Novice » Brskalniki » IE7 končno v naše mlinčke
BendeR ::
Thanks to windows tester and Jason He from the forums for the heads up!
According to a new Vista-related press release on Microsoft's site, Windows Media Player 11 will be released to the public on October 24th.
"Windows Media Player 11 will be available via free download beginning Oct. 24 and will enable users to take advantage of an elegant and intuitive user interface, a new level of online store integration, especially with MTV’s URGE service, and improved navigation for larger music libraries."
An obscure post over on the MSDN blogs, states that Microsoft is targeting October 18th as the release date for Internet Explorer 7. Looks as though Microsoft is planning to release IE7 automatically on November 1st:
"The final release of Internet Explorer 7 is targeted for release October 18th …and will be delivered to customers via Automatic Updates starting November 1st, a few weeks after it’s available for download. Are your Web sites, extensions, and applications ready? Microsoft recommends that Web sites and applications be reviewed and made ready for the release of Internet Explorer 7 this month."
CaqKa ::
>>> Pa še za tistega, ki je izjavil, da je FF prehitel IE7 z tabi... kdo pa je prehitel FF?
opera?
myie
opera?
myie
Vse naštete je pred več leti prehitel en, katerega imena se noben ne spomni. In niti ni pomembno.
zee ::
Netscape Navigator?
zee
krho ::
Jaz pa s si.Mailom in zavihki v odjemalcu elektronske pošte prehitevam vse po vrsti. (Če koga zanima, zadnji development build)
Pobijte se že med sabo, da bo mir.
- zavarovalo slike: gzibret ()
Jao instaliral IE7, brisal še ne, ker IE tak nege z kompa tak da mi je vseeno kiri je gor.
Moja ocena.: Najslabše od najslabšega.
(mam pa ga na piratskih winsih)
Prvič kot prvič se mi bo vtrgalo ker sloh nimam gumba HOME itd. mam sam naprej pa nazaj pa da stran napišem not
Povprečnemu uporabniku neprijazna stvar. Po browserju stiskam levi, desni gumb da bi prišel do kakih nastavitev pa rezultata ni
Na nadzorni plošči sem nastavil domačo stran google....zgleda da bom moral kar lepo restartat IE da bom prišel do googla če mi ni za pisat naslova
BendeR ::
EWEER: bodi tiho in si ne delaj sramote .. ovca prokleta.
Evo ti home. ;)
http://www3.shrani.si/files/home1021790.jpg
- spremenil: BendeR ()
Jaz sem mislil da mi boš ti razložil ko si taka glavca
Nerabim NFO-ja brat, nerabim IE. Still love Mozilla.
BendeR ::
Ni moja dolžnost podpirat neznanje branja NFO datoteke. Želim samo pokazat, kaki talenti se spravijo ocenjevat brskalnik. ;)
Hmmm nekam čudno veliko veš ti o mojem NFO-ju...
Res si glavca, lahk pa prideš sem pogledat NFO (če ga sploh imam), ker nevem odkod ti tile podatki da sem z torentom dol vleko
Če ga najdeš ti ga z veseljem natisnem pa v rit zaklačim.
EDIT.: Sploh te nebom več komentiral v tej temi. Nima smisla
- spremenil: ;-) ()
BendeR ::
Vsak dan imam opravka z ljudmi, ki bi tak ali drugače radi inštalirali dodatke na MS programsko opremo. Pri tem se najdejo tudi taki, ki bi radi obšli WGA . ;)
Kot vidiš uporabljam Visto RC2 kot main OS in kot tak ne potrebujem nobenega branja NFO datotek, ker je IE7 že integriran.
Pri trenutnih metodah inštaliranja IE7 na nelegalne XPje prevladuje WGA bypass, kjer moreš v system32 skopirat določeno dll datoteko. Če tega ne storiš se ti sistem več ne postavi, ampak se explorer sproti sesuva in obtičiš na namizju, ki ga sestavlja le ozadje brez ikon in ostale šare, ki tja spada.
No, ako uporabnik upošteva napotke in IE7 inštalira "pravilno" se včasih pojavi problem, da nima tabov in s tem tudi ostalih ikon, ki se nahajajo v tej vrstici (sam si ugotovil, da ni home ikone). Po tem tudi sklepam, da nisi imel tabov in da nisi sploh mogo sprobat IE7. Če se ta težava pojavi je potrebno upoštevat navodila, ki so pod opombe dodani v NFO datoteki (tu ni nujno, da je dodana samemu IE7, ampak je včasih napisana samo na strani, ker si dobil povezavo).
Manjkajoča vrstica s tabi se je pojavljala tudi že prej pri leakanih verzijah IE7 iz beta faze.
Tolk o tem.
Tolk o tem.
Sprobal sem ga lahko, tabov pač nisem imel
neres ::
A je komu brez WGAja inštaliralo IE7 po avtomatskih updateih?
Namreč na enem PCju, kjer sem bil odstranil WGA z Remove WGA, sem poskusil to narediti. Označil in dal download potem pa se ni zgodilo nič. Niti mi ni ponudilo WGAja, da bi si ga inštaliral ali kaj takega...
Sej ne da rabim IE7, ampak sem hotel zgolj da vidim kako zgleda. Zdej s kakimi cracki in tem se mi ne da ukvarjat, nisem ravno tako radoveden.
Pa nekje sem videl da ti skupaj z IEjem obvezno namesti tudi Malucious software removal tool. Je to res, se sploh ne da brez tega?
OrlyTM ::
am ... a obstaja kaki session saver addon za IE 7 ... drugac mi ful sede, k res hitr pa lepo dela ... sam session saver pa manjka :)
OrlyTM
OrlyTM
<b>Fear is in The Eye Of The Beholder. Don't let it be You!</b>
» | Nova različica IE7 brez WGAOddelek: Novice / Brskalniki | 4965 (3171) | Trdi |
» | Microsoft IE 7.0 in https, Exchange 5.5 gre v pokoj, prihaja MSN Book SearchOddelek: Novice / Brskalniki | 3480 (2844) | ahac |
» | Microsoft oživlja nadaljnji razvoj Internet Explorerja (strani: 1 2 )Oddelek: Novice / Brskalniki | 6022 (6022) | Poldi112 |
» | Linki ponovno dovoljeni za IE uporabnikeOddelek: Novice / Varnost | 2591 (2591) | Vlady |
» | Virus, črv, luknja, virus, črv, luknja, luknja, luknja ...Oddelek: Novice / Varnost | 2983 (2983) | BSD-jas |
