Forum » Navijanje » Slo-Tech 3D Team: 3DMark (2016) Time Spy
Blue3D ::
Blue3D | Intel i5 6600k (4.4GHz/h2o) | GTX 1070 (stock/zrak) | 2x 4GB DDR4 | nimampojma | 5717
http://www.3dmark.com/3dm/17363406
Tested on Quakers
I5 13600K 6800XT
I5 13600K 6800XT
- spremenil: Blue3D ()
m0LN4r ::
m0LN4r | Intel i7 3820 (Stock/voda) | GTX 690 (stock/blower) | 4x 4GB DDR4 | nimampojma | 3498
http://www.3dmark.com/3dm/17565302
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
Hydros ::
Hydros|Xeon E3-1230v5(@4.5/zrak)|Palit Gamerock 1070(+75 core/+600 memory)|HyperX Fury 2X8 DDR4 CL15-15-15-38 @2294 MHz|6253
http://www.3dmark.com/3dm/17683344
OmegaM ::
Ok, danes sem dobil za darilo dejansko KFA2 Gtx1080exoc in to sem zbasal v mašino z naslednjo konfiguracijo.
In ne, nikakor se ne norčujem
OmegaM | Amd A10-5800k (3,8Ghz/zračno) | KFA2 Gtx1080 exoc 1658(boost - 1797)/1251 | Crucial 2x4GB DDR3 1866Mhz, 9-9-9-27 | 4356
Graphics score: 7129
3Dmark link: http://www.3dmark.com/3dm/17718216
Ni nam lahko, bo pa boljše!!!
Hydros ::
Hydros ::
voltage +100% in power +114% več ne gre
mogoče kak custom bios nasnamem ki dovoli večji power limit
m0LN4r ::
m0LN4r | Intel Pentium G4560 (stock/zrak) | Powercolor RX 460 4GB (stock) | 1x8GB DDR4 2400MHz | 1846
http://www.3dmark.com/3dm/17881935
OmegaM ::
OmegaM | Intel Core i5-6500 (3,2Ghz/zračno) | KFA2 Gtx1080 exoc 1658(boost - 1797)/1251 (zrak) | Kingston HyperX 2x4GB DDR3 1600Mhz, 9-10-9-32 | 6122
Graphics score: 7199
- spremenilo: OmegaM ()
OmegaM ::
Še primerjava z 1866Mhz DDR3 pomnilnikom.
OmegaM | Intel Core i5-6500 (3,2Ghz/zračno) | KFA2 Gtx1080 exoc 1658(boost - 1797)/1251 (zrak) | Crucial 2x4GB DDR3 1866Mhz, 9-9-9-27 | 6163
m0LN4r ::
Kako se kaj obnesejo vase Radeonke in Rebrandeonke?
Kmalu pa se Vega
Kmalu pa se Vega
m0LN4r ::
m0LN4r | Intel Core i7-6800 (Stock/Zrak) | VTX3D R9 290 (Stock/Zrak) | Corsair 4x8GB DDR4@2133 | 3895
http://www.3dmark.com/3dm/19693652
m0LN4r ::
Menjal modrozeleno za rdece,rdece,rdece:
m0LN4r | AMD R5 1600X (Stock/Zrak) | Powercolor RX 480 8GB (Stock/Zrak) | Corsair 2x8GB DDR4@2133 | 4167
http://www.3dmark.com/3dm/19891162
- spremenil: m0LN4r ()
m0LN4r ::
Graphics score in CPU score zgornjega sistema vs. https://slo-tech.com/forum/t661258/p529...
Ca. 27/22fps vs. 29/25fps in 19 vs 13
m0LN4r ::
m0LN4r | Intel Core i5-4570 (Stock/Zrak) | Sapphire Nitro RX 470 8GB (Stock/Zrak) | Corsair 2x4GB DDR3@1333 | 3691
http://www.3dmark.com/3dm/20155623
dolenc ::
dolenc | Intel i3 4160 (3.6GHz/vodno) | rx 480/580 1460mhz/2150mhz(vodno) referenčna | crucial 2x4GB DDR3 1600 MHz, 7-8-8-24 | 3984
http://www.3dmark.com/3dm/20482704
m0LN4r ::
m0LN4r | Intel Core i7-4930 (Stock/Zrak) | Palit GTX 1080Ti Gamerock 1573/1506 | 4x4GB DDR3 1866 | 9420
https://www.3dmark.com/3dm/23472748?
m0LN4r ::
m0LN4r | Intel Core i7-4930 (Stock/Zrak) | Sapphire Pulse RX 580 4GB (Stock) | 4x4GB DDR3 1866 | 4418
https://www.3dmark.com/3dm/24144806?
m0LN4r ::
Mali upgrejd:
m0LN4r | Intel Core i7-8700 (Stock/Zrak) | Gigabyte GTX 2080Ti | 2x8GB DDR4 2666 | 12591
https://www.3dmark.com/3dm/30020692?
Hitr comparison:
1080Ti
67.47 - GPU T1
61.46 - GPU T2
2080Ti
91.94 - GPU T1
82.99 - GPU T2
ferjuc ::
m0LN4r, kater model točno od gigabyte imaš? Koliko jo lahko naviješ?
Jaz imam rezultat malo čez 14600 z navito kartico in 8700k na 5100mhz vsa jedra
m0LN4r ::
Tisto najbl poceni, navija se za en drek. Hlajenje je tko slabo, da kartica laufa vecinoma na 78C in pade pod 1900hmz
ferjuc ::
Itak, standard pri gigabyte-u :) sem imel veliko njihovih kartic in nobena ni blestela v tišini in hlajenju nasloh. Recimo, da je edina ok aorus serija, ostalo je pa en bog pomagi :)
dolenc ::
Da si mal popravem rezultat :)
dolenc | Intel i5 4690 (3.5GHz/vodno) | rx 480/580 1470mhz/2120mhz(vodno) referenčna | crucial 2x4GB DDR3 1600 MHz, 7-8-8-24 | 4497
Graphics score: 4821
https://www.3dmark.com/3dm/33631514
opticom1 ::
opticom1 | Intel i9 9900k (5.1/vodno) | asus rtx2080 ti strix core +170mhz/ram +1200 mhz(vodno) | gskill 2x8GB DDR4 3300 MHz, 15-16-16-32 | 15173
https://imgur.com/a/fZMWi8Y
» | Slo-Tech 3D Team: 3D Mark Vantage (strani: 1 2 )Oddelek: Navijanje | 33714 (26590) | vaščan |
» | FX-8320 & 7850 - record! (strani: 1 2 )Oddelek: Navijanje | 43469 (39236) | fr4nc |
