Forum » Pomoč in nasveti » Samsung evo 850 - 250 gb hitrost
ST-777 ::
Morda je to vzrok:
"Samsung EVO 850 SSD Slow Speed ... Your SSD is on asahci64, which means you're using an Asmedia Sata port not the native Intel ones. Check mobo manual and connect to the intel ports. Once you've got your SSD on the intel ports, confirm the Intel Drivers are working by launching AS SSD, it should show iaStorA where you're getting asahci64." http://www.tomshardware.co.uk/answers/i...
filip007 ::
Probaj Wise Driver Care.
http://www.wisecleaner.com/wise-driver-...
Linko ::
Tole matično imam
https://www.gigabyte.com/Motherboard/GA...
Ima samo sata3...
Ne razumem tega točno?
Ima samo sata3...
Morda je to vzrok:
hojnikb ::
ne, ta plata ma x2 sata6gbit in 4x 3gbit
za 6gbit je treba dat v port 0 ali 1
#brezpodpisa
filip007 ::
Tvoj program Samsung Magician, ti pokaže na kaj je priključen, tako da preveč sprašuješ.
» | Random restart računalnika (strani: 1 2 )Oddelek: Strojna oprema | 11722 (9767) | Pero_SLO |
» | Počasen SSD Crucial MX100 256GBOddelek: Pomoč in nasveti | 1093 (823) | gali |
» | Maximus formula 3Oddelek: Strojna oprema | 906 (827) | traxxas |
» | Error ob zagonuOddelek: Pomoč in nasveti | 1486 (1052) | gddr85 |
