Forum » Pomoč in nasveti » Word - enačbe pisava
noraguta ::
pa nauđšlo glih v comic sans(al pa tud) , mislm niso vse pisave podprte ena la vde pa clo delata
skladisce ::
Ajrina ::
V wordu 2010 najprej označi vse skupaj in v zavihku enačb klikni na gumb "Navadno besedilo". Potem lahko spreminjaš pisavo. Še citat rešitve:
1.
For those brave enough to forage in regedit, I found this key *may* control the list of fonts available, but I couldn't seem to make it stick for more than one session, and when it did stick, it was wonky:
HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Common\MathFonts
((Note for Word 2007, I believe the Office version is 12.0 instead of 14.0, so the HKEY would change to be ...\Office\12.0\...))
2.
On the "Equation Tools" Ribbon's "Tool" component, there's a control labeled "Normal Text". It switches a formula from italics to normal and back.
Use this "Normal Text" control to switch the equation from italicized to normal.
Then select the equation's text.
Now use the Font picker from the Home ribbon's Font component to change the equation's font.
P.s.: Odgovor ti da 1. zadetek na googlu, če vpišeš http://bit.ly/s2T91F
1.
2.
» | Word vs. Latex (strani: 1 2 )Oddelek: Programska oprema | 13184 (10070) | GnuceLee |
» | Font: matematični simboliOddelek: Pomoč in nasveti | 4153 (3851) | Mavrik |
» | Pomoč v worduOddelek: Programska oprema | 6272 (6122) | killzone |
» | RandomOddelek: Znanost in tehnologija | 4435 (3665) | Thomas |
