Forum » Programska oprema » 3DMark 2006
3DMark 2006
Tr0n ::
V sredo, 18. januarja @ GameSpot.
# DirectX® 9 3D game performance benchmark
# Includes separate graphics card and CPU benchmarks
# Produces workloads that simulate next generation 3D gaming requirements
# Advanced 3D game engine supports HDR Rendering with SM3.0 Shaders, in addition to SM2.0 Shaders
# Includes two HDR/SM3.0 game tests and two SM2.0 game tests
# CPU performance testing via AI and physics workloads for both single core systems and multi-threaded, multi-core and multiple processor environments
# 3D graphics feature tests include Fill Rate, Pixel Shader, Vertex Shader, SM3.0 tests, and Batch Size tests
NICE
To sem napisal na enmu forumu: I really think that it won't run smoothly on my X800 XT PE. :(
- spremenil: mtosev ()
flipflop ::
Huh, tiste 3 slike so najbrž iz programa? Hudo zgleda, škoda da bom diapozitive gledal. Če bom sploh kej gledal.
Seveda.
Seveda.
Goldee ::
Komaj sem nabavil graficno, da lahk gledam tekoco sliko v 3d Mark 05 - pa je zunaj 06, ko bodo spet diapozitivi, kot s prejsno v 05.
speed machine ::
Še en intervju s futuremark ter seveda predstavitev novega 3d marka.
Zgleda, da je bil tale 3D mark ustvarjen, da izkoristi do konca zadnjo generacijo grafičnih kartic(zato tudi številka 06 in ne 07, kot bi bilo za pričakovati), vmes pa že delajo na novem (verjetno bo primarni cilj DX10).
Finally, are you making it a DirectX 10 benchmark, perhaps with a 9.0c fallback for XP systems or still exclusively DirectX 9?
The next 3DMark is a DirectX9c benchmark for Windows XP. The next next 3DMark is something completely different...
pipy ::
No na nvnews forum-u je objavljen en link za downlodanje. Sicer je malce gre malo bol počasi (ene 35k) pa velikost je tudi 550MB.
http://files.tcmagazine.info/futuremark/3DMark06_v102_installer.exe
(PS.: pa da nebote preveč navali)
pipyemall
MasterMiG ::
Večina strani jo že ma na serverjih, najhitrej gre pa na Guru3d serverjih (baje).
Je pa tale ta nov 3Dmark dost hud, mislm kakšna grafika, kt fotografija skor. Sam škoda, ker komi nabavm eno grafo, s kero mam mal več v 3dmarku (8363), pride nov 3dmark, s katerim mam sam 3500 in sm tm kjer sm bil prej z x700pro
There is nothing to fear but the fear itself.
chucki ::
3776pik z GF 7800GT oc na GPU: 450mhz RAM:1230 mhz
aja pa skoda ko ne mores resolucije spreminjat na free verziji in ti da auto na 1280x1024
sid911 ::
a mogoče kdo ve zakaj mi računalnik frizne ko dam za 3dmark06 prioriteto v stvarnem času ter kliknem na run 3dmar06...miška se malo permakne še, nato pa frizzz
aja...1955 točk z x800xl na 438/570...na defoult ( 400/490) pa 1713..beda
1. Asus P8P67 LE | i3 2100 | HD 3850 | 2x4GB | 320 GB + 2 TB
2. FSC Amilo PRO V3515 ( T2060;2 GB;80GB)
- spremenil: sid911 ()
macgajver ::
jest sm demo pognou demo je na 1280-1024 privzeto laufov
score:2549 nevem če je to glih dobr grafika je pa najhujša za pogledat
6800gt 400/1110
amd xp 3000+
1024 ram
ko registriram zadevo bom naredil se nekaj testov 1024-768
6800gt 400/1110
amd xp 3000+
1024 ram
tenstan krompir je pa zakon
Highlag ::
Ja nimaš kaj. Resolucija 1280 x 1024 je največkrat uporabljena na LCD-jih, ki so postali v zadnjem času zelo popularni.
Moja GF 6600GT doseže celih 1338 markov na A64 3000+ in 512MB rama
To je pač test, ki je namenjen predvsem za mašine ki prihajajo. Glede na to kako igrice, ki sem jih zadnje čase vrtel, delujejo na moji mašini bi rekel, da je že preslaba. Se pa samo zaradi 3d marka ne sekiram preveč. Normalno so mi na mojih računalnikih ponavadi tekli le 2-3 leta stari 3dMarki
Sam sem snel 3D mark zelo hitro preko torrent linka na uradni strani. Glede na to, da bo velika večina uporabnikov uporabljala le demo verzijo, bi lahko izdali še verzijo brez igre in s tem zmanjšali velikost paketa vsaj za 1/2.
macgajver ::
1024-786
3DMark Score 3047 3DMarks
SM2.0 Score 1376
HDR/SM3.0 Score 1311
CPU Score 799
podobn score mam kokr prej pr 3DMARK05 s 9800 pro
SM2.0 Score 1376
CPU Score 799
MasterMiG ::
Je pa tale 3D mark06 men precej bolj na kožo pisan kok 05. S t tastarim (3Dmark05) mi nikakor ni uspelo prehitet X1800XT na stock frekvencah, najdlje kokr sm pršu je blo 8363, kar pa ni niti približno blizu 9100, kokr jih doseže XT. Zdej se je pa to spremenil, na stock frekvencah doseže moja (X1800XL) 3171 rožk, XT pa 3700 pa še mal. Ko pa začnemo navijat, pa v 15 minutah presežem XT in sicer s 4033 točkami. Pa sploh niso ble še tko visoke frekvence (700/1300). Mislm, prej sm poganju tut že s 738/1440, pa ni blo haska. Sej pomoje bi se dal tm do nekje 4400 pridt, sam zaenkrat mam s šolo preveč dela
Gooodspeed ::
NEW 3d MARK 05 RECORD 11558 3DMarks on SLI 6800GS
KLIK
KLIK
- spremenilo: Gooodspeed ()
masterpsi ::
3DMark Score: 641
SM2.0 score: 307
CPU Score 717
CPU: AMD Barton 2500xp+ navit na 2600xp+
ram: 512MB DDR
grafična: Radeon 9600xt 256MB
SM2.0 score: 307
CPU Score 717
ram: 512MB DDR
Amdforce ::
1280-1024
3Dmark score 1730
AMD3700@ 2545
2*512 ram transcend informations
ASUS extreme 6600gt 550/1100
3Dmark score 1730
AMD3700@ 2545
- spremenilo: Amdforce ()
» | 3DMark06 rezultat XP in Windows 7Oddelek: Pomoč in nasveti | 838 (769) | xxxgeekxxx |
» | 3dmark06 scoreOddelek: Pomoč in nasveti | 943 (859) | Kristjan15 |
» | kako ugotoviti dejansko zmogljivost PC-jaOddelek: Strojna oprema | 2336 (2336) | Hister |
» | 3D Mark 2006 (strani: 1 2 3 )Oddelek: Novice / Ostala programska oprema | 14847 (9771) | kuglvinkl |
» | Izdan 3DMark05Oddelek: Novice / Grafične kartice | 3157 (3157) | lukanium |
