Forum » Pomoč in nasveti » Prehod iz kernel-2.4.26 na 2.6.10 in problem
Shaman ::
Problem je sledeci skompajlal sem drugi kernel 2.6.10-gentoo-r6 s podporo za vfat. Vendar, ko hocem mountat fat particije iz drugega diska mi javi naslednje:
mount: wrong fs type, bad option, bad superblock on /dev/hdb5,
or too many mounted file systems
Zadeva je zelo cudna, saj s kernelom 2.4.26 zadeva deluje.
Tu je moj fstab:
/dev/hda1 /boot ext2 noauto,noatime 1 1
/dev/hda3 / xfs noatime 0 0
/dev/hda2 none swap sw 0 0
/dev/hdb5 /mnt/hdb5 vfat exec,rw,umask=0,user 0 0
/dev/hdb6 /mnt/hdb6 vfat exec,rw,umask=0,user 0 0
/dev/hdb7 /mnt/hdb7 vfat exec,rw,umask=0,user 0 0
/dev/cdroms/cdrom0 /mnt/cdrom iso9660 noauto,ro 0 0
/dev/cdroms/cdrom1 /mnt/cdrom1 iso9660 noauto,ro 0 0
/dev/fd0 /mnt/floppy auto noauto 0 0
Kaksen nasvet.....???
Tu je moj fstab:
Shaman ::
# lsmod
Module Size Used by
snd_seq_midi 8512 -
snd_emu10k1_synth 7564 -
snd_emux_synth 38604 -
snd_seq_virmidi 7180 -
snd_seq_midi_emul 7340 -
snd_pcm_oss 53216 -
snd_mixer_oss 19468 -
snd_seq_oss 36512 -
snd_seq_midi_event 7404 -
snd_seq 54352 -
snd_ymfpci 58784 -
snd_vx222 13888 -
snd_vx_lib 37228 -
snd_via82xx_modem 16068 -
snd_via82xx 27488 -
snd_trident 44164 -
snd_sonicvibes 22404 -
snd_rme9652 29252 -
snd_rme96 24900 -
snd_rme32 23136 -
snd_pcxhr 32100 -
snd_nm256 69120 -
snd_mixart 39616 -
snd_maestro3 24356 -
snd_korg1212 40072 -
snd_intel8x0m 18628 -
snd_intel8x0 33408 -
snd_ice1724 60356 -
snd_ice1712 64260 -
snd_ice17xx_ak4xxx 3916 -
snd_ak4xxx_adda 5964 -
snd_cs8427 10028 -
snd_i2c 5708 -
snd_hdsp 54084 -
snd_fm801 16868 -
snd_es1968 30948 -
snd_es1938 22148 -
snd_ens1371 23108 -
snd_ens1370 17732 -
snd_ak4531_codec 7500 -
snd_emu10k1x 20740 -
snd_emu10k1 102372 -
snd_util_mem 4364 -
snd_cs46xx 88072 -
snd_cs4281 20928 -
snd_cmipci 31712 -
snd_ca0106 30180 -
snd_bt87x 14632 -
snd_azx 15104 -
snd_hda_codec 46476 -
snd_azt3328 18088 -
snd_au8830 63072 -
snd_au8820 36192 -
snd_au8810 55904 -
snd_atiixp_modem 17124 -
snd_atiixp 20356 -
snd_als4000 12036 -
snd_sb_common 15692 -
snd_opl3_lib 11372 -
snd_hwdep 9088 -
snd_mpu401_uart 7884 -
snd_rawmidi 24608 -
snd_seq_device 8664 -
snd_ali5451 24292 -
snd_ac97_codec 77472 -
snd_pcm 95016 -
snd_timer 25328 -
snd 56324 -
snd_page_alloc 9744 -
Upam da si mislil ta fajl:
# more /etc/filesystems
nodev sysfs
nodev rootfs
nodev bdev
nodev proc
nodev sockfs
nodev binfmt_misc
nodev pipefs
nodev futexfs
nodev tmpfs
nodev eventpollfs
nodev devpts
ext2
nodev ramfs
msdos
vfat
iso9660
nodev devfs
nodev nfs
nodev nfsd
nodev autofs
nodev rpc_pipefs
Module Size Used by
snd_seq_midi 8512 -
snd_pcm_oss 53216 -
snd_seq_oss 36512 -
snd_seq 54352 -
snd_ymfpci 58784 -
snd_vx222 13888 -
snd_vx_lib 37228 -
snd_via82xx 27488 -
snd_trident 44164 -
snd_rme9652 29252 -
snd_rme96 24900 -
snd_rme32 23136 -
snd_pcxhr 32100 -
snd_nm256 69120 -
snd_mixart 39616 -
snd_ice1724 60356 -
snd_ice1712 64260 -
snd_cs8427 10028 -
snd_i2c 5708 -
snd_hdsp 54084 -
snd_fm801 16868 -
snd_es1968 30948 -
snd_es1938 22148 -
snd_ens1371 23108 -
snd_ens1370 17732 -
snd_util_mem 4364 -
snd_cs46xx 88072 -
snd_cs4281 20928 -
snd_cmipci 31712 -
snd_ca0106 30180 -
snd_bt87x 14632 -
snd_azx 15104 -
snd_azt3328 18088 -
snd_au8830 63072 -
snd_au8820 36192 -
snd_au8810 55904 -
snd_atiixp 20356 -
snd_als4000 12036 -
snd_hwdep 9088 -
snd_rawmidi 24608 -
snd_ali5451 24292 -
snd_pcm 95016 -
snd_timer 25328 -
snd 56324 -
nodev sysfs
nodev rootfs
nodev bdev
nodev proc
nodev sockfs
nodev binfmt_misc
nodev pipefs
nodev futexfs
nodev tmpfs
nodev eventpollfs
nodev devpts
ext2
nodev ramfs
msdos
vfat
iso9660
nodev devfs
nodev nfs
nodev nfsd
nodev autofs
nodev rpc_pipefs
borchi ::
wooohooooo, wholo lotta soundcardz
bw je mislu na .config, ki prebiva v /usr/src/linux.
l'jga
Shaman ::
Ta bi moral biti pravi ..upam:
DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_SYSFS=y
CONFIG_DEVFS_FS=y
CONFIG_DEVFS_MOUNT=y
# CONFIG_DEVFS_DEBUG is not set
# CONFIG_DEVPTS_FS_XATTR is not set
CONFIG_TMPFS=y
# CONFIG_TMPFS_XATTR is not set
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# Miscellaneous filesystems
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_PROC_FS=y
CONFIG_SYSFS=y
CONFIG_DEVFS_FS=y
CONFIG_TMPFS=y
CONFIG_RAMFS=y
Shaman ::
Da ne odpiram nove teme, rad bi imel dualboot kako moram v lilo.conf napisati da bom lahko bootal tudi WinXP iz drugega diska /dev/hdb1 z NTFS particije.
Brane2 ::
Pa si ti ziher, d aimaš na rootu XFS in ne kak ext2, ext3 ali reiser ?
Gentoo ti to butne gor po defaultu in če pozabiš vpisat tja pravo stvar so težave- ne nujno očitne.
Lahko da ti VFAT ne podpira katere od dodatnih opcij in ti zato mount škripne. Probaj ga mountat brez opcij, nato pa jih postopoma dodajaj...
Brane2 ::
Kar se LILO-ta tiče, pojma nimam. Če pa boš prešaltal na GRUB, ti postam config file...
Brane2 ::
Aja, pa tisti "noatime" pobriši pri boot in / particiji.
Mišljen je samo za /boot in še to če imaš gor XFS.
Pri / particiji te to lahko zelo zaje*ava pri emergeanju novega softverja pa še čem...
roscha ::
@ shaman
LILO:
other=/dev/hdb1
label=Windows_XP
table=/dev/hdb
map-drive = 0x80
to = 0x81
map-drive = 0x81
to = 0x80
Pomembno je mapiranje, ostalo prilagodi..
GRUB:
title..........Windows_XP
map..........(hd1)....(hd0)
map..........(hd0)....(hd1)
root...........(hd1,0)
savedefault
makeactive
chainloader....+1
Tudi prilagoditi po okusu
P.S. Stran ima neke težave z tab-i zato sem zaradi preglednosti dodal pikice!
LILO:
other=/dev/hdb1
label=Windows_XP
table=/dev/hdb
map-drive = 0x80
to = 0x81
map-drive = 0x81
to = 0x80
GRUB:
savedefault
makeactive
chainloader....+1
Brane2 ::
Na tistem listingu za GRUB sta tista "map-a" odveč če imaš XPje na prvem disku.
Boot sector GRUB-a itak lahko zapečeš v MBR in bootaš od tam.
No, če dela, pač dela...
roscha ::
Saj hec je da NI na istem disku. Win je na hdb. Drugače se ne bi bilo treba zafrkavat s premapiranjem.
To tudi inštalacije zabluzijo in moraš ročno popravljat. Če je win na istem disku pa inštalerji naredijo pravilne vnose.
Brane2 ::
Vem, samo folk ki daje Linux na mašino, kjer so bili prej Winsi ponavadi ima Winse na prvem disku in takra t ni potrebe za map-om, ravno tako pr folku, ki ima Linux disk sploh na drugem kablu itd.
- spremenil: Brane2 ()
Shaman ::
Poskusil sem mountat brez opcij ampak se vedno ne mounta in tudi floppy dos formated noce mountat.
Saj je skompajlana podpora za vfat?
Brane2 ::
zakaj pa se ne zmounta - mislim a ti stvar kaj pove ?
Si probal ročno zmountat zadevo ?
Kaj ti pove zadeva, če ji rečeš
"mount -t vfat /dev/hdb5 /mnt/hdb5"
Pa ti sploh imaš mapo /mnt/hdb5 ?
Shaman ::
Javi tole
ja in imam mape /mnt/hdb5-7
Zadeva je zelo cudna, saj s kernelom 2.4.26 se vedno deluje ok. Kaj moram z novim kernelom kaka dovoljenja na teh mapah postavit al kaj?
Brane2 ::
pa imaš scompilan vfat v kernelu in kako- vdelan ali kot zunanji modul ?
Če si ga scompilal kot zunanji modul, potem probaj "modprobe vfat" in probaj še enkrat mountat.
Shaman ::
Mislim da je vdelan pac zvezdica pred opcijo ne pa M
JA moje razlage so mal cudne pac zacetnik . :))
to je v /usr/src/linux/.conf vec nekaj postov bolj gor
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
» | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 117494 (33168) | RedDrake |
» | [Gentoo] Kernel upgrade (strani: 1 2 )Oddelek: Operacijski sistemi | 4532 (4058) | Trubadur |
» | kako mountat USB ključ v linuxuOddelek: Operacijski sistemi | 2423 (1930) | Senzacionale |
» | problemi z zvocno v linuxuOddelek: Operacijski sistemi | 1465 (1408) | BigWhale |
» | prilagajanje rad hat 9.0 (strani: 1 2 3 )Oddelek: Operacijski sistemi | 5596 (4191) | TICKO |
