Forum » Kaj kupiti » Katero od teh dveh EPOX plat?
ferdo ::
Je res tistih 6.200SIT razlike..ampak..???
kaj mi nuca RAID?..kaj mi nuca firewire?
kolk je razlike KT333vs. nFORCE2
to me tko grize, kr nevem,
gor bi namonteru
AthlonXP1800+
256MB ddr Samsung 266MHz
Radeon8500
IBM 40GB 7200
kaj se mi splača?
8RDA+ 34.800SIT Nforce2
• Socket A for AMD Athlon™, Duron™, Athlon™ XP CPU. Supports 266/333 FSB
• Nvidia Nforce2 SPP Chipset + Nvidia Nforce2 MCP-T
• 1 Floppy drive controller - 2 serial ports - 1 parallel port
• 6 PCI slots - 1 AGP (AGP 8X)
• 2 x E/IDE Ultra DMA/133, 4 drives max.
• 3 x DDR SDRAM PC3200, 3GB max.
• 4 USB 2.0 ports, 2 extra by optional USB back-panel cable
• Realtek ALC650 6-channel full-duplex integrated sound, with NForce Dolby level decode
• Onboard LAN 10/100 Mbit
• 2 ports IEEE 1394 (firewire™)
• Standard ATX format
8K5A2+ 28.600SIT KT333+raid
Processor AMD Athlon, Athlon XP, Duron
Core Logic VIA Apollo KT333 Chipset + VIA VT8235
BIOS Award/Phoenix BIOS v6.0
Max. FSB 266MHz
Memory 3 x DDR SDRAM PC2700, 3GB max.
Form Factor ATX
Expansion Slots
AGP 1, 1x / 2x / 4x
PCI 6, 32-bit
Ports
PS/2 1 mouse, 1 keyboard.
Serial 2
Parallel 1
USB 4 onboard, 2 optional. USB 2.0
Network 1 x VIA Tahoe VIA VT6103 Physical Layer / Transceiver
Floppy 2 drives max.
IDE 2 x E/IDE Ultra DMA/133, 4 drives max.
RAID IDE 2 x Highpoint HPT372 UDMA/ATA 133 RAID, 4 drives max.
Controllers
Sound Realtek ALC650 6-channel full-duplex integrated sound
gor bi namonteru
AthlonXP1800+
Radeon8500
IBM 40GB 7200
kaj se mi splača?
Max. FSB 266MHz
Form Factor ATX
Expansion Slots
AGP 1, 1x / 2x / 4x
PCI 6, 32-bit
Ports
Serial 2
Parallel 1
Controllers
.: w w w . s l o - t e c h . c o m :.
.: I can`t believe the news today :.
Zheegec ::
nForce2 se ti RES bolj splača, kot KT333 (ali bog ne daj KT400). Osebno bom kmalu tudi jaz 8Rda+ kupu. Če pa boš kdaj RAID rabu pa lahko PCI kontrolerja kupiš, pa bo :) nForce2 ima tudi zelo dobro zvočno in LAN, pa še zelo nadgradljiva je (Bartoni).
Janez Janša, 29.04.2014
ferdo ::
hm, hvala ti alien3001
ampak mene tut zanimajo bonbončki od 8K5a2+ kr ni slaba.
je pa cenejša.
sej mam dnar za 8rda+...ampak
da nebom pol reku, da sm dau več dnarja, vse pa tut nebom izkoristu kar mi plata ponuja.
to je dobr če potpera bartone, samo kdaj pa bodo dobavljivi v sloveniji "ali so že"?, pa njihova cena?
vrjamem da ni izbire kr je 8rda+ res dobra.
mah..neki bluzim bom jo kupu pa bo.
pa še neki, taLE agp8X TO MI JE KRNEKI, , kdaj se misl to izkazat kot res 8x?
je pa cenejša.
- spremenil: ferdo ()
Zheegec ::
Glede Bartona je mišljeno šele v prihodnosti, ker za upgrade samo nov procesor kupiš, ni treba še nove plate. Ima pa veliko features, recimo Dual DDR, AGP 8x (razlika med 4x in 8x bo šele v prihodnosti opazna), zelo dobro zvočno (recimo na KT333 tisto zvočno samo disejblaš, pa eno PCI uporabljaš, pri nForce2 pa ni tako), pa še dober LAN, tako da 2 stvari ti že ni treba kupit. Pa še če imaš Throughbred CPU, je avtomatsko odklenjen.
ferdo ::
dobr ti to poveš
tebe je pa mama dobr naučila
pol je definitivno tale 8rda+ najboljši nakup.
za tak dnar nedobiš plate ki ti tolk ponuja.
si še kej pozabu omenit?
na www.ocworkbench.com se da tut dost prebrat o tej plati.
mislm da tle ni dileme.
tist hladilnik mi je tak vesoljski, me res zanima kako hlajenje zagotavlja, še posebej ko gre FSB tja do 200MHz...
Zheegec ::
Kateri hladilnik?
ferdo ::
na EPOX 8rda+ "beli hladilnik z znakom od EPOXa "
sm biu nejasen?
od enga človeka...
I have an e-mail response directly from Epox tech support that confirms that PCI is locked at 33 mhz on the 8RDA+ motherboard.
See below:
PCI bus is locked at 33MHz.
Thank you for your interest in EPoX products and contacting our support
department. If you reply ensure to include all previous E-mail text. It
will prevent unnecessary delays and guarantee the fastest possible
response.
-----Original Message-----
Sent: Tuesday, December 10, 2002 4:58 PM
To: support@epox.com
Subject: Re: EP-8RDA+: Hello,
Thanks for your response.
Yes I have the System Performance set to Expert, RAM settings are CAS 2
6 3
3, with DIMM voltage at 2.77 v. The FSB is set at 166 mhz. By
increasing
the FSB and lowering the CPU multiplier I am able to increase the RAM
bandwidth results. However, I am concerned about the affect of this on
the PCI clock speed. Is the PCI clock locked such that it will not
increase if I increase the FSB?
Thanks,
Aron Hajde
Epox has made me look like a bigger dummy than I already am. I stand corrected about poor responses from Tech Support.
sm biu nejasen?
od enga človeka...
See below:
response.
6 3
increasing
Thanks,
Aron Hajde
ferdo ::
še to me zanima..
na ramih mi piše:...
Samsung 133
K4H280838B-TCB0
zraven je pa še ena nalepka na njej pa piše:
Korea 0135
M368L3313BT1-CB0
se kdo spozna na te oznake?
Samsung 133
K4H280838B-TCB0
Korea 0135
M368L3313BT1-CB0
morphling1 ::
Fantje mal bluzite, ALIEN razlika med agp8x in 4x ne bo nikoli prisla do izraza, te prihodnjosti ne bos docakal. Ko zacne kartica teksure premikat preko agp busa, se vsa zabava konca in ti tudi visji transfer nic ne pomaga, ker je vse to v primerjavi s internim transferjem med spominom na graficni in gpu-jem zanemarljivo. Ce se bo kaj vecalo, bo to kolicina ter hitrost spomina na graficni za prihodnje pozresne igre. Kar se tice pa nforca in kt333 kt400, razlika med njima je majhna sploh ce vzames najboljso kt333 plato (epox 8k3a) je od nforca pocasnejsa za kake 2-3% nic vec in to na dual chanellu v asinhronih nacinih ter singel chanell ddr je kt333 hitrejsa, samo znati jo je treba nastaviti. Nforce2 je cool plata ce imas dva super dobra ddr modula da gres, lahko z zelo agresivnimi timingi, ker tu ima bios veliko prednost saj lahko vse nastavitve nastavis bolj agresivno kot kjerkoli drugje, samo to ne spada vec v budget sistem. Pac to je cista spica, kjer svoje tudi placas. Btw pri nas takega rama ni za dobiti. Ima se nekaj malenkosti ki pridejo prav pri ekstremnem navijanju. To je da lahko zaklenes hitrost agp busa, ter po vsej verjetnosti deljitelj 6 (ceprav se nihce ni tocno povedal da res obstaja). RAID je za nekatere nujna zadeva in tu imas potem pri nforcu probleme, saj take plate se ni pri nas. Podpora Bartonu bo skoraj sigurno bila tudi na kt333 in kt400 platah. Saj je podnozje enako. Pa se enkrat kt400 ni tako slaba kot vsi hocejo prikazat, res je da ni nic hitrejsa od kt333, oz je slednji hitrejsi v Epox verzijah na 8k3a, ker ima v biosu vklopljen fast cpu command decode. Ta opcija je vklopljiva na vseh Abit platah samo zato rabis dober ram. Pa to ne govorim na podlagi testov po netu, ki so vecinoma narejeni z default nastavitvami, temvec po lastnih testiranjih na enakih timingih na vseh treh platformah. Test sem danes koncal in ga bom probal spisat cez vikend.
morphling1 ::
Aja Ferdo z enim 266 modulom na nforcu2 bos jedel prah kt333 plate...
TheJack ::
Saj se ne gre le za hitrost (razlike so v glavnem par procentov). Bistvene pri platah so stabilnost, neproblematičnost, združljivost...itd. In tu je, sklepam, nForce2 daleč pred Vio. Saj ste brali, kaj so z nForce2 platami počeli pri Anandtechu (vsi ram sloti zasedeni, najbolj agresivni timingi...) in kakšne rezultate so dosegle pri vzdržljivostnih in stabilnostnih testih, ne?
- spremenil: TheJack ()
morphling1 ::
Ja na testu Via plat se jim je pa vse sesuval a ne , mislim ne vem kaj imate toliko proti Vii, jaz se nikoli nisem imel kakrsnih koli stabilnostnih ali kompatibilnostnih tezav. Ce pa mislis da bo nforce2 brez teh tezav se pa motis, cipset je nov in ce mislis da so pri nvidii toliko bolj sposobni kot pri vii, da lahko naredijo cipset v drugo brez vseh tezav se motis, folk ima tudi tu probleme. Problema pa ne bos imel na nobenem od teh cipsetov ce uporabljas normalen (beri kvaliteten hardwer) vecina tezav izhaja iz neznanja uporabnika.
Zheegec ::
KT333 zihr ne, ker ne gre do 200 FSB, KT400 pa bomo videli, samo so nekatere nestabilne na višjih FSBjih (samo da tisti test spet najdem).
morphling1 ::
Pa kje vi take pobirate, jaz sem dosegel 200fsb na via KT266a samo dober ram rabiš, enako bo na nforcu2, edino kar je da dela bolj stabilno če so vsi ram sloti zapolnjeni, samo potem lahko pozabiš na dual chanell. 200+ MHz dela pa tudi na vii brez težav z dvema enakima kvalitetnimam moduloma.
VIA KT333 in KT400 imata praktično enak north bridge tako da obadva podpirata deljitelj 5 nad 166, se pravi, da je pri 200 in čez, pci ter agp že kar navit, samo s pravim hardwerom 200+ ni problem doseči, samo dober ram rabiš kot sem že rekel.
Dobre VIA navijaške plate, beri Epox, Abit podpirata nastavitev fsb-ja mislim da do 250 lahko da celo več in nekaterim s izjemnim ramom (kak corsair pc3500) so dosegli tudi 230 in več, samo 3d programov se ne da več poganjat v večini primerov zaradi grafične kartice, saj je agp že hudo navit.
morphling1 ::
Evo tole sem danes videl na overclockers.com
Epox 8RDA+, I have a couple copies of emails sent to me from Epox technical support saying that the board 1) doesn't have a PCI lock and 2) has a maximum PCI divisor of /5. So that's the big secret
Če to res drži si na enakem kot z VIO kar se tiče navijanja čez 200 fsb
morphling1 ::
Zdaj sem še en dolgo topic prebral o nforcu, Asus definitivno ima pci lock na 33 MHz brez nastavljanja ,Chaintech tudi ter po vsej verjetnosti tudi drugi, samo ne vem zakaj potem pri Epoxu tega ne povedo kot drugje, ampak nekaj bluzijo
ferdo ::
evo mam 8RDA+
kupil sem 1700+ 0.13mikronska tehnologija..
vklopil, šu v bios spustu množilnik na 10
FSB na 166
in glej ga zlomka ..... 1.666GHz
vsa voltaža je na DEFAULT.
PS: tle se da u biosu naštimat da ostane RAM na deklarirani hitrosti in deluje asinhrono glede na procesor!
bom probu še na več, ampak se nemudi nikamor
treba kak boljši ram kupt pol pa. za 1x je to vredu "za moje potrebe"
bodo že pršli cajti ko bo treba pohitrit zadevo
sm pa direkt pršparu 9.000,ooSIT "naj bi jih stem da sm navil procesor"
1700+ 18000SIT
2000+ 27000SIT
zdej dobim točno 8500 3D marks
1024x768 32bit
32bit z buf
32 bit texture
2xAA
glede na bios na tej mamiplati, lahko pa rečem " to j enebeška skrivnost"
dobesedno tako kot piše na nekaterih nastavitvah..AGRESIVNO
še nekej, kaj pomeni to:
nastavu sm množilnik 13x133FSB
in mi je zaznalo kot neki čez 700MHz procesor....
ful čudno...nezastopm tega.
FSB na 166
1700+ 18000SIT
2000+ 27000SIT
1024x768 32bit
32bit z buf
32 bit texture
2xAA
morphling1 ::
Ferdo, kot prvo daj gor najnovejši bios, original je totalen skret. Potem pa nastavi fsb in ram sinhrono, asinhrono na tej plošči sploh ne funkcionira (zmogljivosti) sploh pa če imaš en modul notri, v tem primeru je 8rda lepo počasnejša od via plat. Ker imaš pc2100 ram daj lepo na 133, timinge privij, pa poglej če ti dela stabilno (prime95- turture test) , če ti deluje, počasi dvigaj fsb (še vedno sinhrono). Kar se pa množilnika tiče je pa normalno delal ti bo do 12,5 za višje mislim do moraš še en mostiček povezat na procu, pa še za to nisem 100% da ti bodo delovali višji množilniki. To da ti pa pri 13 procesor skoči na 5,5 je normalno, to ima amd interno rezervirane nizke množilnike, da na starih platah delujejo procesorji z množilnikom višjim od 12,5.
ferdo ::
ja zgleda da bo treba bios update nardit.. gRRRRRRRRRRRRR
ih kako sovražim tole...
vedno ko sem se spravil prvič na kako plati sm zaje...
tm na tistem LED zaslončku WATEWER..neki pač je..ko ti izpiše kako napako
skos mi GORI oznaka FF sm pogledu in sklepam da treba bios update narest.
ena od rešitev je pač ta
sej pravm, boljši ram si morm še nabavit, sam še lep cajt si ga nebom ni potrebe, je več cajta ko dinarja
gremo po novi bios...........
še nekej u WinXP mi nVIDIA control panel SPLJOH nepotegne...ERROR
hoče da pošlem na majkrosoft sendam napako..ko jih jebe...
"se opravičujem izrazu"
NVIDIA nForce Control Panel has encountered a problem and needs to close. We are sorry for the inconvenience. .........
ferdo ::
a lahk tko nardim:
1. nardim zagonsko disketo od win XP
2. bootam iz te diskete
3. direkt iz dosa in direkt iz diska flešnem nou bios..
na netu piše, da nesmem iz diska flešat :) ->
!!!WARNING!!!
Never attempt to Flash your BIOS from a hard disk, DOS Window, DOS
shell, or in Windows NT. If your system is working without problems
or conflicts, then it is not recommended that you flash your BIOS.
Improper flashing procedures may result in a dead system! Follow the
these instructions carefully. DO NOT FLASH THE BIOS IF THE SYSTEM IS
OVERCLOCKED.
na K7S5A sm vedno iz diska na tak način flešnu ..
ko sm pa prvič na njej flešu sm iz diskete in ej disketa zaribala ..drnč tole, nikol več iz diskete!
sm tist AMI bios je en drnč se meni zdi. tale AWARD software mi bolš zgleda, al je pa isti K**C "klinični center Lj. "
!!!WARNING!!!
OVERCLOCKED.
morphling1 ::
FF nima veze z biosom, to je običajna oznaka ko deluje normalno, ko pride čez vse kode pri zagonu, če pa je FF takoj na začetku in ne pride naprej, je pa sranje...
Flashanje je simple ko pasulj. V winsihh formatiraj disketo kot sistemsko, nanjo posnameš awdflash.exe ter bios.bin file. Potem resetiraš ter zaženeš sistem iz diskete. Napišeš awdflash bios.bin /py /sn /cc To je to počakaš nekaj trenutkov da se zadeva opravi, moliš da ne zmanjka elektrike ter po uspešne flashu nastaviš bios tako kot je treba.
ferdo ::
i4ker:
ja..itak..u Mlacomu majo, majo pa 0.13 in 0.18 sm reč morš da hočeš 0.13 seveda:)
men so direkt dal 0.13, sam sm vseen preveru da so mi res dal 0.13 preden sm kupu.
morphling1:
ja razumem in je simpelj ko pasulj, ampak A ni iz diska bolj varno?"nevem zakaj nebi bilo uredu iz diska"
disketa je pomoje bolj nezanesljiv MEDIJ kot disk..
mam SLABE izkušnje stem.
mene sm to zanima če se da iz diska flešat.
bootam iz diskepe potem pa iz direktorija na disku zaženem flash program oz. ceu postopek.
morphling1:
Zheegec ::
Kaj pa je z originalnim BIOSom od 8Rda? Sem se že tolk veselil, sedaj bo treba pa še BIOS flashat po nakupu. jao :)
morphling1 ::
Ja da se iz diska flashat, samo še vedno greš najprej na sistemsko disketo, potem pa na lokacijo na disku. Če bi imel pa win98 greš pa lahko direkt v dos če pritisneš F8 tako ko se začnejo nalagat. Drugače pa iz diskete je čisto varno, ker bios najprej prebere cel bin file da vidi če je OK, potem pa začne s flashom.
i4ker, 0.13 mikrona so zdaj vsi Athlon xp-ji, samo finta je dobit B stepping na nižji frekvenci, teh pa zaenkrat še ne bo tako hitro pri nas. Tbred A se navijajo približno enako kot stari 0.18 mikronski palominoti, mogoče malenkost bolje.
ferdo ::
zakaj pa ti mislš da je ta bios ki je kot original že na plati, da ni dober? :)
malo obrazloži morphling1...
če ni nevem kaj pomembnga nebom šu flešat.
bios pa mam shranjen na disku tko da ni problema.
morphling1 ::
Folk je imel velike probleme s originalnim biosom. Čisto različne zadeve lahko samo povem da so se hudo razburjali kakšen crap je ta plata itd. po novem biosu so pa pomirjeni in zadovoljni. Ne da se mi opisovat ter vam prevajat kakšne probleme so imeli, samo to je običaj za tako nove plate sploh če je čipset popolnoma nov, da je še zelo hroščat bios.
Fix list za najnovejši bios.
Model: EP-8RDA+
BIOS: 8RDA2C10.BIN (0C00)
Fixed:
1.)“FDD_3_Mode” support.
2.)“Assign IRQ for VGA” support.
3.) Fixed 1394 can't control ( En/Dis ) by Setup.
4.) Added 'AC97 Speaker At POST' function.
5.) Added Athlon XP 2600+ support (166*12.5).
6.) Added Athlon XP 2400+ support (166*12).
7.) Turn off keyboard LED before system into S3/S4/S5.
8.) Added support TURBO mode for performance BIOS.
9.) Support Kingmax module compatible issue.
1.KingmaxMPXB62D68KX3MAA
2.KingmaxMPXB62D68KX3MBA
3.KingmaxMPMA82D68KX3MAA
4.KingmaxMPMA82D68KX3MBA
10.) Enable PCI_LATENCY_SELECTABLE and PCI_IRQ_SELECTABLE item.
11.) Patch “System temperature” and “Chassis Fan ” and “Power Fan” declaration error.
12.) Patch CPU ratio adjusts failed for the some 0.13u Athlon XP CPU.
13.) Added code for Athlon Model 10(Barton) support.
14.) Fix USB 2.0 enable failed.
Desk: USB2.0 item -> Disabled -> Enabled -> Usb2.0 enabled fail.
15.) Added "Auto" mode for Memory Clock.
16.) OPEN FSB 250MHZ selectable.
17.) PCI_LATENCY_SELECTABLE support.
18.) PCI_IRQ_SELECTABLE support.
19.) Easy Boot support.
20.) Hot Key flash support.
Pa še za predzadnji bios.
Model: EP-8RDA
BIOS: 8RD12C06.BIN (5A00)
Fixed:
1.) Patch Athlon XP 2400+ (166*12) main processor information shows incorrect at boot screen.
4.) Patch PS2 mouse crazy on the Win98SE resume for 8RDA.
5.) Fix USB 2.0 enable failed.
6.) Change Optimized/Setup default DIMM voltage to 2.77v for Kingmax module.
7.) Added "Auto" mode for Memory Clock follower BPL 2.73.
8.) OPEN FSB 250MHZ Selectable.
9.) Patch Flash Write Protect Init fail.
10.) Enhance FAN detectable range.
Pa ne pozabi naložit najnovejše driverje za samo plato nForce_winxp_2.00.exe
Driver Updates for the EP-8RDA+ & EP-8RGA+ mainboards are now uploaded.
Fixes audio DirectX BSOD issue on Windows XP systems
Adds ASIO driver support
Adds OpenAL driver support
Updated nForce Audio control panel
Incorporates performance improvements and other bug fixes
Notes
Windows XP users must install Service Pack 1 prior to attempting to
install this package. Failure to do so will result in the inability to
support USB 2.0 and NVIDIA IDE drivers.
USB keyboards and/or mice will be disabled during the installation of this
package. Please connect PS2 devices before starting the installation process.
Driver Versions
Audio driver 3.06 WHQL
Audio control panel 3.07
Network driver 2.81 WHQL
GART driver 2.78 WHQL
SMBus driver 2.75 WHQL
Memory controller driver 2.75 WHQL
IDE driver 2.70 In The Box WHQL
IDE driver 3.07 Full Driver -- not WHQL
Display Drivers 40.72 WHQL
Tudi kar nekaj konkretnih popravkov.
Tako zdaj ste pa opremljeni za nove podvige s to plato, ki bo počasi postala zelo
Btw. spremljajte najnovejše zadeve v zvezi z Epox platami tu http://www.epox.org
Model: EP-8RDA+
Fixed:
Model: EP-8RDA
Fixed:
Notes
Driver Versions
Zheegec ::
Aua :) Potem bom pa kar v trgovini rekel, da naj mi updatajo BIOS, ker kakšno leto želim čim manj problemov z garancijo :)
ferdo ::
MNJAh...pa še tale SP1 za WPje....
tolk teh popravkov, da te na sekret porine
učasih je pa uredu če je že treba na SKRET se sm na WEINDOWSE spomneš pa te tkoj prime na SKRET
mal je mankal pa bi em na sekret prjel...
ferdo ::
morphling1, morphling1, morphling1, morphling1, morphling1, morphling1, morphling1,..itd
sploh nevem če sem se kdaj zmotu ko sem pisau tvoj nick name.
se opravičujem z nasmeškom
nastavitve ramov so ap sledeče:
T(ras) 6
T(rcd) 3
T(rp) 3
CAS latency 2.5
se mi zdi da nekako ni stabilno na 160fsb....nevem....bom še testeru.
mislš da se kej pridobi če še malo VOLTAŽO dvignem?
T(ras) 6
T(rcd) 3
T(rp) 3
CAS latency 2.5
morphling1 ::
Ram voltažo lahko brez težav dvigneš do maksimuma 2.9V, imaš samsung original ram, tako da se ti kot kaže kar dobro navija. Z voltažo sigurno pridobiš na stabilnosti, drugače pa najprej nastavi na nižji mp, potem pa dvigaj fsb in testiraj s prime95 nekaj časa da vidiš če je ram stabilen. Z 2.9V ti mogoče rata priti do 166 MHz. Škoda da nima ta plata do 3.2V za rame, sicer pa to se da zrihtat z volt modom
ferdo ::
opažam da si poln skrivnosti :)
al je plata čist nova, ti me pa že napeljuješ na volt mod
C C!:) se nikamor ne mudi:)
kaj je to "mp"? -> množilnik?
kaj je to "prime95"? -> test stabilnosti?...ga nimam.
glej to!
če nastavim FSB manj ko 166 mi bios zazna ram kot 266
če pa nastavim fsb 166 ali več, bios smatra da imam 333 rame.ubistvu so pa deklarirani na 266.
na 160 mi laufajo tistih 6MHz bodo pa še šli ..če se pr 160 potijo, se naj pa še na 166 stabilno, jih bom že prpravu do tega.
bom reku 166 morte delat in pika. pa bodo moral. hehe-> krneki
bom probu z voltažo to poštimat.
pomoje če dvignem voltažo na ramih jih bo treba hladit.
pa od kje ti to vse veš? si kako knjigo pojedu?
jzt bi rad 12x166 s tem hardwerom ko ga mam zdej
upam da mi rata.
Vcore in Vdimm bom zvišu.
in probu 12x166 :)
sej zunej je dost mrzlo
kje se da kako tako slikco dobit ko jo maš ti:)?...
zdej vsaj vem kako zgledaš, če te bom kdaj u Lj. sreču
glej to!
upam da mi rata.
in probu 12x166 :)
ferdo ::
ne rata mi
11.5x160=1840MHz 2200+
to je maxsimum ki mi uspe
če bi znižu množilnik na 10...
10x166=1666MHz 2000+
to mi DELA! 166fsb mi uspe.
tazgorna varjanta je pomoje zmoglivejša čeprau ima samo 160fsb
11.5x160
12x160
11.5x166
12x166
te štiri varjante mi nepotegnejo, se abak obesi.
voltaža: Vcore=1.7V , Vdimm=2.9V
kaj misliš??
11.5x160
12x160
11.5x166
12x166
kaj misliš??
Jure2k ::
S to plato sem mel na začetku probleme, ker mi ni delal na več kot 166MHz. Imam pa corsair 3200. No kasneje sem nastavil na Cas 2 iz default cas3 in je delalo brez problema tudi čez 200MHz, kar sem s KT400 prej lahko samo sanjal.
Zdaj me baše samo temperatura procesorja. Bo treba nekaj ukrenit
Zdaj bom poskusil laufati dual DDR, na 200MHz z slabimi timingi, pa bom videl, če se mi splača dat slabši RAM zraven ali ne.
ferdo ::
CAS latency na ramih imam 2.5 .... -> kaj če bi nastavu na 2 ?
morphling1 ::
mp= množilnik
Prime95 eden najboljših programov za obremeniti procesor, ter obenem preverjati stabilnost. Program je zelo spominsko intenziven in če sistem ni stabilen se ne sesuje, ampak javi napako. Poženeš torture test, če rečeš da imaš res stabilno mašino ti mora delati vsaj nekaj ur.
Neki me bega zakaj ne probaš še ostalih množilnikov, recimo 11*166 kar je 1826 in bi ti verjetno delalo. Drugače me preseneča kako dobro se ti navija procesor, ker 1840 na 1.7V zrak je dober dosežek, zgleda da novejše serije tbred A tudi niso tako slabe, ker tole gre na 2G brez težav z dobrim hlajenjem ter kakimi 2V.
Si bios že flashal ??
Če boš nastavil cas iz 2.5 na 2 bo seveda hitreje, samo vprašanje če ti bo delalo stabilno, ker čudežev pa vseeno ne moreš pričakovat od pc2100cas2.5 rama, ne rečem če bi bil cas2. Pri Juretu je šlo verjetno bolj zato, ker ima ram spd programiran na cas2 in lahko da ga cas3 zeza, to nastavitev ima tako in tako samo Samsung pc3200, ki pa ni nič drugega kot 2700cas2.5 mogoče malenkost boljši.
Eagle ::
Hmm nevem zakaj uporablate pri epox platah bootable disketo za flesanje biosa, ce pa je simpl ko pasulj .. :
The ALT+F2 Method
Download the required BIOS image file from the EPoX website.
Copy or extract the BIOS image file (named xxxxxxxx.bin) to a blank floppy disk with no bad sectors on it.
Restart the machine with the floppy disk in the floppy drive
When prompted at machine initialization, press ALT+F2 to begin performing the flashing of the BIOS.
The BIOS will automatically flash and reboot the machine.
After this, press DEL to enter the BIOS setup and select to "LOAD OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT"
Please note that this does not create a backup of the BIOS binary file.
This does not require you to have a bootable floppy disk.
The ALT+F2 Method
ferdo ::
sneu iz neta Prime95!
če ma fsb160 ali več mi javi najmanj 3errors and 1 warning po parih sekundah testa.
zdej sm dau pa sledeče nastavitve:
12x150fsb=1.8GHz (2200+)
zadeva laufa stabilno
Vdimm=2.9V
Vcore=1.65V
hotu sm bootat na 12.5x150....in mi je abak zmrznu...nevem zakaj!? voltaža je pa ista
zbootu se je, sm ko je pa hotu winse naložit je pa zmrznu.
sm mogu bios reseterat .
in po 20minutah testa ni javilo nobene napake in NO warning
zgleda da mi ram nedela stabilno na 160 ali več..
imam pa nastavleno na CAS Latensy = 2 "dela stabilno"
lahko pogledam kero oznako jedra imam.
pa bomo videli če nimam pak poseben procesor.
pomoje se 0.13 thoroughbredi lepo navijajo.
bom pogledu na moj procesor kaj piše na njem.
pa bomo naprej debaterali
na procesorju piše:... ->
AMD Athlon
AXDA 1700 DL3C 9509088270326
AIUGA 0247VPFW 1999 AMD
to so oznake mojega 1700+ thoroughbreda
kaj pomenijo se mi pa neda po netu brska
morphling1: ti zihr veš napamet
Vdimm=2.9V
Vcore=1.65V
AMD Athlon
morphling1 ::
Ferdo , če ti dela 12*150, kaj misliš da gre tako enostavno potem kar na 12.5*150
To je 75Mhz skok. Bo treba mal voltažo dvignit a ne Ampak ne pretiravat oz. pazi na temperaturo.
tbred steppingov ne poznam točno, mislim pa da so trenutno vsi nižje frekvenčni enaki.
Oznaka AXDA 1700 DL3C 9509088270326 je naročniška koda, po kateri se po novem naroča OEM procesorje, tako da dobre trgovine v tujini imajo to kodo napisano tam kjer izbiraš procesor in pametno je kupovati samo tam kjer te kode imajo, saj ti v drugem primeru lahko podtakne recimo palominota 1700+ v tvojem primeru.
Pri kodi so pomembne tiste oznake po hitrosti 1700D se pravi LT3C (se mi zdi da si pozabil prepisat T)
prva oznaka je napetost jedra
L 1.5V
U 1.6V
K 1.65V
M 1.75V
Vsi palominoti so M se pravi 1.75V, tbred A so od 1.5-1.65V , tbred B pa od 1.6-1.65V
druga oznaka je maksimalna temperatura jedra.
T 90°C
V 85°C
Vsi amd procesorji pod 2200+ so T , vsi nad pa V
3 ne vem točno kaj je
zadnja črka je pa FSB
C 133 MHz
D 166 MHz
Se pravi tvoj je tbred A , tbred B bi bil v primeru 1700DUT3C razlika je v voltaži
Razliko pa vidiš tudi iz steppinga, to je pa druga oznaka
AIUGA 0247VPFW 1999 AMD če se koda konča na A (AIUGA) je to tbred A , tbred B bi bil AIUGB 0247 je pa izdelava, se pravi 47 teden 2002 se pravi da je tvoj procesor res zelo nov in je narejen novembra letos. Iz tvojega navijanja pri nizki voltaži mi je pa tudi jasno da so tudi tbred A zdaj že dosti boljši kot na začetku, tako da 2G ne bi smel biti problem na vodnem hlajenju ter malo dvignjeni voltaži. To pa pomeni res ugodno ceno saj za malo več kot 20ksit dobiš 2500+
L 1.5V
U 1.6V
K 1.65V
M 1.75V
T 90°C
V 85°C
C 133 MHz
D 166 MHz
morphling1 ::
Sem šel pogledta pdf za še ostali dve oznaki, D takoj za 1700 je oznaka pakiranja procesorja D= OPGA (organic pin grid aray) , tista 3 pa pomeni 256 KB L2 predpomnilnika.
Sicer pa si poglej to slikco da bo bolj jasno o čem govorim.
ferdo ::
no polej sm naredu dober nakup:)
dau sm 18.000,ooSIT za ta procesor znjim sem že zdej na 1.8GHz
praviš pa da bi lahko šu na 2GHz.
mam Zalmanovo bakreno pahljačo, in se da znjo kr daleč čez 2GHz.
bom dvignil voltažo procesorju pa bom vidu če bo stabilno.
do kolk pa naj dvignem voltažo?
bom že kej urihtu da bom dobu tist maxsimum
ampak tale 8RDA+ mamaplata je pa res en bombonček,
ko da bi odpru KRAŠ bonbonjero se je zalesketala v polnem sijaju iz škatle
mam jzt še mohga herculesa u rezervi, sploh ga še nism nč naviju pa dobim 10810 3D marks
800x600 32bit vse mam na 32bit NoAA
Jure2k ::
Nekaj čudnega se mi je zgodilo s to plato.
Pokvarlo mi je windowse, ozirona en fajl ki je potreben pri zagonu... in to že dvakrat. Obakrat pri navijanju. Če ima PCI res zaklenjen se to nebi smelo zgodit...ali pač?
Čudno se mi zdi tudi, da se je to zgodilo pri nižjih frekvencah kot sem jih prej dosegal z ABIT KD7. Sicer pa deluje ta plošča odlično tudi pri 207MHz FSB, skrbi me le, ker je northbridge precej vroč ker nima ventilatorja gor.
Če ni pokvaril windowsov previsok PCI bus, kaj je še lahko vzrok? Nestabilen RAM?
ferdo ::
ja jzt bi lahko šu dle kot 150MHz, če bi mel boljši ram. veliko je od rama odvisno, da ti sistem dela stabilno.
zdej sem meu 45min ukloplen test Prime95 ni javlo nobene napake
morphlin1: kot si reku treba voltažo dvignt in seveda si imel SPET prav
sedaj mi procesor tiktaka na 12.5x150= 1.88GHz
Vcore= 1.824V
Vdimm= 2.880V
a bi šlo še kaj več?
CPU temp. = 41°C/105F
hladim z ZALMAN CNPS6000-Cu
Vcore= 1.824V
Vdimm= 2.880V
morphling1 ::
ferdo spet si se zeznu pri nicku drugače pa pozab na 2 GHz z zalmanom. Kot boljše hlajenje mislim vsaj Thermalright ali pa vodo :) Raje povej kakšno temperaturo imaš po pol ure prim95 se pravi na loadu, ker težko verjamem na 41°C z zalmanom na 1880 ter majhnim tbredom, pa četudi 8RDA+ meri temperaturo socketu in ne z interne diode.
Jure, tist se zgodi če je ram prenavit, saj pri meni je bilo parkrat tako, nima veze z diskom. Drugače pa ja nb moraš skoraj nujno hladiti, ker sistem definitivno postane nestabilen zarad pregrevanje, ker greje se kar lepo, saj vidiš da imajo vse ostale firme cooler gor , Epox pa malo špara in ga ni dal.
ferdo ::
se opravičujem za narobe napisan nick
DAMN....pa kje si ta nick pobrau?
PS: a je to mogoče kak bog ljubezni al kaj, ženske tkoj padejo ko te zagledajo?
zdej sm ga mel na 12.5x152MHz=1900MHz
Voltaža je ista.
Vrjamem če odklenem množilnik 13x in več, da pridem kamot na 2GHz in še kaj čes.
sm laufu Prime95 1uro30min brez ERRORs no warning!
temperaturo mi je odčitavalo na 46°~47°C/114F temperatura je skos nihala na tej veličini.
ram mi je nestabilen na 160MHz, multipler pa negre več ko 12.5x
če bi ram zdržu 160MHz bi bil tkoj na 2GHz (2400+) !
PROCESOR dela na 2GH!
1700+ @ 2400+ hm..to pa je že kr ane
vrjemi mi da mi to lahko rata tudi z tem zračnim hlajenjem!
vendar ne z temi rami kot jih imam sedaj.
to je max. kar lahko iztisnem iz mojih ramom.
mogoče bi blo še stabilno na 155MHz ampak mi je lepša cifra 1900MHz
kot pa zmazek 1937MHz
sm že gledu sčim bi odklenu tega thoroughbreda ... s svinčnikom se ga neda bi blo preveč na easy:)
PS: pejt na ZALMAN spletno stran pa boš vidu do kolk GHz je deklariran tale hladilnik. 2GHz ti komot hladi. VSAJ meni BO!...bom že poskrbu za dobro hlajenje
Voltaža je ista.
morphling1 ::
Ok resno, vedno bolj sem navdušen nad tem procesorjem, čeprav si pomoje še vedno preveč optimističen , ker do neke mere gre procesor enostavno potem pa zadane zid, in je vsak napredek dosti težje doseči. Čeprav 1900 pri 1.825V ter bogim zalmanom (v drugo me ne boš prepričal ) govori o tem da je kar še nekaj rezerve v tem procu. Kolk praviš da si dal zanj, mogoče ga bom pa vseeno sprobal.
Kar se pa odklepa tiče pa ne vem, sploh nevem če se da s tem procesorjem dobiti na 12.5 mogoče na tvoji plati , na moji sigurno ne. Ah se bom posvetil problemu če ga bom vzel
A L1 mostički niso bili lasersko rezani ?
» | Navijanje Tbred-ov A in B (strani: 1 2 3 4 … 31 32 33 34 )Oddelek: Navijanje | 63047 (25470) | GaS |
» | Odklep T'bred B???Oddelek: Navijanje | 1606 (1211) | igaiga |
» | Približni rezultat 3000+ Athlona (strani: 1 2 3 4 )Oddelek: Navijanje | 8713 (6438) | Zoidberg |
» | Naviti Athlona XP, nič mi ni jasno večOddelek: Navijanje | 1216 (1021) | Tarzan |
» | večna drama, kateri AMD XP kupit za max izkoristek cpu hitrost/OC/cena ???Oddelek: Navijanje | 2103 (1407) | Cako |
