Novice » Procesorji » Težave s pregrevanjem Ryzen 7000X3D
Torej so "Proizvajalci" prodajali zlate matične plošče, ki so zadovolile minimalno specifikacijo "na električnem nivoju", ki jo zahteva DDR5, reševali so pa z višjo voltažo.
Bilo bi dobro videti katere rame so plošče podpiral na začetku in koliko so bile voltaže.
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Buggy ::
SOC volaze ze na AM4 nabijajo plate obcutno previsoko in s tem nepotrebno grejejo CPU. Sam sem jo na 5800X3D fiksiral na 1100mV, pa se bi sla nizje stable, nakljub -30 na vseh core-ih preko PBO2 tunerja.
https://www.reddit.com/r/Amd/comments/1...
my 7800x3d died after first boot
SPEC:
CPU: 7800x3d
MB: (GIGABYTE) B650M AORUS ELITE AX(REV 1.0) (F2 bios, tried to upgrade to F5 in first boot)
No OC. No EXPO. Factory settings.
SSD: Samsung 990 pro 1T
Memory: G.SKILL Trident Z5 Neo Series AMD EXPO 32GB(F5-6000J3038F16GX2-TZ5N)
Power: Corsair AX850
CPU cooler: Asus rog ryujin 240
GPU: ROG Strix 4090 OC Edition
After installing all the components, the computer was turned on and entered the BIOS. The system passed the self-check by successfully recognizing the 7800x3d.
The initial version of the BIOS displayed as F2, which was then upgraded to the latest version F5a (03/23/2023) using Qflash. The upgrade reached 100%, but then the screen went black and the computer shut down. I assumed the computer would automatically restart, but it did not.
slika cpu, mb
https://preview.redd.it/megathread-for-...
SPEC:
CPU: 7800x3d
slika cpu, mb
- spremenilo: sbawe64 ()
AM4 s tem nima nima nikršnih problemov in MSI plata laufam defult DDR4 3800 CL 16 ob izidu 5800X3D. Razlika v porabi je pa minimalna, ergo nesmiselno.
Soc Voltage (SVI 2 TFN) 1.038V
CPU Core VDI 1.3V
» | AMD najavil procesorje Ryzen 7000 (strani: 1 2 3 )Oddelek: Novice / Procesorji | 19167 (2573) | D3m |
» | Težave s pregrevanjem Ryzen 7000X3D (strani: 1 2 )Oddelek: Novice / Procesorji | 7511 (4913) | Mr.B |
» | Procesorji Ryzen 7000 prispejo konec septembra (strani: 1 2 3 )Oddelek: Novice / Procesorji | 15147 (7759) | FlyingBee |
» | AMDjevi procesorji Ryzen 5000 pridejo po Intelov skalp 5. novembra (strani: 1 2 3 4 )Oddelek: Novice / Procesorji | 29757 (20062) | m0LN4r |
