Forum » Igre » GTA 4 PC
GTA 4 PC
T-Majo ::
Statistics
Average FPS: 11.09
Duration: 37.23 sec
CPU Usage: 98%
System memory usage: 89%
Video memory usage: 99%
Graphics Settings
Video Mode: 1280 x 800 (60 Hz)
Texture Quality: Low
Render Quality: Medium
View Distance: 5
Detail Distance: 5
Hardware
Microsoft® Windows Vista" Ultimate
Service Pack 1
Video Adapter: NVIDIA GeForce 8800 GTS
Video Driver version: 180.48
Audio Adapter: Speakers (High Definition Audio Device)
Intel® Core™2 CPU 6400 @ 2.13GHz (ubistvo je navit na 2.88)-edit
File ID: Benchmark.cli
Average FPS: 11.09
Duration: 37.23 sec
CPU Usage: 98%
Graphics Settings
View Distance: 5
Detail Distance: 5
Hardware
Service Pack 1
- spremenil: T-Majo ()
janwoolf ::
imam problem. ko zaženem igro pa pokaže
"GTA IV FATAL ERROR:RMN40"
kaj naj naredim??
kaj naj naredim??
C2D E8400, Crucial Ballistix Tracer 2x1gb PC-8500,
P5K-E, XFX 8800GTS (G92) 512MB,Antec nine hundred
cooling 4x120mm and 1x200mm, Enermax Infiniti 650W
Tr0n ::
Rockstar je objavil listo error codes in sicer tukaj.
RMN40 - Windows XP: Need to have Service Pack 3 or higher to proceed.
tx-z ::
Kako vam je ratal povečat resolucijo? A morš nujno met 512MB ali večjo grafično da sploh lah povečaš? :O Sej se more dat tut kko drgač :/
tx-z
Goldee ::
Sam to je pa že smešno - singleplayer ne moreš več igrati offline. No, igraš lahko, shraniti pa ne moreš? Pa tudi grafika ni bogve kaj. Oziroma moja 3850 sopiha pri 20 fps, na medium nastavitvah (Atlhon 4400+ in 2gb rama). Mal bedno.
janwoolf ::
@tron
hvala!
spet imam problem, ko zaženem igro meni pokaže
"GTA IV requires a sound card in order to run"
sem dal program realtek AC97, ne pomaga
hvala!
- spremenil: janwoolf ()
Tr0n ::
Katero zvocno pa imas? Imas zadnje gonilnike oz. namesti si zadnje gonilnike za tvojo zvocno (najdes jih ja domaci strani od tvoje maticne plosce ASUS).
- spremenilo: Tr0n ()
samsung113 ::
Nabavi si original!
janwoolf ::
jaz imam integrano zvočno kartico. ne vem katera PCI audio, USB audio, PCI-e audio...
Tr0n ::
Saj pravim, na ASUS strani si presnami audio gonilnike za tvojo maticno. ASUS ima ponavadi SoundMAX.
http://support.asus.com/download/downlo...
janwoolf ::
hvala
Berserker ::
Mogoče je tole offtopic, ker si omenil soundmax me zanima zakaj mi včasih ko recimo sredi igre hrešči in odmeva zvok ko hočem pač na namizje pa mi zašteka čez čas mi končno gre in mi napiše da moram soundmax izbrisat oz. reinstalirat. To mi dela odkar imam novo zvočno.
godi ::
Fantje a je možno da men tk slabo laufa zarad procesorja mam e6750 pa 8800 gt, na 1024x768 pa ni važno al dam na high al pa na low je isti k.?
- polepsal: OmegaBlue ()
OChack ::
ja to je konkurenca crysisu :)
zdej ni več pomembno kok dobro igralno igro nardiš ampak kok zajebano da ti hardwer poklekne
Int€l inside, IDIOT Outside
janwoolf ::
me zanima kako naj shranim.. piše da moram registirat, a morm? kje se dobi cd key..
OmegaBlue ::
Na škatli.
janwoolf ::
nemam originala...
OmegaBlue ::
Potem se prijazno odstrani iz teme.
FrancBula ::
fantje ne da se mi cele teme brat.
je že kdo omenil problem z grafiko na ati grafičnih?
linije sploh niso ravne, ampak je vse nazobčano in so kvadratki.
verjetno treba počakat na nove drajverje?
GA-P35-DS3(rev. 1.0) ; E5200@3.75GHz ; Palit Radeon 4850 ; LC8650 Ozeanos
Goldee ::
Nabavi si original!
To ni odgovor. Zanima me, kaj je fora, da moraš online shranjevati progress v igri?
AapocalypseE ::
Sem se prijavo na social club in dobil e-mail od njih. Problem nastane pri account linking. Dam pod games for windows ADD in sign in. Tukaj potem nevem kaj naret. Če dam mail not, ki sem se prijavo z njim ne gre, če pa dam not mail od msnja pa mi napiše: A LIVE Gamertag was not found with the current Live ID
Lahko kdo pomaga pls, ker mi ne gre sejvat igre zarad tega.
Benchmark:
Benchmark:
- spremenil: AapocalypseE ()
Steinkauz ::
Statistics
Average FPS: 37.30
Duration: 37.21 sec
CPU Usage: 82%
System memory usage: 58%
Video memory usage: 83%
Graphics Settings
Video Mode: 1600 x 1200 (60 Hz)
Texture Quality: Medium
Render Quality: High
View Distance: 25
Detail Distance: 100
Laufa na:
E8400 @ 4,2ghz
Radeon 4850
4gb ram
Average FPS: 37.30
Duration: 37.21 sec
CPU Usage: 82%
Graphics Settings
View Distance: 25
Laufa na:
E8400 @ 4,2ghz
Radeon 4850
4gb ram
Tac20 ::
Ta igra je res čarobna, če izberem resolucijo 1680x1050 in poženem benchmark na medium imam okoli 32 fps, če znižam resolucijo na 1280x720 imam manj kot 30 fps average:)
hardware: HD4870, E6320@2800, 4GB rama
Očitno igra res potrebujeo procesorsko moč, dosti bolj kot zmogljivo grafično
- spremenilo: Tac20 ()
GLAVNI ::
ALO, zakaj meni ne dela. Mam original. Mam gor SP3, pa me sploh ne da not v igro. V program files nimam niti gtaIV.exe fajla, ko kliknem gumb na namizju, me sploh noče not dat, offline account nočem zagnat, da ne bi gesla v prazno zapravo ... Kaj naj naredim???
Tik pred formatiranjem winsow sem...
- spremenil: GLAVNI ()
Scuba ::
1. Uninstall
2. Reinstall
4. Naredi accounte na LIVE in R* Social club
3. Registriraj lepo, lahko tudi offline(ne zapraviš nič)
5. Zaženi Social club in špil štartaj od tam.
2. Reinstall
Guns don't kiil people. Husbands who come home early do.
Galaxy ::
Priporočam ti formatiranje. Jaz sem to naredil. Deluje kot solzica!
mato2002 ::
Po prebranem mi ni čisto jasno če lahko
igrico sploh inštaliram na pc ki nima interneta
in če lahko potem tudi shranim.
tx-z ::
zakaj ne morem dati resolucijo niti na 1280x800? Piše da ima grafična premalo spomina 320MB oz. 297MB. Se da pod control panel spomin povečati (odvzeti od rama)? Ok. Sem ugotovil. Imam glih enih 5fps. Joj...
Explain please.
tx-z
MeGreat ::
jaz imam 1gb rama, 7900gt grafično ter e6300 procesor. ali se mi sploh splača kupiti igro, bom lahko normalno igral ob najnižjih nastavitvah?
tx-z ::
Za primerjavo:
jst mam core2duo 2GHz, 2Gb 800MHz rama, ati x1950pro
Na vse na low(več itq ne morš spremenit), pa na resoluciji 1024*768 je tko tko...na 800*600 dela nekak normalno (seveda na low, kr več sploh ne morm nastavt kr mam samo 256MB rama), več k 1024*768 tut sploh ne morm nastavt; če bom kej naviu sistem bo najbrž se dal čist normalno igrat na 1024*768 vse na low.
tx-z
chicolino ::
Pomojem ko bo vnih patch bo vse drugace, ker ocitno dela probleme samo podpora za dolocen hardware. Ker mnogho ljudi po forumih ima dosti boljse racunalnike od mene pa jim dela slabse. Vecinoma majo intel procesorje, tko da mogoce bo kaj na temu.
Jaz trenutno jo igram na mid/mid draw in detail distance 50/50 shadows 0, promet 60 in mi dela popolnoma brez zatikanj, tudi ko pada dez.
AapocalypseE ::
Sem prvo dvomo, če mi bo delalo tekoče, ampak sem presenečen, da dela tak smooth. Mam vse na max. kar se lahko da z 512MB grafično in mam 40fps average.
T-Majo ::
Jaz sem pa procesor odvil na stock frekvence pa dosti hitreje dela (iz 2.88ghz na 2.13). Ne moreš da verjameš.
novinec1234 ::
Imam 4870 X2 in pri nastavitvah mi spodaj piše max ustage video memory 1024??? kaj to pomeni da zazna samo 1 grafično kartico?
Na High in 1280x1024 mi laufa cca 38 fps. 4GB 1033 in Phenom 9950.
Galaxy ::
Statistics
Average FPS: 39.14
Duration: 37.37 sec
CPU Usage: 94%
System memory usage: 82%
Video memory usage: 75%
Graphics Settings
Video Mode: 1680 x 1050 (60 Hz)
View Distance: 25
Detail Distance: 37
Average FPS: 39.14
Duration: 37.37 sec
CPU Usage: 94%
Graphics Settings
View Distance: 25
Detail Distance: 37
novinec, igra je še vedno polna bugov. počakaj na catalyst 8.12 in kakšen patch za igro
Zheegec ::
Ta špil je blazno buggasto napisan in slabo portan iz konzole. Grafika je čisto povprečna, zahteve pa astronomske. Pa vsaj pol jih dela težave (originalnih)...
Janez Janša, 29.04.2014
Berserker ::
Kak bi kaj delalo z gf9600gt, 2gb ram, dualcore 2. 9 ghz. A bi šlo vsaj na low?
- polepsal: Mavrik ()
laught ::
Ja logično da bi ti šlo,probaj pa boš videl,moj kolega ma slabši komp pa mu špila na medium.
Meizu ::
Tr33k poglej si kšne filmčke na Youtube kjer igrajo z 9600GT in jim dela kr okej zadeva. Celo s teksturami na medium.
GLAVNI ::
Res dela super. Hvala vama!
Slo-One ::
Fak sami bugi. Sam osebno imam samo tistega, ki je itak najbolj tečen. Sence. Kr premikajo se ko nore. Mam ATI grafo. A kdo ve kak popravit?
Tr0n ::
Stari gonilniki verjetno.
Za nVidia uporabnike so na nZone na voljo GTA4 optimized gonilniki.
Grand Theft Auto IV—Downloads
/alien\ ::
http://forums.steampowered.com/forums/s...
a je kdo kej probavov tole za grafiko. mene jebe omejitev za ram. igra dela drgač presenetljivo lepo
» | ATI Radeon HD 5850 (strani: 1 2 3 4 5 6 7 )Oddelek: Strojna oprema | 25282 (12995) | Xserces |
» | GTA4 - menjava procesorjaOddelek: Kaj kupiti | 4221 (2935) | Ancalagon |
» | GTA IV PC Benchmarks (strani: 1 2 )Oddelek: Igre | 11061 (6603) | CaptObvious |
» | Nasvet za upgrade Motherboard in Procesor (strani: 1 2 )Oddelek: Kaj kupiti | 7104 (5549) | ncc2000 |
» | procesor za GTA IVOddelek: Kaj kupiti | 3304 (2076) | samsung113 |
