Forum » Omrežja in internet » Merjenje hitrosti downloada/uploada
darkolord ::
Smack nekam cudno je tole...
Your current bandwidth reading is:
81.92 Mbps
which means you can download at 10.24 MB/sec. from our servers.
tudi ce veckrat probam pokaze tko
81.92 Mbps
EjTi ::
In kaj je kle čudnga?
81,92 Mbit/s = 10,24 MByte/s
8 bit = 1 Byte ... saj do zej je blo skos tko
simon1 ::
Men se pa nč čudn ne zdi, čist lepo mi pokaže:
1005.30kbps which means you can download at 125.66 KB/sec.
Ne vem kaj je vam narobe delal! Zdej je vse v redu!
Ziga Dolhar ::
Itak da je tako -- od kdaj pa 1 bajt ne nosi 80 bitov? .
p.s.: zakaj nekateri tako noro uporabljate "byte", ko pa smo si v slovenščini to lepo sposodili kot bajte? "Mbyti", brrrrrr ....
p.p.s.: meni test sicer prikaže ustrezno hitrost.
https://dolhar.si/
- spremenil: Ziga Dolhar ()
Ziga Dolhar ::
j: Ko sem v davno tega v eni knjigi za Visual Basic bral, koliko neki tipi spremenljivk zavzamejo "zlogov", mi ni blo nič jasno. Tako da -- ne mučimo ljudstva po nepotrebnem.
p.s: "Ziggga" s tremi g-ji. Kot "egggo".
https://dolhar.si/
Shark-357 ::
737.50kbps
which means you can download at 92.19 KB/sec. from our servers.
tole je mal premal men ponavad vlece cez 100 tam do 120 ga zna zamedt
737.50kbps
UniXZonE ::
Speed
869.8 kilobits per second
Communications 869.8 kilobits per second
Storage 106.2 kilobytes per second
1MB file download 9.6 seconds
Subjective rating Good
LittleDevil ::
1.97 Mbps
which means you can download at 252.3 KB/sec. from our servers.
A je to dobr al slabo?
1.97 Mbps
ElectricMan ::
9.35 Mbps
which means you can download at 1.17 MB/sec. from our servers.
9.35 Mbps
sh4rk ::
no ce kazete vsi naj bols bom pa jst naj slabs ;) ADSL 4 mb + me lahko kdo premaga? am mamo tezave na centrali :))
- spremenil: sh4rk ()
Shark-357 ::
747.80kbps
which means you can download at 93.47 KB/sec. from our servers
747.80kbps
SkIDiver ::
DU meter mi pokaže pr testih cca 5Mbit za DL in 2Mbit za UL. Neki podobnga pa se vrtijo testi katerih linke sem našel v tej temi.
Skratka huda pipca tole. Huj kot ADSL. Sam zgleda je PC prešvoh
billy ::
DU meter v bistvu kaže malce višje vrednosti, to pa zato ker meri RAW data.
Medtem ko pa sam protokol požere nekaj in niso prenosi isti.
Nekaj takega...
Nekaj takega...
SkIDiver ::
DC++ mi pokaže prenos 2.5 MB/s največji do sedaj, ki sem ga videl. DU pa skače vse tja do 20mbit.
ElectricMan ::
Kilobits na sekundo pa kilobytes na sekundo sta različna pojma. Seveda prva varijanta pokaže več kot pa druga varijanta.
Leonardo ::
Ne bom se sicer hvalil z nekim posebnim svojim rekordom ali izračunov (imam 2mbit adsl)
ker več ali manj vse te strani prikazujejo napačne podatke kakor ste že prišli do tega zaključka
izprobajte še spodnji link, ne bom rekel da prikazuje niti pravilno niti narobe .. lp
http://performance.chello.at:81/
http://slo-warez.net
bvm ::
....JOJ sem jezen....
Na vseh teh straneh mi kaže kar naprej ~1Mbit. Včasih še manj !!!
Imam pa 4 Mbitno povezavo!!!
Grrrrr
Grrrrr
Gandalfar ::
izvajam 10s upload test (v smeri k internetu) 394.82Kb/s
izvajam 10s download test (v smeri k vam) 1.02Mb/s
hmm .. ce bi le mel taksn link :D
_Dejan_ ::
hm zanimivo
izvajam 10s upload test (v smeri k internetu) 248.26Kb/s
izvajam 10s download test (v smeri k vam) 270.44kb/s
Mam pa ADSL 1024/256
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
DominusSLO ::
izvajam 10s upload test (v smeri k internetu) 215.92Kb/s
izvajam 10s download test (v smeri k vam) 1.95Mb/s
skoraj prav.....
skoraj prav.....
cpu&nb watercooled, gpu on air at the moment
_Dejan_ ::
Ne vem na kakšnem principu to meri sam kadar lowdam z azureusom vedno loudam 100-120kB/s je pa res da mam full visok ping cca130-150ms. Možn da tut ping vpliva na rezultat
_Dejan_ ::
lol vsi programi so ugasnjeni Nč se ne lowda
Sambrosa ::
ej zanima me če mi lahko napiše tist ko maš povezave
56kb/s vleče 2mb tok pa tok sec
128kb/s vleče 2mb tok pa tok
to je nek za zračunat neka stran sam jo ne najdem ,če mi lahko napiše katerg je,
aja pa mal več povezav more bit
DominusSLO ::
sambrosa pa to bi ja lahko sam zračunal.... c c c
leechy ::
2.82 Mbps
which means you can download at 361.14 KB/sec. from our servers.
not bad,not bad at all
2.82 Mbps
espacious ::
hmmmm....kaj naj recem meni tudi ne dela tale speed test od elite.org......a ve kdo kako pa kaj, pa zakaj ne ? mam pa WinXP,SP1,pa ICS preko win20003server.......
djtech ::
pa kaj to je točno ?
elite.org Speedtest
Pritisnite START
Iskanje vmesnih naprav . . . . . . . . . . . . . . . . . . . . . . . OK
izvajam 10s upload test (v smeri k internetu) 109.10Kb/s
izvajam 10s download test (v smeri k vam) 68.07kb/s
Pritisni START za ponovno meritev
Jaz grem SIOL, Telekom tožit ker plačujem za povezavo 1Mb/256kb, ludi res nea vem kaj naj naredim, če mi z ftp. , z irca vleče dol po 10 kb max ali pa 5kb včasih še to ne. Kaj naj naredim ? Centrala pa je 700m vstran
elite.org Speedtest
Pritisnite START
Fukomuko ::
elite.org Speedtest
Pritisnite START
izvajam 10s upload test (v smeri k internetu) 370.66Kb/s
izvajam 10s download test (v smeri k vam) 1.39Mb/s
mam pa siol adsl 2mbit
Pritisnite START
Hammer ::
izvajam 10s upload test (v smeri k internetu) 488.83Kb/s
izvajam 10s download test (v smeri k vam) 1.92Mb/s
Siol ADSL 2048/512
Siol ADSL 2048/512
Robert_S ::
elite.org Speedtest
Pritisnite START
izvajam 10s upload test (v smeri k internetu) 260.11Kb/s
izvajam 10s download test (v smeri k vam) 1.31Mb/s
Information: Other network traffic is congesting the link
Kabl 1024/256 A to sploh prov kaže?
Pritisnite START
Soprano ::
Meni pokaže prav:
izvajam 10s upload test (v smeri k internetu) 249.27Kb/s
izvajam 10s download test (v smeri k vam) 1.47Mb/s
Kabel, paket 1,5M / 256
Robert_S ::
4.30 Mbps
which means you can download at 550.15 KB/sec. from our servers.
28.8 kbps Analog
33.6 kbps Analog
56 kbps Analog
64 kbps ISDN
128 kbps ISDN
384 kbps xDSL
768 kbps xDSL
1000 kbps xDSL
1500 kbps T1
4401.2 kbps YOU
to narobe kaže
4.30 Mbps
28.8 kbps Analog
33.6 kbps Analog
56 kbps Analog
64 kbps ISDN
128 kbps ISDN
384 kbps xDSL
768 kbps xDSL
1000 kbps xDSL
1500 kbps T1
4401.2 kbps YOU
to narobe kaže
Alexius Heristalski ::
Adsl 1024/256:
izvajam 10s upload test (v smeri k internetu) 236.93Kb/s
izvajam 10s download test (v smeri k vam) 984.02kb/s
ponovna meritev:
izvajam 10s upload test (v smeri k internetu) 240.60Kb/s
izvajam 10s download test (v smeri k vam) 980.93kb/s
tretja:
izvajam 10s upload test (v smeri k internetu) 241.73Kb/s
izvajam 10s download test (v smeri k vam) 981.27kb/s
Kar dobro.
ponovna meritev:
tretja:
Kar dobro.
- spremenil: Alexius Heristalski ()
» | Wireless v novem računalniku ne deluje pravilnoOddelek: Pomoč in nasveti | 2115 (1984) | Spajky |
» | speedtest.siOddelek: Omrežja in internet | 13752 (12140) | Pesimist |
» | simobil unlimitedOddelek: Omrežja in internet | 5962 (4460) | madmitch |
» | Blokiran upload?Oddelek: Pomoč in nasveti | 2704 (2481) | farko |
» | Router hitrostOddelek: Omrežja in internet | 2199 (2008) | MrLord |
