Forum » Igre » XCOM 2
XCOM 2
Xserces ::
meni super špil ampak upam da bojo bolj dinamične mape... proti koncu mi je postalo že malo dolgčas.
Dvomim da bo PC ekskluziva, ampak očitno so ugotovili da ta žanr na konzolah ni tako popularen in se raje primarno fokusirajo na PC šele nato pa na konzole.
ahac ::
Menda za konzole ne bo, ker se je XCOM tam res slabo prodajal.
Dami ::
Upam na konkretn upgrade. Da ne bojo sam nove mape in orožja (like ufo->terror from the deep, čeprav je bil slednji vseeno hud )
Izi ::
Kurzweil ::
Iskreno upam, da bodo misije zajebane čim bolj, da bo glasba morbidna in ambient turoben. Vse drugo zame ne XCOM. Glede na to, da je zaenkrat govora samo o PCju sem kar optimističen, ker vse kar se prilagaja na konzole je v veliki večini premerov debilno, prelahko, prilagojeno otrokom, itn.
Osebno upam da research ne bo tako linearen in preprost kot je bil v enki, ter da combat naredijo malo bolj kompleksen.
Xenonauts se dobi brezplačno na GOG.com, če opravite 50 dolarjev nakupa v sklopu GOG Summer Sale.
ahac ::
XCOM 2 NOW COMING TO PC WORLDWIDE ON FEBRUARY 5, 2016
Hello XCOM fans,
We want to give you an update on the release date for XCOM 2. We've set a high bar for the sequel and the entire team has been working hard to make sure we deliver a great follow-up to Enemy Unknown. We just need a little more time to make it the best possible game.
With XCOM 2, we want to have more depth, more replayability, and more investment in your soldiers and this extension will give us the time we need to deliver on our promise to you.
We appreciate your patience and continued support as we move towards February. Good luck, Commander!
-The XCOM 2 Dev Team
ahac ::
"You can have a monocle!"
- spremenil: ahac ()
ahac ::
Opisi so objavljeni.
http://opencritic.com/game/1776/xcom-2
Trenutno Opencritic average: 91/100
https://www.rockpapershotgun.com/2016/0...
http://www.escapistmagazine.com/article... 4.5/5
http://www.pcgamer.com/xcom-2-review/ 94/100
Odlične ocene
Potem pa moram čim prej preigrati prvi del sem ga kupil na zimski razprodaji :)
m0f0x ::
Humble Bundle še ima ca. 7 ur akcijo, če kdo hoče kupit 1. del cheap.
https://www.humblebundle.com/
Lahko pa jaz komu giftam za kak CS:GO skin.
- spremenil: m0f0x ()
Pesimist ::
Kaj v treh dneh izide ze to. Kak te naj v treh dneh obrnem 1ko? Sem mislo da imam vec casa.
Dajte nalimajte kje so kaj cheap CDkey za Steam te.....
http://www.cdkeys.com/pc/games/xcom-2-p...
33€ good deal? Hitro....
ali se splaca reinforcment pack za 47€?
- spremenilo: Pesimist ()
MIHAc27 ::
......ja boš pa čez 4 ali 5 dni začel igrat dvojko, če ti v treh dneh ne uspe enke obrnit. Saj enke ne bodo ukinili z prihodom novejše igre, da bi se tako mudilo.
Ahiles ::
Za tiste k ste že obrnil in bi se radi mal igral z Špilom lista Console komand ni 100% done in niso vse stestirane da delajo ker je pobran z forumov in združen v 1 file.
https://docs.google.com/spreadsheets/d/...
Red_Mamba ::
bom pocakal na popust na steam pol pa nabavim
prejsnji me je razocaral, bil prelahek in prekratek...
[st.slika https://img.shields.io/badge/Slo-Tech-green.svg test]
Linkedin >> http://goo.gl/839Aua
Mamba's Crypto & ICO's: https://t.me/joinchat/AAAAAExTkO4P4UDy0fIZdg
ahac ::
Tole si poglej:
http://www.nexusmods.com/xcom/mods/88/
Pesimist ::
se do danes nisem niti pognal gejma a kupo kot preorder :D
Nocem rpej zacet kot 1ko koncat in tisto se nisem, menda neki na polovici pustil.
Ta psil je res razocarjanje, k da bi dali to delat kupu nesposobnih zacetnikov. Edina potezna strategija, k je celo ok, je civilzation 6.
Unilseptij ::
Evo, ravno kupil po polovični ceni na Steam-u za 20EUR (osnovno igro, ne War of the Chosen). Sem obrnil tudi enko, tako da po prvih primerjavah dvojka ni slaba, čeprav sem vseeno malce razočaran. Ampak sem šele začel igrati tako da bom še malo počakal s prehudo kritiko. Načeloma je zgodba OK in logično sledi enki.... Najbolj me zaenkrat moti, da teče preveč linearno in zgleda bolj kot risanka, kjer občasno klikneš "Next". Taktični del (boj z alieni) tudi izgleda povsem identično enki, razen kozmetičnih popravkov. Bom videl, kako se bo razvila igra, vsekakor ni zanič, ni pa tudi prav dosti več od enke. Na prvi pogled se mi zdi taktični del težji... kar po pravilu ti potolčejo polovico ekipa v večini misij. Tako vojaki težje naberejo izkušnje in napredujejo. Morda se moram še malo navaditi....
- spremenilo: Unilseptij ()
ahac ::
War of the Chosen je res skoraj kot nova igra, tolk stvari so dodal.
Čisto nove misije (stealth misije, zombiji, itd), novi alieni, nov research, novi tipi vojakov, ki se igrajo drugače (od teh resistance factions), ...
Do zdej se mi še ni zgodilo, da bi imel enako misijo kot v vanilla igri.
Ghost007 ::
TO pomeni da se spalca prvo obrniti orginal, potem pa dodatek? Mogoce raje kake pol leta kasneje?
ahac ::
Ja, po moje ni neumno najprej original in kasneje še z expansionom.
Zdi se mi, da je v expansionu preveč stvari za nekoga, ki pred tem ni igral igre. Prvih nekaj misij so me kar zasuval z informacijami in raznimi dogodki npr: srečal smo nek nov resistance faction in moramo tja, srečal smo te "chosen" aliene, treba je poslat ljudi na covert mission, treba je rešit enega od naših, treba je rešit civiliste, morajo zgradit to zgrabo in še drugo zgradbo pa za seveda rabiš power, rabiš scientiste, itd. Vsaj takoj na začetku je kar malo preveč vsega.
» | Manj znane igre (strani: 1 2 3 4 )Oddelek: Igre | 31036 (3776) | D3m |
» | XCOM Enemy Unknown (strani: 1 2 )Oddelek: Igre | 9194 (1881) | FireSnake |
» | Command & Conquer se vrača na začetek (strani: 1 2 )Oddelek: Novice / Igre | 14288 (6864) | -valvoline- |
» | Vaših 5 igr vseh časov (strani: 1 2 3 4 5 )Oddelek: Igre | 37859 (23575) | Sc0ut |
» | Stare igre na XPjihOddelek: Igre | 1208 (1089) | karafeka |
