Forum » Problemi človeštva » Muslimani ne marajo evropskih psov
Mipe ::
In Britain, which has become "ground zero" for Europe's canine controversies, blind passengers are being ordered off buses or refused taxi rides because Muslim drivers or passengers object to their "unclean" guide dogs.
In Reading, for example, one pensioner, a cancer sufferer, was repeatedly confronted by drivers and asked to get off the bus because of his guide dog. He also faced hostility at a hospital and in a supermarket over the animal.
In Nottingham, a Muslim taxi driver refused to carry a blind man because he was accompanied by his guide dog. The taxi driver was later fined £300 ($470).
In Stafford, a Muslim taxi driver refused to carry an elderly blind couple from a grocery store because they were accompanied by their seeing-eye dog.
In Tunbridge Wells, Kent, a blind man was turned away from an Indian restaurant because the owner said it was against his Muslim beliefs to allow dogs into his establishment.
In London, a bus driver prevented a woman from boarding a bus with her dog because there was a Muslim lady on the bus who "might be upset by the dog." As the woman attempted to complain, the doors closed and the bus drove away. When a second bus arrived, she again tried to embark, but was stopped again, this time because the driver said he was Muslim.
Also in Britain, police sniffer dogs trained to spot terrorists at train stations may no longer come into contact with Muslim passengers, following complaints that it was offensive to their religion.
Muslims Declare Jihad on Dogs in Europe
Jao. Če bo kaj takega pri nas, si bom omislil takega ljubljenčka:
Dol mi visi za versko korektnost, če se tako vtikajo v svoboščine drugih. Kaj pa vi menite, bi se bili pripravljeni odpovedati svojemu psu? Kaj pa slepi svojim psom vodičem? Vse za versko korektnost in slogo.
- zaklenil: Gandalfar ()
Aston_11 ::
Saj ljubljenčki niso edina domislica. Eni zavračajo delo v nedeljo, drugi na soboto, eni preganjajo nevernike, ki so vsi ostali. V bistvu je teh par s psemi v manjšini proti hudobijam, ki jih verniki delajo v imenu pravil svojega društva.
Dobra tema, btw, spet bo kregarija! V tem mrazu paše kot šnopček.
RejZoR ::
Sem krščen in vse ampak se mi zdi da so vere en navaden BS in bi moral VSE prepovedat brez izjeme. Sicer same po sebi niso nič napačnega, problem je da si jih vsak intepretira kar nekaj po svoje in na podlagi tega izvajajo neke kvazi svete vojne.
Sploh pa mi je mimo, da se muslimani bunijo v tuji državi. Če si drugje spoštuješ zakone in navade tiste države in ne vsiljuješ svojih. Zakaj pa npr ženske, ki pridejo iz npr Anglije ne smejo v mislimanskih državah hodit okoli v sexy kratkih hlačah in kazat precej več kože? Opa, tega pa ne smejo ker s tem žalijo muslimane. Zakaj že? Kdo pa zdej kaj vsiljuje? Al nej bojo povsod tiho al pa naj tud sami nehajo neki vsiljevat drugim. Tud ko si v npr indiji spoštuješ njihove običaje, pa ne pomnim primerov, ko bi indijci v npr ameriki vsiljevali svoje običaje lokalnemu prebivalstvu. Pa če že so to samo izolirani primerki.
Skratka vse naj prepovejo pa bo.
EDIT:
In kar se tiče prepovedi psov na različnih mestih, naša psička je v vseh pogledih bolj čista in olikana kot pa marsikateri človek, tko da se khm poščijem na vsa neumna mnenja omejenega folka. Pa nima veze kakšne vere je oseba, ki izjavi karkoli proti kožuharčkom. Psi so zakon, to je enostavno fact, ki ga bo potrdil vsak lastnik psa.
EDIT:
- spremenil: RejZoR ()
ahac ::
Kaj pa misliš, da bomo rekl tisti, ki se moramo vsak dan izogibat pasjim drekom na pločniku?
A sem omejen, ker nočem dreka na čevljih prinest domov?
Aston_11 ::
Ne vidim povezave, še manj pa, da bi % možgana ponucal za razmišljanje o dreku po pločnikih. Po travnikih je tega polno, pa ne samo od psov. Od njih še najmanj.
Cca 100% ljudi bi se izogibalo dreku na pločniku, ne glede na to, ali imajo psa ali ne.
Na pločniku imaš še marsikaj drugega motečega.
Tudi povezave med izogibanjem pasjim drekom ne vidim.
ahac ::
Ja, tudi pri nas pred hišo, pa nimamo psa. Prov fajn je, ko s kosilnico zapelješ na njega...
Tear_DR0P ::
eno so pasji dreki - tema te debate je pa nekaj drugega in ne pasji kakci.
Samuel Clemens aka Mark Twain
oldguy ::
Zelo simple rešitev - bus driverje vržt iz službe, taksistu in gostilničarju odvzet dovoljenja. Hit them where it hurts...
Je pa VB postala taka, dosti čudna država v zadnjih 30 letih. Ene stvari gonijo v skrajnosti, pri drugih so pa pussyi.
para! ::
Sej psi na busih so prepovedani tudi pri nas. Dvomim, da tista nalepka s prečrtanim psom ne velja za slepce.
Death before dishonor!
IceIceBaby ::
In Nottingham, a Muslim taxi driver refused to carry a blind man because he was accompanied by his guide dog. The taxi driver was later fined ?300 ($470).
Takole je treba vztrajati, brez agresije in nepotrebnega živciranja. Imajo zadevo pravno urejeno, samo izkoristiti je treba. Prijaviti vsako podobno kršitev, da pokasirajo kazen. 300 tukaj, 300 tam, pa se nabere. Bodo v kratkem duševni bolniki dobro premislili, preden bodo zaprli vrata slepemu človeku, zaradi svojih blodenj.
Druga varjanta pa je, da pozabijo na pse in začnejo bolj množično uporabljati seeing-eye pritlikave konje. How cool is that :)
- spremenil: IceIceBaby ()
RejZoR ::
Zanimivo, zakaj pa od naše psičke NIKOLI ne boste pohodili dreka? Ja, omejen si ker misliš, da so za to krivi psi. Pes ni nič kriv, da mora opravit potrebo. Kriv je lastnik, ki njegovega khm produkta ne pospravi.
Aston_11 ::
Musloti so mi itak čudni, ker ne marajo prašičev in alkohola. Oziroma jim je prepovedano, ali kaj že.
ahac ::
Sej medved tudi ni nič kriv, da mora pojest človeka.... pa se ga vseeno lovi, če samo blizu mesta pride.
vorantz ::
IceIceBaby je izjavil:
Seveda bodo potem začeli protestirat kako se jim kratijo ne vem kakšne pravice, bodo požigali po ulicah itd :/
ahac> Sej medved tudi ni nič kriv, da mora pojest človeka.... pa se ga vseeno lovi, če samo blizu mesta pride.
Če bi imel lastnika, bi se tut lastnika lovilo.
vorantz> Seveda bodo potem začeli protestirat kako se jim kratijo ne vem kakšne pravice, bodo požigali po ulicah itd :/
Ni videt.
Ni videt.
- spremenilo: jype ()
para! ::
Če pa te ubije v gozdu, bomo medveda lepo pustili pri miru tebe pa enostavno pokopali like nothing ever happened!
Neumna primerjava ane, tako kot tvoja, ker je pes domača žival, medved pa zver. In lastniki psov so dolžni (po zakonu) pobirati kakce za svojimi ljubljenčki, tako da jih lahko prijaviš.
Jasno pa, da na avtobusih psi nimajo kaj iskat, tud če gre za vodnike slepih, ker so na busu tud drugi ljudje in se ne morejo izognit psu. Taksi je pa za enega, tako da ne vidim težave, kljub temu, da se mi zdi prisila malo preveč.
para!> tud če gre za vodnike slepih
Napaka. Psi, ki vodijo slepe, so dovoljeni _povsod_ (razen v operacijskih sobah).
vorantz ::
para! ::
Aja, pol tud na busih, kjer je nalepka za prepoved psov, za slepe to ne velja? Če je nekdo na busu alergičen ali se boji psov, who cares, važn da se slep fura.
Lepo do šibkejših, da delamo izjeme, še lepše pa, da ne uporabljam javnih prevozov.
ZaphodBB ::
Tle musliči hodijo po tankem ledu. Če mislijo, da bodo na tak način spreobrnil Evropo so se zmotil.
V Evropi ni prostora za omejenost. Naši predniki so plačali s tisoči življenj, da smo se osvobodili tiranije vraževerja. Kdor ne premore minimalne empatije lahko gre.
IceIceBaby ::
Pozitivna diskriminacija ni ravno nova pogruntavščina. IMHO je odraz civilizirane družbe. Sicer pa psi vodniki niso ravno eni random cucki, so bolj "olikani" od večine srednješolcev na busih.
Mesar ::
Kakšen lastnik, takšen pes.
Your turn to burn!
ZaphodBB ::
A zdej bomo pa zato ker je en alergičen prepovedali transport invalidom? Naj vzame arcnije za blaženje alergije al pa počaka naslednji bus.
Kar se tiče strahu, so pa vodniki poznani po svoji krvoločnosti. Slona ubije v 10 sekundah. To je pogoj, da je sploh lahko vodnik. *facepalm*
thramos ::
IceIceBaby ::
Ampak srednješolci ne smrdijo!!!
Seveda smrdijo. Pa ne samo srednješolci, tudi prešvicani športniki pa umazani klošarji pa prdeči debeluhi pa še kdo smrdi.
Lahko damo detektor smradu na avtobusne, pa preprečimo vstop vsem, ki smrdijo.
Aja, pa posrane dojenčke sem spustil. Tudi smrdijo, prokleta golazen :)
Daedalus ::
Take incidente prijavljat pristojnim službam. Pa naj lepo pobirajo kazni. Me zanima, kdo bo prvi obupal.
No, razen za one, ki s cucki silijo v restavracije. Pes v restavraciji nima kaj iskat, to je jasno. Z izjemo vodnikov za slepe, se razume.
[J.P.Sartre]
[J.P.Sartre]
» | DNK analiza pasjih iztrebkov - Zagreb (strani: 1 2 )Oddelek: Loža | 11524 (8727) | zmaugy |
» | Sranje psov po dvorišču (strani: 1 2 3 )Oddelek: Loža | 32484 (27585) | Pšenični |
» | Zaščita ljudi pred psi (strani: 1 2 3 4 5 6 7 8 )Oddelek: Loža | 56331 (46178) | Massacra |
» | prepovejmo pse v mestih! (strani: 1 2 3 )Oddelek: Problemi človeštva | 22493 (20742) | krneki0001 |
» | Pobiranje pasjih kakcevOddelek: Loža | 3999 (3312) | BendeR |
