Forum » Strojna oprema » Raspberry Pi + Home Assistant
dmok ::
Tnx. Sem vrgel ven attribute (kar mislim, da ni bilo bistveno), ter "On" "Off" dal z malo ("on", "off") in sedaj dela. Hec: na začetku sem že imel z malo, pa ni delalo... čeprav lahko da je bil še kakšen drug problem.
Daj nazaj attribute pa poročaj. Jaz mislim, da je ravno to bil problem. Vsak senzor ima lahko poleg stanja tudi atribute in vsak od atributov neko svojo vrednost. Ko ti v trigger navedeš attribute ti trigger več ne preverja state-a senzorja ampak vrednost navedenega atributa. Vsaj tako jaz razumem dokumentacijo.
poweroff ::
Stupid b*ch od HA-ja...
Ko dam attribute: icon nazaj, pa neha delat. Pri čemer je atribut optional in sicer friendly name, icon ali device class. Kaj naj bi to sploh pomenilo, pa ni nikjer normalno razloženo.
sudo poweroff
dmok ::
State Objects
The attributes of an entity are optional. There are a few attributes that are used by Home Assistant for representing the entity in a specific way. Each integration will also have its own attributes to represent extra state data about the entity. For example, the light integration has attributes for the current brightness and color of the light.
Tako da ti si z "attribute: icon" naročil HA, da naj preverja, kdaj bo vrednost atributa icon enaka on ali off. Kar se ni zgodilo nikoli. Je pa tule par primerov, kjer se lepo vidi kako se uporablja attribute v triggerjih:
https://www.home-assistant.io/docs/auto...
automation: trigger: - platform: numeric_state entity_id: sensor.temperature # Optional value_template: "{{ state.attributes.battery }}" # At least one of the following required above: 17 below: 25 # If given, will trigger when the value of the given attribute for the given entity changes attribute: attribute_name # If given, will trigger when the condition has been true for X time; you can also use days and milliseconds. for: hours: 1 minutes: 10 seconds: 5
d.
poweroff ::
Še eno vprašanje... rad bi, da mi mail notifier pošlje JPEG attachment iz MotionEye. Ter da je mail v več vrsticah. Tole spodaj ne deluje. Attachmenta ni, mail je v eni sami vrstici.
- service: notify.send_email data: message: Ob {{ now().strftime('%H:%M:%S')}} so se odprla vrata. {{'\n'}}Druga vrstica title: Vrata data: image: "/share/motioneye/Camera2/lastsnap.jpg"
sudo poweroff
garamond ::
Glede vrstic, par primerov iz dokumentacije:
Vse skupaj je v "":
Znak > in brez ":
Iz YAML dokumentacije: [...]Values can span multiple lines using | or > [...]
Vse skupaj je v "":
message: "{{ trigger.payload }}"
Znak > in brez ":
message: > Paulus just changed from {{ trigger.from_state.state }} to {{ trigger.to_state.state }}
A parody of extremism is impossible to differentiate from sincere extremism.
poweroff ::
Hmm, ja, tudi tako sem dal:
Pa pride isto vse v eno vrstico. Bug?
data: message: > Ob {{now().strftime('%H:%M:%S')}} so se odprla vrata. Druga vrstica. Tretja vrstica.
sudo poweroff
garamond ::
Glede slike, primer iz dokumentacije:
data: images: - /home/pi/snapshot1.jpg - /home/pi/snapshot2.jpgNa povezavi je tudi vključitev html (namesto plain text email-a, kot je privzeto).
Hmm, ja, tudi tako sem dal: [...]Mogoče poskusiš še, če dela html (taka rešitev, tudi če dela, ne odgovori zakaj ne dela z >. Bo mogoče poslal odgovor kdo drug s preprosto stvarjo, ki smo jo spregledali).
- spremenil: garamond ()
bluefish ::
Svež članek za tiste, ki se lotevajo postavljanja HA: https://arstechnica.com/information-tec...
JanezH ::
A bo vredu, če home assistant za rpi4 laufam iz Samsung FIT Plus USB 3.1 Flash Drive 64GB?
https://www.samsung.com/us/computing/me...
tom_II ::
Pozdrav,
nekaj sem tudi sam začel s home assistant in raspberry Pi.
Rad bi dobil ssl certifikat za lokalni dostop, da mi brskalnik ne bi več javljaj da povezava ni varna.
Povsod sem gledal je vse preko DuckDNS ampak tega postopka ne morem opraviti zaradi interneta preko mobilne povezave 4G.
Imate kakšen dober postopek kako podpisati s certifikatom za lokalni dostop in s tem https://
HVALA
HVALA
poweroff ::
Poglej si Let's Encrypt oz certbot paket na RaspberryPi. Je free, pa lahko avtomatiziraš podaljševanje.
sudo poweroff
poweroff ::
Zdaj mi je Rain Radar entiteta izginila iz HA. Ko kliknem na sliko, kjer bi se morala prikazati radarska slika padavin, se pokaže tole besedilo:
Kartica v lovelace je naslednja:
V "/config/configuration.yaml" imam pa tole:
Ta entiteta ("camera.rain_radar") nima enoličnega ID-ja, zato njenih nastavitev ni mogoče upravljati iz uporabniškega vmesnika. Za več podrobnosti glejte dokumentacija . You can overwrite some attributes in the entity customizations section.
aspect_ratio: 0% camera_image: camera.rain_radar entity: camera.rain_radar hold_action: action: more-info image: camera.rain_radar show_name: true show_state: false tap_action: action: more-info type: picture-entity name: Radarska slika padavin
camera: - platform: generic name: 'Rain Radar' still_image_url: 'http://meteo.arso.gov.si/uploads/probase/www/observ/radar/si0-rm-anim.gif' verify_ssl: false
sudo poweroff
tonis ::
Ali kdo ve, kako Sonoff THR316D spravit v flash mode? Poskušam Tasmoto spravit na napravo, pa vedno ostane samo pri Connecting... Pri flash modeu naj bi gorela wifi dioda, pri meni pa gori(ali utripa) samo tista zadnja.
Google mi ni v pomoč oz ne znam vprašat...
HVala
HVala
Matko ::
flash mode
držiš gumb in priključiš komunikacijski kabel
(glej, da NIMAŠ priključeno na 230v~)
tonis ::
Matko hvala.. Mislim da vem kje tiči zajec - to kar si napisal sem sicer probal večkrat, pa žal neuspešno.
Moj flešer je PL3203 ki baje ni najbolj recommended, baje je treba 3,3V pripeljat ločeno, in sem to naredil preko arduina, pa nekako ne spelje..
Skratka, čakam da mi Aliexpress dostavi flasher, ki je bilj primeren za te zadeve..
//aja, prej sem ves čas iskal pod THR316D kar je dejanski model in najdem same neuporabne reči, danes sem šel pa škatlo pogledat in piše na veliko Sonoff TH Elite, pod tem imenom je pa več uporabnih linkov.
tonis ::
Glej, kar se samega štroma tiče, sem precej zelen, zato ne experimentiram kaj dosti, da ne bi kaj skuril. Včeraj sem iz nemčije naročil flešer, ki je po priporočilih Tasmote najbolj primeren, v nekaj dneh bo zadeva tu in računam da bo potem šlo.
xgeorgex ::
fulgur ::
Fantje, imam en problem in ga ne znam rešiti. Na Winse na Intelovem NUC-u sem inštaliral Home assistant kot virtual machine na VirtualBox-u. Zadeva špila. Problem pa je integracija “SONOFF Zigbee 3.0 USB Dongle Plus, Zigbee Gateway TI CC2652P + CP2102N Zigbee USB Stick”. Uspelo mi je po dolgem času doseči, da je USB palčka v HA OS prepoznana in vidna. Ko sem jo skušal integrirati, sem najprej izbral “Erase Network Settings and Create a New Network”, nato pa se je samo dolgo vrtelo sporočilo “Loading Next Step For ZHA“ in se ni nikoli nič zgodilo. Tudi dejansko je HA OS v tem primeru zamrznil. Probal sem palčko vtakniti v USB 3.0 in 2.0 port, uporabil sem USB podaljše, USB dock, ampak zadeva v nobenem primeru me špila. Edino flash-al še nisem Sonoffa.
Kaj lahko naredim, da bo zadeva laufala?
Hvala za pomoč že vnaprej.
» | Pametno stanovanje (strani: 1 2 3 4 … 50 51 52 53 )Oddelek: Elektrotehnika in elektronika | 475610 (1402) | jhames |
» | Raspberry Pi & alternative (strani: 1 2 3 4 … 22 23 24 25 )Oddelek: Strojna oprema | 263477 (22693) | pierch |
» | Domače omrežje - preveč heavy duty za hardwareOddelek: Omrežja in internet | 3165 (1592) | roki11 |
» | Philipsove pametne žarnice kot vhodna vrata za hekerjeOddelek: Novice / Varnost | 10955 (7789) | MrStein |
» | pametno wifi stikalo 220v na senzorOddelek: Elektrotehnika in elektronika | 9578 (1748) | laguna1 |
