Novice » Grafične kartice » Nvidia lansirala Geforce GTX 1650
Ti šment, cele 2% razlike od najcenejše:
https://geizhals.at/palit-geforce-gtx-1...
I to pravijo na tvoje zaključke ...
Radeon RX 570 is considerably faster
More expensive than competing options (RX 570)
Fan could be quieter when fully loaded
No idle-fan-stop
No DisplayPort output
No backplate
Fan speed RPM cannot be monitored
Memory not overclocked
In ko še rad utrujaš z bolho za 105€ dobiš RX580
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
- spremenil: Mr.B ()
Treer ::
Seveda si pezdetko izpustil pozitivne stvari:
No additional power connector required
Comes at NVIDIA MSRP of $150
Extremely energy efficient
Solid overclocking potential
Compact design
Overclocked out of the box
DVI, HDMI 2.0b support
In pa čisto zadnji odstavek:
One thing the Palit GTX 1650 StormX has going for it is that you can just plop it into any old computer and get a massive boost to graphics performance without having to upgrade the power supply. Not requiring an additional 6-pin power helps because many OEM computers don't have a spare 6-pin power connector on their PSU. This also takes out a lot of complexity for less experienced users because all they have to do is plug in the card and connect the monitor (which is still scary enough for many of them). The closest cards without additional power are the RX 560 and GTX 1050 Ti--both are much much slower than the GTX 1650. While I am a bit reluctant to give our the "Recommended" award due to pricing, there exists no alternative on the market if you want to move on from integrated graphics or upgrade an older system in the most simple way.
Compact design
- spremenil: Treer ()
Compact design
Z iste strani, celo napišejo da za tak denar dobiš no :
If you are willing to buy used, you'll find a ton of graphics cards between $100 and $200 that will offer better price performance, too
Čud me higijena Adminov, ampak nič zato.
FlyingBee ::
Spet nič novega, Mr.B. Rabljene še vpletmo, ja.
Potem pa še 2400g, dobiš isti perf pa še cpu, pa smo tam.
- spremenil: FlyingBee ()
Ravno zadnjič je pa pljuval čez rabljene - shizofrenik v akciji!
Še 1x do sedaj nisi našel web strani ki bi priporočala 1650 pred ostalimi... lol
Ja no glede na to da podajajo na bolhi rabljene 1060 za samo 150€, potem bi se čudil zakaj je tako visoka vajina vsihčenost pri izidu te grafične
FlyingBee ::
Nimata isti final destination, moraš razumeti, zakaj 1650, ni njen namen za sub 100eur diy stručkotom prodajat.
Imaš srečo, da amd razprodaja 3 leta stare.
Sej vem, da boš TI le našel pozitivno priporočilo te grafične, ki bo preseglo ne rabi dodatnega napajanja ter majhno porabo.
Lol sem mislil da je 1650 res 100€ ko sem bral kako je NE pluvajo.
FlyingBee ::
Ne, rx 570 je boljši p/p, tukaj nimamo kaj.
Imaš težave z razumevanje, ok.
Ne znamo brati, a prizadetek? Ta karta je pač za specifične scenarije in v tej ji ni para:
Ta kartica ni primerna za nič, za multimedijski strojček zraven TV-ja, ker je ensotavno prevelika, ni primerna za igre, ker jo vse ostalo, vkjučujoč za nekaj 30€ več povozi 1660 ..
No ja namenjena je za tiste, ki jim je ravno crknila 1060, in čakajo kaj bo sedaj plunil ven Amd, glede na to da njihov i7 K verzija nima grafične, pa ne more trolat na tem forumu.
Treer se stabo ne strinja, celo graf je prilimal.
Seveda toplo priporočam da se na bolhi zdilata za rabljeno 1060. Morda jo bosta dobila potem za ceno 1650, ker Amd-ja nimata rada... da si ravno iz solranih panelov napajat Pc, drugače bi za manj dnarja dobila ne ravno osnovni rabljeni Rx580
FlyingBee ::
Kaj praviš na 2400g, eno in isto z 1650 pp grafičnih zmogljivostih pa še cpi zraven dobiš za podoben dnar.
Ti pač veš vse, nimamo kaj.
Škoda, da sploh tech review strani obstajajo.
Kot sem rekel, Treer se stabo ne strinja. Morda če ti napišeš da je krš bo nehal utrujat. Razen če boš začel z robnimi pogoji...
FlyingBee ::
Grafi točno to pokažejo, ampak ti bi nekaj zdaj po svoje to zavil.
Sploh ne vem kje je problem, imamo rezultate, vsi se lahko strinjamo, da je rx 570 hitrejša in cenejša, vse ostalo pa je prilagajanje glede na hw pcja, v katerega se bi 1650 vgrajevala. Me prav zanima kolikšna je cena za sestavljalce računalnikov, recimo za večje, ki kupijo več tisoč ali pa vsaj več sto grafičnih.
Cene so že nizke. Problem je strošek CE certifikat na vsako kišto.
SLO sestavljalec mora imeti minimalno 100 RVC po prodani kišti.
|HP EliteBook|R5 6650U|
FlyingBee ::
Ne bodo pod ceno novo robo prodajali preko etailerjev, gpu je idealen za sestavljene builde in tam so cene drugačne. Zdaj pa razumi že. Ni to treba nič kupiti.
Can AMD's Ryzen 2400G APU Handle Demanding Shooters At 1080p?
Ker nimaš za 1080p televizor... in rabiš na vikendu majhno porabo na 35€ an AMD-ju...
Glede na to do kje seže 2040G in do kje bo segel 3xxxG, no bi rekel, da moraš biti res tepec za kakršnokoli investicijo v GTX 1650
Treer ::
Lmao, pa ravno Intli imajo vsi do nedavnih f serij igpu, medtem ko so vsi Ryzni razen APU-jev brez, ti bi pa spet rad zaspinal okoli! Glej, nimaš za burek s svojimi nebulozami, smetenjem in debilizmi in na vsakem resnem (tujem) forumu bi te že desetkrat ban-ali
Torej do sedaj nisi uspel najti NITI ENE STRANI, ki bi priporočala nakup 1650.
Zadnje dva dneva utrujaš da je 1650 best buy in ti govoriš o banu s teme. Daj izpluni vsaj dve strani, ki priporočata nakup pred AMD-jem, kaj šele Nvidio.
Trenutno je RX570 objektivno najboljša rešitev za nezahtevnega uporabnika, zato vse ostalo odpade.. Nobene druge kartice ne moreš priporočat. Še posebej, če gledaš samo p/p razmerje in prav na to se naslanjajo vse te strani. Nenazadnje je p/p najpomembnejši podatek pri kartici.
Ampak to je trenutno začasno stanje na trgu in zadaj se skriva veliko razlogov, pogojenih z mining apokalipso in posledičnim zlomom low-mid trga.. Bomo videli kaj bo čez par mesecev oz. pol leta.
Anekdotalni dokazi ne štejejo veliko, pa vseeno bom omenil, da smo s kolegi v zadnje pol leta kupili ~30 teh cheap novih RX570 kartic od Asusa. Nobenega rudarjenja, izključno namenjeno za office in gaming.. Do danes jih je romalo nazaj v garancijo nekje 8 komadov. Bogsigavedi na kakšne refurbished zadeve smo to naleteli, verjetno brez vsake qulity kontrole.
Test kjer je Treer rekel da je best buy, pišejo da 1660 Ti porabi manj kot 1660
Tole so relane cene : razlika je cca 30€ za 30 manj dobis 570 ter za 30€ več dobiš 1660.
126,08 € RX 570 4G -> DE 118,02 € -> newegg 119,99 $
156,77 € GTX 1650 -> DE 149,00 € -> newegg 137,99 $sd
159,00 € GTX 1060 3GB -> DE 169,90 €
161,29 € RX 580 4G -> DE 158,97 € -> newegg 175,99 $
177,90 € RX 580 8G -> DE 168,92 € -> newegg 173,99 $
189,00 € GTX 1660 -> DE 218,02 € -> newegg 201,99 $
218,99 € RX 590 8G -> DE 198,02 € -> newegg 202,99 $
267,00 € GTX 1660 TI -> DE 268,02 € -> newegg 257,99 $
337,76 € GTX 1070 -> DE 279,00 € -> newegg 385,32 $
Ps : za 5€ več dobiš 580 4G, ki je glede na teste daleč pred no celo v GTA
Jaz vidim average gaming porabo 110W proti 116W.. Sicer pa ne more bit bistvene razlike med njima. 1660Ti ima za odtenek višje specse, ampak pridobi na porabi z varčnejšimi GDDR6 rami, napram GDDR5 ramom od 1660. Posledično se poraba praktično izenači in pristaneš v okvirih merske napake in variacij med primerki.
Bolj zanimivo mi je, zakaj je 1-2w razliko med 1660 in ti sploh privlekel v temo o 1650?
Darvin ti je lepo odgovoril na tudi tvoje vprasanje. ce ti ni kaj jasno pa postavi razumsko zastavljeno vprasanje.
blackbfm ::
Lol.. Ne bi bilo slabo ce za trenutek vklopis common sense
2400g ima 65w tdp - od tega gre le del za grafiko- koliko nimam pojma, medtem ko namenska kartica da ven (naj bi dala) 75w čiste grafične moči ..oba čipa imata približno isti fab in stevilo tranzistorjev. Common sense meni pravi da je namenska kartica občutno zmogljivejša.
Cange ::
Gtx 1650 zaradi počasnosti ne more zamenjati trenutnih GPU. Poleg tega stara Vega 11 nakazuje da iGPU s performansom ~GTX 1650 ni daleč, teoretično samo podvojijo vego11 na 7nm, 95W 6+6 core.
- spremenilo: Cange ()
Teoretično...
Seveda lahko. Low end kartice.
High in mid pa seveda ne, saj je sama low end kartica.
Enako kot GT 1030. Seveda ne zamenja GTX 970 in ostale.
Zamenja pa GT530 in podobne.
- spremenil: MrStein ()
Shegevara ::
Najprej moram priznat, da sem bil presenečen in mi je bilo v bistvu zelo všeč, da je ta 75w kartica samo 10% počasnejša od radeon 570.
Ampak, ko sem gledal benchmarke na netu pa vidim, da testirajo gtx 1650 s 6 pinskim konektorjem, ki imajo višji clock speed in porabo pod obremenitvijo 190W. Seveda še vedno boljše od amdjevih pečk ampak bistveno manj impresivno.
Tako da tukaj vprašam, če je kdo videl benchmarke 1650ke brez dodatnega napajanja in ima res samo 75w porabe. Naj prosim nalima kako se taka verzija dejansko obnese. Hvala.
Treer ::
https://www.techpowerup.com/reviews/Pal...
Dva na hitro, v obeh primerih presenečeni, da karet brez 6pina niso praktično nič počasnejše
Praktično vse imajo porabo pod 75W, dokler ne naviješ čez 2000Mhz, potem najbrž 80-90W.
Shegevara, ti si gledal total system power podatek, torej porabo celotnega računalnika.
Cange ::
Teoretično...
S tako ceno ne more bit Office gpu, s takim performancom ne more bit gaming gpu. Tudi če bi bila 90e za gamerja ni zanimiva zaradi podhranjenosti performensa.
Treer ::
Manj kot 10% hitrejša (in 2-3krat bolj požrešna) 570-ka je pa seveda holy grail buđet gamerstva? Aja, jasno, morajo se slišat venti in čutit toplota, da veš da je to GAMING POWWWWWAAAAAAAA!
blackbfm ::
Kerga spila v zadnjih 10 letih ta kartica ne zmore da je po tvoje tako slaba? Al si gejmer samo ce spilas neka nova fps jajca v minimalno 4k z raytracingom, ostalo ne steje?
Ljudje so (baje) zadovoljni z integrirano vego, zdaj pa je kar naenkrat najnovejsa dedicated grafa ze "podhranjena"..
- spremenilo: blackbfm ()
Cange ::
Čaki malo, RX 480 je stara tri leta, ceno je imela 199$. Praviš da je tak GPU danes vreden več ker imamo po novem raytracing?
Shegevara ::
Torej je dodatno napajanje brezveze in je itak boljš da vzameš 75W, ker vsaj ne žre preveč. Če kdo posodablja kak odpisan office PC in ne misle menjat napajalnika zna pridt u poštev.
Tiste z dodatnim napajanjem imajo boljše hlajenje in jih lahk naviješ na ~2100 Mhz.. Ampak bistvene razlike ne bo. Za teh 75W TDP je tudi cheap hladilnik z enim ventilatorjem dovolj..
FlyingBee ::
Ja, pač ceno so dali glede na rx 570 previsoko, ni pa to 3 leta stara tehnologija, ki jo morajo razprodati pred Navijem.
Shegevara ::
Ja ampak bottleneck bo itak spomin in število jeder, tko da tud z navijanjem ne pride preveč blizu cenovno primerljivi konkurenci tipa rabljene 1060 al pa nove radeon 570, 580 in si na boljšem brez navijanja in z nizko porabo ker tako dobiš vsaj veliko performansa za tistih 75W. 190W še zdaleč ni tako impressive kot 75.
- spremenil: Shegevara ()
Še enkrat - 190W si gledal total system power. Kake komedije eni zganjate. :))))
- spremenil: DarwiN ()
Shegevara ::
se posipam s pepelom, kar sedaj gledam je 100W max power ki ga požre ta kartica, ne 190
Buggy ::
Lepo prosim dejmo mal tole na big picture seenkrat.
Poraba je vazna morda res za tiste s starimi OEM masinami, ki bi res zeleli dodati nekaj puncha v sistem. Tak clovek je kupil OEM masino z razlogom in je promil takih DIY, ki bojo sli nek recimo HP z210 nadgravat z neko kvazi ko bajagi gaming grafo.
V OEM HP z210, ki ima 400W nestandardni napajlink sem zadegal undervolt RX 480 in OC-jaL, pred tem pa je bila notri HD 7950 undervoltana in OC-jana...stvar po 4-ih letih zacuda se zmeraj dela, pa je rudarila vmes pri 280W peak porabe. Imam gor priklopljen projektor in masina je silen temp pa nikoli, tudi ko grem steam big picture in v spil nikoli cez 75 stopinj. Stvar dela bomba s Kodijom tako da dram, ki jih eni tukaj delate okoli AMD ne razumem. Malo potweekas pa je. Tudi sinov laptop HP Omen z GTX 1060 je bilo potrebno optimizirat, da se stvar ne dere na ventih in dela na visjih frekvencah kot default.
Vse vedno merjeno na voltmetru iz vticnice in kar se main masine tice mi je ratalo GTX 1080ti sistem spravit na 400W pri miningu in 350W W3 in Dirt rally gamingu..pa vse do tega da je dalala se zmer spodobno pod 300W ko sem iskal sweet spot frekvence in TDP.
Ni vse tako enostavno no.
1% večji defekt ali 2% večji defekt pri grafični je ok 96% oziroma 97% verjetno da grafična ne bo nikoli crklnila. Pač vsak izgovor je dober napihovati te cene. Sej če si lastiš ene 10 mining kart 1060 ki jih proidajaš po 150€ na bolhi bos seveda rekel best of the best pa čeprav 1%
FlyingBee ::
Buggy, undervoltaš in ocjaš, 1650 pa bodo šle v sestavljene walmart pcje, toliko o big picture.
» | Po Geforcih RTX Super so prišli še GTXi Super (strani: 1 2 3 )Oddelek: Novice / Grafične kartice | 19021 (15769) | FlyingBee |
» | ASUS GeForce GTX 1650 ali MSI Radeon RX570 ARMOR? (strani: 1 2 )Oddelek: Kaj kupiti | 7477 (6771) | klinker |
» | GTX 1650 različne izvedbeOddelek: Kaj kupiti | 1422 (1076) | techuser |
» | Katero GTX kartico? (strani: 1 2 )Oddelek: Kaj kupiti | 8969 (7513) | Mr.B |
