchmark run is precise. Therefor you need to have the High Precision Event Timer (HPET) enabled in your BIOS settings and your system settings. To check the status of the latter, open up a command prompt with administration rights and run:
SHELL:
bcdedit /enum
The value of useplatformclock should be "Yes". If it's not, you can fix this by running:
SHELL:
bcdedit /set useplatformclock yes
A reboot might be necessary afterwards.
nvfl4sh ::
nvlf4sh | 2x Titan X 12GB(stock/355.98) | INTEL i7 4790K (4.7GHz/NZXT Kraken X41) | 8GB@2666MHz, 11-13-13-35 | 11s 132ms
1BHWBOT both
1BHWBOT both
- spremenil: nvfl4sh ()
Bleeh ::
1BHWBOT both
Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 26s 502ms
32B HWBOT both
Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 28min 2s 529ms
32B HWBOT both
- spremenil: Bleeh ()
fr4nc ::
1BHWBOT both
Drugače pa a lahko požeš še test z samo eno kartico, da bo čim več rezultatov na bodoči lestvici?
fr4nc ::
Prva popolna lestvica...presenečen sem nad odzivom, sploh glede na to, da recimo 1B HWBOT both vzame manj kot 5min vašega časa...
1B HWBOT both
1. Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 26s 502ms
2. Fr4nc | AMD HD 7950 (1320/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 42s 606ms
3. MacGyver141 | NVIDIA GTX 650 Ti BOSST (1097.4/1502/stock/355.98) | INTEL i5 6600K (4.2GHz/Scythe Ninja 4) | 16GB@2133MHz, 15-15-15-36 | 3m 15s 263ms
32B HWBOT both
1. Bleeh | AMD Radeon R290 (stock/stock/stock/15.7.1) | Intel i7 4770k(3.9GHZ[stock]/Thermalright Macho rev. A) | 8GB@2133MHz, 11-11-11-30 | 28min 2s 529ms
2. Fr4nc | AMD HD 7950 (1200/1500/stock/15.7.1) | AMD FX-8320 (3.7GHz(stock)/Mugen 3 Rev. B) | 8GB@1926MHz, 9-9-9-27 | 46m 04s 616ms
1B HWBOT both
32B HWBOT both
krneki0001 ::
This is mandatory for Windows 8 and higher to avoid skewed timing.
You'll find a guide on how to enable the HPET timer on your system
in our FAQ. Open about dialog in the menu above for the link.
fr4nc ::
krneki0001 je izjavil:
Verjetno to reši težavo...sam sicer nisem imel tega problema.
https://slo-tech.com/forum/t654491/p491...
krneki0001 ::
Nisem še, cudo za mojo kartico moram še inštalirat, pa čakam, da pride še dodatek za Visual Studio 2015.
- spremenilo: krneki0001 ()
dj_uro ::
dj_uro | gtx 970 G1 gaming (stock/stock/stock/355.98) | I7 4790K (4.00GHz/Noctua NH-D14) | 16GB@1600MHz, 10-10-10-27 | rezultat (40s 742ms)
vw-klub.si
galu ::
Sprememba formata oddaje:
To pa zato, da bo lažje updejtati lestvico.
Tako to gre.
» | Slo-Tech 3D Team: 3DMark (2016) Time Spy (strani: 1 2 3 )Oddelek: Navijanje | 89030 (44974) | opticom1 |
» | Unigine Heaven 4.0 (strani: 1 2 3 )Oddelek: Navijanje | 41155 (26561) | barocco |
