Forum » Programiranje » [android] vstavljanje slike
messi ::
Hočem vstaviti sliko vendar mi zadeve ne deluje in sicer me zanima ali moram kaj dodati v xml, če hočem da mi dela, vendar jaz nalagam ta imige v drawview,..ali pa je nekaj narobe v tej kodi..
package com.example.pii; public class Draw extends Activity { private static final String TAG = "FingerPaint"; //a variable to store the system brightness private int brightness; //the content resolver used as a handle to the system's settings private ContentResolver cResolver; //a window object, that will store a reference to the current window private Window window; /** Menu ID for the command to clear the window. */ private static final int CLEAR_ID = Menu.FIRST; /** Menu ID for the command to toggle fading. */ private static final int SAMPLES_ID = Menu.FIRST+1; /** Menu ID for about **/ private static final int ABOUT_ID = Menu.FIRST+2; private static final int INSERT_ID = Menu.FIRST+3; /** The view responsible for drawing the window. */ TesterView mView; @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); // Set full screen view this.requestWindowFeature(Window.FEATURE_NO_TITLE); this.getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN); setRequestedOrientation(getResources().getConfiguration().orientation); // Create and attach the view that is responsible for painting. mView = new TesterView(this, null, 0); setContentView( R.layout.activity_main); mView =(TesterView) findViewById (R.id.DrawView); // mView=(mView) findViewById (R.id.DrawView); // mView = new findViewById(mView); mView.requestFocus(); } @Override public boolean onCreateOptionsMenu(Menu menu) { menu.add(0, CLEAR_ID, 0, "Clear"); menu.add(0, SAMPLES_ID, 0, "Samples").setCheckable(true); menu.add(0, ABOUT_ID, 0, "Version "+this.getString(R.string.app_name)); menu.add(0, INSERT_ID, 0, "Insert"); return super.onCreateOptionsMenu(menu); } @Override public boolean onPrepareOptionsMenu(Menu menu) { // menu.findItem(SAMPLES_ID).setChecked(mSamples); return super.onPrepareOptionsMenu(menu); } @Override public boolean onOptionsItemSelected(MenuItem item) { switch (item.getItemId()) { case CLEAR_ID: mView.clear(); return true; case SAMPLES_ID: mView.bShowSamples = !mView.bShowSamples; return true; case ABOUT_ID: return true; case INSERT_ID: setCustomBackground(mView); return true; default: return super.onOptionsItemSelected(item); } } void setCustomBackground(TesterView v) { Intent fileChooserIntent = new Intent(); fileChooserIntent.addCategory(Intent.CATEGORY_OPENABLE); fileChooserIntent.setType("image/*"); fileChooserIntent.setAction(Intent.ACTION_GET_CONTENT); startActivityForResult(Intent.createChooser(fileChooserIntent, "Select Picture"), 1); /* // menu option for setting a custom background String Url = "http://www.google.ca"; // http://www.google.ca Intent fileChooserIntent = new Intent(Intent.ACTION_CHOOSER, Uri.parse(Url)); this.startActivity(fileChooserIntent); */ } @Override protected void onActivityResult(int requestCode, int resultCode, Intent data) { // if statement prevents force close error when picture isn't selected if (resultCode == RESULT_OK) { Uri resultUri = data.getData(); //String resultString = data.getData().toString(); String drawString = resultUri.getPath(); String galleryString = getGalleryPath(resultUri); // if Gallery app was used if (galleryString != null) { Log.d(TAG, galleryString); drawString = galleryString; } // else another file manager was used else { Log.d(TAG, drawString); //File Manager: "content://org.openintents.cmfilemanager/mimetype//mnt/sdcard/DCIM/Camera/IMG_20110909_210412.jpg" //ASTRO: "file:///mnt/sdcard/DCIM/Camera/IMG_20110924_133324.jpg" if (drawString.contains("//")) { drawString = drawString.substring(drawString.lastIndexOf("//")); } } // set the background to the selected picture if (drawString.length() > 0) { Drawable drawBackground = Drawable.createFromPath(drawString); mView.setBackgroundDrawable(drawBackground); } } } // used when trying to get an image path from the URI returned by the Gallery app public String getGalleryPath(Uri uri) { String[] projection = { MediaStore.Images.Media.DATA }; Cursor cursor = managedQuery(uri, projection, null, null, null); if (cursor != null) { int column_index = cursor.getColumnIndexOrThrow(MediaStore.Images.Media.DATA); cursor.moveToFirst(); return cursor.getString(column_index); } return null; } @Override protected void onResume() { super.onResume(); // If fading mode is enabled, then as long as we are resumed we want // to run pulse to fade the contents. } @Override protected void onSaveInstanceState(Bundle outState) { super.onSaveInstanceState(outState); // Save away the fading state to restore if needed later. Note that // we do not currently save the contents of the display. } @Override protected void onPause() { super.onPause(); // Make sure to never run the fading pulse while we are paused or // stopped. } private Handler mHandler = new Handler() { @Override public void handleMessage(Message msg) { switch (msg.what) { // Upon receiving the fade pulse, we have the view perform a // fade and then enqueue a new message to pulse at the desired // next time. default: super.handleMessage(msg); } } }; }
package nt.finger.paint; import java.io.File; import java.io.FilenameFilter; import android.app.Activity; import android.app.AlertDialog; import android.app.AlertDialog.Builder; import android.app.Dialog; import android.content.DialogInterface; import android.graphics.Color; import android.os.Bundle; import android.os.Environment; import android.util.Log; import android.view.Window; import android.view.WindowManager; public class FileChooser extends Activity { private static final String TAG = "FileChooser"; private String[] mFileList; private File mPath = new File(Environment.getExternalStorageDirectory() + "//yourdir//"); private String mChosenFile; private static final String JPG = ".jpg"; private static final String JPEG = ".jpeg"; private static final String PNG = ".png"; private static final int DIALOG_LOAD_FILE = 1000; @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); // Set full screen view getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN); requestWindowFeature(Window.FEATURE_NO_TITLE); loadFileList(); } private void loadFileList() { try { mPath.mkdirs(); } catch(SecurityException e) { Log.e(TAG, "unable to write on the SD card " + e.toString()); } if (mPath.exists()) { FilenameFilter filter = new FilenameFilter() { public boolean accept(File dir, String filename) { File sel = new File(dir, filename); return filename.contains(JPG) || filename.contains(JPEG) || filename.contains(PNG) || sel.isDirectory(); } }; mFileList = mPath.list(filter); } else { mFileList = new String[0]; } } protected Dialog onCreateDialog(int id) { Dialog dialog = null; AlertDialog.Builder builder = new Builder(this); switch (id) { case DIALOG_LOAD_FILE : builder.setTitle("Choose your background"); if (mFileList == null) { Log.e(TAG, "Showing file chooser before loading the file list"); dialog = builder.create(); return dialog; } builder.setItems(mFileList, new DialogInterface.OnClickListener(){ public void onClick(DialogInterface dialog, int which){ mChosenFile = mFileList[which]; // do other shit with file } }); break; } dialog = builder.show(); return dialog; } }
dolenc ::
Sem odpru obe temi in v napačni odgovoril, se nanaša na vprašanje v tisti temi kako porinit slikco v emulator...
Lahko preko ADBja, Push
- spremenil: dolenc ()
messi ::
Ma kdo idejo zakaj se mi sesuva zadeva...
09-05 18:39:19.958: W/dalvikvm(870): threadid=1: thread exiting with uncaught exception (group=0x40a13300)
09-05 18:39:20.068: E/AndroidRuntime(870): FATAL EXCEPTION: main
09-05 18:39:20.068: E/AndroidRuntime(870): java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{com.example.pi1_2/com.example.pi1_2.MainActivity}: java.lang.ClassNotFoundException: com.example.pi1_2.MainActivity
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1983)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2084)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread.access$600(ActivityThread.java:130)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1195)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.os.Handler.dispatchMessage(Handler.java:99)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.os.Looper.loop(Looper.java:137)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread.main(ActivityThread.java:4745)
09-05 18:39:20.068: E/AndroidRuntime(870): at java.lang.reflect.Method.invokeNative(Native Method)
09-05 18:39:20.068: E/AndroidRuntime(870): at java.lang.reflect.Method.invoke(Method.java:511)
09-05 18:39:20.068: E/AndroidRuntime(870): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
09-05 18:39:20.068: E/AndroidRuntime(870): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
09-05 18:39:20.068: E/AndroidRuntime(870): at dalvik.system.NativeStart.main(Native Method)
09-05 18:39:20.068: E/AndroidRuntime(870): Caused by: java.lang.ClassNotFoundException: com.example.pi1_2.MainActivity
09-05 18:39:20.068: E/AndroidRuntime(870): at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:61)
09-05 18:39:20.068: E/AndroidRuntime(870): at java.lang.ClassLoader.loadClass(ClassLoader.java:501)
09-05 18:39:20.068: E/AndroidRuntime(870): at java.lang.ClassLoader.loadClass(ClassLoader.java:461)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.Instrumentation.newActivity(Instrumentation.java:1053)
09-05 18:39:20.068: E/AndroidRuntime(870): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1974)
09-05 18:39:20.068: E/AndroidRuntime(870): ... 11 more
messi ::
ali prilimam kodo samo je izjemno dolga 600 vrstic, mogoče je bolje če mi nekdo razloži, ali pa pove kako naj te napake berem..
messi ::
Smo popravl prejšne crashe ima kdo kako idejo kaka napaka je v vzgornjem isertingu slike. Če ma kdo kako idejo mi naj prosim prosim pomaga..
Mavrik ::
Premalo stacktracea si prilepil. Lepo se pomikaj navzdol in gledaj kaki exceptioni so se ti vrgli po vrsti.
messi ::
Nobeni le insertat sliko mi ne more, po tisti kodi..Testiram pa na realnem sistemu ker na drugi ne morem..
messi ::
Zanima me kako se reče zadevi da bi naredil nekako takole:
Gumbe v orodni vrstici pa nebi bili gumbi vendar slikice primer je pain ..
https://play.google.com/store/apps/deta...
Takole kot prikazujejo spodnji gumbi, kako bi dodal tole, ne zanima me koda ampak kako se temu reče. Hvala lepa..
» | [android] java.lang.RuntimeExceptionOddelek: Programiranje | 1020 (712) | piki12 |
» | Programiranje problem androidOddelek: Programiranje | 1105 (870) | g333kk |
» | [Android] Aplikacija se zrušiOddelek: Programiranje | 751 (588) | g333kk |
» | android črtaOddelek: Programiranje | 2291 (1562) | g333kk |
» | [android] crashOddelek: Programiranje | 1274 (1083) | messi |
