Forum » Strojna oprema » Nvidia Nforce 3.13 drivers !!!
kuglvinkl ::
Vleka
Kewl!
Sicer bom sporbal jutr (hebeni dialup).
Audio Improvements:
* Realtek ALC655 codec support added
* Fix for BSOD on loading DLS files
* Reduced susceptibility to audio glitches under heavy system load; additional fixes for 6 channel GetPosition glitches
* ASIO support for recording at sample rates other than 48kHz; lower and more predictable latency
* Fixes for NOLF. The 3D minimum and maximum distance and the roll off factor were not being taken into account for air absorption. Also modified reverb gain so that the max distance was taken into account
* Fix for EAX reverbs; initialized EAX reverbs to off when querying for the EAX listener interface; updated EAX property handlers to ignore invalid parameters instead of range limiting -- this matches Creative EAX behavior
Windows XP Driver Versions
* Audio driver 3.66 (WHQL)
* Audio utilities 3.66
* Ethernet driver 3.63 (WHQL)
* GART driver 3.34 (WHQL)
* Memory controller driver 3.38 (WHQL)
* SMBus driver 3.38 (WHQL)
* IDE In-the-box driver 3.58 (WHQL)
* IDE 2.0 NVIDIA driver 3.66 (WHQL)
* Display driver 52.16 (WHQL)
* Installer 3.77
Windows 2000 Driver Versions
* Installer 3.77
Novi IDE driverji.
Kewl!
Audio Improvements:
* Installer 3.77
* Installer 3.77
Novi IDE driverji.
Alexius Heristalski ::
Če se bo tole dobro obneslo, rabim samo še dober bios za abitko nf7 ...
kuglvinkl ::
Mogoče je pa tokrat v resnici nforce2 platformi KT880 za petami.
Kakorkoli, spuste benche čez.
ganzi ::
jih že vlečem
Sam ta telesmeh me spet neki zaj.. tko da nikamor ne gre
Kako nej odstranim starejše driverje? Add/remove programs al kako ?
Zheegec ::
Že vlečem - 10% complete in 6 minut left - Kuglvinkl, če bodo povzročali težave bom najprej blemal tebe, šele potem nVidio
Resno
Resno
Janez Janša, 29.04.2014
- spremenil: Zheegec ()
kuglvinkl ::
Piše na uradni strani.
Ma že kdo gor? O MemContrl. ne pričakujem čudežev, IDE part bi pa lahko bil izboljšan.
ganzi ::
jih mam že dol.
Sam ne vem kako nej odstranm stare.
a tole piše al kaj?
a tole piše al kaj?
Zheegec ::
Ja, stare daj uninstall, ker vedno še kaj ostane od njih.
Anyway, jih imam že dol, samo ne bom nič benchal, ker je fresh sistem, pa še nimam nič gor, mogoče Aquamark probam
kuglvinkl ::
Sem vedu kam moram pogledat (k SauerKrautom , pedantni in natančni, ni kaj):
Insgesamt scheinen Festplattenaktionen schneller anzulaufen (so kommts mir zumindest vor) der benchmarks der nforcehq Leute zufolge ist der MS Treiber aber schneller und komatibler.
Ich habe bissher nur eine Merkwürdige Sache festgestellt und zwar wenn ich MP3's über iTunes im Hintergrund höre und dann in Nvidias System Tool gehe und darin herumfuhrwerke bekomme ich Sound Aussetzer trotz den höchstens 27% CPU Auslastung die der Task Manager anzeigt.
kuglvinkl ::
ferdo, vrži vse skupi dol, in na novo naloži.
in pol folk jamra, kolk je AMD v nekje....
ganzi ::
A bi se dal tole kako instalerat brez da bi se zravn namestil še video driver.
ker bi rad še naprej uporablju isti driver za grafo (prov od winfasta za a280)
- spremenil: ganzi ()
kuglvinkl ::
Po moje se da. A ti ne ponudi izbire? Sicer pa lahko verjetno preprosto zbrišeš direktorij z Detonatorji (prej unpack se ve).
kuglvinkl ::
Läuft hier auch ohne Probleme.Die Werte des HDD Test von Sandra sind zwar etwas gesunken.Ist aber nicht viel.
Dafür sind bei mir die Speichertestwerte etwas gestiegen.
Aber auch nur ein paar Punkte.Werde ihn erstmal drauf lasssen.
To pobiram iz 3dcenter.de (sicer več kot odlična nemška stran).
- spremenil: kuglvinkl ()
ganzi ::
tenks, sm jih prej odpakiru, pa kr zbrisu mapo pa jih ni namestil.
A se da kje kej tazga prebrat vsaj v angleščini k eni smo z dojčo bl skregani..
Al pa nej nekjdo pove a kej dobrga piše al slabo?
kuglvinkl ::
Pobom na AOA noče bootat... Nemškim kolegom dela OK, tudi na amdmb.
Običajno se vsuje na forumih ob takih zadevah, zdej so zgleda več ali manj "preplašeni" in čakajo na poročilo. Jep, to je pa škoda iz 2.41.
Zheegec ::
No, deluje vse
Benchati se mi pa ne da, sem se že preveč zaje**val z Winsi danes
boštjan ::
jaz sem novi na nforce2 pa me zanima kaj je najbolje:
a)uninstal starih nForce2 driverjev in ne vem kolko krat reboot ali
b)kar čez stare te nove nForce 3.13
Ne bi rad se spet zajebavo z instalacijo winsew.
Zheegec ::
Itaq da je najbolje dat najprej uninstall ter restart. Potem ti bo hotelo ponovno driverje za grafo, mrežno,... namestiti ob restartu, pa daš samo next pa ti posname dosedajšnje, pa istočasno posnemi 3.13 driverje ter restart, potem ti posname še nekaj driverjev (najde nove naprave), pa še 1x restart in to je to -- aja pa pod audio moraš potem dati hardware acceleration na ful, ker ti ga kar na eno opcijo manj da
boštjan ::
No zdaj sem na nForcesHQ tale prvi post prebral:
If, like most enthusiasts.. you intend to tinker with various nforce drivers please remember that..as with previous UDP/Nforce drivers.. you MUST let Windows detect bits and reboot between uninstalling any older drivers and then installing newer ones. Not doing so will cause problems. It should go like this:
1. Uninstall all nForce bits.
2. Reboot.
3. Let Windows try to find, and fail, at all the nForce stuff.
4. Reboot.
5. Install the new nForce drivers.
6. Reboot.
7. Install the graphics drivers all by themselves.
8. Reboot.
Grafiko pa mi je itak od radeona
we'll do
2. Reboot.
4. Reboot.
6. Reboot.
8. Reboot.
we'll do
Zheegec ::
Takšne nastavitve za ATA so bile že v neki napol stabilni beta verziji 3/4 leta nazaj
log2 ::
Jaz sem naletel na naslednji problem(že nekaj časa nazaj pa do izpred dveh dni nisem imel rešitve) - če odinštaliraš nforce driverje verzijo 2.45 potem hitro ugotoviš, da po reštartu windows-ov izgubiš driverje za grafično in obenem možnost ponovne inštalaciije driverjev za grafično kartico. Ne pomaga niti ponovna inštalacija driverjev 2.45 (ne vem kako pa je z novimi 3.13). Izgleda da odinštalacijski program zbriše pomemben del registra . Če se komu pojavi ta problem naj naredi datoteko z naslednjo vsebino (.reg) in jo vnese v register:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}]
"Class"="Display"
@="Display adapters"
"Installer32"="Desk.Cpl,DisplayClassInstaller"
"TroubleShooter-0"="tshoot.chm,tsdisp.htm"
"Icon"="-1"
"Class"="Display"
"Icon"="-1"
- spremenilo: log2 ()
kuglvinkl ::
Sam sem se pred dnevi igral z nekimi driverji za sound. Mi zbriše dol nvidiene driverje, novih ne usposobim. Po nerdodnosti kliknem na inštalacijo 2.03. Uninstall, reboot, 640×400, naložim 2.45, dela vse kot mora. Pojma nimam, kaj vas muči? GPU je RV250.
frenk ::
kuglvinkl: jest sm šu tud takoj po inštalaciji pogledat ide in zgleda da so zrihtal ravno to kar mi je delal probleme...bom zdele probal posnet en cd
boštjan ::
naložo nove nForcere,vse dela OK,edino IP mi je zbrisalo in sem moral na novo vpisovat IP in druge cifre.če pa je kaki improvement v benchih pa bomo še vidli
VASkO ::
meni pa ide driveri se vedno ne delajo
noce specti cdjev v nerotu (6.0.0.15), ne dela nero image drive - zmrzne, ne dela hot swap na racku
naj gre nvidia v tri p.m. in se malo zamisli
btw, nisem edini, poglejte na nforcershq.com
me pa zanima, kako lahko dobijo taki gonilniki WHQL pecat?!?!? se to sploh testira ali boj tak tak?
pomoje tak tak
pomoje tak tak
BlackHole ::
A potem pa ni z mojim pekačem nič narobe odkar sem nabavil nov kompjuter z nforce2 čipovjem?! To je torej znan problem, da zablokira sistem včasih med pečenjem (Nero seveda)? Obstaja že kakršnakoli rešitev?
boštjan ::
napredka v benchin ni,vsaj 3dmark2001SE mam manjši za 200pik.kako pa je s pečenjem,pa bom pol poskušal.
- spremenil: boštjan ()
boštjan ::
no kaj se glede pečenja tiče meni brez problema 700MB datoteko speče v 5min in 10sek s yamaha pekačem 20/10/40 in nero 5.5.10.35.Nero 6 še ne zaupam.Aja pa ko pečem, vgasnem vse ,nisem na netu,onemogočim nortona.700MB datoteko pa mi skopira v 3min in 10sekundah.uporabljam pa plave smurtbuy CD 52X
matyaz ::
Meni tudi liteon 52/24/52 ni hotel peči z Nerotom 6.0015, toda sedaj, ko sem ga posodobil na 6.0019 dela brezhibno.
Fury ::
men zaenkrat vse ql dela :)
sound driverje uporablam 3.62 ker imajo boljsi zvok (tazadji 3.66 majo rahlo cuden zvok - ful srednjih tonov manka)
Zheegec ::
8Rda -> pečem (nero 5.5), hkrati pa igram igre, foldam ter downloadam, brez težav še dosedaj.
VASkO ::
matyaz, ti dela NeroImage Drive? meni z SW-IDE driverji ne dela pa hot swap na racku mi ne dela
ta SW-IDE je za en drek (kot vsi ostali prej)
ziher ni dober - ce ga prevec obremenis, se vsipa
ce pa delas osnovne stvari pa se vam seveda zdi dober plus to, da vam v Sandri navrze malo pik vec, kar pa nic ne pomeni
kuglvinkl ::
Sound dela definitivno bolje.
In sistem se mi zboota hitreje.
_Dejan_ ::
hm zvok je mogoče res malo boljši,
glede ide gonilnikov pa ne vem al so kej izopoljneni al ne ker ma disk na Serial ATA
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
matyaz ::
Vasko naredil sem image 700MB Cd-ja z divx filmom in ga naložil na image drive ter zagnal z bsplayerjem.Stvar deluje brezhibno, drugače mam pa ABIT NF7-S V2.0 plato, Liteon 52/24/52 pekač Nerota 6.0019 in seveda te tanove nforce gonilnike o katerih teče pogovor.Pa še to, Nero image drive mi naloži kot SCSI pogon, če je to kaj važno.
ganzi ::
posnel dva cdja brez problema..
Zravn normalno poslušal muzko na winampu in brskal po internetu, pa sem ga hotu se mal sprobat sem pa še divx zalvfu.. pa je use delal brez štekanja.. aja pa še bitorent pa mula sta bla v elementu ..
abit nf7-s
2400+
512ddr
in seveda ta novi driverji.
Je pa neki -sistem je bil na novo postavljen.
abit nf7-s
2400+
512ddr
falotXP ::
Kako prideš do NVIDIA nForce(tm) SPP/IGP ATA Controller nastavitev, kot kaže kuglvinklova slika??
» | Novi "predelani" gonjači za nForce 2 chipset. (strani: 1 2 )Oddelek: Navijanje | 4995 (3310) | JIM22 |
» | Mnozilnik 10 in 10.5Oddelek: Navijanje | 930 (823) | Caligula |
» | Abit NF7-problem z integ. zvočnoOddelek: Strojna oprema | 927 (821) | VASkO |
» | nForce2 zadnji gonilniki (link)Oddelek: Strojna oprema | 1615 (1307) | Oblivion |
» | KT 600Oddelek: Strojna oprema | 1075 (879) | Clemento |
