Forum » Problemi človeštva » Peticija proti gradnji plinskega terminala v tržaškem zalivu
CCfly ::
- okolje bo zaradi 800 ton varikine letno najbrž zelo nastradalo
Citiram crni-ja:
Kinda like sodium chloride. That'll kill ya. Or the chlorine in the swimming pool, you know, the one that's supposed to keep that one clean. Quantities don't mean shit, it's the concentration that's important. Besides, they might even have some kind of reduction filters at the end, to reduce the chlorine to chloride. And if we are talking cold water being pumped back into the sea, that might not even be that bad. If I remember correctly the overabundance of nasty algae about 10 years ago might have been because the water was too warm. I can't say that I approve the LGT, but I think a lot of the stuff that's said about it is totally overblown and spread by some envionmentalists who are definitely not any kind of experts on the technical points.
vir: Carniola
- zaradi ohladitve vode izumrtje nekaterih živalskih vrst
Prej bodo krivi za izmrtje ribiči, kot pa za nekaj stopinj hladnejša voda 200m okoli terminala. Totalna bedarija.
- potencialna ogroženost zaradi terorizma
Naj razmislim. Terorist se bo zapeljal do Kopra, se vkrcal na gumenjak in veslal do temrinala, ki spada pod varovano območje. Yeah right.
- na izgled grd terminal, ki bo zastiral pogled
Nič manj kot zasidrana ladja.
Citiram crni-ja:
vir: Carniola
"My goodness, we forgot generics!" -- Danny Kalev
gzibret ::
Samo še vedno ne vem, zakaj ne morejo tega terminala zgradit na obali? Zakaj glih na sredi morja?
Vse je za neki dobr!
drejc ::
Jah, če bo speljan do obale, potemtakem sklepam da bo tut manj temu namenjenega prometa ob obali, manj sranja ob obali... če je tako potemtakem je terminal na morju ne samo dobra, ampak odlična rešitev.
"Rise above oneself and grasp the world"
- Archimedes of Syracuse
krneki0001 ::
Zato ker ob obali ne morejo cevi prat z varikino - bi bila prevelika koncentracija ob obali.
poweroff ::
Ja, ampak saj varikina ni nič škodljiva, ali kako?
Mislim, če ne bo vplivov v sredini zaliva, jih tudi ob obali ne bo, kali?
sudo poweroff
BluPhenix ::
Mislim da je tukaj bolj zaradi varnosti. Tako v primeru da gre kaj narobe pri precrpavanju. Če se to zgodi na morju, bo pac BooM. Če pa se kaj takega zgodi ob obali bo pa boom in katastrofa.
Podpisa ni več, ker so me poskušali asimilirati.
Thomas ::
> Kako zelo je pa sploh vnetljiv plin pri -162?
S pomočjo kakšnega raketnega izstrelka ali torpeda se že segreje toliko, da se vname, pa ogreva še tekočega, za sprotno rabo gorenja.
Ena raketa/bomba bi ga lahko zažgala. Samo, če bi to bilo na morju, bi z obale samo izgledalo spektakularno.
Cofko Cof ::
Thomas bo kdo še kšno napačno idejo dobu. Recimo ognjemet na morju :D
Ars longa,vita brevis.
Thomas ::
Se bojim, da te ideje že imajo. Ene 1972 so v Trstu že zažgali skladišče nafte. Iz Vrsarja je bilo na moč podobno gobi atomske bombe.
A kdo je zažgal?
Palestinci.
A kdo je zažgal?
Palestinci.
- spremenil: Thomas ()
poweroff ::
Se pravi je tudi varnost kar naenkrat problem? Ker če je, potem se lahko nadejamo strožjega režima na morju.
A niso ravno tega "ekologi" navajali kot argument proti LOKACIJI?
P. S. Bravo Thomas, to je "dokaz", da so imeli Palestinci že v 18. stoletju jedrske ambicije....
sudo poweroff
Thomas ::
Po tej logiki podrimo vse gozdove. Da ne pride do požara!
1972 NI 18. stoletje. So pa Arabci imeli nuklearne ambicije že vsaj 1952. Naser je takrat delal umazane bombe s pomočjo ex nacijev. Dokler jih Mosad ni razturil.
p.s.
tudi 1952 NI 18. stoletje.
p.s.
Stepni Volk ::
Zadnjo Izraelsko / Palestinsko temo imata tukaj: Izrael vs. Palestina. Tu ostanimo pri plinskem terminalu.
poweroff ::
Se opravičujem glede 18. stoletja, sem malo narobe prebral letnico.
Cikam pa na to, da do prejle argument o nevarnosti sploh ni bil resen argument. Zdaj, ko bi se lahko pokazala "jedrska" goba je pa nenadoma to resen argument.
sudo poweroff
Thomas ::
Bencinsko pumpo tudi delajo tako, da je čimmanj nevarna.
Je pa "argument" - pumpe so nevarne, ne jih postavljat - precej zelen.
krneki0001 ::
Par zadev zakaj ni tega na obali;
1.) Tok je v sredini zaliva močnejši kot ob obali in zato hitreje meša in odnaša varikino, ki jo spuščajo skozi cevi.
2.) ker je zadeva na odprtem in je manj možnosti, da bi jo potencialni teroristi probali kej uničit( večji nadzor je če je vsenaokrog morje)
3.) Manjša nevarnost za obmorske kraje, če to raznese v vodi, kot pa če raznese na obali.
4.) Ker na obali ni dost placa za kaj takega - sploh pa ne v tem delu, kjer sta na eni strani luka koper na drugi pa luka trst
5.)ker s tem ne bodo ladje vozuile v luko, ampak bodo na morju pretakali plin - manj prometa v notranjost luke( osnovnega prometa bo enako, samo povečal se zaradi tega ne bo drastično).
Thomas ::
Seveda. Mislil si, da sem to gledal v 17. stoletju, ko je bilo v Trstu že skladišče nafte, ki so ga zažgali Palestinci.
Pajade.
Pajade.
poweroff ::
Ja, včasih je treba dvakrat pogledati - se posipam s pepelom.
Vendar se s podobnimi nelogičnimi prepričanji srečujem vsak dan, tako da me ne bi presenetilo, če bi kdo na forumu zagovarjal kakšno butasto tezo o tem, da so Palestinci že pred 500 leti razvijali jedrsko orožje.
Konec koncev smo poslušali precejšnje bedarije glede WMD v Iraku, pa tudi glede ekoloških vprašanj.
sudo poweroff
Stajerc ::
Še nekaj dejstev v številkah:
800 ton varekine letno (ampak ob dejstvu da se na dnu tržaškega zaliva že nahaja 30.000 ton živega srebra) kakšna je kombinacija? (tržaški zaliv je tudi dokaj plitek)
Največja globina tržaškega zaliva je 24 metrov ladje pa imajo ugreza 17 m
Osem milijard kubičnih metrov zemeljskega plina letno kar znese 200 ali več ladij letno
Ne gre samo za eden terminal na spornem mestu - morski ampak za 2 ki bi vplivala na nas in sicer morski in kopenski.
spremenjen bo režim plovbe, zaradi ostrih varnostnih ukrepov bo prosta plovba skorajda onemogočena.
Zdaj pa politika:
investitorji prizadetim lokalnim skupnostim v Italiji zagotovili različne kompenzacije, ne pa tudi slovenskim
guverner Furlanije - Julijske krajine Ricardo Illy vpleten tudi z lastnim vložkom, saj je skupaj z Endeso ustanovil mešano družbo. (močan politični pritisk in oseben interes napram strokovnem mnenju)
Na vprašanje slovenski strani:
kdo bo na današnji okrogli mizi v Rimu, kjer bo investitor predstavil tehnične podatke o terminalih, zastopal slovensko stališče ?
Odgovor:
da kljub prizadevanjem Slovenija na sestanek ni povabljena
Torej v čem bi slovenija z temi terminali pridobila? Bi kaj izgubila? Mislim človek ne more mimo dejstev pač nikoli drugače se slepi! Lahko se gleda na to kot politika zelenih lahko pa se tudi z čisto gospodarske plati kjer bo slovenija izgubila.
Mi se ne prepiramo namreč o terminalu ki bi ga mi radi zgradili in mi imeli koristi od njega ampak ga gradi nekdo drug na našo škodo. npr. tuja tovarna kemičnih čistil na tvojem dvorišču tebi pač ne prinese koristi neglede na dobičke ki se v njej ustvarjajo.
Navedki so iz časopisa Večer in sem jih pač napisal še vam ker semi zdijo zanimivi in preverljivi in niso iz moje glave da mi nebo kdo kaj očital ampak povejo pač bistvo te zgodbe (seveda pa manka strokovna študija katere pomojem nikoli nebo) Zakaj le?
Zdaj pa politika:
Odgovor:
Have a nice day.
Thomas ::
Sej zdej bo Prodi taglaven v Italiji. Levičar, s podporo komunistične prenove in tako naprej. Se boste pa že zmenili z njim, da bo za vse prav!
perci ::
Thomas ima očitno rajš mafijo na oblasti kot Prodija. Sam, da ni lev pa je dober - tut če je kriminalc.
Thomas ::
Italija je v globji krizi, kot jo je bil sposoben odpraviti Berslusconi, pa ne tako globoki, da je Prodi ne bi še poglobil.
BluPhenix ::
Thomas, pač ne poznaš dogajanja v italiji. Sej, se lahko zgodi vsakomur.
Berlusconi italije ni spravil nikamor, razen v irak. Precej je poglobil jamo dolgov in razslojil italijo na bogate, super bogate in revne, super revne. Toliko je naredil. Zdej pa trobi kolikor hočeš. To tvoje, kot je že napisal perci "samo da ni levica" je že smešno. In kot je napisal perci, raje vidiš kriminalca na oblasti. Ja je kriminalec, kakorkoli pogledaš. Še ne veš zakaj je Berlusconi stopil v politiko? Za boljšo italijo, ja, to bo to... Zato da bi ušel sodnemu pregonu za kup obtožnic, ne, to pa sigurno ne ...
Aja, to je tema o terminalu.
_sem_ ::
Kaj bi rekel Tržaški župan na projekt druge slovenske nuklearke vizavi plinskega terminala???
krneki0001 ::
Vode za hlajenje reaktorja je ogromno, če jo pa skupaj s terminalom združimo bo pa plin ohlajal nuklearko, pa še zeleni nimajo kej za težit, ker ne bo okolje zasvinjano, ker ne bo treba uporabljat morske vode.
BluPhenix ::
nebivedu: hlajenje nuklearke? Mislis na tisto vodo, ki je v zaprtem krogu, ki jo reaktor uparjuje, da lahko s paro poganja turbine in potem le-to utekocinja nazaj v ohlajevalnikih? To bi blo dobro kombinirat s plinom. Ne ne sej hecam.
Glede "hladilne" vode ... heh ja pol bi prisla nazaj v morje z isto temp.
perci ::
Mislm, poglejte kok ma Sava pretoka, pa jo nuklearka vseeno segreje za kako stopinjo. Zdej vi bi pa kar greli uno vodo iz terminalov? Ja hudiča, zakaj ne bi potem z nuklearkami raje ogrevali vode za ogrevanje stanovanj, namesto, da si sploh gradijo terminal? Pa zakaj elektrarne Krško za to ne uporabljajo? Zakaj sploh mamo toplarne, ce bi se pa lahko vse z nuklearko spedenal, pa se nic dodatnega goriva ne bi bilo porabljenega??? Najbrz ni tok simpl, ane.-
Perci, je problem, to vodo speljat po domovih.
Toplarna je malo bliže, se mi zdi. Če ti pa uspe ljudi prepričat, da bi investirali v toplovod iz nuklearke...
perci ::
Toplarna je v LJ tam na Zaloški - Fužine. V spodnji šiški voda iz te toplarne brez problema ogreva stanovanj.
Thomas ::
JT - jedrska toplarna, za ogrevanje stanovanj in sanitarne vode, bi bila dobra stvar. Vprašaj Zelene! Povej jim, da potem mogoče odpade pa terminal v morju in vetrnica na Volovji rebri.
Navdušeni bodo!
Navdušeni bodo!
perci ::
Ja, jst mislm, da ta zadeva niti ni možna, ker za jedrski reaktor rabs ti veliko kolicino vode da ohlajas reaktor in to lahko dobis samo iz reke. Ne mores pa potem reke pumpat v radiatorske cevi, menda. Mislm, ce se da, me zanima zakaj tega nikjer se ni. Mal dvomim, da smo se mi na ST-ju prvi tega spomnili. Nek keč mora bit.
Azrael ::
Sistem, da so termo elektrarno uporabili kot toplarno, za ogrevanje mesta, je bil na Jesenicah v uporabi do decembra 2003, ko so po 60. letih obratovanja dokončno ustavili parno elektrarno.
Ta elektrarna je imela inštalirane moči le okoli 10MW in je zadoščala za ogrevanje Jesenic in za potrebe industrije (para in topla voda).
Jedrska elektrarna ima IMHO preveč moči (termična moč reaktorja je ~3x večja od moči na pragu elektrarne), da bi hlajenje kot toplarna zadoščalo in bi v vsakem primeru potrebovali še hladilne stolpe ali reko z dovolj velikim pretokom.
Zdi se mi pa, da so v bivši SZ uporabljali nuklearke tudi kot toplarne, na Zahodu pa zaradi paničnega strahu pred radiacijo ne.
Nekoč je bil Slo-tech.
Pyr0Beast ::
10MW električne moči je bore malo. 10MW toplotne je pa kr veliko.
V rusiji se toplarne na JE že dolgo uporablja. V povprečnem stanovanju (dobro ogrevanem) je pozimi okoli -20°C, zunaj je okoli -60°C. Če vzamemo, da ima hladilna voda JE okoli 20°C se to splača zelo. Pri nas je pa razlike med T vode JE in temp. stanovanj 3°C (t hladilne vode JE 22-24°C/stanovanje 20°C). V savo gre okoli 1GW toplote. Če vzamemo, da je za povprečje potrebno okoli 1.5kW na osebek je to zadosti za 'ogrevanje' ~ 600k folka (dalo bi se zvišati na 35°C, če bi bilo v interesu vodstva JE). IMO se bolj splača ogrevati z toploto iz JE (100 SIT/MWh), kot pa z toploto proivedeno z štromom (15000/MWh)
gzibret ::
Sej radiacija ni problem. Tele JE zahodnega tipa imajo dva ločena krogotoka vode. Ona voda, ki jo neposredno greje uran, je zgolj v reaktorju (pod pritiskom, da se lahko segreje do cca. 160 stopinj). Uparjalnik pa je zato, da upari sekundarni krogotok vode. Ni pa nobenega fizičnega stika med obema vodama.
Pa če bi zeleni še vedno protestirali, pa bi lahko naredili še en izmenjevalec toplote, ki bi grel vodo v terciarnem krogotoku.
snow ::
Puste JE tu zdej na mir.
800 ton varikine na leto? En je pa prej rekel peroksid? S čim zdej?
Kakšen je volumen vode v zalivu - tja kamor se bo ta varikina zlivala?
Random mutation plus nonrandom cumulative natural selection - Richard Dawkins
_marko ::
Na koliko časa se bo ta zalivksa voda zamenjala ter premešala z še večjim volumnom?
The saddest aspect of life right now is that science
gathers knowledge faster than society gathers wisdom.
Thomas ::
Hehe, BW ... homeopatski učinek bo seveda blagodejen.
snow,
S koliko morja se zmeša tista varikina? Z vsaj 1000 kubičnimi kilometri morja. Toliko, da tiste varikine ne ločiš več od vse ostale svinjarije nikakor.
Torej tona varikine na kubični kilometer morja. Ena proti milijardo. Preveč koncentrirano za vsako homeopatsko uporabo.
snow,
snow ::
Aha se pravi koncentracija je ranga ppb. Se pravi 0 - vsaj kar se oksidativnega učinka tiče.
_sem_ ::
Tole je en bolan forum.
Človek navrže eno JE kot očitno provokacijo, tehnično udarjeni ljudje pa ti takoj začnejo računat energetske in sinergetske učinke.
In tuhtat o blagodejnih možnostih uporabe odvečne toplote iz TE in JE za ogrevanje, pri čemer v Mostah že leta stoji fabrika z imenom TE-TOL. Izumili toplo vodo
Namontirajte si že vendar pedale pod mizo in se sinhronizirajte z omrežjem!
gzibret ::
_sem_> Človek navrže eno JE kot očitno provokacijo, tehnično udarjeni ljudje pa ti takoj začnejo računat energetske in sinergetske učinke.
Pol pa povej, zakaj tak sistem ne obstaja v NEK Krško.
Jux ::
_sem_: HAHAHA: "Namontirajte si že vendar pedale pod mizo in se sinhronizirajte z omrežjem!
You made my day!
You made my day!
web&blog&etc: http://lukabirsa.com
Thomas ::
BANANA okoljevarstvena politika:
Build Absolutely Nothing Anywhere Near Anything
keber ::
Thomas, da ti pomagam pri debunkanju:
Iz tukajle:
Naj si koncentracije 2 kubična metra peroksida dnevno potem vsak izračuna sam, potem pa govori o ekološki katastrofi . Ah seveda, pa še to sem pozabil. Menda "okoljevarstveniki" ne mislite, da to varikino kar direktno spuščajo v morje, je malček predraga
Iz tukajle:
ECOLOGICAL INFORMATION
ECOTOXICOLOGICAL INFORMATION:
Channel catfish 96-hour LC50 = 37.4 mg/L
Fathead minnow 96-hour LC50 = 16.4 mg/L
Daphnia magna 24-hour EC50 = 7.7 mg/L
Daphnia pulex 48-hour LC50 = 2.4 mg/L
Freshwater snail 96-hour LC50 = 17.7 mg/L
For more information refer to ECETOC "Joint Assessment of Commodity Chemicals No. 22, Hydrogen
Peroxide." ISSN-0773-6339, January 1993
CHEMICAL FATE INFORMATION: Hydrogen peroxide in the aquatic environment is
subject to various reduction or oxidation processes and decomposes into water and oxygen. Hydrogen
peroxide half-life in freshwater ranged from 8 hours to 20 days, in air from 10-20 hrs. and in soils from
minutes to hours depending upon microbiological activity and metal contaminants.
» | Plinski terminali v ŽavljahOddelek: Znanost in tehnologija | 1382 (1111) | Icematxyz |
» | V boju proti podnebnim spremembam so obnovljivi viri boljša rešitev kot nuklearna ene (strani: 1 2 )Oddelek: Problemi človeštva | 29686 (28809) | steev |
» | Potem bo pa Rus pipo zaprl... (strani: 1 2 3 4 5 6 )Oddelek: Problemi človeštva | 25407 (19304) | Brane2 |
» | Z umetniškim projektom proti (plinskim) terminalomOddelek: Problemi človeštva | 1745 (1291) | Thomas |
» | GazpromOddelek: Problemi človeštva | 2129 (1415) | jype |
