Forum » Problemi človeštva » Demokratični socializem
ZaphodBB ::
Link na Wikiju ne dela, tega kar piše pa ni nikjer v sosednjih dokumentih.
Lažeš.
ne pa prodajati pravljic, da bo prosti trg rešil problem emisij
Jaz samo pravim, da ekosadizem in centralno plansko gospodarstvo tega gotovo ne bosta rešila. Pa če se še tako dereš.
Tudi Hansen je velik zagovornik davka na CO2.
Spet lažeš: http://news.heartland.org/newspaper-art...
Citiram:
No Emissions Cuts Necessary
However, Harris continued, the underlying belief that carbon dioxide emissions are causing a global warming crisis is off base.
"They are completely wrong to promote the hopelessly flawed idea that we can significantly affect global climate through the elimination of our most important sources of energy: hydrocarbon fuels. Their stated goal of achieving 'climate stabilization' through energy choices defies sound science," said Harris.
"Climate has never been stable and never will be. There is nothing humanity can do about it. Aside from continuing fundamental research into better understanding climate change, the only sensible climate policy is one of adaptation to whatever nature throws at us next," Harris added.
- spremenil: ZaphodBB ()
dstr17_ ::
Heartland institute je trobilo fosilne industrije, International Climate Science Coalition (ICSC) pa tudi.Tudi Hansen je velik zagovornik davka na CO2.
Citiram:
To kar si citiral ni izjavil Hansen (on je izjavil le to, da podpira jedrsko energijo), ampak je komentar enega od zanikovalcev fizike. Ni lepega načina da ti to povem, ampak tako je. Fosilna industrija te je nategnila in te nateguje še naprej.
Fosilni industriji status quo ustreza, verniki v prosti trg pa jim pri tem še dodatno pomagajo, ker onemogočajo opustitev fosilnih goriv. Eksternalij nočejo obdavčiti, subvencij za jedrsko energijo nočejo, jasno pa je, da dokler bo atmosfera zastonj smetnjak, se bo uporabljalo fosilna goriva in to kljub temu, da se drugim ljudem onemogoča dostojno življenje, da se iztreblja druge vrste in da se nesmiselno uničuje okolje. Vera v prosti trg je de facto del problema.
- spremenilo: dstr17_ ()
sheeshkar ::
Smo v temi Demokratični socializem, ti pa v njej izključno pljuvaš čez "neoliberalce" (čeprav še sam ne veš, kdo sploh so), prosti trg (čeprav ne razumeš, kaj to je) in se igraš okoljevarstvenika (čeprav za rešitve ponujaš samo višanje davkov). Ali lahko morda razložiš, kako bo okoljske probleme rešil demokratični socializem/levica/Sizira/Luka Mesec/kdorkoli?
dstr17_ ::
Ali lahko morda razložiš, kako bo okoljske probleme rešil demokratični socializem/levica/Sizira/Luka Mesec/kdorkoli?TRS, ki je del ZL, ima to lepo razdelano v programu: več subvencij za energetsko učinkovitost in obnovljive vire. Siriza ne poznam podrobno, ampak med glavnimi točkami ima napisano podobno.
Mene predvsem skrbi, da to morda ne bo dovolj. Številke so zaskrbljujoče. Nekaj uspehov do zdaj je sicer bilo, ampak potrebno bo vse skupaj dati v malo višjo prestavo. Davek na CO2 je pomoje ta višja prestava.
nekikr ::
Dvomim, da so oni za jedrske elektrarne. Vetrne in fotovoltaične pa pač niso ne energetsko ne okoljsko učinkovite.
Ja, tipično, si že večkrat povedal, da ne veš kaj se v svetu dogaja.
1. Davek.
2. ???
3. Čistejši zrak.
A lahko poveš za koliko je zrak boljši od uvedbe CO2 kraje?
ZaphodBB ::
TRS, ki je del ZL
je ladja norcev, ki verjame v chemtraile, lizardmane in ne-cepljenje.
dstr17_ ::
1. Davek.1. Davek (naraščajoč, dovolj visok).
2. ???
3. Čistejši zrak.
2. Trg najde rešitve, ki ne obremenjujejo okolja.
3. Čistejši zrak.
A lahko poveš za koliko je zrak boljši od uvedbe CO2 kraje?Trenutni davek na CO2 je premajhen, da bi imel kakršenkoli opazen učinek, razen tega da so vsi z njim nezadovoljni. Zato ga je treba povečati, da bo imel učinek. Nezadovoljstvo se da nasloviti tako, da se povečanje tega davka kombinira z znižanjem drugih davkov, tako da je glede skupne količine nevtralno (kar je dobra liberalna rešitev, samo liberalci tega še niso čisto ponotranjili - bom odprl šampanjec, ko bo kakšna liberalna stranka to aktivno promovirala v svojem programu).
ZaphodBB ::
Trg, ki ne obstaja in je fikcija v glavah neoliberalcev? Dafuq ti kadiš model.
Matako ::
TRS, ki je del ZL
Pa itak ponavadi so ti liki sposobni v enem stavku govoriti o "energetski učinkovitosti" nakar v naslednjem, da je treba popirati domačo lesno industrijo s kurjenjem gnilih sekancev.
Itd.
Ni pa, zanimivo, nikoli ideje za povečanje energetske učinkovitost z odslovitvijo odvečnih JU miškosukov. Čeprav so tu ogromne rezerve. Celo če bi samo ostali doma bi bilo vseeno bolje, kot da po 8h na dan tratijo CPU čas v ogrevanih/klimatiziranih prostorih v katere se pripeljejo z motorji na notranje izgorevanje.
Je Hanž za to?
/\/\.K.
- spremenil: Matako ()
nekikr ::
Torej sedaj države kradejo ljudem vedoč, da ni prav nobene učinka? Koliko pa je tega denarja trenutno pobranega? Koliko bi pa moralo biti in kaj bi to pomenilo? Številke prosim, ne ekofašističnih blodenj.
Če boš slučajno za Zaphoda kaj zrihtal, daj še meni, ker imaš super robo.
ZaphodBB ::
Saj vemo kam pes taco moli...
Poberemo CO2 davke. Potem pa vložimo v miškosuke in penzionerje, da jim ne bo revčkom standard padel. Tako kot z davki na gorivo in cestnino.
Daedalus ::
US unemployment rate falls to 5.6 percent in best year since 1999.
Kako pa gre vam v demokratično socialističnem raju?
[J.P.Sartre]
[J.P.Sartre]
- spremenilo: Daedalus ()
Nerodno jim/nam je, ker se revolucija v Grčiji ni zgodila. Bodi malo uvideven, no!
Matako ::
Mramor ne špara jezika, nameni Grkom "hvala, prijatelji" govor:
Poleg tega zameri, da nas niso niti vprašali!
http://www.rtvslo.si/evropska-unija/mra...
"Pri takšni izpostavljenosti, kot jo ima Slovenija do Grčije, pri takšni solidarnosti, kot smo jo nudili, je Grčija sporočila, da namerava povečevati pokojnine, poviševati plače, zaposlovati v javnem sektorju in zahtevati dodatno zmanjševanje obveznosti do Slovenije, medtem ko v Sloveniji znižujemo plače in varčujemo na vseh področjih," je položaj opisal Mramor.
/\/\.K.
nekikr ::
Seveda se je! Samo naslednji dan so pogledali številke in so z revolucijo zaključili. Saj veš kako je bilo z našo Alenčico....najpametnejša in proti vsemu, en obisk Bruslja jo je pa hitro streznil, da je bila za vse :)
Super, zdaj naša vlada ve, kako je stradati, zato da v neki JU ni treba dodatka za gretje stola zmanjšati. Mogoče pa kaj bo iz te vlade.
ZaphodBB ::
Oni se pogovarjajo samo z Lunatikom.
Jasno je, da pravi demokratični socialist ne bo govoril z neoliberalno svinjo kot je Mramor. Na take se samo laja.
Matako ::
Mramor je po pričakovanju že označen za "bruseljskega hlapca", ker zahteva naš denar nazaj.
Mislim, kar nazaj bi ga imel! Ne gre to tako v demosocu.
/\/\.K.
reader ::
Zaenkrat se Grki še niso dogovorili - pravilno, nimajo se kaj pogajati z zlobnimi neoliberalci!
Najbolje bo, da dajo v višjo prestavo, nabijejo 95% davek na CO2, tako dobijo denar ki ga potrebujejo za dvig penzij in plač v JS ter eko subvencij, pa bodo po domnovi matematiki v dveh letih tehnološko-ekološka velesila!
/sarcasm off
Bom nehal circlejerkat. Unproductive.
/sarcasm off
Kaj pa če bi namesto 95% CO2 davka, reki zmanjšajmo izpuste CO2-ja za 95%. to je lažje izvedljivo, tko da prepovejo turizem, ter odženejo kitajce, ki delajo biznis z najetimi pomoli...
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Madonca, od kar so naši na oblasti, so se spet začele udarniške brigade... Pa naj še kdo z gobem utresa da so minimalci prenizki. Raje naj zaposlijo te mojstre, ki delajo za vizijo...
Spet nam ubijaj dobre stare čase : http://mises.ca/posts/articles/the-econ...
mzakelj ::
a še niste zaključili debate o teh združenih lenuhih. Živijo v oblakih kot vsi v parlamentu.
donfilipo ::
Kar dobro poročilo, ker vsaj številke delajo :) Torej kljub sesutju bratstva i jedinstva, .. socializma in titoizma, smo zadolženi realno nekje 150% bolj, kot v sistemu, ...kjer je bilo dovolj moliti k Titu in si preživel Ljudje se sprašujejo počasi, h komu bi dejansko morali moliti..zdaj?
Ok tu je seveda še problem, ker po definiciji von Miesesa danes že živimo v socializmu in ker imamo tudi demokracijo, smo zgleda že v demokratičnem socializmu Pomeni imamo konflikt, ko nek sistem realno nekako ne uspe intervenirati v simbolično in preko tega tudi v imaginarno.. Bemti Žižek je strupen
In kaj se po kmečko dogaja? Grčija in Siriza sta lakmusov papirček, kako in koliko je dejansko sploh mogoče uveljavljati voljo naroda v okvirih omejene ekonomije. Tu pač poudarjam da recimo USA, kot slika i prilika pravilnega :), niso kaj prida manj pro capita zadolžene kot grki, ...ampak ok, po Miesesu tudi oni že ves čas živijo v socializmu. Iščemo nekoga ki ne, ...in tako izmed vrstic sem razbral, da so to po njihovem činezi. Hm tele nove sintetične droge bi morali poceniti
In times of Universal Deceit, telling the truth
becomes revolutionary act. Orwell
ampak ok, po Miesesu tudi oni že ves čas živijo v socializmuZa moj okus najboljša ameriška humoristična nadaljevanka ta hip je Last man standing. In ravno v včerajšnji epizodi ata Baxter pravi takole:
Let's look at some famous couples.
Uh, Franklin and Eleanor Roosevelt, America's favorite inbred first family.
They were cousins, which you'd think would make them close, but they actually spent very little time together.
Eleanor was traveling the world visiting socialist countries while Franklin was here turning America into one.
- spremenil: Okapi ()
donfilipo ::
Hm ja. Najprej poglejmo malo serije...potem pa obnovim uno o socializmih.
Utopični...znanstveni itd.... Nemara se danes ideje levice lahko tudi resetirajo na potolčene prakse recimo anarhistov, ki jim je korporacija Marx:) obesila bombe in neznanstvenost, ...pa so morda imeli vsaj nekateri bolj sprejemljive in predvsem manj smrtonosne ideje. Ker kot vemo, se je nujnost revolucije in krvavega preobrata spreobrnila nazadnje v farso, v kateri se je bolj kot ne molilo diktatorja, ..od njegove dobre volje pa je bilo potem odvisno preživetje proletariata. Bi rekli, da si verjetno Marx ni točno tako zadeve zamislil, (predvsem ne revolucije v praktično fevdalni deželi in ne deželi, kjer visoko razvit kapitalizem že sam sebe duši:)...ampak, čisto brez krivde pa vsekakor niti doktrina Marxa in Engelsa vsekakor ni....
Po moje če to pošteno in vsaj na kratko preletim...potem bodo vprašanja a) ali je pravična družba mogoča in predvsem b) ali si jo ljudje RES zavedno in nezavedno želimo Če ne je morda bolje flikati to kar imamo...in prilagajati revolucijam, ki jih prinašajo nove tehnologije.
donfilipo ::
Medklic:
Sem pogledal nekaj od nadaljevanke. Tako kot Coca Cola. Prekleto dobro. In sladko Verjetno se ne zavedajo globin, ki jih lahko da kaka socrealistična drama, ko protagonisti zamišljeno skozi okna zrejo v daljavo..... In potem greš na eno pivo in končaš z vsakdanjo za povprečne smrtonosno zastrupitvijo z alkoholom...Ali komunista zdrži čuda Milina ta socializem res
[....s tem se seveda ubada tudi moj heroj Žižek, namreč kapitalizem nam po domače povedano v tintari povprečnika, ...če ne v realnem delu zagotovo v domišljijskem in svetu želja ...neprestano ustvarja sliko sladke prihodnosti užitka in uspeha, ...rahlo posuti samo s trni komičnih sladkih konfliktov... Družbeno kritično Hollywood je nekje umrl v sedemdesetih. In verjetno ubil-dokrajčil:) svojega Hyde-a (dr.Jeckyll in Mr.Hyde), to je avtoritarni 'znanstveni' socializem, pripet na oltar tobožnje znanosti Marxa in Engelsa...
No ja malce pretiravam Ampak kolikor ga je res in kolikor je še možna neka resna leva kritika njegove glupe sivine, da ne govorim krvave brezizhodnoti,...v toliko je to znak, da nekje je tudi boljša ideja.
- spremenilo: donfilipo ()
donfilipo ::
In še en medklic tale pa strogo on topic.
Spasit če nas higiena i demokratični socializam? Ne
Pravna država. Ordnung und disziplin
Da to napiše sodnik ni tako slab znak. Ne samo da sebi zagotavlja obilico dela in časti (stanu pa denarja:), ....misliti nam da, da so vsaj sodniki za vekomaj izgubili svoj privzgojeni socialistični leitmotiv. 20let jih je proleter šolal, nato pa puf :) in so jedro doktrine (socialistično pravo:) vrgli v ajmar
Ampak napisano je preverjeno, po svetu ubijanje kurupcije in debirokratizacija trga da dela, to kar drži. Le da je VELIKO vprašanje kaj balkancu in še komu prinese ordnung? Sami sodniki in represija očitno ne ...čeprav pomaga pa že malo :)
http://www.finance.si/8351025/Demokrati...
donfilipo,
zakaj se namesto Amerike, ne uporablja primerjave Avstrija. Z njimi imamo velko skupnega, celo banko. Madonca, celo porast Nemcev ki bežijo iz grde nemačke v Avstijo, ker je tam bolje delat. Tega za Slovenijo ne boš kaj dosti videl, razen kot tranzicijsko "viza" države..
donfilipo ::
A jebi ga. Sem kričal po tem da bi lahko in v jedru morali biti nekje kot Avstrijci, pa smo daleč od tega.
In kaj je z Avstrijo?
Hja Švabi so in natrpali so si banke z denarjem, ki je bežal s celega balkana. Anonimisch die komunisten werden es nicht kriegen...a jebi ga i oni ga donose
Naprej Avstrijci nimajo avtrijske šole,...ampak lepo klasično socialdemokratsko z zgledno socialno državo. In soliden multikulti, ...saj je švedov gor, da nema nikakva dljaka da padne u sljadoled
Recept za uspeh? :
Uspešne privatizacije, kjer verjetno odvetniške hiše Lopovski tiči in Čefurji raus:)...niso svetovale mojim daljnim sorodnikom: 'v kapitalizmu se pač moraš znajti, to je jedro sistema' ,...da so potem preučevali kazenski zakonik, kjer so kazniva dejanja, ki se splačajo bila lepo našteta na kupu (ne razmetana kot v avstrijskem:)--pač pa so denar raje lovili tudi z balkana in pametno investirali. Delavce niso tako stisnili kot Nemci,..pač pa imajo precej močne sindikate in obenem tudi zavidljiv standard. In ja če je treba pa znajo biti tudi naciji. Kurz und klar. Ordnung und dicziplin
Ampak dobro tu govorimo, kaj utegne države kjer kapitalizem ne dela. privesti v demokratični socializem, ...ki kot gledam ima kar nekaj populističnih pa tudi deloma pravilnih ideoloških tez! Avstrijcem gre predobro, da bi se spuščali v avanture. Zaenkrat.
Recept za uspeh? :
donfilipo ::
Hm ja. Še tole za pojasnilo. Se boste tisti, ki boste preverili, lažje soočali z basanji politikov in manipulantov. Ni vsaka marija devica!!!! in stranka, ki ima v imenu socializem oziroma izpeljanko, ...ni nujno da ima resne vezi z njim Socialdemokratske stranke pač niso socialistične Opet vas je Mises napravio volom
Glavne politične ideologije, ki sestavljajo socialistične ideologije so: utopični socializem, socialna anarhija, demokratični socializem in komunizem (Marx, Engels, Lenin, Stalin, Tito). Socialdemokracija je mehka običajno sredinsko leva veja v okvirih normalnega kapitalizma, ki se ponavadi zavzema malo bolj za delavske pravice in socialno državo od desnega ljudskega centra (Sarkozy)...ni pa to nujno!
Tako da po Miesesu ni mimo niti 40 let, kar imajo solidno socialno državo (kar je zanj povod za oznako socializem:)...po normalnih definicijah pa razen nekaj okoli nasilja pariške komune in plapolanja neznanega...Francozi socializma še niso videli. Spremembe ne bodo ideološke...bo pa po TV kakšna Francoska zastava in himna več. To je pa tudi to
Odin ::
Tukaj sta dve lestvici ekonomske svobode (slisi se boljse kot pa kapitalizem, ki 90% slovencem dvigne krvni tlak):
Malta nas je prehitela po GDP per capita ze leta 2010. Ceska nas je prehitela lani. Kdo bo naslednji? Vsaj po teh lestvicah bi jaz rekel Estonija ali Litva v roku 5ih let. Spodaj je lista kandidatov, ki so naproti nam naredili najvecji skok iz leta 2002 (Eurostat):
http://www.freetheworld.com/release.html - Economic Freedom of the World
http://www.heritage.org/index/ranking - Index of Economic Freedome
52% nasega GDP per capita v 2002 do 89% v 2013 - Litva
58% - 89% - Estonija
65% - 91% - Slovaska
57% - 82% - Poljska
Odin,
cervantes bo rekel da se cedi med in mleko. Pa smo se kljub temu lasnko leto zadolžili za cca 8 mijardojrov..
A. Smith ::
57% - 82% - Poljska
Ne me sezuvat
105. mesto od 152 držav si delimo s Sierra Leone Pred nami so Rusija, BiH, Mongolija, Kolumbija in Brazilija
Eat this, Mencinger!!!
In ja, nasprotovanje privatizaciji ima neposreden vpliv na mesto v lestvici.
"Be professional, be polite,
- General James Mattis
GTX970 ::
Pojasnilo je enostavno:
državo vodijo (so ugrabili) stari ljudje/strukture (oni, ki so bili na oblasti v prejšnjem sitemu in času), ki skrbijo samo za to, da stanje zanje ostaja enako.Za vse ostale jim dol visi.
- spremenilo: GTX970 ()
Cervantes ::
Cervantes,
te sile centralnih osi imajo dolge lovke.
» | Ali vas ob takšnem ravnanju naše "elite" kaj mine do sodelovanja v tem sistemu? (strani: 1 2 )Oddelek: Loža | 11264 (8363) | Fritz |
» | Apple, Google, Intel in Adobe sedaj ponujajo 415-milijonsko odškodninoOddelek: Novice / Tožbe | 11785 (9731) | leiito |
» | Novopečeni diktator Venezuele Maduro (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Problemi človeštva | 102257 (96513) | NavadniNimda |
» | Komunizem + demokracija = možno? (strani: 1 2 )Oddelek: Problemi človeštva | 13678 (9439) | jype |
