Tero ::
Heh Loney in ti si jezna? Večina žensk bi bila vesela če bi tolko shujšala :)
In ja to je moj eee ja :) vedno poleg mene v postelji spi :)
Looney ::
Nisem "jezna".. samo ni bilo namenoma.
Luškan je.:)
Tody ::
Mogoče bi pa mogla kako knjigo napisat :)
Looney ::
O?
Tody ::
Kako izgubiti 4 kg v enem tednu! Sigurn sem da bo uspešnica >:D :D
whatever ::
To ni nič. Meni je ratalo v 2 mesecih shujšati 27 kg. Sem pa na žalost v naslednjih nekaj mesecih potem vse kile dobil spet nazaj.
Looney ::
Saj je čisto preprosto... očitno sem se prehladila, izgubila tek in pridobila glavobol. Kaj je lahko bolj enostavnega?:D
@whatever ta je pa mal kruta. =/
  • spremenila: Looney ()
whatever ::
Ja, je pa res. To je blo pred 8 leti.
tx-z ::
flat earth society hahahaha:D :D :D
The flat Earth faced challenges posed by photographs of the earth from space and later the moon. Member Samuel Shenton remarked: "It's easy to see how a photograph like that could fool the untrained eye."
The Flat Earth Society also maintains that the Earth is accelerating upward at a rate of 9.8 m/s², thereby simulating gravity. [
;) Itd itd :D Joj kaj sm se nasmeju zdej :D
edit: ahahaha
še forum
Q: "Why doesn't water run off the Earth?"
A: There is a vast ice wall that keeps the water where it is. The ice wall is roughly 150ft high. This also explains why you can find a vast plane of ice when you travel south.
Antarctica as a continent does not exist.
Q: "How does global warming affect the ice wall?"
A1: The Ice Wall is really a mountain range. It just happens to be covered in ice and snow.
tx-z
  • spremenilo: tx-z ()
T-h-o-r ::
Maturantski pleeesss:d 0:):))
Ziga Dolhar ::
Jest sm pa en zagrenjen moderator :P :P :P
https://dolhar.si/
mare_ ::
Nekoč je že bila tema o tem na st-ju, vendar se ne spomnim, kaj ste pogruntali, niti je ne najdem več. Primer: beseda SDS. Izgovori se esdees. Se potem piše z SDS ali s SDS?
(pa mimogrede, tale SDS mislim :P)
Looney ::
Mare, "s SDS" kolkr vem. Ker je potem "s SDS-ji" in ne "z SDS-i". To mislim za napisano. Izgovor je drugo.
r5r ::
Z je, ker vem, da se motim, če uporabim s.
Itak pa je tam na strani še ena možnost NaDS. :P
And it makes me wonder.
Looney ::
Am ne ne, ne bo držalo. Imam kar prav. "S" je. Pogledala v pravopis.>:D
mare_ ::
aha, ok, hvala. grem popravljat :)
strictom ::
Pršu iz maturanca. Sreča da se punci ni čevelj sezu med maršom, sreča da ji ni venček dol pado in sreča da ni denarnice zgubla. Poleg tega je blo pa fajn :)
iggy ::
In premalo pijače da si ti tega spomniš >:D
Hey, you're fat!
  • spremenila: iggy ()
root987 ::
strictom: Ob 1200 ni bilo nikogar ki bi štopal domov - so do takrat že vsi obupali ali ste vsi bili še na mizah? :)
"Myths which are believed in tend to become true."
--- George Orwell
sid911 ::
Jah, jas sm mu ponudil žganje:D
1. Asus P8P67 LE | i3 2100 | HD 3850 | 2x4GB | 320 GB + 2 TB
2. FSC Amilo PRO V3515 ( T2060;2 GB;80GB)
r5r ::
Ta novi videz ST je neuporaben, saj mi ne omogoča nastavitve ikone sporočila, pa še vsi smeški so enaki, grrrr. :)
iggy ::
za tistih 5 min ko pridem še na slotech, bom uporabljal kar tastar videz. Tale novi ni omembe vreden.
Hey, you're fat!
t3hn0 ::
no..sej zadeva se se dela smajliji naj bi bli zjutri ;)
St@jler ::
Aaarghhh. my eyes! MY EYES!!! The white...
overlord_tm ::
Hmmmm, prov najbolsi je :D
Matr, jest sem bil ze preprican da je to propadel projekt ... ker tole so nas sprasval tko kak let dober nazaj če nam je ušeč ...
PrimozR ::
Nov ST roxorz my soxorz!!!
d0rK ::
Prov una tipicna geek reakcija...The light, ARRGGHHH, the liighhtt! >:D
Looney ::
Dobila mail od Anni-ja.:D
  • zavarovala slike: Looney ()
roli ::
Samo ne na ta datum!:D
Drugače a je tale nov ST stil tudi prvoaprilska šala:D ? Stari hladno moder stil je meni veliko bolj všeč.
http://www.r00li.com
sid911 ::
strictom, a maš še vedno mačka?:D
Kdsa pa je tvoja punca denarnico zgubla? A na plesu ali v preši? Ker na plesu so rekli da se je ena denarnica najdla...
PrimozR ::
Dvomim da je 5 let dela na dizajnu šala :P
roli ::
Hehe najbrž ni ampak malo čuden datum so izbrali!
bi0s ::
5 let ? :o
strictom ::
sid111, na plesu. Na zgornjem desnem šanku. Fora je bla, ko jo je lih iskala in je ni našla, pa un reče "pri zgornjem desnem šanku se je našla denarnica". Njena reakcija: "o, fak!".
WTF? Kje so smajliji? Uuuuu realtime prewiev mojga posta, ... Me likes, me likes.
Tody ::
Hihi da se postat tudi čisto nič :D :):):):) Smiliji še ne delajo :D :D :P :O
  • spremenil: Tody ()
d0rK ::
Par stvari morjo se postelat pa bo supr.
Ampak se je tut vlekla ta sprememba. Se spomnm teh oziroma podobnih dizjanov se iz casov ko sem jaz ircal.
moj_nick ::
Smajliji delajo
:):D:|:))8-):(>:D:8);((8-O:O:'(;(:P;):8)
skor usi :8):8)
>:D
110111001001010001010000
d0rK ::
Heh.
It's amazing how fast can a great day turn to shit.
root987 ::
sid111: Ti si tut iz računalniške/gimnazije na ravnah?
--- George Orwell
sid911 ::
nop. punca je z gimnazije:D
strictom ::
Uf kaj naredi IE6 iz strani. Obup.
whatever ::
Kak se vam zdi moj nov podpis?:D
Veliko jih je notri, še več jih je pa zunaj.
Bilijarde v šole! - Ivan Kramberger
Abnormal behaviour of abnormal brain makes me normal.
  • zavaroval slike: Primoz ()
Tody ::
PA je res ? :D
whatever ::
Zna bit, da bo res. Konkretno, računalniški faks nameravam obesit na klin, kar bi najbrž moral narediti že zdavnaj. Ne samo, da je faks zajeban, marveč se mi tudi zdi, da tak šiht ne bi bil za mene. Stalno se je treba neki učit, stalno neki gruntat... samo garanje. Saj vem, da tudi pri drugih službah je vedno nekaj novega in se je tud treba kaj izobraževat dodatno, ampak je marsikatera v končni fazi vseeno bolj rutinska. Kakorkoli že, naslednje leto grem na šiht, bom videl kaj bom delal in kako bo ali ne bo zajeban in kaj bi sploh v lajfu delal... na faks se še zmeraj lahko vrnem. Ali pa grem študirat izredno ob delu kaj drugega.
iggy ::
Se ti pridružim čez mesec in pol :)
Hey, you're fat!
Tody ::
Srečno fanta :)
Blum ::
oh ja :)
St@jler ::
MihaFirst ::
LINK (druga ponudba)
A ma ta tip sploh šanse, da bo nekdo nardil vse to v upanju, da bo osvojil nagrado 200€? :D
Azrael ::
Eni so optimisti.
Nekoč je bil Slo-tech.
348 / 1180
