Forum » Igre » cod2 server problemi[pomoč please]- modem???
xmind ::
LP. Prosil bi vas da mi pri cod2 pomagate narediti server. Prebral sem že veliko forumov kako narediti server, a po vseh teh navodilih mi ne uspe uspostavit serverja....
nimam nobenega routerja kjer bi bilo potrebno odpreti porte.... IMAM PA MODEM NA 2 PRIKLJUČKA imenuje se SPEEDTOUCH MODEM, KI SEM GA DOBIL PRI AMISU....
če ker ve odgovor na to temo mi prosim napišite kk pa kaj ali pa mi pošljite ZS na e-mail: dani.smon@gmail.com ali pa če napišete svoj Xfire da was dodam ali pa vi mene na dsshooter100
tule pa še je besedilo, ki mi ga je u konzoli napisalo...:
CoD2 MP 1.3 build win-x86 May 1 2006
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Activision\Call of Duty 2\main\_G_ClientSide_Mods.iwd (10 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_rywals_mod.iwd.iwd (57 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_nodustmod_v2.iwd (17 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_nodustmod_v2.19ee43a4.iwd (17 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_all_rifles_v1.5.iwd (18 files)
C:\Program Files\Activision\Call of Duty 2\main\nadesmod.iwd (7 files)
C:\Program Files\Activision\Call of Duty 2\main\mp_hawkeyeaim.iwd (13 files)
C:\Program Files\Activision\Call of Duty 2\main\mp_deltaforcedocks_v2.iwd (14 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_15.iwd (85 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_14.iwd (4038 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_13.iwd (22624 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_12.iwd (1016 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_11.iwd (1462 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_10.iwd (1936 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_09.iwd (2142 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_08.iwd (2723 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_07.iwd (3384 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_06.iwd (990 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_05.iwd (928 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_04.iwd (698 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_03.iwd (26 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_02.iwd (40 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_01.iwd (16 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_00.iwd (102 files)
C:\Program Files\Activision\Call of Duty 2\main\DoM_GOB_pack.iwd (73 files)
C:\Program Files\Activision\Call of Duty 2/main
C:\Program Files\Activision\Call of Duty 2/raw
C:\Program Files\Activision\Call of Duty 2/raw_shared
C:\Program Files\Activision\Call of Duty 2/devraw
C:\Program Files\Activision\Call of Duty 2/devraw_shared
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw11.iwd (1 files)
localized assets iwd file for english
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
81889 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
execing players/Smon/config_mp.cfg
sv_cheats is write protected.
dedicated is read only.
Measured CPU speed is 3.01 GHz
System memory is 1024 MB (capped at 1 GB)
Video card is "WinFast PX9800 GT(NVIDIA)"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: :28960
Hostname: dani-be618a9d83
IP: 192.168.1.64
--- Common Initialization Complete ---
execing server.cfg
net_ip will be changed upon restarting.
logfile opened on Wed Apr 29 15:57:34 2009
g_gametype will be changed upon restarting.
map_rotate...
"sv_mapRotation" is:"map mp_dawnville map mp_burgundy map mp_carentan map mp_matmata map mp_toujane"
"sv_mapRotationCurrent" is:" gametype sd map mp_dawnville gametype sd map mp_toujane"
Setting g_gametype: sd.
Setting map: mp_dawnville.
------ Server Initialization ------
Server: mp_dawnville
File Handles:
handle 1: console_mp.log
163778 files in iwd files
Loading 'ui_mp/ingame.menu'...
Loading 'ui_mp/ingame_controls.menu'...
Loading 'ui_mp/ingame_options.menu'...
Loading 'ui_mp/ingame_system.menu'...
Loading 'ui_mp/ingame_leave.menu'...
Loading 'ui_mp/ingame_callvote.menu'...
Loading 'ui_mp/wm_quickmessage.menu'...
Menu load error: ui_mp/wm_quickmessage.menu, line 9: unknown menu keyword name
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword quickmessage
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword visible
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword fullscreen
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword rect
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 640
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 480
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword focuscolor
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword disablecolor
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword style
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 17: unknown menu keyword onOpen
Menu load error: ui_mp/wm_quickmessage.menu, line 18: unknown menu keyword {
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword setDvar
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword cl_bypassMouseInput
Menu load error: ui_mp/wm_quickmessage.menu, line 20: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 20: menu has no name
------- Game Initialization -------
gamename: Call of Duty 2
gamedate: May 1 2006
Info string length exceeded
key: 'sv_referencedIwds'
value: '2114676056 742172524 -418909182 35495740 -369904732 181429573 780394069 1101180720 1046874969 1053665859 1659111092 -1222475534 '
Info string:
\bg_fallDamageMaxHeight\480\bg_fallDamageMinHeight\256\g_synchronousClients\0\sv_cheats\0\sv_disableClientConsole\0\sv_iwdNames\_G_ClientSide_Mods zzz_rywals_mod.iwd zzz_nodustmod_v2 zzz_nodustmod_v2.19ee43a4 zzz_all_rifles_v1.5 nadesmod mp_hawkeyeaim mp_deltaforcedocks_v2 iw_15 iw_14 iw_13 iw_12 iw_11 iw_10 iw_09 iw_08 iw_07 iw_06 iw_05 iw_04 iw_03 iw_02 iw_01 iw_00 DoM_GOB_pack\sv_iwds\2114676056 742172524 435045284 435045284 -1390077376 -418909182 35495740 -369904732 181429573 -1449716526 780394069 -1333623355 -1980843666 1334775335 -621896007 1101180720 1046874969 1053665859 1842349204 -1652414412 1659111092 -1085686032 -2025394354 178615151 -1222475534 \sv_pure\1\sv_referencedIwdNames\main/_G_ClientSide_Mods main/zzz_rywals_mod.iwd main/nadesmod main/mp_hawkeyeaim main/mp_deltaforcedocks_v2 main/iw_15 main/iw_13 main/iw_08 main/iw_07 main/iw_06 main/iw_03 main/DoM_GOB_pack
sv_punkbuster is write protected.
Working directory: C:\Program Files\Activision\Call of Duty 2
PunkBuster Server: 0 Power Players loaded from C:\Program Files\Activision\Call of Duty 2\pb\pbpower.dat
PunkBuster Server: 0 PB Rcon Filters loaded from C:\Program Files\Activision\Call of Duty 2\pb\pbrcon.dat
PunkBuster Server: 0 Map lines loaded from C:\Program Files\Activision\Call of Duty 2\pb\pbsvmaps.cfg
PunkBuster Server: PunkBuster Server (v1.107 | A1302 C1.203) Enabled
Hitch warning: 3339 msec frame time
Resolving cod2master.activision.com
cod2master.activision.com resolved to 63.146.124.40:20710
Sending heartbeat to cod2master.activision.com
PunkBuster Server: Game Version [CoD2 MP 1.3 build pc_1.3_1_1 Mon May 01 2006 05:05:43PM win-x86]
cod2master.activision.com resolved to 63.146.124.40:20700
Hitch warning: 10686 msec frame time
File Handles:
Winsock Initialized
IP: 192.168.1.64
execing server.cfg
map_rotate...
File Handles:
Info string:
- zaklenil: Mavrik ()
xmind ::
hm... a ti je težko dat 12€ za server?
hmh.... lej terkrat ko grem js cod špilat se mi ne splača dat 12€. rad bi pa useeno zvedo zaka ne gre narest
PujsaPepa ::
A da na enem PCju enostavno ad-hoc igrco CoD2 zaženeš in na tem PCju pač nič ne špilaš ampak je samo kot Spectator, pa ne bi šlo ?
Drugi se pa povežejo nanj in nabijajo ?
Kaj več dobiš pri "pravem" serverju ?
xmind ::
a mi lahko bol nazorno poveš ka si mislu....jst hočem met server ne da bi neki spectator ...ka si mislu ne wem
» | Kako narediti svoj server v Call of Duty 2 ?Oddelek: Igre | 8667 (2327) | deadzone |
» | CoD Problemi (strani: 1 2 )Oddelek: Igre | 10695 (6668) | hojnikb |
» | Call of duty 2!ne dela server!problems!Oddelek: Igre | 5361 (3363) | ViperR |
⊘ | COD 2 ne delujeOddelek: Igre | 2712 (1721) | Heavy |
» | COD2 set dedicated 2Oddelek: Igre | 3200 (3055) | Mr.B |
