Forum » Igre » COD2 set dedicated 2
Rad bi nastavil COD2 kod samostojni server. Sicer bi laufal pod windowsi ampak le.
Ne rabim da laufa kot servis ampak bi bilo dosti da bi zalaufal ročno preko bljižnice.
Problem je v tem, da na mašino ne morem direkt, in če v bljižnici napišem še set dedicated 2 mi ne laufa.
Oziroma se iz nobenega na lan omrežju ne morem povezati na njega.
81577 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
execing players/MrB/config_mp.cfg
dedicated is read only.
Measured CPU speed is 3.30 GHz
System memory is 1023 MB (capped at 1 GB)
Video card is "RADEON 9700 PRO - Secondary"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: abakus
IP: x.x.x.x
--- Common Initialization Complete ---
Working directory: C:\Program Files\Activision\Call of Duty 2
Hitch warning: 4022 msec frame time
tu bi moralo še kaj biti pa ni nič ?
Winsock Initialized
Hostname: abakus
IP: x.x.x.x
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
- premaknilo iz Pomoč in nasveti: bastadu ()
matvoz ::
CoD2MP_s.exe +set dedicated 2 +exec server.cfg
verjetno ne dela, ker nimas server.cfg
oz. ce je to config_mp.cfg, pol ne vem :)
meni z zgornjim ukazom deluje.. tako preko racunalnika kot tudi preko remote desktopa..
Kami ::
Jap, logika da ne dela, ker binda port na localhostu in pol je dosegljiv smao z localhosta.
Bindaj port na private IP-ju (LAN IP-ju tvojega PC-ja) pol bi pa moglo delat.
Nekak tak je mensezdi
+set net_ip 192.168.0.100:28960
Ja imam samo public IP, pa sem dal njega notri, pa je identičen rezultat...
OK:
Alfa.cfg je pod main direktorijem
1. Komanda
"C:\Program Files\Activision\Call of Duty 2\cod2mp_s.exe" +set dedicated 2 +set net_ip X.X.X.X:28960 +exec alfa.cfg
CoD2 MP 1.0 build win-x86 Oct 6 2005
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Activision\Call of Duty 2\main\iw_14.iwd (4038 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_13.iwd (22624 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_12.iwd (1016 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_11.iwd (1462 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_10.iwd (1936 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_09.iwd (2142 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_08.iwd (2723 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_07.iwd (3384 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_06.iwd (990 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_05.iwd (928 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_04.iwd (698 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_03.iwd (26 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_02.iwd (40 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_01.iwd (16 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_00.iwd (102 files)
C:\Program Files\Activision\Call of Duty 2/main
C:\Program Files\Activision\Call of Duty 2/raw
C:\Program Files\Activision\Call of Duty 2/raw_shared
C:\Program Files\Activision\Call of Duty 2/devraw
C:\Program Files\Activision\Call of Duty 2/devraw_shared
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
localized assets iwd file for english
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
couldn't exec players/erchi/config_mp.cfg
execing safemode_mp.cfg
========= autoconfigure
configure_mp.csv: using CPU configuration 0 GHz 512 MB
execing configure_mp.cfg
configure_mp.csv: using GPU configuration "*"
Measured CPU speed is 1.69 GHz
System memory is 768 MB (capped at 1 GB)
Video card is "RDPDD"
Winsock Initialized
Opening IP socket: X.X.X.X:28960:28960
WARNING: UDP_OpenSocket: bind: WSAEADDRNOTAVAIL
Opening IP socket: X.X.X.X:28960:28961
Opening IP socket: X.X.X.X:28960:28962
Opening IP socket: X.X.X.X:28960:28963
Opening IP socket: X.X.X.X:28960:28964
Opening IP socket: X.X.X.X:28960:28965
Opening IP socket: X.X.X.X:28960:28966
Opening IP socket: X.X.X.X:28960:28967
Opening IP socket: X.X.X.X:28960:28968
Opening IP socket: X.X.X.X:28960:28969
WARNING: Couldn't allocate IP port
execing alfa.cfg
sv_maxclients will be changed upon restarting.
sys_configSum is write protected.
sys_cpuGHz is write protected.
sys_gpu is write protected.
sys_sysMB is write protected.
Hitch warning: 3644 msec frame time
2. Komanda :
"C:\Program Files\Activision\Call of Duty 2\cod2mp_s.exe" +set dedicated 2 +set net_ip X.X.X.X +exec alfa.cfg
File Handles:
execing players/erchi/config_mp.cfg
Winsock Initialized
Hostname: COD_Server
IP: X.X.X.X
execing alfa.cfg
Hitch warning: 3613 msec frame time
3. komanda:
"C:\Program Files\Activision\Call of Duty 2\cod2mp_s.exe" set dedicated 2 +exec alfa.cfg
File Handles:
Winsock Initialized
IP: X.X.X.X
execing alfa.cfg
Hitch warning: 3628 msec frame time
1. Komanda
File Handles:
Winsock Initialized
execing alfa.cfg
2. Komanda :
File Handles:
Winsock Initialized
IP: X.X.X.X
execing alfa.cfg
3. komanda:
File Handles:
Winsock Initialized
IP: X.X.X.X
execing alfa.cfg
fs_game is write protected.
map_rotate...
"sv_mapRotation" is:""
"sv_mapRotationCurrent" is:""
No map specified in sv_mapRotation - forcing map_restart.
Server is not running.
Hitch warning: 3645 msec frame time
map_rotate...
Kot pričakolcal od ST.
map mp_downtown
map mp_downtown
» | Kako narediti svoj server v Call of Duty 2 ?Oddelek: Igre | 8668 (2328) | deadzone |
» | CoD Problemi (strani: 1 2 )Oddelek: Igre | 10695 (6668) | hojnikb |
» | Call of duty 2!ne dela server!problems!Oddelek: Igre | 5361 (3363) | ViperR |
⊘ | COD 2 ne delujeOddelek: Igre | 2712 (1721) | Heavy |
⊘ | cod2 server problemi[pomoč please]- modem???Oddelek: Igre | 2426 (2352) | Mavrik |
