Forum » Kaj kupiti » Plošča QDI KinetiZ-da ali ne?
AnZo ::
Kupujem
Ploščo QDI KinetiZ, 256 RAM, Thunder 1GhZ
Plošča:
Chipset
North bridge:VIA KT-133A
South bridge:VIA VT82C686B
Bus Type
5 PCI slots
1 AMR
1 AGP
1 ISA
CPU Support Socket A AMD Athlon and Duron Processors
AMD Athlon Processors at 750/800/850/900/950MHz , 1.1GHz and future 266MHZ FSB Athlon processor
AMD Duron Processors at 600/650/700/750/800MHz and future
System Memory Three 168 pin 3.3V PC133 DIMM sockets
Supports up to 1.5G SDRAM
Supports 66/100/133 MHz Synchronous DRAM and VCM SDRAM
And 66MHz EDO DRAM
Power Management ACPI V1.0 and APM compliant
Supports S0, S1, S3, S4, S5 ACPI power status
Auto adjust FAN speed in the different power status
USB 4 USB ports (2 for I/O panel and 2 for front panel)
USB 1.1 specification compliant
Bus Speed 200/266MHz FSB
BIOS 2 Mbit Flash ROM
Licensed advanced AWARD BIOS
Supports Plug and Play
Supports ACPI and OS directed power management
Storage system Two PCI Master IDE ports support up to 4 IDE devices
Supports ATA 100
One floppy port support up to two 3.5¡± or 5.25¡± floppy drives
( 360K/720K/1.2M/1.44M/2.88M)
Supports LS-120 floppy disk drive and ZIP drive
I/O Feature 2 High Speed Serial Ports (16550 Fast UART Compatible)
1 Enhanced Parallel Port Support EPP/ECP/SPP
1 PS/2 keyboard port
1 PS/2 mouse port
IrDA port support up to 115.2Kb/s transfer rate
All I/O ports can be enabled/disabled by BIOS setup
Graphics AGP 4X Support
Universal AGP Slot
Transfer rate up to 1 GB/s
Kdo pozna to firmo? Cena je 65.000 za vse skupaj (plata, ram, cpu)
Plošča:
Chipset
Bus Type
5 PCI slots
1 AMR
1 AGP
1 ISA
And 66MHz EDO DRAM
Supports ATA 100
1 PS/2 mouse port
Universal AGP Slot
Snowboarding is the best thing you can do with your pants on...
ChiefThunder ::
jz bi raje vzel plato, ki podpira ddr in athlone xp, za mali denar- ECS K7S5A.
... po liniji najmanjšega odpora. ;)
chucki ::
plato ki ima via 266 ali sis! Jst sm tak pijan!
Teslo ::
QDI Kineti xxx je sheeeeeeeeeeeeeeeeet
Smo jih kar nekaj že pokupili in je kar veliko reklamacij. Te plate rade crkavajo. Raje kupi plato pri Mlacomu ...
Elite poceni, dobra in stabilna...
Windi ::
Jaz pa ti odsvetujem elite, ker jo imam jaz zdaj noter. imam procesor 1200MHZ, 512MB SDRama in Geforce MX 400 64MB pa ti povem, da sošolcu mašina hitreje leti kot meni. Sošolec ima 700MHZ procesor in 128MB SDRama. Sicer pa še DDR-a nisem probal, zato ti ne morem povadit, kako se tam obnese. Jaz je ne bi kupil.
frik ::
jaz pa imam QDI kineti 7b pa mi zdej ko mam XP-je gor in neke nastavitve popravlene čist lepo dela
nič ne šteka-skor enkrat na tedn
men je uredu
men je uredu
Koci ::
QDI si znane kot full dobre, predvsem pa stabilne plate, zato se uporabljajo predvsem za večje strežnike. Njihova edina slabost je, da se z njimi ne da navijat AMD-jev.
Panta rei!!
Jux ::
Windi - model mal poglej nastavitve plate, jst sem primerjal moj sistem z sosedovim in ga v 3dmarku posekam - mava pa oba d800 in 256mb rama (on SDR in jaz DDR) pa jst mam KyroII in MX400.
Sam sem blazno zadovoljen z plato - edino mal mori ker se je ne da navijat. (ta vikend grem rezat povezave gor na procu, da bomo voltazo povecal he he).
Poleg tega sem pa dvema kolegoma sestavil racunanik z eliktkami (en ma D800 drug XP1600) in ne morta prehvalt stabilnosti in hitrosti plate. Uporabljata pa sdram.
web&blog&etc: http://lukabirsa.com
» | Dva računalnika na izbiroOddelek: Kaj kupiti | 1233 (1076) | opeter |
» | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 1962 (1769) | Blinder |
» | ATA disk prenos + QDI Excellent 1 plataOddelek: Strojna oprema | 1355 (1305) | Daedalus |
» | Morebitne težave z matično ploščo.Oddelek: Strojna oprema | 1414 (1244) | D4rkDoG |
» | QDI plataOddelek: Strojna oprema | 1287 (1212) | Koci |
