Forum » Pomoč in nasveti » systemctl zagon programa
korenje3 ::
A kdo ve zakaj mi ne zažene skripte?
Kako bi lahko videl tist blob data oz. kako lahko debug startam nek program s systemctl?
skripta:
zagon systemctl:
skripta:
#!/bin/sh #/etc/init.d/homeautomation export PATH=$PATH:/usr/bin export NODE_PATH=$NODE_PATH:/usr/lib/node_modules case "$1" in start) cd /homeautomation exec /usr/bin/forever start --sourceDir=/homeautomation -m 5 --minUptime 5000 --spinSleepTime 5000 -l /homeautomation/forever.log -o /homeautomation/foreverout.log -e /homeautomation/forevererr.log BBB.js ;; stop) exec /usr/bin/forever stop --sourceDir=/homeautomation BBB.js ;; *) echo "Usage: /etc/init.d/homeautomation {start|stop}" exit 1 ;; esac exit 0
zagon systemctl:
root@beaglebone:/etc/init.d# systemctl status homeautomation homeautomation.service - Run the home automation script Loaded: loaded (/lib/systemd/system/homeautomation.service; enabled) Active: failed (Result: exit-code) since Thu 2015-06-04 20:56:40 CEST; 30min ago Process: 2884 ExecStart=/etc/init.d/homeautomation start (code=exited, status=255) CGroup: name=systemd:/system/homeautomation.service Jun 04 20:56:36 beaglebone systemd[1]: Starting Run the home automation script... Jun 04 20:56:36 beaglebone systemd[1]: Started Run the home automation script. Jun 04 20:56:40 beaglebone homeautomation[2884]: [60B blob data] Jun 04 20:56:40 beaglebone homeautomation[2884]: [39B blob data] Jun 04 20:56:40 beaglebone homeautomation[2884]: [108B blob data] Jun 04 20:56:40 beaglebone systemd[1]: homeautomation.service: main process exited, code=exited, status=255/n/a Jun 04 20:56:40 beaglebone systemd[1]: Unit homeautomation.service entered failed state
korenje3 ::
angstrom linux-
hojnikb ::
kaj fura ta linux systemd al init.d ?
Ker je videt v fajlu init.d direktorij, a furaš systemctl, ki je del systemd.
Also, ima skripta taprave pravice ?
#brezpodpisa
korenje3 ::
hm sem dal verbose messages v forever in dobim tole:
ni mi jasno zakaj hoče logirat v /root/.forever ko ima pa arngstrom root direktorij v /home/root.
Jun 04 21:47:38 beaglebone homeautomation[3156]: info: Forever processing file: BBB.js Jun 04 21:47:38 beaglebone homeautomation[3156]: fs.js:338 Jun 04 21:47:38 beaglebone homeautomation[3156]: return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); Jun 04 21:47:38 beaglebone homeautomation[3156]: ^ Jun 04 21:47:38 beaglebone homeautomation[3156]: Error: ENOENT, no such file or directory '/root/.forever/IHyh.log' Jun 04 21:47:38 beaglebone homeautomation[3156]: at Object.fs.openSync (fs.js:338:18) Jun 04 21:47:38 beaglebone homeautomation[3156]: at Object.forever.startDaemon (/usr/lib/node_modules/forever/lib/forever.js:406:14) Jun 04 21:47:38 beaglebone homeautomation[3156]: at app.cmd.cli.startDaemon (/usr/lib/node_modules/forever/lib/forever/cli.js:257:13) Jun 04 21:47:38 beaglebone homeautomation[3156]: at /usr/lib/node_modules/forever/lib/forever/cli.js:144:5 Jun 04 21:47:38 beaglebone homeautomation[3156]: at forever.stat (/usr/lib/node_modules/forever/lib/forever.js:358:11) Jun 04 21:47:38 beaglebone homeautomation[3156]: at Object.oncomplete (fs.js:297:15) Jun 04 21:47:38 beaglebone systemd[1]: homeautomation.service: main process exited, code=exited, status=1/FAILURE Jun 04 21:47:38 beaglebone systemd[1]: Unit homeautomation.service entered failed state
- spremenil: korenje3 ()
korenje3 ::
Sem odstranil forever, ker je očitno buggan. Environment fajl sem moral dodati, da mi je našlo node skripte.
[Service]
Type=simple
WorkingDirectory=/homeautomation
User=root
EnvironmentFile=/etc/sysconfig/homeautomation
ExecStart=/usr/bin/node BBB.js
[Service]
Type=simple
User=root
» | Dnsmasq problemOddelek: Omrežja in internet | 987 (614) | BlaY0 |
» | dnsmasq problemOddelek: Omrežja in internet | 1715 (1455) | poweroff |
» | Zaznavanje Arduina priklopljenega preko USB v LinuxuOddelek: Programiranje | 1510 (1004) | mojster_joni |
» | problem pri sprembi root gesla v MySQL v UbuntuOddelek: Pomoč in nasveti | 1223 (803) | killa bee |
» | [Ubuntu] SambaOddelek: Programska oprema | 1769 (1559) | black ice |
