Siol Route
Siol Route
Spc ::
Siol spet route-a preko slovenskega omrežja >:D
traceroute to hestija.siol.net (193.189.160.170), 30 hops max, 38 byte packets
1 server (192.168.0.1) 0.447 ms 0.220 ms 0.204 ms
2 cnet-2.ac.triera.net (213.161.8.1) 7.610 ms 11.664 ms 7.778 ms
3 cartman.ip.triera.net (213.161.2.1) 8.478 ms 11.111 ms 9.379 ms
4 nexus.ip.triera.net (213.161.1.238) 9.415 ms 12.180 ms 13.050 ms
5 lj2-so-0-2-1-0.router.amis.net (212.18.35.114) 12.258 ms 10.856 ms 9.392 ms
6 six.siol.net (193.2.141.38) 15.561 ms 14.187 ms 13.809 ms
7 213.250.19.202 (213.250.19.202) 16.983 ms 15.154 ms 14.455 ms
8 hestija.siol.net (193.189.160.170) 19.245 ms 14.637 ms 13.882 ms
to sem opazil danes ;)
Gandalfar ::
traceroute to www.slo-tech.com (212.93.228.2), 30 hops max, 38 byte packets
1 pythia.rozica.com (192.168.0.1) 0.518 ms 0.214 ms 0.196 ms
2 BSN-access.dsl.siol.net (213.250.19.90) 84.821 ms 51.498 ms 16.105 ms
3 193.189.161.28 (193.189.161.28) 11.183 ms 79.752 ms 33.264 ms
4 kklag1-176-61.net.uta.at (212.152.176.61) 59.247 ms 32.552 ms 58.771 ms
5 kklag1-48-66.net.uta.at (62.218.48.66) 86.105 ms 14.694 ms 38.833 ms
6 telemach.gw.amis.net (212.18.35.166) 38.004 ms 13.938 ms 14.071 ms
7 rt0.rt1.gi0.cs.telemach.net (213.143.64.34) 143.896 ms 79.019 ms 14.714 ms
8 linda.moj.net (213.143.66.2) 15.162 ms 25.935 ms 14.004 ms
9 slo-tech.com (212.93.228.2) 15.965 ms 107.225 ms 14.788 ms
niti ne.. :>
Spc ::
Hmmm ?
V čem pa je fora ? jaz sem danes ob 17.00 probal .. pa ni delovalo .. se pravi se je zaj moglo zgodit ? .. samo zgleda samo one way ?
Probal sem tudi pri prijatlu, ki ima arnes in zadeva gre preko slovenskega
btw. Gandalfar .. hude pinge maš to .. hudo vlke
8-O
  • spremenil: Spc ()
bradek ::
Japajade.
Poglej kam te peljejo na kako drugo stran ki ni na siolu/telemachu.
Sami sebe pa valda ne bodo routal preko avstrije, kajne?
Dredd ::
Zakaj se mi pri "tracert www.slo-tech.com" po uti še vedno ustavi??
Tiger ::
Ker nekateri avstrijski ISP-ji blokirajo ICMP,...
McHregec ::
Tracing route to www.triera.net [213.161.22.50]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.123.254
2 138 ms 34 ms 36 ms BSN-access.dsl.siol.net [213.250.19.90]
3 43 ms 18 ms 17 ms pollux.siol.net [213.250.19.207]
4 19 ms 19 ms 98 ms kklag1-176-57.net.uta.at [212.152.176.57]
5 92 ms 56 ms 18 ms kklag1-48-66.net.uta.at [62.218.48.66]
6 52 ms 80 ms 20 ms mb3-so-0-1-1-0.router.amis.net [212.18.35.113]
7 68 ms 37 ms 44 ms wildfire.ip.triera.net [213.161.1.237]
8 31 ms 23 ms 22 ms charlie.ip.triera.net [213.161.2.10]
9 22 ms 23 ms 28 ms raven.triera.net [213.161.22.50]
Trace complete.
Pingi so malo čudni ker še emula laufa. :)
Destroyer Of The Worlds.
PaJo ::
Saj Siol -- Arnes se routa preko .si, le z ostalimi ISP se ne;(
Ne se preveč sekirat, rajši uživat:)
Sergio ::
S Telemachom tudi ima peering, PaJo ;-)
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
swar ::
Tut s perftechom majo.
CaqKa ::
hmm kaj še pa potem ostane? amis in triera? hm.. torej od štajerske odrezani?
McHregec ::
Siola ima z Amisom peering preko SIX-a.
PaJo ::
Pardon za napako, sem prehitro rekel, ceprav sem vedel da dela se na nekaterih drugih isp-jih tudi. Saj promet iz ostalih isp-jev na siol gre mislim da povsod direkt preko SIX-a, le kontra gre obicajno preko tujine;(
Samo resnicno ne bom zastopil te tumaste Siolove politike, ker ce bi bil folk kaj pameten bi sloveska izmnjava prometa laufal vsaj pri 1Gbit ce ne celo 10Gbit in to med vsemi ponudniki. Temo bi jaz potem rekel super organiziran drzavni internet, po tem dogovoru pa bi se lahko sli konkretno e-drzavo in zaceli ves .si folk na online podrocju izobrazevat:D
Blokirani porti pri dostopu na slo-tech.com (strani: 1 2 )
Oddelek: Omrežja in internet
608153 (6662) MrStein
Kaj se dogaja z networkom ????
61412 (1375) Spc
Internet štekal danes ponoči (ADSL) (strani: 1 2 )
808032 (6300) IceLord
kabelski internetnet VS. ADSL (strani: 1 2 )
8713354 (11675) Soprano
SiOL in povezave z drugimi SLO ISPji
293843 (3106) Ales
