Forum » Programiranje » [android] crash
[android] crash
messi ::
Mi prosim lahko kdo razloži tile napake, zakaj se mi aplikacija crasha, sicer se opravičujem ker je koda tako dolga ampak ne morem pomagat.. Hvala.
09-04 11:44:43.798: D/AndroidRuntime(2235): Shutting down VM
09-04 11:44:43.798: W/dalvikvm(2235): threadid=1: thread exiting with uncaught exception (group=0x40a13300)
09-04 11:44:45.248: E/AndroidRuntime(2235): FATAL EXCEPTION: main
09-04 11:44:45.248: E/AndroidRuntime(2235): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.pii/com.example.pii.Draw}: android.util.AndroidRuntimeException: requestFeature() must be called before adding content
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2059)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2084)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread.access$600(ActivityThread.java:130)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1195)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.os.Handler.dispatchMessage(Handler.java:99)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.os.Looper.loop(Looper.java:137)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread.main(ActivityThread.java:4745)
09-04 11:44:45.248: E/AndroidRuntime(2235): at java.lang.reflect.Method.invokeNative(Native Method)
09-04 11:44:45.248: E/AndroidRuntime(2235): at java.lang.reflect.Method.invoke(Method.java:511)
09-04 11:44:45.248: E/AndroidRuntime(2235): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
09-04 11:44:45.248: E/AndroidRuntime(2235): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
09-04 11:44:45.248: E/AndroidRuntime(2235): at dalvik.system.NativeStart.main(Native Method)
09-04 11:44:45.248: E/AndroidRuntime(2235): Caused by: android.util.AndroidRuntimeException: requestFeature() must be called before adding content
09-04 11:44:45.248: E/AndroidRuntime(2235): at com.android.internal.policy.impl.PhoneWindow.requestFeature(PhoneWindow.java:215)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.Activity.requestWindowFeature(Activity.java:3225)
09-04 11:44:45.248: E/AndroidRuntime(2235): at com.example.pii.Draw.onCreate(Draw.java:71)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.Activity.performCreate(Activity.java:5008)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1079)
09-04 11:44:45.248: E/AndroidRuntime(2235): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2023)
09-04 11:44:45.248: E/AndroidRuntime(2235): ... 11 more
Koda aplikacije:
in še clas..
Koda aplikacije:
package com.example.pii; import android.app.Activity; import android.view.WindowManager.LayoutParams; import android.content.ContentResolver; import android.os.Bundle; import android.os.Handler; import android.os.Message; import android.provider.Settings.SettingNotFoundException; import android.provider.Settings.System; import android.util.Log; import android.view.Menu; import android.view.MenuItem; import android.view.View; import android.view.Window; import android.view.WindowManager; import android.widget.Button; import android.widget.SeekBar; import android.widget.SeekBar.OnSeekBarChangeListener; import android.widget.TabHost; import android.widget.TabHost.TabSpec; import android.widget.Toast; public class Draw extends Activity { SeekBar bar; static float discrete=0; float start=0; float end=100; float start_pos=0; int start_position=0; //UI objects// //the seek bar variable private SeekBar brightbar; //a variable to store the system brightness private int brightness; //the content resolver used as a handle to the system's settings private ContentResolver cResolver; //a window object, that will store a reference to the current window private Window window; /** Menu ID for the command to clear the window. */ private static final int CLEAR_ID = Menu.FIRST; /** Menu ID for the command to toggle fading. */ private static final int SAMPLES_ID = Menu.FIRST+1; /** Menu ID for about **/ private static final int ABOUT_ID = Menu.FIRST+2; /** The view responsible for drawing the window. */ TesterView mView; @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); // Set full screen view this.requestWindowFeature(Window.FEATURE_NO_TITLE); this.getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN); // Create and attach the view that is responsible for painting. mView = new TesterView(this, null, 0); setContentView(mView); mView.requestFocus(); getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN, WindowManager.LayoutParams.FLAG_FULLSCREEN); requestWindowFeature(Window.FEATURE_NO_TITLE); TabHost tabHost=(TabHost)findViewById(R.id.tabHost); tabHost.setup(); TabSpec spec1=tabHost.newTabSpec("Tab 1"); spec1.setContent(R.id.tab1); spec1.setIndicator("Tab 1",getResources().getDrawable(R.drawable.set)); TabSpec spec2=tabHost.newTabSpec("Tab 2"); spec2.setIndicator("Tab 2",getResources().getDrawable(R.drawable.set)); spec2.setContent(R.id.tab2); TabSpec spec3=tabHost.newTabSpec("Tab 3"); spec3.setIndicator("Tab 3",getResources().getDrawable(R.drawable.set)); spec3.setContent(R.id.tab3); tabHost.addTab(spec1); tabHost.addTab(spec2); tabHost.addTab(spec3); Button knof; knof=(Button)findViewById(R.id.button1); knof.setOnClickListener(new View.OnClickListener() { @Override public void onClick(View v) { ColorPickerDialog aa; //new ColorPickerDialog(this, this, DROIDS_COLOR_KEY, a.getInt(DROIDS_COLOR_KEY, DROIDS_COLOR_DEFAULT), DROIDS_COLOR_DEFAULT).show(); // ((PreferenceScreen)this.findPreference(SETTINGS_KEY)).getEditor().putInt(key, color).commit(); aa = new ColorPickerDialog(null,null,"",0,0); setContentView(R.layout.io); // aa.requestFocus(); } }); //začetek sekkbara start=0; //you need to give starting value of SeekBar end=10; //you need to give end value of SeekBar start_pos=5; //you need to give starting position value of SeekBar start_position=(int) (((start_pos-start)/(end-start))*10); discrete=start_pos; SeekBar seek=(SeekBar) findViewById(R.id.seekBar1); seek.setProgress(start_position); seek.setOnSeekBarChangeListener(new OnSeekBarChangeListener() { @Override public void onStopTrackingTouch(SeekBar seekBar) { // TODO Auto-generated method stub Toast.makeText(getBaseContext(), "discrete = "+String.valueOf(discrete), Toast.LENGTH_SHORT).show(); } @Override public void onProgressChanged(SeekBar seekBar, int progress,boolean fromUser) { // TODO Auto-generated method stub // To convert it as discrete value float temp=progress; float dis=end-start; discrete=(start+((temp/10)*dis)); } @Override public void onStartTrackingTouch(SeekBar seekBar) { // TODO Auto-generated method stub } }); //konec seek bara za velikost .. // start bright //get the seek bar from main.xml file brightbar = (SeekBar) findViewById(R.id.sb_brightbar); //get the content resolver cResolver = getContentResolver(); //get the current window window = getWindow(); //seek bar settings// //sets the range between 0 and 255 brightbar.setMax(255); //set the seek bar progress to 1 brightbar.setKeyProgressIncrement(1); try { //get the current system brightness brightness = System.getInt(cResolver, System.SCREEN_BRIGHTNESS); } catch (SettingNotFoundException e) { //throw an error case it couldn't be retrieved Log.e("Error", "Cannot access system brightness"); e.printStackTrace(); } //sets the progress of the seek bar based on the system's brightness brightbar.setProgress(brightness); //register OnSeekBarChangeListener, so it can actually change values brightbar.setOnSeekBarChangeListener(new OnSeekBarChangeListener() { @Override public void onStopTrackingTouch(SeekBar seekBar) { //set the system brightness using the brightness variable value System.putInt(cResolver, System.SCREEN_BRIGHTNESS, brightness); //preview brightness changes at this window //get the current window attributes LayoutParams layoutpars = window.getAttributes(); //set the brightness of this window layoutpars.screenBrightness = brightness / (float)255; //apply attribute changes to this window window.setAttributes(layoutpars); } @Override public void onStartTrackingTouch(SeekBar seekBar) { } @Override public void onProgressChanged(SeekBar seekBar, int progress, boolean fromUser) { //sets the minimal brightness level //if seek bar is 20 or any value below if(progress<=20) { //set the brightness to 20 brightness=20; } else //brightness is greater than 20 { //sets brightness variable based on the progress bar brightness = progress; } } }); //zaključek bright super.onCreate(savedInstanceState); }// zaključuje on create public static float getState() { // TODO Auto-generated method stub return discrete; } @Override public boolean onCreateOptionsMenu(Menu menu) { menu.add(0, CLEAR_ID, 0, "Clear"); menu.add(0, SAMPLES_ID, 0, "Samples").setCheckable(true); menu.add(0, ABOUT_ID, 0, "Version "+this.getString(R.string.app_name)); /* idea from http://www.connorgarvey.com/blog/?p=9 */ return super.onCreateOptionsMenu(menu); } @Override public boolean onPrepareOptionsMenu(Menu menu) { // menu.findItem(SAMPLES_ID).setChecked(mSamples); return super.onPrepareOptionsMenu(menu); } @Override public boolean onOptionsItemSelected(MenuItem item) { switch (item.getItemId()) { case CLEAR_ID: mView.clear(); return true; case SAMPLES_ID: mView.bShowSamples = !mView.bShowSamples; return true; case ABOUT_ID: return true; default: return super.onOptionsItemSelected(item); } } @Override protected void onResume() { super.onResume(); // If fading mode is enabled, then as long as we are resumed we want // to run pulse to fade the contents. } @Override protected void onSaveInstanceState(Bundle outState) { super.onSaveInstanceState(outState); // Save away the fading state to restore if needed later. Note that // we do not currently save the contents of the display. } @Override protected void onPause() { super.onPause(); // Make sure to never run the fading pulse while we are paused or // stopped. } private Handler mHandler = new Handler() { @Override public void handleMessage(Message msg) { switch (msg.what) { // Upon receiving the fade pulse, we have the view perform a // fade and then enqueue a new message to pulse at the desired // next time. default: super.handleMessage(msg); } } }; }
in še clas..
package com.example.pii; import java.util.ArrayList; import java.util.List; import android.graphics.Bitmap; import android.graphics.Color; import android.graphics.Rect; import android.content.Context; import android.graphics.Canvas; import android.graphics.Paint; import android.util.AttributeSet; import android.util.Log; import android.view.MotionEvent; import android.view.View; import android.view.View.OnTouchListener; public class TesterView extends View { private static final int MAXFINGERS = 20; // count the toes too! private Bitmap mBitmap; private Canvas mCanvas; private final Rect mRect = new Rect(); private final Paint mPaint; private float mCurX; private float mCurY; private float[] mPrevX = new float[MAXFINGERS]; // previous values of x,y to draw line private float[] mPrevY = new float[MAXFINGERS]; public boolean bShowSamples = true; public TesterView(Context c, AttributeSet attrs, int defStyle) { super(c,attrs,defStyle); setFocusable(true); mPaint = new Paint(); mPaint.setAntiAlias(true); mPaint.setARGB(255, 255, 255, 255); } public TesterView(Context c, AttributeSet attrs) { this(c, attrs, 0); } public TesterView(Context c) { this(c, null, 0); } /* if clear command under App's view Menu is used */ public void clear() { if (mCanvas != null) { mPaint.setARGB(0xff, 255, 255, 255); mCanvas.drawPaint(mPaint); invalidate(); } } @Override protected void onSizeChanged(int w, int h, int oldw, int oldh) { int curW = mBitmap != null ? mBitmap.getWidth() : 0; int curH = mBitmap != null ? mBitmap.getHeight() : 0; if (curW >= w && curH >= h) { return; } if (curW < w) curW = w; if (curH < h) curH = h; Bitmap newBitmap = Bitmap.createBitmap(curW, curH, Bitmap.Config.RGB_565); newBitmap.eraseColor(Color.WHITE); /* screen goes white */ Canvas newCanvas = new Canvas(); newCanvas.setBitmap(newBitmap); if (mBitmap != null) { newCanvas.drawBitmap(mBitmap, 0, 0, null); } mBitmap = newBitmap; mCanvas = newCanvas; /* initialize previous finger locations so we know later they need to be filled for the first time */ for (int finger=0; finger<MAXFINGERS; finger++){ mPrevX[finger]=-1; mPrevY[finger]=-1; } } @Override protected void onDraw(Canvas canvas) { if (mBitmap != null) { canvas.drawBitmap(mBitmap, 0, 0, null); } } @Override public boolean onTouchEvent(MotionEvent event) { int action = event.getActionMasked(); int numPtrs; switch (action) { case MotionEvent.ACTION_DOWN: /* primary pointer */ case MotionEvent.ACTION_POINTER_DOWN: /* any subsequent pointer */ numPtrs = event.getPointerCount(); for (int finger = 0; finger < numPtrs; finger++) { mPrevX[finger] = mPrevY[finger] = -1; } break; case MotionEvent.ACTION_MOVE: /* any number of pointers move */ int N = event.getHistorySize(); numPtrs = event.getPointerCount(); for (int histndx = 0; histndx < N; histndx++) { for (int finger = 0; finger < numPtrs; finger++) { mCurX = event.getHistoricalX(finger, histndx); mCurY = event.getHistoricalY(finger, histndx); drawPoint(mCurX, mCurY, event.getHistoricalPressure(finger, histndx), event.getHistoricalSize(finger, histndx), finger); } } for (int finger = 0; finger < numPtrs; finger++) { mCurX = event.getX(finger); mCurY = event.getY(finger); drawPoint(mCurX, mCurY, event.getPressure(finger), event.getSize(finger),finger); } break; case MotionEvent.ACTION_POINTER_UP: case MotionEvent.ACTION_UP: /* all pointers are up */ case MotionEvent.ACTION_CANCEL: for (int finger=0; finger<MAXFINGERS; finger++){ mPrevX[finger]=-1; mPrevY[finger]=-1; } break; } return true; } private void drawLine(int finger) { mPaint.setARGB(255,0,0,255); /* blue */ mCanvas.drawLine(mPrevX[finger],mPrevY[finger],mCurX,mCurY,mPaint); } private void drawPoint(float x, float y, float pressure, float width, int finger) { //Log.i("TouchPaint", "Drawing: " + x + "x" + y + " p=" // + pressure + " width=" + width); int lowX,lowY,highX,highY; if (mBitmap != null) { float radius = (float) 2.0; mPaint.setARGB(255,255,0,0); if (bShowSamples) mCanvas.drawCircle(x, y, radius, mPaint); // current point if ((mPrevX[finger]==-1 && mPrevY[finger]==-1)) { /* we don't need to draw a line */ mPrevX[finger] = x; mPrevY[finger] = y; mRect.set((int) (x - 3*radius), (int) (y - 3*radius), (int) (x + 3*radius), (int) (y + 3*radius)); } else { /* we do need to draw line as we have a valid previous location */ drawLine(finger); if (mPrevX[finger] <= mCurX){ lowX = (int) (mPrevX[finger] - 3*radius); highX = (int) (mCurX + 3*radius); } else { lowX = (int) (mCurX - 3*radius); highX = (int) (mPrevX[finger] + 3*radius); } if (mPrevY[finger] <= mCurY){ lowY = (int) (mPrevY[finger] - 3*radius); highY = (int) (mCurY + 3*radius); } else { lowY = (int) (mCurY - 3*radius); highY = (int) (mPrevY[finger] + 3*radius); } mRect.set(lowX,lowY,highX,highY); mPrevX[finger] = mCurX; mPrevY[finger] = mCurY; } invalidate(mRect); } } }
Dejcc ::
v 5. vrstici ti piše napako. Popravi metodo onCreate
pzagor2 ::
V Activity-ju Draw v vrstici 71 kličeš "requestWindowFeature(Window.FEATURE_NO_TITLE);" za setContentView(mView); kar ni dovoljeno. Pa če prav vidim maš podvojeno 60 in 71 vrstico + še nakaj drugih vrstic.
messi ::
Hvala za pomoč sicer je bilo napaka v xml kodi
<com.example.pii.TesterView v tem ;)Je bil star ime. Drugače me pa zanima je tale programeranje praviln in če so poiskane prave rešitve, ali je bolj špageti. In če je slab če ima kdo kako izboljšavo v mislih mi naj porsim pove...Hvala, vsem za pomoč
messi ::
Moogoče še to sedaj sem zamenjal setcontientview(R.layout.prvastran.xml), pa kar ne dela več clear in menjave vzorcev ;( prej je bilo setcontientview(mView)
messi ::
Da mogoče bolje razložim dodajal sem tab, spacebare in še gumbe ki sem jih postavil na drugo stran pri tem sem pa ogromno stvari pomeš, ker sedaj setcontientview ni več z mView ampak je z prvastran.xml
» | Android - ZačetnikOddelek: Programiranje | 1717 (1042) | hurlimannxt |
» | Programiranje problem androidOddelek: Programiranje | 1105 (870) | g333kk |
» | [Android] Aplikacija se zrušiOddelek: Programiranje | 751 (588) | g333kk |
» | android črtaOddelek: Programiranje | 2291 (1562) | g333kk |
» | [android] vstavljanje slikeOddelek: Programiranje | 1156 (1053) | messi |
