Forum » Programska oprema » Adobe Flash povzroča BSOD !!???
ion ::
Neverjetno, ampak moje praktično novo računalo se ob vsaki inštalaciji Adobeja (ne glede na verzijo) začne čudno obnašat. BSOD ob različnih priložnostih. Včasih med brskanjem po spletu, predvajanjem glasbe prek Media Playerja, med špilom, ob uporabi Worda... Na novo inštaliral Windows 7 Ultimate 64bit. Ne pomaga. Datoteke zaradi katerih bi naj prišlo do BSODja so različne. Če ima kdo kakršnokoli obliko rešitve PROSIM. Prilagam zadnje podatke o BSOD.
SYSTEM_THREAD_EXCEPTION
_NOT_HANDLED 0x1000007e ffffffff`c0000005 fffff880`03d7957a fffff880`0291b558 fffff880`0291adc0 dxgmms1.sys
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff800`032010bf fffff880`0628ef50 00000000`00000000 ntoskrnl.exe
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff880`04401f0f fffff880`08a37e30 00000000`00000000 dxgmms1.sys
_NOT_HANDLED 0x1000007e ffffffff`c0000005 fffff880`04528d90 fffff880`02166668 fffff880`02165ed0 dxgmms1.sys
IRQL_NOT_LESS_OR_EQUAL 0x0000000a fffffa00`0323d580 00000000`00000002 00000000`00000000 fffff800`030cc14b ntoskrnl.exe
_NOT_HANDLED 0x1000007e ffffffff`c0000005 fffff880`04564d90 fffff880`02166668 fffff880`02165ed0 dxgmms1.sys
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff880`041c265b fffff880`09380780 00000000`00000000 atikmdag.sys
KMODE_EXCEPTION_NOT_HANDLED 0x0000001e ffffffff`c0000005 fffff880`0109bf00 00000000`00000000 ffffffff`ffffffff ataport.SYS
PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 fffffa80`29487f28 00000000`00000000 fffff880`04431c87 00000000`00000002 ntoskrnl.exe
MEMORY_MANAGEMENT 0x0000001a 00000000`00041284 fffff980`0c9b8001 00000000`000073af fffff780`c0000000 ntoskrnl.exe
IRQL_NOT_LESS_OR_EQUAL 0x0000000a fffffa20`0558f090 00000000`00000002 00000000`00000000 fffff800`02b6daef ntoskrnl.exe
KMODE_EXCEPTION_NOT_HANDLED 0x0000001e 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 tcpip.sys
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff800`02845885 fffff880`090dc170 00000000`00000000 ntoskrnl.exe
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff880`044b1ef0 fffff880`094b2e60 00000000`00000000 dxgkrnl.sys
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff960`000c6680 fffff880`0795c100 00000000`00000000 win32k.sys
SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000`c0000005 fffff880`04423c97 fffff880`0925ff80 00000000`00000000 dxgmms1.sys
blackbfm ::
Verjetno problem z ramom. Defekten ram ali pa mogoče samo napačna voltaža. Lahko pa je tudi napajalnik.
connel ::
Hm, podobne sem tudi sam imel v win 7, v xp-jih sem ga doživel samo enkrat, pognal mem test, v prvem preizkusu našel preko 200 napak v 5 minutah, vzamem eno palčko ven, ena napaka, zamenjam, brez napak. Potem zopet obe palčki noter in po eni uri brez napak,...
Poizkusi preverit ram, jaz sem dl verzijo za na usb ključek, fina zadeva.
ion ::
Že preveril z memtest. Laufal cca. 10 ur. Nobenih napak. Tudi prime95 je laufal par ur. Nič. Voltaža za ram u BIOS je na auto. Imam Mushkin XP2 kit, 1066 mhz 4096 MB. Kakšna voltaža je primerna? Naložil tudi najnovejše posodobitve. Ugibam, ali se ne bi u primeru okvare na hardweru napaka pojavljala vseskozi? Tako pa samo ob inštalaciji Adobe FPja
- spremenil: ion ()
denial ::
Hmm, skor ne morem verjet, da je takšen exception lahko posledica uporabniške aplikacije. Na sistemu imaš mapo MiniDump v kateri se kreira dump file exceptiona. Ta .dmp file lahko uvoziš v WinDbg in narediš analizo BSOD-a.
SELECT finger FROM hand WHERE id=3;
- spremenil: denial ()
noraguta ::
a je takšen exception lahko posledica uporabniške aplikacije.aplikacija zihr ni , je pa lahko driver in kak acpi ali pa kaka podobna obskurna zadeva. sicer pa tvoj nasvet diangnostike drži. +tega memtest vsaj meni tud ni našel nič prek 4gb. mašina se je pa vsuvala. po odjebu modula je pa nekak čudežno stabilna.
» | BSODOddelek: Pomoč in nasveti | 549 (482) | mihafaceb |
» | BSOD 0x00000124Oddelek: Pomoč in nasveti | 1510 (951) | s1m0n |
» | BSOD problemOddelek: Pomoč in nasveti | 1638 (1296) | Oktan |
» | BSODOddelek: Operacijski sistemi | 2067 (1741) | Bolf3nk |
» | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2264 (2003) | Duhec |
