Forum » Strojna oprema » kaj gre na ASUS A7V133-M
radiator ::
Kar nisem ravno into AMD bom raje vprašal... Kaj lahko dam na to ploščo? Chipset je KT133A. ASUS pravi Athlon/Duron (Thunderbird) 550-1.3+GHz. Kaj zaj to pomeni v AMD številkah? Lahko dam gor Athlon XP2000+(266FSB) ali XP2400+ (266FSB) ?? Zdaj je gor Duron 900...
tia
tia
Lime ::
http://www.asus.com.tw/support/cpusuppo...
Podpira do Athlon XP2100 od biosa 1007 naprej.
Athlon 700
Athlon 750
Athlon 800
Athlon 850
Athlon 900
Athlon 950
Athlon 1000 (200 MHz FSB)
Athlon 1000 (266 MHz FSB)
Athlon 1100 (200 MHz FSB)
Athlon 1133 (266 MHz FSB)
Athlon 1200 (200 MHz FSB)
Athlon 1200 (266 MHz FSB)
Athlon 1300 (200 MHz FSB)
Athlon 1333 (266 MHz FSB)
Athlon 1400 (200 MHz FSB)
Athlon 1400 (266 MHz FSB)
Athlon XP 1500+(Model 6)(Palomino) since bios 1007
Athlon XP 1600+(Model 6)(Palomino) since bios 1007
Athlon XP 1700+(Model 6)(Palomino) since bios 1007
Athlon XP 1800+(Model 6)(Palomino) since bios 1007
Athlon XP 1900+(Model 6)(Palomino) since bios 1007
Athlon XP 2000+(Model 6)(Palomino) since bios 1007
Athlon XP 2100+(Model 6)(Palomino) since bios 1007
Duron 600 (Model 3)
Duron 650 (Model 3)
Duron 700 (Model 3)
Duron 750 (Model 3)
Duron 800 (Model 3)
Duron 850 (Model 3)
Duron 900 (Model 3)
Duron 900 (Model 7)(Morgan) since bios 1005
Duron 950 (Model 3)
Duron 950 (Model 7)(Morgan) since bios 1005
Duron 1000 (Model 7)(Morgan) since bios 1005
Duron 1100 (Model 7)(Morgan) since bios 1005
Duron 1200 (Model 7)(Morgan) since bios 1005
Duron 1300 (Model 7)(Morgan) since bios 1005
Athlon 700
Athlon 750
Athlon 800
Athlon 850
Athlon 900
Athlon 950
Duron 600 (Model 3)
Duron 650 (Model 3)
Duron 700 (Model 3)
Duron 750 (Model 3)
Duron 800 (Model 3)
Duron 850 (Model 3)
Duron 900 (Model 3)
Duron 950 (Model 3)
- spremenil: Lime ()
jest10 ::
To je že malo stara razpredelnica.
Delali bi tudi vsi tbred b procesorji do 12,5x množilnika z nekaj sreče pa tudi z višjim. Prav tako tudi duron 1400 in 1600 mogoče pa tudi 1800
SodVina ::
jest sem probal durona 1800 na plati, ki podpira 133 in 12,5x , pa so bli rezultati taki, da ni slo. tako da sem potem mogu se dat 20k za plato.
» | Kateri procesor imate? (strani: 1 2 3 )Oddelek: Strojna oprema | 8083 (5484) | GamingFish |
» | a7v266-e kateri cpu in ram?Oddelek: Kaj kupiti | 1116 (1069) | Eru |
» | Kwa je bolše: AMD 1700+ & 2500+ (strani: 1 2 )Oddelek: Navijanje | 4198 (3199) | Mulh |
» | Abit KT7A + TB 1,4........Oddelek: Navijanje | 1569 (1215) | kuglvinkl |
» | Plošča QDI KinetiZ-da ali ne?Oddelek: Kaj kupiti | 1489 (1353) | Jux |
