Forum » Izdelava spletišč » [JavaScript] Vrtenje slik
krajcar ::
Rad bi naredil tri različne prostore, kjer se vrtijo naključne slike iz iste mape. Slike normalno pobere iz mape a vrtijo se samo v tretjem zadnjem prostoru.
Kakšna ideja kaj bi bilo lahko narobe?
Hvala.
Hvala.
<div id="slike"> <div id="slika1"> <script language="javascript"> var delay=1000 //set delay in miliseconds var curindex=0 var randomimages=new Array() randomimages[0]="slide/1.jpg" randomimages[1]="slide/2.jpg" randomimages[2]="slide/3.jpg" randomimages[3]="slide/4.jpg" randomimages[4]="slide/5.jpg" randomimages[5]="slide/6.jpg" var preload=new Array() for (n=0;n<randomimages.length;n++) { preload[n]=new Image() preload[n].src=randomimages[n] } document.write('<img name="defaultimage" src="'+randomimages[Math.floor(Math.random()*(randomimages.length))]+'">') function rotateimage() { if (curindex==(tempindex=Math.floor(Math.random()*(randomimages.length)))){ curindex=curindex==0? 1 : curindex-1 } else curindex=tempindex document.images.defaultimage.src=randomimages[curindex] } setInterval("rotateimage()",delay) </script> </div> <div id="slika2"> <script language="javascript"> var delay=1000 //set delay in miliseconds var curindex=0 var randomimages=new Array() randomimages[0]="slide/1.jpg" randomimages[1]="slide/2.jpg" randomimages[2]="slide/3.jpg" randomimages[3]="slide/4.jpg" randomimages[4]="slide/5.jpg" randomimages[5]="slide/6.jpg" var preload=new Array() for (n=0;n<randomimages.length;n++) { preload[n]=new Image() preload[n].src=randomimages[n] } document.write('<img name="defaultimage" src="'+randomimages[Math.floor(Math.random()*(randomimages.length))]+'">') function rotateimage() { if (curindex==(tempindex=Math.floor(Math.random()*(randomimages.length)))){ curindex=curindex==0? 1 : curindex-1 } else curindex=tempindex document.images.defaultimage.src=randomimages[curindex] } setInterval("rotateimage()",delay) </script> </div> <div id="slika3"> <script language="javascript"> var delay=1000 //set delay in miliseconds var curindex=0 var randomimages=new Array() randomimages[0]="slide/1.jpg" randomimages[1]="slide/2.jpg" randomimages[2]="slide/3.jpg" randomimages[3]="slide/4.jpg" randomimages[4]="slide/5.jpg" randomimages[5]="slide/6.jpg" var preload=new Array() for (n=0;n<randomimages.length;n++) { preload[n]=new Image() preload[n].src=randomimages[n] } document.write('<img name="defaultimage" src="'+randomimages[Math.floor(Math.random()*(randomimages.length))]+'">') function rotateimage() { if (curindex==(tempindex=Math.floor(Math.random()*(randomimages.length)))){ curindex=curindex==0? 1 : curindex-1 } else curindex=tempindex document.images.defaultimage.src=randomimages[curindex] } setInterval("rotateimage()",delay) </script> </div> </div>
- spremenil: Mavrik ()
msjr ::
Zelo nerodno napisano....
Takole, za začetek function rotateimage() se ti trikrat ponovi. Če so v vseh treh div-ih iste slike, ni treba definirat randomimages 3x
Za začetek je tale koda, dogajalo se ti bo, da bodo v vseh treh oknih iste slike (mogoče pa celo hočeš tako):
Koda je nalašč napisana na bolj šolski način, da sploh vidiš kako in kaj.
<div id="slike"> <div id="slika1"></div> <div id="slika2"></div> <div id="slika3"></div> </div> <script type="text/javascript"> function rotateimage() { for (i = 1; i <= 3; i++) { //trikrat ponovimo za vsak div oz. za vsak image src = Math.floor(Math.random() * (randomimages.length)); //index v arrayu raje takole, da lahko kasneje kaj popraviš if (init == true){ document.getElementById('slika' + i).innerHTML = '<img id="jpeg'+ i +'" src="'+ randomimages[src] +'">'; //prvič zapiše html kodo }else{ document.getElementById('jpeg' + i).src = randomimages[src]; //vsakič naslednjič je dovolj da spremeni samo src od slike } } init = false; //za un if zgoraj setTimeout('rotateimage()',1000); //ponovimo funkcijo vsako sekundo } var init = true; // osnova za un if zgoraj // bolj enostavno zapišemo array var randomimages = new Array ( 'slide/1.jpg', 'slide/2.jpg', 'slide/3.jpg', 'slide/4.jpg', 'slide/5.jpg', 'slide/6.jpg' ); //preloadamo vse slike (ajde neka) var preload = new Array(); for (n=0; n < randomimages.length; n++) { preload[n] = new Image(); preload[n].src = randomimages[n]; } //štartamo našo funkcijo ko se zloada cel window window.onload = function() { rotateimage(); } </script>
- spremenil: msjr ()
» | Potrebujem javascript pomočOddelek: Programiranje | 1151 (901) | no1pheeew |
» | Javascript - izračun razlike v datumihOddelek: Programiranje | 1818 (1673) | kogledom |
» | Definiranje spremenjivke - javascriptOddelek: Programiranje | 1152 (1075) | a-ptuj |
» | Internet strani kot slideshowOddelek: Izdelava spletišč | 2006 (1757) | sverde21 |
» | Kako se tole naredi?Oddelek: Izdelava spletišč | 1437 (1137) | njok |
